[PATCH 1/2] ARM: dts: rk3588-rock-5b-u-boot: add u-boot, dm-spl to pinctrl for sdmmc
To be able to initialize the pinctrl correctly at SPL level and read u-boot proper from SD-Card, the pinctrl must be initialized.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index e1d240baf35d..65aa2095cbf6 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -124,6 +124,8 @@ };
&pinctrl { + u-boot,dm-spl; + usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; @@ -131,6 +133,22 @@ }; };
+&sdmmc_bus4 { + u-boot,dm-spl; +}; + +&sdmmc_clk { + u-boot,dm-spl; +}; + +&sdmmc_cmd { + u-boot,dm-spl; +}; + +&sdmmc_det { + u-boot,dm-spl; +}; + &usb_host0_ehci { companion = <&usb_host0_ohci>; phys = <&u2phy2_host>;
Add pinctrl driver in SPL. Do not remove pinctrl properties for SPL dtb.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- configs/rock5b-rk3588_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 86acb6da4306..6ae57874c4d5 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -48,7 +48,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y -CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -65,6 +65,7 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_SPL_PINCTRL=y CONFIG_REGULATOR_PWM=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_ROCKCHIP=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Thanks, - Kever
&pinctrl {
- u-boot,dm-spl;
- usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
+&sdmmc_bus4 {
- u-boot,dm-spl;
+&sdmmc_clk {
- u-boot,dm-spl;
+&sdmmc_cmd {
- u-boot,dm-spl;
+&sdmmc_det {
- u-boot,dm-spl;
- &usb_host0_ehci { companion = <&usb_host0_ohci>; phys = <&u2phy2_host>;
Eugen Hristev
Kever Yang
