[U-Boot] Please help for Data TLB Error in MPC8544
Hi all, My board can't boot normally, and I found it just hang in data tlb error through the system.map. Could any one help for this? Some regisers are as below: ============================================ DEAR: 0xf400fff0 (L1 init ram base address is 0xf4010000) IVPR : 0xfff80000 , IVPR3: 0x000004000 EELADR: 0xf4010000 , CSn_BNDS: all 0x00000000 (I think SPD of DDR is not found yet) L2MMU_TLB0 : 84000000 51000000 ff7000000 ff7000000 (CCSR is not relocated to 0xe0000000 yet) ============================================
The TLB1 registers from CodeWarrior is as below: ================================================= L2MMU_CAM0 600007CA 1C080000 FFC00000 FFC000001 (boot flash, 4M) L2MMU_CAM1 A0007FCA 1C080000 80000000 800000001 (PCIE, 1G) L2MMU_CAM2 90003FCA 1C080000 C0000000 C00000001 (PCI, 256M) L2MMU_CAM3 90003FCA 1C080000 D0000000 D00000001 (PCI, 256M) L2MMU_CAM4 80001FCA 1C080000 E0000000 E00000001 (CCSR, 64M) L2MMU_CAM5 80001FCA 1C080000 F0000000 F00000001 (?? , 64M) L2MMU_CAM6 300000CA 18080000 FF040000 FF0400001 (NAND, 64K) L2MMU_CAM7 20000042 18080000 FF010000 FF0100001 (NAND, 16K) L2MMU_CAM8 20000042 18080000 FF050000 FF0500001 (NAND, 16K) L2MMU_CAM9 C87FD651 EB40000D 27DE6000 2397E000 L2MMU_CAM10 D0E2E2DF EB680009 B494F000 8F634000 L2MMU_CAM11 00FC8DCA 5A11000D BCB9B000 77EF6000 L2MMU_CAM12 300000CA 18080000 FF000000 FF000001 (NAND, 64K) L2MMU_CAM13 D891AFD8 18180002 50A70000 F7AB6000 L2MMU_CAM14 E0F6AE97 DA390009 F5DF6000 4F425000 L2MMU_CAM15 D8EFEF88 C750000F AEBA7000 3229F000 ===================================================
And this is my init.s below: ================================================================== #include <ppc_asm.tmpl> #include <ppc_defs.h> #include <asm/cache.h> #include <asm/mmu.h> #include <config.h> #include <mpc85xx.h>
#define LAWAR_TRGT_PCI1 0x00000000 #define LAWAR_TRGT_PCIE1 0x00200000 #define LAWAR_TRGT_PCIE2 0x00100000 #define LAWAR_TRGT_PCIE3 0x00300000 #define LAWAR_TRGT_LBC 0x00400000 #define LAWAR_TRGT_DDR 0x00f00000
#define entry_start \ mflr r1 ; \ bl 0f ;
#define entry_end \ 0: mflr r0 ; \ mtlr r1 ; \ blr ;
.section .bootpg, "ax" .globl tlb1_entry tlb1_entry: entry_start
/* * Number of TLB0 and TLB1 entries in the following table */ .long (2f-1f)/16 1: /* * TLB0 4K Non-cacheable, guarded * 0xff700000 4K Initial CCSRBAR mapping * * This ends up at a TLB0 Index==0 entry, and must not collide * with other TLB0 Entries. */ .long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_CCSRBAR_DEFAULT), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_CCSRBAR_DEFAULT), 0,0,0,0,0,1,0,1,0,1)
/* * TLB0 16K Cacheable, guarded * Temporary Global data for initialization * * Use four 4K TLB0 entries. These entries must be cacheable * as they provide the bootstrap memory before the memory * controler and real memory have been configured. * * These entries end up at TLB0 Indicies 0x10, 0x14, 0x18 and 0x1c, * and must not collide with other TLB0 entries. */ .long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR),0,0,0,0,0,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR),0,0,0,0,0,1,0,1,0,1)
.long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 4 * 1024),0,0,0,0,0,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 4 * 1024),0,0,0,0,0,1,0,1,0,1)
.long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 8 * 1024),0,0,0,0,0,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 8 * 1024),0,0,0,0,0,1,0,1,0,1)
.long TLB1_MAS0(0, 0, 0) .long TLB1_MAS1(1, 0, 0, 0, 0) .long TLB1_MAS2(E500_TLB_EPN(CFG_INIT_RAM_ADDR + 12 * 1024),0,0,0,0,0,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_INIT_RAM_ADDR + 12 * 1024),0,0,0,0,0,1,0,1,0,1)
/* * TLB 0: 4M Non-cacheable, guarded * 0xffc00000 4M Covers FLASH at 0xFFC00000 * Out of reset this entry is only 4K. */ .long TLB1_MAS0(1, 0, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_4M) .long TLB1_MAS2(E500_TLB_EPN(CFG_BOOT_BLOCK), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_BOOT_BLOCK), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 1: 1G Non-cacheable, guarded * 0x80000000 1G PCIE 8,9,a,b */ .long TLB1_MAS0(1, 1, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_1G) .long TLB1_MAS2(E500_TLB_EPN(CFG_PCIE_PHYS),0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_PCIE_PHYS),0,0,0,0,0,1,0,1,0,1)
/* * TLB 2: 256M Non-cacheable, guarded */ .long TLB1_MAS0(1, 2, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI_PHYS),0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI_PHYS),0,0,0,0,0,1,0,1,0,1)
/* * TLB 3: 256M Non-cacheable, guarded */ .long TLB1_MAS0(1, 3, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_256M) .long TLB1_MAS2(E500_TLB_EPN(CFG_PCI_PHYS + 0x10000000),0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_PCI_PHYS + 0x10000000),0,0,0,0,0,1,0,1,0,1)
/* * TLB 4: 64M Non-cacheable, guarded * 0xe000_0000 1M CCSRBAR * 0xe100_0000 255M PCI IO range */ .long TLB1_MAS0(1, 4, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) .long TLB1_MAS2(E500_TLB_EPN(CFG_CCSRBAR), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(CFG_CCSRBAR), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 5: 64M Non-cacheable, non-guarded , reserve from MPC8544DS (don't know what is it for) */ .long TLB1_MAS0(1, 5, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64M) .long TLB1_MAS2(E500_TLB_EPN(0xf0000000), 0,0,0,0,0,0,0,0) .long TLB1_MAS3(E500_TLB_RPN(0xf0000000), 0,0,0,0,0,1,0,1,0,1)
/* * TLB 6: 64K Non-cacheable, guarded * 0xff040000 64K 1G NAND flash 2 area 1 0xff040000 */ .long TLB1_MAS0(1, 6, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64K) .long TLB1_MAS2(E500_TLB_EPN(0xff040000), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(0xff040000), 0,0,0,0,0,0,0,1,0,1)
/* * TLB 7: 16K Non-cacheable, guarded * 0xff010000 16K 1G NAND flash 1 area 2 0xff010000 */ .long TLB1_MAS0(1, 7, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_16K) .long TLB1_MAS2(E500_TLB_EPN(0xff010000), 0,0,0,0,0,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(0xff010000), 0,0,0,0,0,0,0,1,0,1)
/* * TLB 8: 16K Non-cacheable, guarded * 0xff050000 16K 1G NAND flash 2 area 2 0xff050000 */ .long TLB1_MAS0(1, 8, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_16K) .long TLB1_MAS2(E500_TLB_EPN(0xff050000), 0,0,0,0,0,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(0xff050000), 0,0,0,0,0,0,0,1,0,1)
/* * TLB 12: 64K Non-cacheable, guarded * 0xff000000 64K 1G NAND flash 1 area 1 0xff000000 */ .long TLB1_MAS0(1, 12, 0) .long TLB1_MAS1(1, 1, 0, 0, BOOKE_PAGESZ_64K) .long TLB1_MAS2(E500_TLB_EPN(0xff000000), 0,0,0,0,1,0,1,0) .long TLB1_MAS3(E500_TLB_RPN(0xff000000), 0,0,0,0,0,0,0,1,0,1) 2: entry_end
/* * LAW(Local Access Window) configuration: */
.section .bootpg, "ax" .globl law_entry law_entry: entry_start
.long (4f-3f)/8 3: .long 0 .long LAWAR_EN | LAWAR_TRGT_DDR | (LAWAR_SIZE & LAWAR_SIZE_1G)
.long (CFG_PCI1_MEM_PHYS>>12) & 0xfffff .long LAWAR_EN | LAWAR_TRGT_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_512M)
.long (CFG_PCI1_IO_PHYS>>12) & 0xfffff .long LAWAR_EN | LAWAR_TRGT_PCI1 | (LAWAR_SIZE & LAWAR_SIZE_64K)
.long (0xf0000000>>12) & 0xfffff .long LAWAR_EN | LAWAR_TRGT_LBC | (LAWAR_SIZE & LAWAR_SIZE_256M)
.long 0 .long 0
.long (CFG_PCIE1_IO_PHYS>>12) & 0xfffff .long LAWAR_EN | LAWAR_TRGT_PCIE1 | (LAWAR_SIZE & LAWAR_SIZE_32G) 4: entry_end ==============================================================================
What I think the problem might be 1. I didn't access the SPD to initial DDR , so failed ? 2. The TLB1_5 should take away ? 3. I shall add one more TLB for DDR ? 4. The real problem is not related with any above, and I shall post the other regisers for check ??
Thanks.
EELADR - 0XF4010000, it is INIT_RAM address, why the transaction with address(0xF4010000) go to system bus? It should keep in the cache due to cache lock, never out to system bus.
2: entry_end
- LAW(Local Access Window) configuration:
.long 0 .long 0
Why the PCIE1_IO have 32G space? It seems like one typo.
The u-boot version is very old, if you can post your start.S and board.h, It will be helpful.
Thanks, Dave
I don't know why... and it just happened.... shall I allocate a entry of tlb for it?? or cover it in some space ?
I reduce the size of PCIE1_IO and it doesn't help.
The u-boot version is very old, if you can post your start.S and board.h,It
will be helpful.
Thanks, Dave
I didn't change anything in start.s and I build it from the latest LTIB of mpc8544 of freescale. But I did change memory map in board.h.
include/configs/mpc8544ds.h is as below: ============================================================================== /* * mpc8544ds board configuration file * */ #ifndef __CONFIG_H #define __CONFIG_H
/* High Level Configuration Options */ #define CONFIG_BOOKE 1 /* BOOKE */ #define CONFIG_E500 1 /* BOOKE e500 family */ #define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ #define CONFIG_MPC8544 1 #define CONFIG_MPC8544DS 1
#define CONFIG_PCI 1 /* Enable PCI/PCIE */ #define CONFIG_PCI1 1 /* PCI controller 1 */ #define CONFIG_PCIE1 0 /* PCIE controler 1 (slot 1) */ #define CONFIG_PCIE2 0 /* PCIE controler 2 (slot 2) */ #define CONFIG_PCIE3 0 /* PCIE controler 3 (ULI bridge) */ #define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */
#define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE #define CONFIG_SPD_EEPROM /* Use SPD EEPROM for DDR setup */ #undef CONFIG_DDR_DLL #undef CONFIG_DDR_2T_TIMING /* Sets the 2T timing bit */
#define CONFIG_DDR_ECC /* only for ECC DDR module */ #define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ #define CONFIG_MEM_INIT_VALUE 0xDeadBeef
#define CONFIG_DDR_ECC_CMD #undef CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */
/* * When initializing flash, if we cannot find the manufacturer ID, * assume this is the AMD flash associated with the CDS board. * This allows booting from a promjet. */ #define CONFIG_ASSUME_AMD_FLASH
#define MPC85xx_DDR_SDRAM_CLK_CNTL /* 85xx has clock control reg */
#ifndef __ASSEMBLY__ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif #define CONFIG_SYS_CLK_FREQ get_board_sys_clk(0) /* sysclk for MPC85xx */
/* * These can be toggled for performance analysis, otherwise use default. */ #define CONFIG_L2_CACHE /* toggle L2 cache */ #define CONFIG_BTB /* toggle branch predition */ #define CONFIG_ADDR_STREAMING /* toggle addr streaming */ #undef CONFIG_CLEAR_LAW0 /* Clear LAW0 in cpu_init_r */
/* * Only possible on E500 Version 2 or newer cores. */ #define CONFIG_ENABLE_36BIT_PHYS 1
#define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */
#undef CFG_DRAM_TEST /* memory test, takes time */ #define CFG_MEMTEST_START 0x00200000 /* memtest works on */ #define CFG_MEMTEST_END 0x00400000 #define CFG_ALT_MEMTEST #define CONFIG_PANIC_HANG /* do not reset board on panic */
/* * Base addresses -- Note these are effective addresses where the * actual resources get mapped (not physical addresses) */ #define CFG_CCSRBAR_DEFAULT 0xff700000 /* CCSRBAR Default */ #define CFG_CCSRBAR 0xe0000000 /* relocated CCSRBAR */ #define CFG_IMMR CFG_CCSRBAR /* PQII uses CFG_IMMR */
#define CFG_PCI1_ADDR (CFG_CCSRBAR+0x8000) #define CFG_PCIE1_ADDR (CFG_CCSRBAR+0xa000) #define CFG_PCIE2_ADDR (CFG_CCSRBAR+0x9000) #define CFG_PCIE3_ADDR (CFG_CCSRBAR+0xb000)
/* * DDR Setup */ #define CFG_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ #define CFG_SDRAM_BASE CFG_DDR_SDRAM_BASE
#define SPD_EEPROM_ADDRESS 0x51 /* DDR DIMM */
/* * Make sure required options are set */ #ifndef CONFIG_SPD_EEPROM #error ("CONFIG_SPD_EEPROM is required") #endif
#undef CONFIG_CLOCKS_IN_MHZ
/* * Memory map * * 0x0000_0000 0x7fff_ffff DDR 2G Cacheable * * 0x8000_0000 0xbfff_ffff PCI Express Mem 1G non-cacheable * * 0xc000_0000 0xdfff_ffff PCI 512M non-cacheable * * 0xe000_0000 0xe00f_ffff CCSR 1M non-cacheable * 0xe100_0000 0xe3ff_ffff PCI IO range 4M non-cacheable * * Localbus cacheable * * 0xf000_0000 0xf3ff_ffff SDRAM 64M Cacheable * 0xf401_0000 0xf401_3fff L1 for stack 4K Cacheable TLB0 * * Localbus non-cacheable * * 0xf800_0000 0xf80f_ffff NVRAM/CADMUS (*) 1M non-cacheable * 0xff00_0000 0xff7f_ffff FLASH (2nd bank) 8M non-cacheable * 0xff80_0000 0xffff_ffff FLASH (boot bank) 8M non-cacheable * */ #define CFG_64BIT_VSPRINTF 1 #define CFG_64BIT_STRTOUL 1
#define CFG_ID_EEPROM #define ID_EEPROM_ADDR 0x57
/* * Local Bus Definitions */ #define CFG_BOOT_BLOCK 0xffc00000 /* boot TLB */ #define CFG_LBC_CACHE_BASE 0xf0000000 /* Localbus cacheable */ #define CFG_FLASH_BASE 0xffc00000 /* start of FLASH 4M */
#define CFG_BR0_PRELIM 0xffc01001 #define CFG_BR1_PRELIM 0xff000881
#define CFG_OR0_PRELIM 0xffc06e65 /*NAND Flash 1*/ #define CFG_OR1_PRELIM 0xfffe6000
#define CFG_BR3_PRELIM 0xff040881 /*NAND Flash 2*/ #define CFG_OR3_PRELIM 0xfffe6000
//#define CFG_FLASH_BANKS_LIST {0xfe800000,CFG_FLASH_BASE}
#define CFG_FLASH_QUIET_TEST #define CFG_MAX_FLASH_BANKS 3 /* number of banks */ #define CFG_MAX_FLASH_SECT 128 /* sectors per device */ #undef CFG_FLASH_CHECKSUM #define CFG_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
#define CFG_MONITOR_BASE TEXT_BASE /* start of monitor */
#define CFG_FLASH_CFI_DRIVER #define CFG_FLASH_CFI #define CFG_FLASH_EMPTY_INFO /* #define CFG_FLASH_AMD_CHECK_DQ7 */ #define CFG_FLASH_AMD_CHECK_DATA_COMPARE
#define CFG_LBC_NONCACHE_BASE 0xf8000000
#define CONFIG_FSL_PIXIS 1 /* use common PIXIS code */ #define PIXIS_BASE 0xf8100000 /* PIXIS registers */ #define PIXIS_ID 0x0 /* Board ID at offset 0 */ #define PIXIS_VER 0x1 /* Board version at offset 1 */ #define PIXIS_PVER 0x2 /* PIXIS FPGA version at offset 2 */ #define PIXIS_RST 0x4 /* PIXIS Reset Control register */ #define PIXIS_AUX 0x6 /* PIXIS Auxiliary register; Scratch * register */ #define PIXIS_SPD 0x7 /* Register for SYSCLK speed */ #define PIXIS_VCTL 0x10 /* VELA Control Register */ #define PIXIS_VCFGEN0 0x12 /* VELA Config Enable 0 */ #define PIXIS_VCFGEN1 0x13 /* VELA Config Enable 1 */ #define PIXIS_VBOOT 0x16 /* VELA VBOOT Register */ #define PIXIS_VSPEED0 0x17 /* VELA VSpeed 0 */ #define PIXIS_VSPEED1 0x18 /* VELA VSpeed 1 */ #define PIXIS_VCLKH 0x19 /* VELA VCLKH register */ #define PIXIS_VCLKL 0x1A /* VELA VCLKL register */
/* define to use L1 as initial stack */ #define CONFIG_L1_INIT_RAM 1 #define CFG_INIT_L1_LOCK 1 #define CFG_INIT_L1_ADDR 0xf4010000 /* Initial L1 address */ #define CFG_INIT_L1_END 0x00004000 /* End of used area in RAM */
/* define to use L2SRAM as initial stack */ #undef CONFIG_L2_INIT_RAM #define CFG_INIT_L2_ADDR 0xf8fc0000 #define CFG_INIT_L2_END 0x00040000 /* End of used area in RAM */
#ifdef CONFIG_L1_INIT_RAM #define CFG_INIT_RAM_ADDR CFG_INIT_L1_ADDR #define CFG_INIT_RAM_END CFG_INIT_L1_END #else #define CFG_INIT_RAM_ADDR CFG_INIT_L2_ADDR #define CFG_INIT_RAM_END CFG_INIT_L2_END #endif
#define CFG_GBL_DATA_SIZE 128 /* num bytes initial data */ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
#define CFG_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ #define CFG_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */
/* Serial Port - controlled on board with jumper J8 * open - index 2 * shorted - index 1 */ #define CONFIG_CONS_INDEX 1 #undef CONFIG_SERIAL_SOFTWARE_FIFO #define CFG_NS16550 #define CFG_NS16550_SERIAL #define CFG_NS16550_REG_SIZE 1 #define CFG_NS16550_CLK get_bus_freq(0)
#define CFG_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200}
#define CFG_NS16550_COM1 (CFG_CCSRBAR+0x4500) #define CFG_NS16550_COM2 (CFG_CCSRBAR+0x4600)
/* Use the HUSH parser */ #define CFG_HUSH_PARSER #ifdef CFG_HUSH_PARSER #define CFG_PROMPT_HUSH_PS2 "> " #endif
/* pass open firmware flat tree */ #define CONFIG_OF_FLAT_TREE 1 #define CONFIG_OF_BOARD_SETUP 1
#define OF_CPU "PowerPC,8544@0" #define OF_SOC "soc8544@e0000000" #define OF_TBCLK (bd->bi_busfreq / 8) #define OF_STDOUT_PATH "/soc8544@e0000000/serial@4500"
/* I2C */ #define CONFIG_FSL_I2C /* Use FSL common I2C driver */ #define CONFIG_HARD_I2C /* I2C with hardware support */ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CFG_I2C_SPEED 400000 /* I2C speed and slave address */ #define CFG_I2C_EEPROM_ADDR 0x57 #define CFG_I2C_SLAVE 0x7F #define CFG_I2C_NOPROBES {0x69} /* Don't probe these addrs */ #define CFG_I2C_OFFSET 0x3100
/* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ #define CFG_PCIE_PHYS 0x80000000 /* 1G PCIE TLB */ #define CFG_PCI_PHYS 0xc0000000 /* 512M PCI TLB */
#define CFG_PCI1_MEM_BASE 0xc0000000 #define CFG_PCI1_MEM_PHYS CFG_PCI1_MEM_BASE #define CFG_PCI1_MEM_SIZE 0x20000000 /* 512M */ #define CFG_PCI1_IO_BASE 0x00000000 #define CFG_PCI1_IO_PHYS 0xe1000000 #define CFG_PCI1_IO_SIZE 0x00010000 /* 64k */
/* PCI view of System Memory */ #define CFG_PCI_MEMORY_BUS 0x00000000 #define CFG_PCI_MEMORY_PHYS 0x00000000 #define CFG_PCI_MEMORY_SIZE 0x80000000
/* controller 2, Slot 1, tgtid 1, Base address a000 */ #define CFG_PCIE2_MEM_BASE 0x0 #define CFG_PCIE2_MEM_PHYS CFG_PCIE2_MEM_BASE #define CFG_PCIE2_MEM_SIZE 0x10000000 /* 256M */ #define CFG_PCIE2_IO_BASE 0x00000000 #define CFG_PCIE2_IO_PHYS 0x0 #define CFG_PCIE2_IO_SIZE 0x00000000 /* 64k */
/* controller 1, Slot 2,tgtid 2, Base address 8000 */ #define CFG_PCIE1_MEM_BASE 0x0 #define CFG_PCIE1_MEM_PHYS CFG_PCIE1_MEM_BASE #define CFG_PCIE1_MEM_SIZE 0x20000000 /* 512M */ #define CFG_PCIE1_IO_BASE 0x00000000 #define CFG_PCIE1_IO_PHYS 0x0 #define CFG_PCIE1_IO_SIZE 0x00000000 /* 64k */
/* controller 3, direct to uli, tgtid 3, Base address b000 */ #define CFG_PCIE3_MEM_BASE 0xb0000000 #define CFG_PCIE3_MEM_PHYS CFG_PCIE3_MEM_BASE #define CFG_PCIE3_MEM_SIZE 0x00100000 /* 1M */ #define CFG_PCIE3_IO_BASE 0x00000000 #define CFG_PCIE3_IO_PHYS 0xb0100000 /* reuse mem LAW */ #define CFG_PCIE3_IO_SIZE 0x00000000 /* 1M */ #define CFG_PCIE3_MEM_BASE2 0x0 #define CFG_PCIE3_MEM_PHYS2 CFG_PCIE3_MEM_BASE2 #define CFG_PCIE3_MEM_SIZE2 0x00000000 /* 1M */
#if defined(CONFIG_PCI)
/* video */ #define CONFIG_VIDEO
#if defined(CONFIG_VIDEO) #define VIDEO_IO_OFFSET CFG_PCIE1_IO_PHYS #define CONFIG_BIOSEMU #define CONFIG_CFB_CONSOLE #define CONFIG_VIDEO_SW_CURSOR #define CONFIG_VGA_AS_SINGLE_DEVICE #define CONFIG_ATI_RADEON_FB #define CONFIG_VIDEO_LOGO
/*#define CONFIG_CONSOLE_CURSOR*/ #define CFG_ISA_IO_BASE_ADDRESS CFG_PCIE1_IO_PHYS #endif
#define CONFIG_NET_MULTI #define CONFIG_PCI_PNP /* do pci plug-and-play */
#undef CONFIG_EEPRO100 #undef CONFIG_TULIP #define CONFIG_RTL8139
#ifdef CONFIG_RTL8139 /* This macro is used by RTL8139 but not defined in PPC architecture */ #define KSEG1ADDR(x) ({u32 _x=le32_to_cpu(*(u32 *)(x)); (&_x);}) #define _IO_BASE 0x00000000 #endif
#ifndef CONFIG_PCI_PNP #define PCI_ENET0_IOADDR CFG_PCI1_IO_BASE #define PCI_ENET0_MEMADDR CFG_PCI1_IO_BASE #define PCI_IDSEL_NUMBER 0x11 /* IDSEL = AD11 */ #endif
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #define CONFIG_DOS_PARTITION #define CONFIG_SCSI_AHCI
#ifdef CONFIG_SCSI_AHCI #define CONFIG_SATA_ULI5288 #define CFG_SCSI_MAX_SCSI_ID 4 #define CFG_SCSI_MAX_LUN 1 #define CFG_SCSI_MAX_DEVICE (CFG_SCSI_MAX_SCSI_ID * CFG_SCSI_MAX_LUN) #define CFG_SCSI_MAXDEVICE CFG_SCSI_MAX_DEVICE #endif /* SCSCI */
#endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET)
#ifndef CONFIG_NET_MULTI #define CONFIG_NET_MULTI 1 #endif
#define CONFIG_SGMII_RISER #define TSEC1_SGMII_PHY_ADDR_OFFSET 0x1c #define CONFIG_TSEC_TBI #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ #define CONFIG_TSEC1 1 #define CONFIG_TSEC1_NAME "eTSEC1" #define CONFIG_TSEC3 1 #define CONFIG_TSEC3_NAME "eTSEC3"
#define TSEC1_PHY_ADDR 0 #define TSEC3_PHY_ADDR 1
#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) #define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED)
#define TSEC1_PHYIDX 0 #define TSEC3_PHYIDX 0
#define CONFIG_ETHPRIME "eTSEC1"
#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ #endif /* CONFIG_TSEC_ENET */
/* * Environment */ #define CFG_ENV_IS_IN_FLASH 1 #if CFG_MONITOR_BASE > 0xfff80000 #define CFG_ENV_ADDR 0xfff80000 #else #define CFG_ENV_ADDR (CFG_MONITOR_BASE + 0x70000) #endif #define CFG_ENV_SIZE 0x2000 #define CFG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) */
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* * BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* * Command line configuration. */ #include <config_cmd_default.h>
#define CONFIG_CMD_PING #define CONFIG_CMD_I2C #define CONFIG_CMD_MII
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_BEDBUG #define CONFIG_CMD_NET #define CONFIG_CMD_SCSI #define CONFIG_CMD_EXT2 #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_LOAD_ADDR 0x2000000 /* default load address */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ #if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ #endif #define CFG_PBSIZE (CFG_CBSIZE+sizeof(CFG_PROMPT)+16) /* Print Buffer Size */ #define CFG_MAXARGS 16 /* max number of command args */ #define CFG_BARGSIZE CFG_CBSIZE /* Boot Argument Buffer Size */ #define CFG_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
/* Cache Configuration */ #define CFG_DCACHE_SIZE 32768 #define CFG_CACHELINE_SIZE 32 #if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ #endif
/* * Internal Definitions * * Boot Flags */ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif
/* * Environment Configuration */
/* The mac addresses for all ethernet interface */ #if defined(CONFIG_TSEC_ENET) #define CONFIG_HAS_ETH0 #define CONFIG_ETHADDR 00:E0:0C:02:00:FD #define CONFIG_HAS_ETH1 #define CONFIG_ETH1ADDR 00:E0:0C:02:01:FD #define CONFIG_HAS_ETH2 #define CONFIG_ETH2ADDR 00:E0:0C:02:02:FD #define CONFIG_HAS_ETH3 #define CONFIG_ETH3ADDR 00:E0:0C:02:03:FD #endif
#define CONFIG_IPADDR 192.168.1.251
#define CONFIG_HOSTNAME 8544ds_unknown #define CONFIG_ROOTPATH /nfs/mpc85xx #define CONFIG_BOOTFILE 8544ds/uImage.uboot #define CONFIG_UBOOTPATH 8544ds/u-boot.bin /* TFTP server */
#define CONFIG_SERVERIP 192.168.0.1 #define CONFIG_GATEWAYIP 192.168.0.1 #define CONFIG_NETMASK 255.255.0.0
#define CONFIG_LOADADDR 1000000 /*default location for tftp and bootm*/
#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ #undef CONFIG_BOOTARGS /* the boot command will set bootargs*/
#define CONFIG_BAUDRATE 115200
#if defined(CONFIG_PCIE1) || defined(CONFIG_PCIE2) || defined(CONFIG_PCIE3) #define PCIE_ENV \ "pciereg=md ${a}000 6; md ${a}020 4; md ${a}bf8 2; echo o;md ${a}c00 25;" \ "echo i; md ${a}da0 15; echo e;md ${a}e00 e; echo d; md ${a}f00 c\0" \ "pcieerr=md ${a}020 1; md ${a}e00 e;" \ "pci d.b $b.0 7 1; pci d.w $b.0 1e 1;" \ "pci d.w $b.0 56 1;" \ "pci d $b.0 104 1;pci d $b.0 110 1;pci d $b.0 130 1\0" \ "pcieerrc=mw ${a}020 ffffffff; mw ${a}e00 ffffffff;" \ "pci w.b $b.0 7 ff; pci w.w $b.0 1e ffff; pci w.w $b.0 56 ffff;" \ "pci w $b.0 104 ffffffff; pci w $b.0 110 ffffffff;" \ "pci w $b.0 130 ffffffff\0" \ "pciecfg=pci d $b.0 0 20; pci d $b.0 100 e; pci d $b.0 400 69\0" \ "pcie1regs=setenv a e000a; run pciereg\0" \ "pcie2regs=setenv a e0009; run pciereg\0" \ "pcie3regs=setenv a e000b; run pciereg\0" \ "pcie1cfg=setenv b 3; run pciecfg\0" \ "pcie2cfg=setenv b 5; run pciecfg\0" \ "pcie3cfg=setenv b 0; run pciecfg\0" \ "pcie1err=setenv a e000a; setenv b 3; run pcieerr\0" \ "pcie2err=setenv a e0009; setenv b 5; run pcieerr\0" \ "pcie3err=setenv a e000b; setenv b 0; run pcieerr\0" \ "pcie1errc=setenv a e000a; setenv b 3; run pcieerrc\0" \ "pcie2errc=setenv a e0009; setenv b 5; run pcieerrc\0" \ "pcie3errc=setenv a e000b; setenv b 0; run pcieerrc\0" #else #define PCIE_ENV "" #endif
#if defined(CONFIG_PCI1) #define PCI_ENV \ "pcireg=md ${a}000 3; echo o;md ${a}c00 25; echo i; md ${a}da0 15;" \ "echo e;md ${a}e00 9\0" \ "pci1regs=setenv a e0008; run pcireg\0" \ "pcierr=md ${a}e00 8; pci d.b $b.0 7 1; pci d.w $b.0 1e 1;" \ "pci d.w $b.0 56 1\0" \ "pcierrc=mw ${a}e00 ffffffff; mw ${a}e0c 0; pci w.b $b.0 7 ff;" \ "pci w.w $b.0 1e ffff; pci w.w $b.0 56 ffff\0" \ "pci1err=setenv a e0008; setenv b 7; run pcierr\0" \ "pci1errc=setenv a e0008; setenv b 7; run pcierrc\0" #else #define PCI_ENV "" #endif
#if defined(CONFIG_TSEC_ENET) #define ENET_ENV \ "enetreg1=md ${a}000 2; md ${a}010 9; md ${a}050 4; md ${a}08c 1;" \ "md ${a}098 2\0" \ "enetregt=echo t;md ${a}100 6; md ${a}140 2; md ${a}180 10; md ${a}200 10\0" \ "enetregr=echo r;md ${a}300 6; md ${a}330 5; md ${a}380 10; md ${a}400 10\0" \ "enetregm=echo mac;md ${a}500 5; md ${a}520 28;echo fifo;md ${a}a00 1;" \ "echo mib;md ${a}680 31\0" \ "enetreg=run enetreg1; run enetregm; run enetregt; run enetregr\0" \ "enet1regs=setenv a e0024; run enetreg\0" \ "enet3regs=setenv a e0026; run enetreg\0" #else #define ENET_ENV "" #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ "protect off " MK_STR(TEXT_BASE) " +$filesize; " \ "erase " MK_STR(TEXT_BASE) " +$filesize; " \ "cp.b $loadaddr " MK_STR(TEXT_BASE) " $filesize; " \ "protect on " MK_STR(TEXT_BASE) " +$filesize; " \ "cmp.b $loadaddr " MK_STR(TEXT_BASE) " $filesize\0" \ "consoledev=ttyS0\0" \ "ramdiskaddr=2000000\0" \ "ramdiskfile=8544ds/ramdisk.uboot\0" \ "dtbaddr=c00000\0" \ "dtbfile=8544ds/mpc8544ds.dtb\0" \ "bdev=sda3\0" \ "eoi=mw e00400b0 0\0" \ "iack=md e00400a0 1\0" \ "ddrreg=md ${a}000 8; md ${a}080 8;md ${a}100 d; md ${a}140 4; md ${a}bf0 4;" \ "md ${a}e00 3; md ${a}e20 3; md ${a}e40 7; md ${a}f00 5\0" \ "ddrregs=setenv a e0002; run ddrreg\0" \ "gureg=md ${a}000 2c; md ${a}0b0 1; md ${a}0c0 1; md ${a}b20 3;" \ "md ${a}e00 1; md ${a}e60 1; md ${a}ef0 15\0" \ "guregs=setenv a e00e0; run gureg\0" \ "ecmreg=md ${a}000 1; md ${a}010 1; md ${a}bf8 2; md ${a}e00 6\0" \ "ecmregs=setenv a e0001; run ecmreg\0" \ "lawregs=md e0000c08 4b\0" \ "lbcregs=md e0005000 36\0" \ "dma0regs=md e0021100 12\0" \ "dma1regs=md e0021180 12\0" \ "dma2regs=md e0021200 12\0" \ "dma3regs=md e0021280 12\0" \ PCIE_ENV \ PCI_ENV \ ENET_ENV
#define CONFIG_NFSBOOTCOMMAND \ "setenv bootargs root=/dev/nfs rw " \ "nfsroot=$serverip:$rootpath " \ "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $loadaddr $bootfile;" \ "tftp $dtbaddr $dtbfile;" \ "bootm $loadaddr - $dtbaddr"
#define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $ramdiskaddr $ramdiskfile;" \ "tftp $loadaddr $bootfile;" \ "tftp $dtbaddr $dtbfile;" \ "bootm $loadaddr $ramdiskaddr $dtbaddr"
#define CONFIG_BOOTCOMMAND \ "setenv bootargs root=/dev/$bdev rw " \ "console=$consoledev,$baudrate $othbootargs;" \ "tftp $loadaddr $bootfile;" \ "tftp $dtbaddr $dtbfile;" \ "bootm $loadaddr - $dtbaddr"
#endif /* __CONFIG_H */ =============================================================================
the cpu/mpc85xx/start.s is as below: ============================================================================ /* U-Boot Startup Code for Motorola 85xx PowerPC based Embedded Boards * * The processor starts at 0xfffffffc and the code is first executed in the * last 4K page(0xfffff000-0xffffffff) in flash/rom. * */
#include <config.h> #include <mpc85xx.h> #include <version.h>
#define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */
#ifndef CONFIG_IDENT_STRING #define CONFIG_IDENT_STRING "" #endif
#undef MSR_KERNEL #define MSR_KERNEL ( MSR_ME ) /* Machine Check */
/* * Set up GOT: Global Offset Table * * Use r14 to access the GOT */ START_GOT GOT_ENTRY(_GOT2_TABLE_) GOT_ENTRY(_FIXUP_TABLE_)
GOT_ENTRY(_start) GOT_ENTRY(_start_of_vectors) GOT_ENTRY(_end_of_vectors) GOT_ENTRY(transfer_to_handler)
GOT_ENTRY(__init_end) GOT_ENTRY(_end) GOT_ENTRY(__bss_start) END_GOT
/* * e500 Startup -- after reset only the last 4KB of the effective * address space is mapped in the MMU L2 TLB1 Entry0. The .bootpg * section is located at THIS LAST page and basically does three * things: clear some registers, set up exception tables and * add more TLB entries for 'larger spaces'(e.g. the boot rom) to * continue the boot procedure.
* Once the boot rom is mapped by TLB entries we can proceed * with normal startup. * */
.section .bootpg,"ax" .globl _start_e500
_start_e500:
/* clear registers/arrays not reset by hardware */
/* L1 */ li r0,2 mtspr L1CSR0,r0 /* invalidate d-cache */ mtspr L1CSR1,r0 /* invalidate i-cache */
mfspr r1,DBSR mtspr DBSR,r1 /* Clear all valid bits */
/* * Enable L1 Caches early * */
lis r2,L1CSR0_CPE@H /* enable parity */ ori r2,r2,L1CSR0_DCE mtspr L1CSR0,r2 /* enable L1 Dcache */ isync mtspr L1CSR1,r2 /* enable L1 Icache */ isync msync
/* Setup interrupt vectors */ lis r1,TEXT_BASE@h mtspr IVPR,r1
li r1,0x0100 mtspr IVOR0,r1 /* 0: Critical input */ li r1,0x0200 mtspr IVOR1,r1 /* 1: Machine check */ li r1,0x0300 mtspr IVOR2,r1 /* 2: Data storage */ li r1,0x0400 mtspr IVOR3,r1 /* 3: Instruction storage */ li r1,0x0500 mtspr IVOR4,r1 /* 4: External interrupt */ li r1,0x0600 mtspr IVOR5,r1 /* 5: Alignment */ li r1,0x0700 mtspr IVOR6,r1 /* 6: Program check */ li r1,0x0800 mtspr IVOR7,r1 /* 7: floating point unavailable */ li r1,0x0900 mtspr IVOR8,r1 /* 8: System call */ /* 9: Auxiliary processor unavailable(unsupported) */ li r1,0x0a00 mtspr IVOR10,r1 /* 10: Decrementer */ li r1,0x0b00 mtspr IVOR11,r1 /* 11: Interval timer */ li r1,0x0c00 mtspr IVOR12,r1 /* 12: Watchdog timer */ li r1,0x0d00 mtspr IVOR13,r1 /* 13: Data TLB error */ li r1,0x0e00 mtspr IVOR14,r1 /* 14: Instruction TLB error */ li r1,0x0f00 mtspr IVOR15,r1 /* 15: Debug */
/* * After reset, CCSRBAR is located at CFG_CCSRBAR_DEFAULT, i.e. * 0xff700000-0xff800000. We need add a TLB1 entry for this 1MB * region before we can access any CCSR registers such as L2 * registers, Local Access Registers,etc. We will also re-allocate * CFG_CCSRBAR_DEFAULT to CFG_CCSRBAR immediately after TLB1 setup. * * Please refer to board-specif directory for TLB1 entry configuration. * (e.g. board/<yourboard>/init.S) * */ bl tlb1_entry mr r5,r0 lwzu r4,0(r5) /* how many TLB1 entries we actually use */ mtctr r4
0: lwzu r6,4(r5) lwzu r7,4(r5) lwzu r8,4(r5) lwzu r9,4(r5) mtspr MAS0,r6 mtspr MAS1,r7 mtspr MAS2,r8 mtspr MAS3,r9 isync msync tlbwe isync bdnz 0b
1: #if (CFG_CCSRBAR_DEFAULT != CFG_CCSRBAR) /* Special sequence needed to update CCSRBAR itself */ lis r4,CFG_CCSRBAR_DEFAULT@h ori r4,r4,CFG_CCSRBAR_DEFAULT@l
lis r5,CFG_CCSRBAR@h ori r5,r5,CFG_CCSRBAR@l srwi r6,r5,12 stw r6,0(r4) isync
lis r5,0xffff ori r5,r5,0xf000 lwz r5,0(r5) isync
lis r3,CFG_CCSRBAR@h lwz r5,CFG_CCSRBAR@l(r3) isync #endif
/* set up local access windows, defined at board/<boardname>/init.S */ lis r7,CFG_CCSRBAR@h ori r7,r7,CFG_CCSRBAR@l
bl law_entry mr r6,r0 lwzu r5,0(r6) /* how many windows we actually use */ mtctr r5
li r2,0x0c28 /* the first pair is reserved for */ li r1,0x0c30 /* boot-over-rio-or-pci */
0: lwzu r4,4(r6) lwzu r3,4(r6) stwx r4,r7,r2 stwx r3,r7,r1 addi r2,r2,0x0020 addi r1,r1,0x0020 bdnz 0b
/* Clear and set up some registers. */ li r0,0x0000 lis r1,0xffff mtspr DEC,r0 /* prevent dec exceptions */ mttbl r0 /* prevent fit & wdt exceptions */ mttbu r0 mtspr TSR,r1 /* clear all timer exception status */ mtspr TCR,r0 /* disable all */ mtspr ESR,r0 /* clear exception syndrome register */ mtspr MCSR,r0 /* machine check syndrome register */ mtxer r0 /* clear integer exception register */ lis r1,0x0002 /* set CE bit (Critical Exceptions) */ ori r1,r1,0x1200 /* set ME/DE bit */ mtmsr r1 /* change MSR */ isync
/* Enable Time Base and Select Time Base Clock */ lis r0,HID0_EMCP@h /* Enable machine check */ #if defined(CONFIG_ENABLE_36BIT_PHYS) ori r0,r0,(HID0_TBEN|HID0_ENMAS7)@l /* Enable Timebase & MAS7 */ #else ori r0,r0,HID0_TBEN@l /* enable Timebase */ #endif mtspr HID0,r0
li r0,(HID1_ASTME|HID1_ABE)@l /* Addr streaming & broadcast */ mtspr HID1,r0
/* Enable Branch Prediction */ #if defined(CONFIG_BTB) li r0,0x201 /* BBFI = 1, BPEN = 1 */ mtspr BUCSR,r0 #endif
#if defined(CFG_INIT_DBCR) lis r1,0xffff ori r1,r1,0xffff mtspr DBSR,r1 /* Clear all status bits */ lis r0,CFG_INIT_DBCR@h /* DBCR0[IDM] must be set */ ori r0,r0,CFG_INIT_DBCR@l mtspr DBCR0,r0 #endif
/* L1 DCache is used for initial RAM */
/* Allocate Initial RAM in data cache. */ lis r3,CFG_INIT_RAM_ADDR@h ori r3,r3,CFG_INIT_RAM_ADDR@l li r2,512 /* 512*32=16K */ mtctr r2 li r0,0 1: dcbz r0,r3 dcbtls 0,r0,r3 addi r3,r3,32 bdnz 1b
/* Jump out the last 4K page and continue to 'normal' start */ #ifdef CFG_RAMBOOT bl 3f b _start_cont #else /* Calculate absolute address in FLASH and jump there */ /*--------------------------------------------------------------*/ lis r3,CFG_MONITOR_BASE@h ori r3,r3,CFG_MONITOR_BASE@l addi r3,r3,_start_cont - _start + _START_OFFSET mtlr r3 #endif
3: li r0,0 #if !defined(CONFIG_CW) mtspr SRR1,r0 /* Keep things disabled for now */ #endif mflr r1 mtspr SRR0,r1 rfi isync
.text .globl _start _start: .long 0x27051956 /* U-BOOT Magic Number */ .globl version_string version_string: .ascii U_BOOT_VERSION .ascii " (", __DATE__, " - ", __TIME__, ")" .ascii CONFIG_IDENT_STRING, "\0"
.align 4 .globl _start_cont _start_cont: /* Setup the stack in initial RAM,could be L2-as-SRAM or L1 dcache*/ lis r1,CFG_INIT_RAM_ADDR@h ori r1,r1,CFG_INIT_SP_OFFSET@l
li r0,0 stwu r0,-4(r1) stwu r0,-4(r1) /* Terminate call chain */
stwu r1,-8(r1) /* Save back chain and move SP */ lis r0,RESET_VECTOR@h /* Address of reset vector */ ori r0,r0,RESET_VECTOR@l stwu r1,-8(r1) /* Save back chain and move SP */ stw r0,+12(r1) /* Save return addr (underflow vect) */
GET_GOT bl cpu_init_f bl board_init_f isync
. = EXC_OFF_SYS_RESET .globl _start_of_vectors _start_of_vectors:
/* Critical input. */ CRIT_EXCEPTION(0x0100, CriticalInput, CritcalInputException)
/* Machine check */ MCK_EXCEPTION(0x200, MachineCheck, MachineCheckException)
/* Data Storage exception. */ STD_EXCEPTION(0x0300, DataStorage, UnknownException)
/* Instruction Storage exception. */ STD_EXCEPTION(0x0400, InstStorage, UnknownException)
/* External Interrupt exception. */ STD_EXCEPTION(0x0500, ExtInterrupt, ExtIntException)
/* Alignment exception. */ . = 0x0600 Alignment: EXCEPTION_PROLOG(SRR0, SRR1) mfspr r4,DAR stw r4,_DAR(r21) mfspr r5,DSISR stw r5,_DSISR(r21) addi r3,r1,STACK_FRAME_OVERHEAD li r20,MSR_KERNEL rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ lwz r6,GOT(transfer_to_handler) mtlr r6 blrl .L_Alignment: .long AlignmentException - _start + _START_OFFSET .long int_return - _start + _START_OFFSET
/* Program check exception */ . = 0x0700 ProgramCheck: EXCEPTION_PROLOG(SRR0, SRR1) addi r3,r1,STACK_FRAME_OVERHEAD li r20,MSR_KERNEL rlwimi r20,r23,0,16,16 /* copy EE bit from saved MSR */ lwz r6,GOT(transfer_to_handler) mtlr r6 blrl .L_ProgramCheck: .long ProgramCheckException - _start + _START_OFFSET .long int_return - _start + _START_OFFSET
/* No FPU on MPC85xx. This exception is not supposed to happen. */ STD_EXCEPTION(0x0800, FPUnavailable, UnknownException)
. = 0x0900 /* * r0 - SYSCALL number * r3-... arguments */ SystemCall: addis r11,r0,0 /* get functions table addr */ ori r11,r11,0 /* Note: this code is patched in trap_init */ addis r12,r0,0 /* get number of functions */ ori r12,r12,0
cmplw 0,r0,r12 bge 1f
rlwinm r0,r0,2,0,31 /* fn_addr = fn_tbl[r0] */ add r11,r11,r0 lwz r11,0(r11)
li r20,0xd00-4 /* Get stack pointer */ lwz r12,0(r20) subi r12,r12,12 /* Adjust stack pointer */ li r0,0xc00+_end_back-SystemCall cmplw 0,r0,r12 /* Check stack overflow */ bgt 1f stw r12,0(r20)
mflr r0 stw r0,0(r12) mfspr r0,SRR0 stw r0,4(r12) mfspr r0,SRR1 stw r0,8(r12)
li r12,0xc00+_back-SystemCall mtlr r12 mtspr SRR0,r11
1: SYNC rfi _back:
mfmsr r11 /* Disable interrupts */ li r12,0 ori r12,r12,MSR_EE andc r11,r11,r12 SYNC /* Some chip revs need this... */ mtmsr r11 SYNC
li r12,0xd00-4 /* restore regs */ lwz r12,0(r12)
lwz r11,0(r12) mtlr r11 lwz r11,4(r12) mtspr SRR0,r11 lwz r11,8(r12) mtspr SRR1,r11
addi r12,r12,12 /* Adjust stack pointer */ li r20,0xd00-4 stw r12,0(r20)
SYNC rfi _end_back:
STD_EXCEPTION(0x0a00, Decrementer, timer_interrupt) STD_EXCEPTION(0x0b00, IntervalTimer, UnknownException) STD_EXCEPTION(0x0c00, WatchdogTimer, UnknownException)
STD_EXCEPTION(0x0d00, DataTLBError, UnknownException) STD_EXCEPTION(0x0e00, InstructionTLBError, UnknownException)
CRIT_EXCEPTION(0x0f00, DebugBreakpoint, DebugException )
.globl _end_of_vectors _end_of_vectors:
. = . + (0x100 - ( . & 0xff )) /* align for debug */
/* * This code finishes saving the registers to the exception frame * and jumps to the appropriate handler for the exception. * Register r21 is pointer into trap frame, r1 has new stack pointer. */ .globl transfer_to_handler transfer_to_handler: stw r22,_NIP(r21) lis r22,MSR_POW@h andc r23,r23,r22 stw r23,_MSR(r21) SAVE_GPR(7, r21) SAVE_4GPRS(8, r21) SAVE_8GPRS(12, r21) SAVE_8GPRS(24, r21)
mflr r23 andi. r24,r23,0x3f00 /* get vector offset */ stw r24,TRAP(r21) li r22,0 stw r22,RESULT(r21) mtspr SPRG2,r22 /* r1 is now kernel sp */
lwz r24,0(r23) /* virtual address of handler */ lwz r23,4(r23) /* where to go when done */ mtspr SRR0,r24 mtspr SRR1,r20 mtlr r23 SYNC rfi /* jump to handler, enable MMU */
int_return: mfmsr r28 /* Disable interrupts */ li r4,0 ori r4,r4,MSR_EE andc r28,r28,r4 SYNC /* Some chip revs need this... */ mtmsr r28 SYNC lwz r2,_CTR(r1) lwz r0,_LINK(r1) mtctr r2 mtlr r0 lwz r2,_XER(r1) lwz r0,_CCR(r1) mtspr XER,r2 mtcrf 0xFF,r0 REST_10GPRS(3, r1) REST_10GPRS(13, r1) REST_8GPRS(23, r1) REST_GPR(31, r1) lwz r2,_NIP(r1) /* Restore environment */ lwz r0,_MSR(r1) mtspr SRR0,r2 mtspr SRR1,r0 lwz r0,GPR0(r1) lwz r2,GPR2(r1) lwz r1,GPR1(r1) SYNC rfi
crit_return: mfmsr r28 /* Disable interrupts */ li r4,0 ori r4,r4,MSR_EE andc r28,r28,r4 SYNC /* Some chip revs need this... */ mtmsr r28 SYNC lwz r2,_CTR(r1) lwz r0,_LINK(r1) mtctr r2 mtlr r0 lwz r2,_XER(r1) lwz r0,_CCR(r1) mtspr XER,r2 mtcrf 0xFF,r0 REST_10GPRS(3, r1) REST_10GPRS(13, r1) REST_8GPRS(23, r1) REST_GPR(31, r1) lwz r2,_NIP(r1) /* Restore environment */ lwz r0,_MSR(r1) mtspr SPRN_CSRR0,r2 mtspr SPRN_CSRR1,r0 lwz r0,GPR0(r1) lwz r2,GPR2(r1) lwz r1,GPR1(r1) SYNC rfci
mck_return: mfmsr r28 /* Disable interrupts */ li r4,0 ori r4,r4,MSR_EE andc r28,r28,r4 SYNC /* Some chip revs need this... */ mtmsr r28 SYNC lwz r2,_CTR(r1) lwz r0,_LINK(r1) mtctr r2 mtlr r0 lwz r2,_XER(r1) lwz r0,_CCR(r1) mtspr XER,r2 mtcrf 0xFF,r0 REST_10GPRS(3, r1) REST_10GPRS(13, r1) REST_8GPRS(23, r1) REST_GPR(31, r1) lwz r2,_NIP(r1) /* Restore environment */ lwz r0,_MSR(r1) mtspr SPRN_MCSRR0,r2 mtspr SPRN_MCSRR1,r0 lwz r0,GPR0(r1) lwz r2,GPR2(r1) lwz r1,GPR1(r1) SYNC rfmci
/* Cache functions. */ invalidate_icache: mfspr r0,L1CSR1 ori r0,r0,L1CSR1_ICFI msync isync mtspr L1CSR1,r0 isync blr /* entire I cache */
invalidate_dcache: mfspr r0,L1CSR0 ori r0,r0,L1CSR0_DCFI msync isync mtspr L1CSR0,r0 isync blr
.globl icache_enable icache_enable: mflr r8 bl invalidate_icache mtlr r8 isync mfspr r4,L1CSR1 ori r4,r4,0x0001 oris r4,r4,0x0001 mtspr L1CSR1,r4 isync blr
.globl icache_disable icache_disable: mfspr r0,L1CSR1 lis r3,0 ori r3,r3,L1CSR1_ICE andc r0,r0,r3 mtspr L1CSR1,r0 isync blr
.globl icache_status icache_status: mfspr r3,L1CSR1 andi. r3,r3,L1CSR1_ICE blr
.globl dcache_enable dcache_enable: mflr r8 bl invalidate_dcache mtlr r8 isync mfspr r0,L1CSR0 ori r0,r0,0x0001 oris r0,r0,0x0001 msync isync mtspr L1CSR0,r0 isync blr
.globl dcache_disable dcache_disable: mfspr r3,L1CSR0 lis r4,0 ori r4,r4,L1CSR0_DCE andc r3,r3,r4 mtspr L1CSR0,r0 isync blr
.globl dcache_status dcache_status: mfspr r3,L1CSR0 andi. r3,r3,L1CSR0_DCE blr
.globl get_pir get_pir: mfspr r3,PIR blr
.globl get_pvr get_pvr: mfspr r3,PVR blr
.globl get_svr get_svr: mfspr r3,SVR blr
.globl wr_tcr wr_tcr: mtspr TCR,r3 blr
/*------------------------------------------------------------------------------- */ /* Function: in8 */ /* Description: Input 8 bits */ /*------------------------------------------------------------------------------- */ .globl in8 in8: lbz r3,0x0000(r3) blr
/*------------------------------------------------------------------------------- */ /* Function: out8 */ /* Description: Output 8 bits */ /*------------------------------------------------------------------------------- */ .globl out8 out8: stb r4,0x0000(r3) blr
/*------------------------------------------------------------------------------- */ /* Function: out16 */ /* Description: Output 16 bits */ /*------------------------------------------------------------------------------- */ .globl out16 out16: sth r4,0x0000(r3) blr
/*------------------------------------------------------------------------------- */ /* Function: out16r */ /* Description: Byte reverse and output 16 bits */ /*------------------------------------------------------------------------------- */ .globl out16r out16r: sthbrx r4,r0,r3 blr
/*------------------------------------------------------------------------------- */ /* Function: out32 */ /* Description: Output 32 bits */ /*------------------------------------------------------------------------------- */ .globl out32 out32: stw r4,0x0000(r3) blr
/*------------------------------------------------------------------------------- */ /* Function: out32r */ /* Description: Byte reverse and output 32 bits */ /*------------------------------------------------------------------------------- */ .globl out32r out32r: stwbrx r4,r0,r3 blr
/*------------------------------------------------------------------------------- */ /* Function: in16 */ /* Description: Input 16 bits */ /*------------------------------------------------------------------------------- */ .globl in16 in16: lhz r3,0x0000(r3) sync blr
/*------------------------------------------------------------------------------- */ /* Function: in16r */ /* Description: Input 16 bits and byte reverse */ /*------------------------------------------------------------------------------- */ .globl in16r in16r: lhbrx r3,r0,r3 sync blr
/*------------------------------------------------------------------------------- */ /* Function: in32 */ /* Description: Input 32 bits */ /*------------------------------------------------------------------------------- */ .globl in32 in32: lwz 3,0x0000(3) sync blr
/*------------------------------------------------------------------------------- */ /* Function: in32r */ /* Description: Input 32 bits and byte reverse */ /*------------------------------------------------------------------------------- */ .globl in32r in32r: lwbrx r3,r0,r3 sync blr
/*------------------------------------------------------------------------------- */ /* Function: ppcDcbf */ /* Description: Data Cache block flush */ /* Input: r3 = effective address */ /* Output: none. */ /*------------------------------------------------------------------------------- */ .globl ppcDcbf ppcDcbf: dcbf r0,r3 blr
/*------------------------------------------------------------------------------- */ /* Function: ppcDcbi */ /* Description: Data Cache block Invalidate */ /* Input: r3 = effective address */ /* Output: none. */ /*------------------------------------------------------------------------------- */ .globl ppcDcbi ppcDcbi: dcbi r0,r3 blr
/*-------------------------------------------------------------------------- * Function: ppcDcbz * Description: Data Cache block zero. * Input: r3 = effective address * Output: none. *-------------------------------------------------------------------------- */
.globl ppcDcbz ppcDcbz: dcbz r0,r3 blr
/*------------------------------------------------------------------------------- */ /* Function: ppcSync */ /* Description: Processor Synchronize */ /* Input: none. */ /* Output: none. */ /*------------------------------------------------------------------------------- */ .globl ppcSync ppcSync: sync blr
/* * void relocate_code (addr_sp, gd, addr_moni) * * This "function" does not return, instead it continues in RAM * after relocating the monitor code. * * r3 = dest * r4 = src * r5 = length in bytes * r6 = cachelinesize */ .globl relocate_code relocate_code: mr r1,r3 /* Set new stack pointer */ mr r9,r4 /* Save copy of Init Data pointer */ mr r10,r5 /* Save copy of Destination Address */
mr r3,r5 /* Destination Address */ lis r4,CFG_MONITOR_BASE@h /* Source Address */ ori r4,r4,CFG_MONITOR_BASE@l lwz r5,GOT(__init_end) sub r5,r5,r4 li r6,CFG_CACHELINE_SIZE /* Cache Line Size */
/* * Fix GOT pointer: * * New GOT-PTR = (old GOT-PTR - CFG_MONITOR_BASE) + Destination Address * * Offset: */ sub r15,r10,r4
/* First our own GOT */ add r14,r14,r15 /* the the one used by the C code */ add r30,r30,r15
/* * Now relocate code */
cmplw cr1,r3,r4 addi r0,r5,3 srwi. r0,r0,2 beq cr1,4f /* In place copy is not necessary */ beq 7f /* Protect against 0 count */ mtctr r0 bge cr1,2f
la r8,-4(r4) la r7,-4(r3) 1: lwzu r0,4(r8) stwu r0,4(r7) bdnz 1b b 4f
2: slwi r0,r0,2 add r8,r4,r0 add r7,r3,r0 3: lwzu r0,-4(r8) stwu r0,-4(r7) bdnz 3b
/* * Now flush the cache: note that we must start from a cache aligned * address. Otherwise we might miss one cache line. */ 4: cmpwi r6,0 add r5,r3,r5 beq 7f /* Always flush prefetch queue in any case */ subi r0,r6,1 andc r3,r3,r0 mr r4,r3 5: dcbst 0,r4 add r4,r4,r6 cmplw r4,r5 blt 5b sync /* Wait for all dcbst to complete on bus */ mr r4,r3 6: icbi 0,r4 add r4,r4,r6 cmplw r4,r5 blt 6b 7: sync /* Wait for all icbi to complete on bus */ isync
/* * Re-point the IVPR at RAM */ mtspr IVPR,r10
/* * We are done. Do not return, instead branch to second part of board * initialization, now running from RAM. */
addi r0,r10,in_ram - _start + _START_OFFSET mtlr r0 blr /* NEVER RETURNS! */ .globl in_ram in_ram:
/* * Relocation Function, r14 point to got2+0x8000 * * Adjust got2 pointers, no need to check for 0, this code * already puts a few entries in the table. */ li r0,__got2_entries@sectoff@l la r3,GOT(_GOT2_TABLE_) lwz r11,GOT(_GOT2_TABLE_) mtctr r0 sub r11,r3,r11 addi r3,r3,-4 1: lwzu r0,4(r3) add r0,r0,r11 stw r0,0(r3) bdnz 1b
/* * Now adjust the fixups and the pointers to the fixups * in case we need to move ourselves again. */ 2: li r0,__fixup_entries@sectoff@l lwz r3,GOT(_FIXUP_TABLE_) cmpwi r0,0 mtctr r0 addi r3,r3,-4 beq 4f 3: lwzu r4,4(r3) lwzux r0,r4,r11 add r0,r0,r11 stw r10,0(r3) stw r0,0(r4) bdnz 3b 4: clear_bss: /* * Now clear BSS segment */ lwz r3,GOT(__bss_start) lwz r4,GOT(_end)
cmplw 0,r3,r4 beq 6f
li r0,0 5: stw r0,0(r3) addi r3,r3,4 cmplw 0,r3,r4 bne 5b 6:
mr r3,r9 /* Init Data pointer */ mr r4,r10 /* Destination Address */ bl board_init_r
/* * Copy exception vector code to low memory * * r3: dest_addr * r7: source address, r8: end address, r9: target address */ .globl trap_init trap_init: lwz r7,GOT(_start_of_vectors) lwz r8,GOT(_end_of_vectors)
li r9,0x100 /* reset vector always at 0x100 */
cmplw 0,r7,r8 bgelr /* return if r7>=r8 - just in case */
mflr r4 /* save link register */ 1: lwz r0,0(r7) stw r0,0(r9) addi r7,r7,4 addi r9,r9,4 cmplw 0,r7,r8 bne 1b
/* * relocate `hdlr' and `int_return' entries */ li r7,.L_CriticalInput - _start + _START_OFFSET bl trap_reloc li r7,.L_MachineCheck - _start + _START_OFFSET bl trap_reloc li r7,.L_DataStorage - _start + _START_OFFSET bl trap_reloc li r7,.L_InstStorage - _start + _START_OFFSET bl trap_reloc li r7,.L_ExtInterrupt - _start + _START_OFFSET bl trap_reloc li r7,.L_Alignment - _start + _START_OFFSET bl trap_reloc li r7,.L_ProgramCheck - _start + _START_OFFSET bl trap_reloc li r7,.L_FPUnavailable - _start + _START_OFFSET bl trap_reloc li r7,.L_Decrementer - _start + _START_OFFSET bl trap_reloc li r7,.L_IntervalTimer - _start + _START_OFFSET li r8,_end_of_vectors - _start + _START_OFFSET 2: bl trap_reloc addi r7,r7,0x100 /* next exception vector */ cmplw 0,r7,r8 blt 2b
lis r7,0x0 mtspr IVPR,r7
mtlr r4 /* restore link register */ blr
/* * Function: relocate entries for one exception vector */ trap_reloc: lwz r0,0(r7) /* hdlr ... */ add r0,r0,r3 /* ... += dest_addr */ stw r0,0(r7)
lwz r0,4(r7) /* int_return ... */ add r0,r0,r3 /* ... += dest_addr */ stw r0,4(r7)
blr
#ifdef CFG_INIT_RAM_LOCK .globl unlock_ram_in_cache unlock_ram_in_cache: /* invalidate the INIT_RAM section */ lis r3,(CFG_INIT_RAM_ADDR & ~31)@h ori r3,r3,(CFG_INIT_RAM_ADDR & ~31)@l li r4,512 mtctr r4 1: icbi r0,r3 dcbi r0,r3 addi r3,r3,32 bdnz 1b sync /* Wait for all icbi to complete on bus */ isync blr #endif ============================================================================
A quick question is, there is a FPGA(actel pixis) in mpc8544ds board, and it seems related with system clock ??? There is no such FPGA in my board, is it the problem??
Shall I remove the pixis related code from board.h and board.c and try to configure system clock by myself ?? Still confusing.....
Thanks for any help.
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
transaction with
system bus.
Not need.
It is possible to be problem.
Yes, remove the pixis related code. Configure the sys clk directly.
Thanks, Dave
Hi Dave, It still shows data tlb error tho. I found it occur error around the GET_GOT of start.s. The SRR0 and SRR1 show the error address of system.map is _start_cont. Suspect the DDR setting problem ?? But I thought all the DDR setting are from SPD. So, I didn't set any entry of DDR in TLB1. Any hint?
transaction with
system bus.
Not need.
Thanks, Dave _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
duckycool
Liu Dave-R63238
