[U-Boot] [PATCH 7/7 v3] OMAP3: Clean up MMC code
Clean up OMAP3 MMC code:
* Convert register access to struct & readx/writex style * Replace hardcode values by macros * Remove macro defined twice
Signed-off-by: Dirk Behme dirk.behme@googlemail.com
--- Changes in v3:
Rebase after MMC framework merge to mainline. No functional change.
This patch is against U-Boot master branch, commit e5e88c3614b79b54719905f66aefb51f9494bc1f "ARM:OMAP3 Change mmc_init to mmc_legacy_init"
This patch replaces v2 version of this patch
http://lists.denx.de/pipermail/u-boot/2009-February/047454.html
All other patches of OMAP3 v2 patch series
http://lists.denx.de/pipermail/u-boot/2009-February/047450.html
still apply cleanly to above master branch and are unchanged.
drivers/mmc/omap3_mmc.c | 145 +++++++++++++++--------------- include/asm-arm/arch-omap3/mmc_host_def.h | 64 ++++++++----- include/asm-arm/arch-omap3/omap3.h | 3 3 files changed, 118 insertions(+), 94 deletions(-)
Index: u-boot-main/include/asm-arm/arch-omap3/mmc_host_def.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap3/mmc_host_def.h +++ u-boot-main/include/asm-arm/arch-omap3/mmc_host_def.h @@ -25,30 +25,50 @@ #ifndef MMC_HOST_DEF_H #define MMC_HOST_DEF_H
+/* T2 Register definitions */ +#define T2_BASE 0x48002000 + +typedef struct t2 { + unsigned char res1[0x274]; + unsigned int devconf0; /* 0x274 */ + unsigned char res2[0x2A8]; + unsigned int pbias_lite; /* 0x520 */ +} t2_t; + +#define MMCSDIO1ADPCLKISEL (1 << 24) + +#define PBIASLITEPWRDNZ0 (1 << 1) +#define PBIASSPEEDCTRL0 (1 << 2) +#define PBIASLITEPWRDNZ1 (1 << 9) + /* * OMAP HSMMC register definitions */ -#define OMAP_HSMMC_SYSCONFIG (*(unsigned int *) 0x4809C010) -#define OMAP_HSMMC_SYSSTATUS (*(unsigned int *) 0x4809C014) -#define OMAP_HSMMC_CON (*(unsigned int *) 0x4809C02C) -#define OMAP_HSMMC_BLK (*(unsigned int *) 0x4809C104) -#define OMAP_HSMMC_ARG (*(unsigned int *) 0x4809C108) -#define OMAP_HSMMC_CMD (*(unsigned int *) 0x4809C10C) -#define OMAP_HSMMC_RSP10 (*(unsigned int *) 0x4809C110) -#define OMAP_HSMMC_RSP32 (*(unsigned int *) 0x4809C114) -#define OMAP_HSMMC_RSP54 (*(unsigned int *) 0x4809C118) -#define OMAP_HSMMC_RSP76 (*(unsigned int *) 0x4809C11C) -#define OMAP_HSMMC_DATA (*(unsigned int *) 0x4809C120) -#define OMAP_HSMMC_PSTATE (*(unsigned int *) 0x4809C124) -#define OMAP_HSMMC_HCTL (*(unsigned int *) 0x4809C128) -#define OMAP_HSMMC_SYSCTL (*(unsigned int *) 0x4809C12C) -#define OMAP_HSMMC_STAT (*(unsigned int *) 0x4809C130) -#define OMAP_HSMMC_IE (*(unsigned int *) 0x4809C134) -#define OMAP_HSMMC_CAPA (*(unsigned int *) 0x4809C140) +#define OMAP_HSMMC_BASE 0x4809C000
-/* T2 Register definitions */ -#define CONTROL_DEV_CONF0 (*(unsigned int *) 0x48002274) -#define CONTROL_PBIAS_LITE (*(unsigned int *) 0x48002520) +typedef struct hsmmc { + unsigned char res1[0x10]; + unsigned int sysconfig; /* 0x10 */ + unsigned int sysstatus; /* 0x14 */ + unsigned char res2[0x14]; + unsigned int con; /* 0x2C */ + unsigned char res3[0xD4]; + unsigned int blk; /* 0x104 */ + unsigned int arg; /* 0x108 */ + unsigned int cmd; /* 0x10C */ + unsigned int rsp10; /* 0x110 */ + unsigned int rsp32; /* 0x114 */ + unsigned int rsp54; /* 0x118 */ + unsigned int rsp76; /* 0x11C */ + unsigned int data; /* 0x120 */ + unsigned int pstate; /* 0x124 */ + unsigned int hctl; /* 0x128 */ + unsigned int sysctl; /* 0x12C */ + unsigned int stat; /* 0x130 */ + unsigned int ie; /* 0x134 */ + unsigned char res4[0x8]; + unsigned int capa; /* 0x140 */ +} hsmmc_t;
/* * OMAP HS MMC Bit definitions @@ -159,8 +179,6 @@ typedef struct { } mmc_card_data;
#define mmc_reg_out(addr, mask, val)\ - (addr) = (((addr)) & (~(mask))) | ((val) & (mask)); -#define mmc_reg_out(addr, mask, val)\ - (addr) = (((addr)) & (~(mask))) | ((val) & (mask)); + writel((readl(addr) & (~(mask))) | ((val) & (mask)), (addr))
#endif /* MMC_HOST_DEF_H */ Index: u-boot-main/drivers/mmc/omap3_mmc.c =================================================================== --- u-boot-main.orig/drivers/mmc/omap3_mmc.c +++ u-boot-main/drivers/mmc/omap3_mmc.c @@ -28,6 +28,7 @@ #include <mmc.h> #include <part.h> #include <i2c.h> +#include <asm/io.h> #include <asm/arch/mmc.h>
const unsigned short mmc_transspeed_val[15][4] = { @@ -50,6 +51,7 @@ const unsigned short mmc_transspeed_val[
mmc_card_data cur_card_data; static block_dev_desc_t mmc_blk_dev; +static hsmmc_t *mmc_base = (hsmmc_t *)OMAP_HSMMC_BASE;
block_dev_desc_t *mmc_get_dev(int dev) { @@ -60,55 +62,49 @@ void twl4030_mmc_config(void) { unsigned char data;
- data = 0x20; - i2c_write(0x4B, 0x82, 1, &data, 1); - data = 0x2; - i2c_write(0x4B, 0x85, 1, &data, 1); + data = DEV_GRP_P1; + i2c_write(PWRMGT_ADDR_ID4, VMMC1_DEV_GRP, 1, &data, 1); + data = VMMC1_VSEL_30; + i2c_write(PWRMGT_ADDR_ID4, VMMC1_DEDICATED, 1, &data, 1); }
unsigned char mmc_board_init(void) { - unsigned int value = 0; + t2_t *t2_base = (t2_t *)T2_BASE;
twl4030_mmc_config();
- value = CONTROL_PBIAS_LITE; - CONTROL_PBIAS_LITE = value | (1 << 2) | (1 << 1) | (1 << 9); + writel(readl(&t2_base->pbias_lite) | PBIASLITEPWRDNZ1 | + PBIASSPEEDCTRL0 | PBIASLITEPWRDNZ0, + &t2_base->pbias_lite);
- value = CONTROL_DEV_CONF0; - CONTROL_DEV_CONF0 = value | (1 << 24); + writel(readl(&t2_base->devconf0) | MMCSDIO1ADPCLKISEL, + &t2_base->devconf0);
return 1; }
void mmc_init_stream(void) { - volatile unsigned int mmc_stat; + writel(readl(&mmc_base->con) | INIT_INITSTREAM, &mmc_base->con);
- OMAP_HSMMC_CON |= INIT_INITSTREAM; + writel(MMC_CMD0, &mmc_base->cmd); + while (!(readl(&mmc_base->stat) & CC_MASK));
- OMAP_HSMMC_CMD = MMC_CMD0; - do { - mmc_stat = OMAP_HSMMC_STAT; - } while (!(mmc_stat & CC_MASK)); - - OMAP_HSMMC_STAT = CC_MASK; + writel(CC_MASK, &mmc_base->stat);
- OMAP_HSMMC_CMD = MMC_CMD0; - do { - mmc_stat = OMAP_HSMMC_STAT; - } while (!(mmc_stat & CC_MASK)); + writel(MMC_CMD0, &mmc_base->cmd); + while (!(readl(&mmc_base->stat) & CC_MASK));
- OMAP_HSMMC_STAT = OMAP_HSMMC_STAT; - OMAP_HSMMC_CON &= ~INIT_INITSTREAM; + writel(readl(&mmc_base->con) & ~INIT_INITSTREAM, &mmc_base->con); }
unsigned char mmc_clock_config(unsigned int iclk, unsigned short clk_div) { unsigned int val;
- mmc_reg_out(OMAP_HSMMC_SYSCTL, (ICE_MASK | DTO_MASK | CEN_MASK), - (ICE_STOP | DTO_15THDTO | CEN_DISABLE)); + mmc_reg_out(&mmc_base->sysctl, (ICE_MASK | DTO_MASK | CEN_MASK), + (ICE_STOP | DTO_15THDTO | CEN_DISABLE));
switch (iclk) { case CLK_INITSEQ: @@ -123,12 +119,12 @@ unsigned char mmc_clock_config(unsigned default: return 0; } - mmc_reg_out(OMAP_HSMMC_SYSCTL, - ICE_MASK | CLKD_MASK, (val << CLKD_OFFSET) | ICE_OSCILLATE); + mmc_reg_out(&mmc_base->sysctl, ICE_MASK | CLKD_MASK, + (val << CLKD_OFFSET) | ICE_OSCILLATE);
- while ((OMAP_HSMMC_SYSCTL & ICS_MASK) == ICS_NOTREADY) ; + while ((readl(&mmc_base->sysctl) & ICS_MASK) == ICS_NOTREADY);
- OMAP_HSMMC_SYSCTL |= CEN_ENABLE; + writel(readl(&mmc_base->sysctl) | CEN_ENABLE, &mmc_base->sysctl); return 1; }
@@ -138,59 +134,63 @@ unsigned char mmc_init_setup(void)
mmc_board_init();
- OMAP_HSMMC_SYSCONFIG |= MMC_SOFTRESET; - while ((OMAP_HSMMC_SYSSTATUS & RESETDONE) == 0) ; - - OMAP_HSMMC_SYSCTL |= SOFTRESETALL; - while ((OMAP_HSMMC_SYSCTL & SOFTRESETALL) != 0x0) ; - - OMAP_HSMMC_HCTL = DTW_1_BITMODE | SDBP_PWROFF | SDVS_3V0; - OMAP_HSMMC_CAPA |= VS30_3V0SUP | VS18_1V8SUP; - - reg_val = OMAP_HSMMC_CON & RESERVED_MASK; - - OMAP_HSMMC_CON = CTPL_MMC_SD | reg_val | WPP_ACTIVEHIGH | - CDP_ACTIVEHIGH | MIT_CTO | DW8_1_4BITMODE | MODE_FUNC | - STR_BLOCK | HR_NOHOSTRESP | INIT_NOINIT | NOOPENDRAIN; + writel(readl(&mmc_base->sysconfig) | MMC_SOFTRESET, + &mmc_base->sysconfig); + while ((readl(&mmc_base->sysstatus) & RESETDONE) == 0); + + writel(readl(&mmc_base->sysctl) | SOFTRESETALL, &mmc_base->sysctl); + while ((readl(&mmc_base->sysctl) & SOFTRESETALL) != 0x0); + + writel(DTW_1_BITMODE | SDBP_PWROFF | SDVS_3V0, &mmc_base->hctl); + writel(readl(&mmc_base->capa) | VS30_3V0SUP | VS18_1V8SUP, + &mmc_base->capa); + + reg_val = readl(&mmc_base->con) & RESERVED_MASK; + + writel(CTPL_MMC_SD | reg_val | WPP_ACTIVEHIGH | CDP_ACTIVEHIGH | + MIT_CTO | DW8_1_4BITMODE | MODE_FUNC | STR_BLOCK | + HR_NOHOSTRESP | INIT_NOINIT | NOOPENDRAIN, &mmc_base->con);
mmc_clock_config(CLK_INITSEQ, 0); - OMAP_HSMMC_HCTL |= SDBP_PWRON; + writel(readl(&mmc_base->hctl) | SDBP_PWRON, &mmc_base->hctl);
- OMAP_HSMMC_IE = 0x307f0033; + writel(IE_BADA | IE_CERR | IE_DEB | IE_DCRC | IE_DTO | IE_CIE | + IE_CEB | IE_CCRC | IE_CTO | IE_BRR | IE_BWR | IE_TC | IE_CC, + &mmc_base->ie);
mmc_init_stream(); return 1; }
unsigned char mmc_send_cmd(unsigned int cmd, unsigned int arg, - unsigned int *response) + unsigned int *response) { - volatile unsigned int mmc_stat; + unsigned int mmc_stat;
- while ((OMAP_HSMMC_PSTATE & DATI_MASK) == DATI_CMDDIS) ; + while ((readl(&mmc_base->pstate) & DATI_MASK) == DATI_CMDDIS);
- OMAP_HSMMC_BLK = BLEN_512BYTESLEN | NBLK_STPCNT; - OMAP_HSMMC_STAT = 0xFFFFFFFF; - OMAP_HSMMC_ARG = arg; - OMAP_HSMMC_CMD = cmd | CMD_TYPE_NORMAL | CICE_NOCHECK | - CCCE_NOCHECK | MSBS_SGLEBLK | ACEN_DISABLE | BCE_DISABLE | - DE_DISABLE; + writel(BLEN_512BYTESLEN | NBLK_STPCNT, &mmc_base->blk); + writel(0xFFFFFFFF, &mmc_base->stat); + writel(arg, &mmc_base->arg); + writel(cmd | CMD_TYPE_NORMAL | CICE_NOCHECK | CCCE_NOCHECK | + MSBS_SGLEBLK | ACEN_DISABLE | BCE_DISABLE | DE_DISABLE, + &mmc_base->cmd);
while (1) { do { - mmc_stat = OMAP_HSMMC_STAT; + mmc_stat = readl(&mmc_base->stat); } while (mmc_stat == 0);
if ((mmc_stat & ERRI_MASK) != 0) return (unsigned char) mmc_stat;
if (mmc_stat & CC_MASK) { - OMAP_HSMMC_STAT = CC_MASK; - response[0] = OMAP_HSMMC_RSP10; + writel(CC_MASK, &mmc_base->stat); + response[0] = readl(&mmc_base->rsp10); if ((cmd & RSP_TYPE_MASK) == RSP_TYPE_LGHT136) { - response[1] = OMAP_HSMMC_RSP32; - response[2] = OMAP_HSMMC_RSP54; - response[3] = OMAP_HSMMC_RSP76; + response[1] = readl(&mmc_base->rsp32); + response[2] = readl(&mmc_base->rsp54); + response[3] = readl(&mmc_base->rsp76); } break; } @@ -200,7 +200,7 @@ unsigned char mmc_send_cmd(unsigned int
unsigned char mmc_read_data(unsigned int *output_buf) { - volatile unsigned int mmc_stat; + unsigned int mmc_stat; unsigned int read_count = 0;
/* @@ -208,7 +208,7 @@ unsigned char mmc_read_data(unsigned int */ while (1) { do { - mmc_stat = OMAP_HSMMC_STAT; + mmc_stat = readl(&mmc_base->stat); } while (mmc_stat == 0);
if ((mmc_stat & ERRI_MASK) != 0) @@ -217,19 +217,22 @@ unsigned char mmc_read_data(unsigned int if (mmc_stat & BRR_MASK) { unsigned int k;
- OMAP_HSMMC_STAT |= BRR_MASK; + writel(readl(&mmc_base->stat) | BRR_MASK, + &mmc_base->stat); for (k = 0; k < MMCSD_SECTOR_SIZE / 4; k++) { - *output_buf = OMAP_HSMMC_DATA; + *output_buf = readl(&mmc_base->data); output_buf++; read_count += 4; } }
if (mmc_stat & BWR_MASK) - OMAP_HSMMC_STAT |= BWR_MASK; + writel(readl(&mmc_base->stat) | BWR_MASK, + &mmc_base->stat);
if (mmc_stat & TC_MASK) { - OMAP_HSMMC_STAT |= TC_MASK; + writel(readl(&mmc_base->stat) | TC_MASK, + &mmc_base->stat); break; } } @@ -273,8 +276,8 @@ unsigned char mmc_detect_card(mmc_card_d mmc_card_cur->card_type = MMC_CARD; ocr_value |= MMC_OCR_REG_ACCESS_MODE_SECTOR; ret_cmd41 = MMC_CMD1; - OMAP_HSMMC_CON &= ~OD; - OMAP_HSMMC_CON |= OPENDRAIN; + writel(readl(&mmc_base->con) & ~OD, &mmc_base->con); + writel(readl(&mmc_base->con) | OPENDRAIN, &mmc_base->con); }
argument = ocr_value; @@ -342,8 +345,8 @@ unsigned char mmc_detect_card(mmc_card_d mmc_card_cur->RCA = ((mmc_resp_r6 *) resp)->newpublishedrca; }
- OMAP_HSMMC_CON &= ~OD; - OMAP_HSMMC_CON |= NOOPENDRAIN; + writel(readl(&mmc_base->con) & ~OD, &mmc_base->con); + writel(readl(&mmc_base->con) | NOOPENDRAIN, &mmc_base->con); return 1; }
@@ -518,7 +521,7 @@ unsigned long mmc_bread(int dev_num, uns void *dst) { omap_mmc_read_sect(blknr, (blkcnt * MMCSD_SECTOR_SIZE), &cur_card_data, - (unsigned long *) dst); + (unsigned long *) dst); return 1; }
Index: u-boot-main/include/asm-arm/arch-omap3/omap3.h =================================================================== --- u-boot-main.orig/include/asm-arm/arch-omap3/omap3.h +++ u-boot-main/include/asm-arm/arch-omap3/omap3.h @@ -206,6 +206,8 @@ typedef struct gpio { #define VAUX2_DEDICATED 0x79 #define VAUX3_DEV_GRP 0x7A #define VAUX3_DEDICATED 0x7D +#define VMMC1_DEV_GRP 0x82 +#define VMMC1_DEDICATED 0x85 #define VPLL2_DEV_GRP 0x8E #define VPLL2_DEDICATED 0x91 #define VDAC_DEV_GRP 0x96 @@ -227,5 +229,6 @@ typedef struct gpio { #define VAUX3_VSEL_28 0x03 #define VPLL2_VSEL_18 0x05 #define VDAC_VSEL_18 0x03 +#define VMMC1_VSEL_30 0x02
#endif
Dirk Behme
