[PATCH 1/2] Revert "riscv: Allow use of reset drivers"
This reverts commit 958a3f464c7f8ef7e10db9feb663e9e80445ce2f.
A more appropriate change below is already in mainline. Commit fd31e4fd184f ("riscv: Do not build reset.c if SYSRESET is on")
Revert this patch, so that U-Boot can be built successfully for SiFive Fu540 board.
Signed-off-by: Bin Meng bin.meng@windriver.com ---
arch/riscv/lib/reset.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/riscv/lib/reset.c b/arch/riscv/lib/reset.c index 6008bbe..8779c61 100644 --- a/arch/riscv/lib/reset.c +++ b/arch/riscv/lib/reset.c @@ -7,7 +7,6 @@ #include <command.h> #include <hang.h>
-#ifndef CONFIG_SYSRESET int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { printf("resetting ...\n"); @@ -17,4 +16,3 @@ int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
return 0; } -#endif
This reverts commit 23da3c682a84a2ad67a67287979dd4f5259ff607.
Now the build failure of sifive_fu540_defconfig board has been fixed, revert this "revert patch".
board/sifive/fu540/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/sifive/fu540/Kconfig b/board/sifive/fu540/Kconfig index 86193d7..6f65681 100644 --- a/board/sifive/fu540/Kconfig +++ b/board/sifive/fu540/Kconfig @@ -65,5 +65,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply SMP imply MISC imply SIFIVE_OTP + imply SYSRESET + imply SYSRESET_GPIO
endif
return 0; } -#endif
Reviewed-by: Sean Anderson seanga2@gmail.com
Hi Rick,
} -#endif
Could we get this series applied soon? thanks!
Regards, Bin
return 0; } -#endif
Reviewed-by: Leo Liang ycliang@andestech.com
Bin Meng
Leo Liang
Sean Anderson
