[U-Boot] [PATCH v2] mx51evk: support new relocation scheme
This patch is to fix build breakage and support new relocatoin scheme for mx51evk.
- Correct IRAM base address and add size definition
The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than 0x1FFE8000 which is for older revision.
- Include imx-regs.h in mx51evk.h
Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be referred to.
- Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE
This is something suggested by Wolfgang, and for automatic calculation of macros like CONFIG_SYS_GBL_DATA_SIZE (done) and CONFIG_SYS_INIT_SP_ADDR (later).
- Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been buried by Wolfgang's commit below
25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value
Signed-off-by: Shawn Guo shawn.gsc@gmail.com --- Changes for v2: - Combine two patches before into one, as the separation is not so logical. - Define init stack at the end of init RAM to address comments from Stefano, Heiko and Wolfgang.
arch/arm/include/asm/arch-mx5/imx-regs.h | 3 ++- board/freescale/mx51evk/mx51evk.c | 6 +++--- include/configs/mx51evk.h | 9 +++++++-- 3 files changed, 12 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 3ddda40..0b6249a 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -26,7 +26,8 @@ /* * IRAM */ -#define IRAM_BASE_ADDR 0x1FFE8000 /* internal ram */ +#define IRAM_BASE_ADDR 0x1FFE0000 /* internal ram */ +#define IRAM_SIZE 0x00020000 /* 128 KB */ /* * Graphics Memory of GPU */ diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index c8d7d39..8820698 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -52,9 +52,9 @@ u32 get_board_rev(void)
int dram_init(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = get_ram_size((long *)PHYS_SDRAM_1, - PHYS_SDRAM_1_SIZE); + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE); return 0; }
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index f31fc4e..6dc1ffc 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -24,11 +24,11 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <asm/arch/imx-regs.h>
/* High Level Configuration Options */
#define CONFIG_MX51 /* in a mx51 */ -#define CONFIG_SKIP_RELOCATE_UBOOT
#define CONFIG_SYS_MX5_HCLK 24000000 #define CONFIG_SYS_MX5_CLK32 32768 @@ -51,7 +51,6 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) -/* size in bytes reserved for initial data */
#define BOARD_LATE_INIT
@@ -174,6 +173,12 @@ #define PHYS_SDRAM_1 CSD0_BASE_ADDR #define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024)
+#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE) + #define CONFIG_SYS_DDR_CLKSEL 0 #define CONFIG_SYS_CLKTL_CBCDR 0x59E35100
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
2010/10/27 Shawn Guo shawn.gsc@gmail.com:
What's change is for the build breakage fix? Please state it clearly.
- /* dram_init must store complete ramsize in gd->ram_size */
- gd->ram_size = get_ram_size((volatile void *)CONFIG_SYS_SDRAM_BASE,
return 0; }
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE)
-- 1.7.1
The new relocation scheme requires the definition of CONFIG_SYS_INIT_SP_ADDR and CONFIG_SYS_SDRAM_BASE. It's the reason that build on master has been in failure for some time.
Okay, I noticed that Stefano has already sent out patch before to fix relocation and I have applied his patch on my local tree, so I don't find build break.
-- Regards, Shawn
Dear Shawn Guo,
Um... this is NOT what we discussed.
No. This is not what I want to se.
Memory allocation in the inital ram has the global data at the top.
Please use something like
#define CONFIG_SYS_INIT_SP_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
On Wed, Oct 27, 2010 at 7:46 PM, Wolfgang Denk wd@denx.de wrote:
Dear Shawn Guo,
Are you saying that automatic calculation of CONFIG_SYS_INIT_SP_ADDR will not happen?
If the automatic calculation of CONFIG_SYS_INIT_SP_ADDR will not happen, I can send another patch to fix it, since it's been applied by Stefano already.
Dear Shawn Guo,
Sorry for that. I was too fast and I have not read the patch with attention. I revert the patch after I see Wolfgang's comment. You can send V3 version of this patch and you can forget the "applied" message.
Stefano
Dear Shawn Guo,
In message AANLkTi=7r4mcSFxpSsdU3bUr_CNMyZey3MLUO2t0-MVm@mail.gmail.com you wrote:
Yes, it will.
But the stack pointer will not start at the end of the initial ram area, but below the global data area which lies at the end.
On Wed, Oct 27, 2010 at 8:23 PM, Wolfgang Denk wd@denx.de wrote:
Dear Shawn Guo,
Yes, it will.
I thought the manual definition of CONFIG_SYS_INIT_SP_ADDR is the near term solution, since it will be replaced by automatic calculation. So I did not put much attention to reflect the layout you want to see.
Anyway, v3 is coming soon.
Dear Shawn Guo,
In message AANLkTinAMZbqGKiTt=bBPhqxNWvsHcV2=CcKHZYctkOs@mail.gmail.com you wrote:
Well, we can only calculate this automatically if all boards us the same layout of the internal RAM area. That's why this is needed.
Dear Shawn Guo,
It ends up with the following compiling error.
start.S:175: Error: garbage following instruction -- `ldr sp,=(((0x1FFE0000)+((0x00020000)-#96)))'
Can we just go the current way for the near term, and wait for the auto calculation to clean it up?
Dear Shawn Guo,
In message AANLkTinOgVhJ8B2BuDQBUjjWKi+ADN98eTYfK2H+8bWJ@mail.gmail.com you wrote:
This has been fixed - see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/87669
This patch is to fix build breakage and support new relocation scheme for mx51evk.
They are used to define init RAM layout.
Signed-off-by: Shawn Guo shawn.gsc@gmail.com --- Changes for v3: - Correct init RAM layout to have global data at the top.
arch/arm/include/asm/arch-mx5/imx-regs.h | 3 ++- board/freescale/mx51evk/mx51evk.c | 6 +++--- include/configs/mx51evk.h | 12 ++++++++++-- 3 files changed, 15 insertions(+), 6 deletions(-)
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index f31fc4e..6282467 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -24,11 +24,11 @@ #ifndef __CONFIG_H #define __CONFIG_H
@@ -174,6 +173,15 @@ #define PHYS_SDRAM_1 CSD0_BASE_ADDR #define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024)
+#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + #define CONFIG_SYS_DDR_CLKSEL 0 #define CONFIG_SYS_CLKTL_CBCDR 0x59E35100
participants (5)
Jason Liu
Shawn Guo
Stefano Babic
