[U-Boot] [PATCH] Add README for the "Falcon" mode
Simple howto to add support to a board for booting the kernel from SPL ("Falcon" mode).
Signed-off-by: Stefano Babic sbabic@denx.de CC: Marek Vasut marex@denx.de CC: Otavio Salvador otavio@ossystems.com.br CC: Tom Rini trini@ti.com --- doc/README.falcon | 124 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 124 insertions(+) create mode 100644 doc/README.falcon
diff --git a/doc/README.falcon b/doc/README.falcon new file mode 100644 index 0000000..d50b8c3 --- /dev/null +++ b/doc/README.falcon @@ -0,0 +1,124 @@ +U-Boot "Falcon" Mode +==================== + +Introduction +------------ + +This documents provides an overview how to add support for "Falcon" mode +to a board. +Falcon mode is introduced to speed up the booting process, allowing +to boot a Linux kernel (or whatever image) without a full blown U-Boot. + +Falcon mode relies on the SPL framework. In fact, to make booting faster, +U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot +image. In mostly implementations, SPL is used to start U-Boot when booting from +a mass storage, such as NAND or SD-Card. SPL has now support for other media, +and can be generalized seen as a way to start an image performing the minimum +required initialization. SPL initializes mainly the RAM controller, and after +that copies U-Boot image into the memory. The "Falcon" mode extends this way +allowing to start any kind of image, an in particular a Linux kernel, preparing +a snapshot of the parameters (ATAG or DT) required by the kernel to boot. + +Falcon adds a command under U-Boot to reuse all code responsible to prepare +the interface with the kernel. In usual U-boot systems, these parameters are +generated each time before loading the kernel, passing to Linux the address +in memory where the parameters can be read. +With falcon, this snapshot can be saved into persistent storage and SPL is +informed to load it before running the kernel. + +To boot the kernel, these steps under a Falcon-aware U-Boot are required: + +1. Boot the board into U-Boot. +Use the "spl export" command to generate the kernel parameters area or the DT. +U-boot runs as when it boots the kernel, but stops before passing the control +to the kernel. + +2. Saves the prepared snapshot into persistent media. +The address where to save it must be configured into board configuration +file (CONFIG_CMD_SPL_NAND_OFS for NAND). + +3. Boot the board into "Falcon" mode. SPL will load the kernel and copy +the parameters area to the address required address. + +It is required to implement a custom mechanism to select if SPL loads U-Boot +or another image. +The value of a GPIO is a simple way to operate the selection, as well as +reading a character from the SPL console if CONFIG_SPL_CONSOLE is set. + +Falcon mode is generally activated by setting CONFIG_SPL_OS_BOOT. This tells +SPL that U-Boot is not the only available image that SPL is able to start. + +Configuration +---------------------------- +CONFIG_CMD_SPL Enable the "spl export" command. + The command "spl export" is then available in U-Boot + mode +CONFIG_SPL_OS_BOOT Activate Falcon mode. + A board should implement the following functions: + +CONFIG_SPL_OS_BOOT_KEY Common name for GPIO used to select between U-Boot + and kernel image. Optional. + +CONFIG_SYS_SPL_ARGS_ADDR Address in RAM where the parameters must be + copied by SPL. + In most cases, it is <start_of_ram> + 0x100 + +CONFIG_SYS_NAND_SPL_KERNEL_OFFS Offset in NAND where the kernel is stored + +CONFIG_CMD_SPL_NAND_OFS Offset in NAND where the parameters area was saved. + +CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied + +Function that a board must implement +------------------------------------ + +void spl_board_prepare_for_linux(void) : optional + Called from SPL before starting the kernel + +spl_start_uboot() : required + Returns "0" if SPL starts the kernel, "1" if U-Boot + must be started. + + +Using spl command +----------------- + +twister => spl +spl - SPL configuration + +Usage: +spl export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr if <img> = fdt] - export a kernel parameter image + initrd_img can be set to "-" if fdt_addr without initrd img isused + +img : "atags" or "fdt" +kernel_addr : kernel is loaded as part of the boot process, but it is not started. + This is the address where a kernel image is stored. +init_addr : optional for atags - the address where the parameters area is generated into RAM +fdt_addr : in case of fdt, the address of the device tree. + +Example (for the twister board): + +twister => spl export atags 0x82000000 +## Booting kernel from Legacy Image at 82000000 ... + Image Name: Linux-3.5.0-rc4-14089-gda0b7f4 + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 3654808 Bytes = 3.5 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK + Loading Kernel Image ... OK +OK +cmdline subcommand not supported +bdt subcommand not supported +Argument image is now in RAM at: 0x80000100 + +The parameters generated with this step can be saved into NAND at the offset +0x800000 (value for twister for CONFIG_CMD_SPL_NAND_OFS) + +Next time, the board can be started into "Falcon mode" moving the +CONFIG_SPL_OS_BOOT_KEY GPIO. +The kernel is loaded directly by the SPL without passing through U-Boot. + +Falcon mode was presented at the RMLL 2011. Slides are available at: + +http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf
Dear Stefano Babic,
-----------------^ In most implementations?
------------------------------------------^ and in particular? ------------------------------------------------------------------------^ to achieve that, to be able to boot linux, ... ? The 'preparing a snapshot...' part of this sentence sounds weird to me.
--------------------------------^ first address is not necessary here
mode
copied by SPL.
- Called from SPL before starting the kernel
must be started.
In which way interact the CONFIG_SPL_OS_BOOT_KEY with the spl_start_uboot()? Is both required, can one use one or the other?
-------------------------------------------------------------^ persistently? This is the place in mass storage, right?
how about the initrd_addr mentioned above?
- Image Name: Linux-3.5.0-rc4-14089-gda0b7f4
- Image Type: ARM Linux Kernel Image (uncompressed)
- Data Size: 3654808 Bytes = 3.5 MiB
- Load Address: 80008000
- Entry Point: 80008000
- Verifying Checksum ... OK
- Loading Kernel Image ... OK
Best regards
Andreas Bießmann
On 12/11/2012 12:35, Andreas Bießmann wrote:
Hi Andreas,
Thanks, I fix it.
I am a specialist to write weird sentences. I rewrite this part for V2, hoping to clarify what I like to explain.
Right
must be started.
Really checking the implementation, it should be better to remove CONFIG_SPL_OS_BOOT_KEY. There is not a weak function for spl_start_uboot(), and I think it is better so. But CONFIG_SPL_OS_BOOT_KEY is used only inside spl_start_uboot() in the board's implementation. IMHO it will be better to use a local define for the GPIOs inside board files, and drop CONFIG_SPL_OS_BOOT_KEY (in another patch, I mean).
No, but it could be (for NOR flash, for example). It is the address where a uImage can be found. It could be in RAM after loading it with tftp, or in a NOR flash.
In any case, the spl command does not call itself utilities to copy the kernel from mass storage - such as "nand read" or "fatload", for example.
What is not clear ? init_addr is the destination address, where spl puts its result. Is it not clear from the description ?
Best regards, Stefano Babic
Hi Stefano,
<snip>
must be started.
sounds good to me.
Ok, thats what I thought. But on first read of this README it was not clear to me which address I should write there. The step by step example should have some 'nand read' in it to clarify.
Well, the usage() for spl does not have a 'init_addr' but an 'initrd_addr'. Also your example line states:
---8<--- Usage: spl export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr if <img> = fdt] - export a kernel parameter image initrd_img can be set to "-" if fdt_addr without initrd img isused --->8---
So for me it is not clear where the 'init_addr' come from. BTW: I find your detailed description way better than current usage() of spl command. Would IMHO be useful to add it there in another patch. another BTW: is there a typo in usage() for spl cmd? One line states 'initrd_addr' but some later it says 'initrd_img'.
And last: the spl puts its result at a self gained position. The position is defined at compile time or when generating the uImage but not at command line for 'spl export' (see spl_export(): gd->bd->bi_boot_params vs. images.ft_addr).
Best regards
Andreas Bießmann
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes in v2: - spelling, language fixes (Andreas Biessman) - rewrite some unclear sentences - drop CONFIG_SPL_OS_BOOT_KEY - make example with twister more exhaustive
doc/README.falcon | 163 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 163 insertions(+) create mode 100644 doc/README.falcon
diff --git a/doc/README.falcon b/doc/README.falcon new file mode 100644 index 0000000..94126fd --- /dev/null +++ b/doc/README.falcon @@ -0,0 +1,163 @@ +U-Boot "Falcon" Mode +==================== + +Introduction +------------ + +This documents provides an overview how to add support for "Falcon" mode +to a board. +Falcon mode is introduced to speed up the booting process, allowing +to boot a Linux kernel (or whatever image) without a full blown U-Boot. + +Falcon mode relies on the SPL framework. In fact, to make booting faster, +U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot +image. In most implementations, SPL is used to start U-Boot when booting from +a mass storage, such as NAND or SD-Card. SPL has now support for other media, +and can be generalized seen as a way to start an image performing the minimum +required initialization. SPL initializes mainly the RAM controller, and after +that copies U-Boot image into the memory. The "Falcon" mode extends this way +allowing to start the Linux kernel directly from SPL. A new command is added +to U-Boot to prepare the parameters that SPL must pass to the kernel, using +ATAGS or Device Tree. + +Falcon adds a command under U-Boot to reuse all code responsible to prepare +the interface with the kernel. In usual U-boot systems, these parameters are +generated each time before loading the kernel, passing to Linux the address +in memory where the parameters can be read. +With falcon, this snapshot can be saved into persistent storage and SPL is +informed to load it before running the kernel. + +To boot the kernel, these steps under a Falcon-aware U-Boot are required: + +1. Boot the board into U-Boot. +Use the "spl export" command to generate the kernel parameters area or the DT. +U-boot runs as when it boots the kernel, but stops before passing the control +to the kernel. + +2. Saves the prepared snapshot into persistent media. +The address where to save it must be configured into board configuration +file (CONFIG_CMD_SPL_NAND_OFS for NAND). + +3. Boot the board into "Falcon" mode. SPL will load the kernel and copy +the parameters area to the required address. + +It is required to implement a custom mechanism to select if SPL loads U-Boot +or another image. +The value of a GPIO is a simple way to operate the selection, as well as +reading a character from the SPL console if CONFIG_SPL_CONSOLE is set. + +Falcon mode is generally activated by setting CONFIG_SPL_OS_BOOT. This tells +SPL that U-Boot is not the only available image that SPL is able to start. + +Configuration +---------------------------- +CONFIG_CMD_SPL Enable the "spl export" command. + The command "spl export" is then available in U-Boot + mode +CONFIG_SPL_OS_BOOT Activate Falcon mode. + A board should implement the following functions: + +CONFIG_SYS_SPL_ARGS_ADDR Address in RAM where the parameters must be + copied by SPL. + In most cases, it is <start_of_ram> + 0x100 + +CONFIG_SYS_NAND_SPL_KERNEL_OFFS Offset in NAND where the kernel is stored + +CONFIG_CMD_SPL_NAND_OFS Offset in NAND where the parameters area was saved. + +CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied + +Function that a board must implement +------------------------------------ + +void spl_board_prepare_for_linux(void) : optional + Called from SPL before starting the kernel + +spl_start_uboot() : required + Returns "0" if SPL starts the kernel, "1" if U-Boot + must be started. + + +Using spl command +----------------- + +spl - SPL configuration + +Usage: + +spl export <img=atags|fdt> [kernel_addr] [fdt_addr if <img> = fdt] - export a kernel parameter image + +img : "atags" or "fdt" +kernel_addr : kernel is loaded as part of the boot process, but it is not started. + This is the address where a kernel image is stored. +fdt_addr : in case of fdt, the address of the device tree. + + +The spl puts its result at a self gained position. The position is defined at compile +time or when generating the uImage but not at command line for 'spl export' +(see spl_export(): gd->bd->bi_boot_params vs. images.ft_addr). + +Example (for the twister board): +-------------------------------- + +Using mtd names and with the following (default) configuration +for mtdparts: + +device nand0 <omap2-nand.0>, # parts = 9 + #: name size offset mask_flags + 0: MLO 0x00080000 0x00000000 0 + 1: u-boot 0x00100000 0x00080000 0 + 2: env1 0x00040000 0x00180000 0 + 3: env2 0x00040000 0x001c0000 0 + 4: kernel 0x00600000 0x00200000 0 + 5: bootparms 0x00040000 0x00800000 0 + 6: splashimg 0x00200000 0x00840000 0 + 7: mini 0x02800000 0x00a40000 0 + 8: rootfs 0x1cdc0000 0x03240000 0 + + +twister => nand read 82000000 kernel + +NAND read: device 0 offset 0x200000, size 0x600000 + 6291456 bytes read: OK + +Now the kernel is in RAM at address 0x82000000 + +twister => spl export atags 0x82000000 +## Booting kernel from Legacy Image at 82000000 ... + Image Name: Linux-3.5.0-rc4-14089-gda0b7f4 + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 3654808 Bytes = 3.5 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK + Loading Kernel Image ... OK +OK +cmdline subcommand not supported +bdt subcommand not supported +Argument image is now in RAM at: 0x80000100 + +The result can be checked at address 0x80000100: + +twister => md 0x80000100 +80000100: 00000005 54410001 00000000 00000000 ......AT........ +80000110: 00000000 00000067 54410009 746f6f72 ....g.....ATroot +80000120: 65642f3d 666e2f76 77722073 73666e20 =/dev/nfs rw nfs + +The parameters generated with this step can be saved into NAND at the offset +0x800000 (value for twister for CONFIG_CMD_SPL_NAND_OFS) + +nand erase.part bootparms +nand write 0x80000100 bootparms 0x4000 + +Now the parameters are stored into the NAND flash at the address +CONFIG_CMD_SPL_NAND_OFS (=0x800000). + +Next time, the board can be started into "Falcon mode" moving the +setting the gpio (on twister gpio 55 is used) to kernel mode. + +The kernel is loaded directly by the SPL without passing through U-Boot. + +Falcon mode was presented at the RMLL 2011. Slides are available at: + +http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory.
board/technexion/twister/twister.c | 8 ++++---- board/technexion/twister/twister.h | 2 ++ board/timll/devkit8000/devkit8000.c | 8 ++++---- board/timll/devkit8000/devkit8000.h | 3 +++ include/configs/devkit8000.h | 1 - include/configs/twister.h | 1 - 6 files changed, 13 insertions(+), 10 deletions(-)
diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c index 1471559..bbc29b7 100644 --- a/board/technexion/twister/twister.c +++ b/board/technexion/twister/twister.c @@ -161,10 +161,10 @@ void spl_board_prepare_for_linux(void) int spl_start_uboot(void) { int val = 0; - if (!gpio_request(CONFIG_SPL_OS_BOOT_KEY, "U-Boot key")) { - gpio_direction_input(CONFIG_SPL_OS_BOOT_KEY); - val = gpio_get_value(CONFIG_SPL_OS_BOOT_KEY); - gpio_free(CONFIG_SPL_OS_BOOT_KEY); + if (!gpio_request(SPL_OS_BOOT_KEY, "U-Boot key")) { + gpio_direction_input(SPL_OS_BOOT_KEY); + val = gpio_get_value(SPL_OS_BOOT_KEY); + gpio_free(SPL_OS_BOOT_KEY); } return val; } diff --git a/board/technexion/twister/twister.h b/board/technexion/twister/twister.h index a2051c0..cff479c 100644 --- a/board/technexion/twister/twister.h +++ b/board/technexion/twister/twister.h @@ -38,6 +38,8 @@ const omap3_sysinfo sysinfo = { #define XR16L2751_UART1_BASE 0x21000000 #define XR16L2751_UART2_BASE 0x23000000
+/* GPIO used to select between U-Boot and kernel */ +#define SPL_OS_BOOT_KEY 55
/* * IEN - Input Enable diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 35f5e15..d8e7ebe 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -172,10 +172,10 @@ void spl_board_prepare_for_linux(void) int spl_start_uboot(void) { int val = 0; - if (!gpio_request(CONFIG_SPL_OS_BOOT_KEY, "U-Boot key")) { - gpio_direction_input(CONFIG_SPL_OS_BOOT_KEY); - val = gpio_get_value(CONFIG_SPL_OS_BOOT_KEY); - gpio_free(CONFIG_SPL_OS_BOOT_KEY); + if (!gpio_request(SPL_OS_BOOT_KEY, "U-Boot key")) { + gpio_direction_input(SPL_OS_BOOT_KEY); + val = gpio_get_value(SPL_OS_BOOT_KEY); + gpio_free(SPL_OS_BOOT_KEY); } return !val; } diff --git a/board/timll/devkit8000/devkit8000.h b/board/timll/devkit8000/devkit8000.h index aa69e6c..c1965e2 100644 --- a/board/timll/devkit8000/devkit8000.h +++ b/board/timll/devkit8000/devkit8000.h @@ -32,6 +32,9 @@ const omap3_sysinfo sysinfo = { "NAND", };
+/* GPIO used to select between U-Boot and kernel */ +#define SPL_OS_BOOT_KEY 26 + /* * IEN - Input Enable * IDIS - Input Disable diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index da3263f..54b5eeb 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -353,7 +353,6 @@
/* SPL OS boot options */ #define CONFIG_SPL_OS_BOOT -#define CONFIG_SPL_OS_BOOT_KEY 26
#define CONFIG_CMD_SPL #define CONFIG_CMD_SPL_WRITE_SIZE 0x400 /* 1024 byte */ diff --git a/include/configs/twister.h b/include/configs/twister.h index a852481..4205a11 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -58,7 +58,6 @@ #define CONFIG_CMD_SPL_NAND_OFS (CONFIG_SYS_NAND_SPL_KERNEL_OFFS+\ 0x600000) #define CONFIG_SPL_OS_BOOT -#define CONFIG_SPL_OS_BOOT_KEY 55
#define CONFIG_SYS_SPL_ARGS_ADDR (PHYS_SDRAM_1 + 0x100) #define CONFIG_SPL_BOARD_INIT
Tested on Devkit8000.
Tested-by: Thomas Weber thomas.weber@corscience.de Acked-by: Thomas Weber thomas.weber@corscience.de
Hello Stefano,
there are some inconsistency for the writing of the Falcon mode: "Falcon" mode, Falcon mode, Falcon, falcon, "Falcon mode"
Changes in v2:
This document provides ...
U-boot => U-Boot
Saves => Save
mode
copied by SPL.
must be started.
+Usage:
- #: name size offset mask_flags
- 0: MLO 0x00080000 0x00000000 0
- 1: u-boot 0x00100000 0x00080000 0
- 2: env1 0x00040000 0x00180000 0
- 3: env2 0x00040000 0x001c0000 0
- 4: kernel 0x00600000 0x00200000 0
- 5: bootparms 0x00040000 0x00800000 0
- 6: splashimg 0x00200000 0x00840000 0
- 7: mini 0x02800000 0x00a40000 0
- 8: rootfs 0x1cdc0000 0x03240000 0
- 6291456 bytes read: OK
I think it was in 2012.
Regards, Thomas
Dear Stefano Babic,
Changes in v2:
<snip>
mode
I think reordering this list to have the required functions directly after the colon would be helpful. Alternatively add a pointer to the list of functions after the list of defines.
copied by SPL.
must be started.
+Usage:
I think you got me wrong by my last remarks about the usage() of 'spl export'.
First of all there is presumably a typo in the descriptive text.
The current code has this usage(): ---8<--- "export <img=atags|fdt> [kernel_addr] [initrd_addr] " "[fdt_addr if <img> = fdt] - export a kernel parameter image\n" "\t initrd_img can be set to "-" if fdt_addr without initrd img is" "used") --->8--- The arguments say something about 'initrd_addr' but the descriptive text has 'initrd_img'. I think (but do not know since I have not used the spl command so often) that the 'initrd_img' should be written 'initrd_addr' (cc Simon Schwarz for that).
The second thing in my last review of your patch was maybe shortly described. You did write there the correct usage() of 'spl export' but later on add a more descriptive text about the parameters of 'spl export'. In these descriptive text you did write 'init_addr' instead of 'initrd_addr' - that was my comment about. Additionally I thought your descriptive text is way better than the current descriptive text of 'spl export', so I asked to add your description to the command.
Now the main reason for my writing here ;) Your usage() of 'spl export' some lines above is wrong cause it is missing the 'initrd_addr' parameter.
<snip example>
Best regards
Andreas Bießmann
Yes, it is what I wanted to do. In fact, the phrase now before the colon seems incomplete, because the functions are missing. I will this entry at the end of the define, so that the functions will follow after it.
+Usage:
Probably...
Ok, I cannot avoid to fix this typo the command with a separate patch. Else documentation and code remain inconsistent.
Ok, it seems I misunderstood. But I think your comment about where spl stores the result is helpful, even if the address is printed by the command itself.
Ok - I will put it into the spl help as well.
Correct - to be fixed ;-)
Changes in v2:
In the text you have the offset to save the image onto a NAND offset so I fail to see how it'd be used for SD-Card.
Can you elaborate it a bit?
You mix Falcon and falcon. I'd say you always use Falcon as it is the name of the feature so it ought to be in upper case. Another thing, 'With falcon, ' ought to be move to the previous line or have an empty line before it.
And for others?
An empty line before "The value"?
U-Boot
mode
copied by SPL.
And other media?
Is there others optional? Otherwise you could call it as:
Adding Falcon mode support for a board
must be started.
+Usage:
1.7.9.5
Regards,
On 14/11/2012 11:29, Otavio Salvador wrote:
Hi Otavio,
No, I can't without introducing errors. Current code supports Falcon only booting from NAND - I do not think that it is a big thing to use another media, but it is not yet done. This document must
You're right, there are already comments about this. This will be fixed globally in V3 (I will use Falcon Mode consistently).
Ok
And for others?
Not yet implemented, patches welcome ! But you are right, there is already a patch to use a NOR flash that should flow soon into mainline. I will check and add documentation for it. For the orher media, the document must be updated together when they will be full supported.
Ok
Hi Otavio,
So I'd say to drop the SD-Card from the document.
Ok
And for others?
copy
set.
Ok
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes in v3: - parameter initrd_addr was removed in V2 (Andreas Biessmann) - added patch to fix help usage for spl export (Andreas Biessmann) - Added empty lines (Otavio Salvador) - add a more exhaustive description explaining that spl export does not save into media (Lukasz Majewski).
doc/README.falcon | 173 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 173 insertions(+) create mode 100644 doc/README.falcon
diff --git a/doc/README.falcon b/doc/README.falcon new file mode 100644 index 0000000..87279e4 --- /dev/null +++ b/doc/README.falcon @@ -0,0 +1,173 @@ +U-Boot Falcon Mode +==================== + +Introduction +------------ + +This document provides an overview how to add support for Falcon Mode +to a board. +Falcon Mode is introduced to speed up the booting process, allowing +to boot a Linux kernel (or whatever image) without a full blown U-Boot. + +Falcon Mode relies on the SPL framework. In fact, to make booting faster, +U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot +image. In most implementations, SPL is used to start U-Boot when booting from +a mass storage, such as NAND or SD-Card. SPL has now support for other media, +and can be generalized seen as a way to start an image performing the minimum +required initialization. SPL initializes mainly the RAM controller, and after +that copies U-Boot image into the memory. The Falcon Mode extends this way +allowing to start the Linux kernel directly from SPL. A new command is added +to U-Boot to prepare the parameters that SPL must pass to the kernel, using +ATAGS or Device Tree. + +Falcon Mode adds a command under U-Boot to reuse all code responsible to prepare +the interface with the kernel. In usual U-Boot systems, these parameters are +generated each time before loading the kernel, passing to Linux the address +in memory where the parameters can be read. +With Falcon Mode, this snapshot can be saved into persistent storage and SPL is +informed to load it before running the kernel. + +To boot the kernel, these steps under a Falcon-aware U-Boot are required: + +1. Boot the board into U-Boot. +Use the "spl export" command to generate the kernel parameters area or the DT. +U-Boot runs as when it boots the kernel, but stops before passing the control +to the kernel. + +2. Save the prepared snapshot into persistent media. +The address where to save it must be configured into board configuration +file (CONFIG_CMD_SPL_NAND_OFS for NAND). + +3. Boot the board into Falcon Mode. SPL will load the kernel and copy +the parameters area to the required address. + +It is required to implement a custom mechanism to select if SPL loads U-Boot +or another image. + +The value of a GPIO is a simple way to operate the selection, as well as +reading a character from the SPL console if CONFIG_SPL_CONSOLE is set. + +Falcon Mode is generally activated by setting CONFIG_SPL_OS_BOOT. This tells +SPL that U-Boot is not the only available image that SPL is able to start. + +Configuration +---------------------------- +CONFIG_CMD_SPL Enable the "spl export" command. + The command "spl export" is then available in U-Boot + mode +CONFIG_SPL_OS_BOOT Activate Falcon Mode. + A board should implement the following functions: + +CONFIG_SYS_SPL_ARGS_ADDR Address in RAM where the parameters must be + copied by SPL. + In most cases, it is <start_of_ram> + 0x100 + +CONFIG_SYS_NAND_SPL_KERNEL_OFFS Offset in NAND where the kernel is stored + +CONFIG_CMD_SPL_NAND_OFS Offset in NAND where the parameters area was saved. + +CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied + +Function that a board must implement +------------------------------------ + +void spl_board_prepare_for_linux(void) : optional + Called from SPL before starting the kernel + +spl_start_uboot() : required + Returns "0" if SPL starts the kernel, "1" if U-Boot + must be started. + + +Using spl command +----------------- + +spl - SPL configuration + +Usage: + +spl export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ] + +img : "atags" or "fdt" +kernel_addr : kernel is loaded as part of the boot process, but it is not started. + This is the address where a kernel image is stored. +initrd_addr : Address of initial ramdisk + can be set to "-" if fdt_addr without initrd img is used +fdt_addr : in case of fdt, the address of the device tree. + +The spl puts its result at a self gained position. The position is defined at compile +time or when generating the uImage but not at command line for 'spl export' +(see spl_export(): gd->bd->bi_boot_params vs. images.ft_addr). + +spl export' does not write directly to a storage media. This command is intended to save +the prepared information in RAM. This information must then be transferred to a final destination +where the SPL will load it, that is defined at compile time +(CONFIG_CMD_SPL_NAND_OFS in case of NAND). + +The user is responsible to save the data into the required media, as described +on the following example. + +Usage on the twister board: +-------------------------------- + +Using mtd names with the following (default) configuration +for mtdparts: + +device nand0 <omap2-nand.0>, # parts = 9 + #: name size offset mask_flags + 0: MLO 0x00080000 0x00000000 0 + 1: u-boot 0x00100000 0x00080000 0 + 2: env1 0x00040000 0x00180000 0 + 3: env2 0x00040000 0x001c0000 0 + 4: kernel 0x00600000 0x00200000 0 + 5: bootparms 0x00040000 0x00800000 0 + 6: splashimg 0x00200000 0x00840000 0 + 7: mini 0x02800000 0x00a40000 0 + 8: rootfs 0x1cdc0000 0x03240000 0 + + +twister => nand read 82000000 kernel + +NAND read: device 0 offset 0x200000, size 0x600000 + 6291456 bytes read: OK + +Now the kernel is in RAM at address 0x82000000 + +twister => spl export atags 0x82000000 +## Booting kernel from Legacy Image at 82000000 ... + Image Name: Linux-3.5.0-rc4-14089-gda0b7f4 + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 3654808 Bytes = 3.5 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK + Loading Kernel Image ... OK +OK +cmdline subcommand not supported +bdt subcommand not supported +Argument image is now in RAM at: 0x80000100 + +The result can be checked at address 0x80000100: + +twister => md 0x80000100 +80000100: 00000005 54410001 00000000 00000000 ......AT........ +80000110: 00000000 00000067 54410009 746f6f72 ....g.....ATroot +80000120: 65642f3d 666e2f76 77722073 73666e20 =/dev/nfs rw nfs + +The parameters generated with this step can be saved into NAND at the offset +0x800000 (value for twister for CONFIG_CMD_SPL_NAND_OFS) + +nand erase.part bootparms +nand write 0x80000100 bootparms 0x4000 + +Now the parameters are stored into the NAND flash at the address +CONFIG_CMD_SPL_NAND_OFS (=0x800000). + +Next time, the board can be started into Falcon Mode moving the +setting the gpio (on twister gpio 55 is used) to kernel mode. + +The kernel is loaded directly by the SPL without passing through U-Boot. + +Falcon Mode was presented at the RMLL 2012. Slides are available at: + +http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf
Add a more descriptive text to the help of the spl command.
common/cmd_spl.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/common/cmd_spl.c b/common/cmd_spl.c index 9ec054a..b21d41d 100644 --- a/common/cmd_spl.c +++ b/common/cmd_spl.c @@ -182,7 +182,11 @@ static int do_spl(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
U_BOOT_CMD( spl, 6 , 1, do_spl, "SPL configuration", - "export <img=atags|fdt> [kernel_addr] [initrd_addr] " - "[fdt_addr if <img> = fdt] - export a kernel parameter image\n" - "\t initrd_img can be set to "-" if fdt_addr without initrd img is" - "used"); + "export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ]\n" + "\timg\t\t"atags" or "fdt"\n" + "\tkernel_addr\taddress where a kernel image is stored.\n" + "\t\t\tkernel is loaded as part of the boot process, but it is not started.\n" + "\tinitrd_addr\tAddress of initial ramdisk\n" + "\t\t\tcan be set to "-" if fdt_addr without initrd img is used\n" + "\tfdt_addr\tin case of fdt, the address of the device tree.\n" + );
Dear Stefano Babic,
- "used");
- "export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ]\n"
---------------------------------------------------------------------^ unnecessary blank
- "\timg\t\t"atags" or "fdt"\n"
- "\tkernel_addr\taddress where a kernel image is stored.\n"
- "\t\t\tkernel is loaded as part of the boot process, but it is not started.\n"
- "\tinitrd_addr\tAddress of initial ramdisk\n"
------------------------^ Capitalization should be uniform. Either change all other places to capital beginning or start here with small letters.
- "\t\t\tcan be set to "-" if fdt_addr without initrd img is used\n"
--------------------------------------------------------------^ I think we should write here either 'initrd image'/'initial ramdisk image' or 'initrd_addr'. I know img is a well known abbreviation for image, but in a descriptive text we should IMHO not abbreviate. Additionally the sentence should stop with a full stop like the others do.
- "\tfdt_addr\tin case of fdt, the address of the device tree.\n"
Best regards
Andreas Bießmann
From the above text it seems the Falcon Mode is already available in
SD-Card however this is not truth. Please rework this so it is clear what is already working and what needs to be done.
On 19/11/2012 11:14, Otavio Salvador wrote:
On Mon, Nov 19, 2012 at 7:11 AM, Stefano Babic <sbabic@denx.de mailto:sbabic@denx.de> wrote:
... +Falcon Mode relies on the SPL framework. In fact, to make booting faster, +U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot +image. In most implementations, SPL is used to start U-Boot when booting from +a mass storage, such as NAND or SD-Card. SPL has now support for other media, +and can be generalized seen as a way to start an image performing the minimum +required initialization. SPL initializes mainly the RAM controller, and after +that copies U-Boot image into the memory. The Falcon Mode extends this way +allowing to start the Linux kernel directly from SPL. A new command is added +to U-Boot to prepare the parameters that SPL must pass to the kernel, using +ATAGS or Device Tree.
From the above text it seems the Falcon Mode is already available in SD-Card however this is not truth. Please rework this so it is clear what is already working and what needs to be done.
I reread the sentence, and I am really describing what SPL alone does, not Falcon mode. SPL is already available for different storage and there are some boards booting from SD. Check for CONFIG_SPL_MMC_SUPPORT in include/configs, there are plenty of boards using it.
On the other side, Falcon Mode (SPL + CONFIG_SPL_OS_BOOT) is set only for two boards, twister and devkit8000, bpth booting from NAND.
Dear Stefano Babic,
despite a small change
Acked-by: Andreas Bießmann andreas.devel@googlemail.com
Changes in v3:
Changes in v2:
<snip>
mode
copied by SPL.
must be started.
shouldn't we reorder that thing here (move CONFIG_SPL_OS_BOOT down to the functions)?
Best regards
Andreas Bießmann
On 19/11/2012 11:21, Andreas Bießmann wrote:
Dear Stefano Babic,
Changes in v3:
Changes in v2:
<snip>
mode
copied by SPL.
must be started.
arghh..right, I missed this change - I will do in V4.
Signed-off-by: Stefano Babic sbabic@denx.de --- Changes in v4: - fix capitalization, styling, in spl help (Andreas Biessmann) - move CONFIG_SPL_OS_BOOT before function in doc (Andreas Biessmann)
diff --git a/doc/README.falcon b/doc/README.falcon new file mode 100644 index 0000000..1c041ea --- /dev/null +++ b/doc/README.falcon @@ -0,0 +1,173 @@ +U-Boot Falcon Mode +==================== + +Introduction +------------ + +This document provides an overview how to add support for Falcon Mode +to a board. +Falcon Mode is introduced to speed up the booting process, allowing +to boot a Linux kernel (or whatever image) without a full blown U-Boot. + +Falcon Mode relies on the SPL framework. In fact, to make booting faster, +U-Boot is split into two parts: the SPL (Secondary Program Loader) and U-Boot +image. In most implementations, SPL is used to start U-Boot when booting from +a mass storage, such as NAND or SD-Card. SPL has now support for other media, +and can be generalized seen as a way to start an image performing the minimum +required initialization. SPL initializes mainly the RAM controller, and after +that copies U-Boot image into the memory. The Falcon Mode extends this way +allowing to start the Linux kernel directly from SPL. A new command is added +to U-Boot to prepare the parameters that SPL must pass to the kernel, using +ATAGS or Device Tree. + +Falcon Mode adds a command under U-Boot to reuse all code responsible to prepare +the interface with the kernel. In usual U-Boot systems, these parameters are +generated each time before loading the kernel, passing to Linux the address +in memory where the parameters can be read. +With Falcon Mode, this snapshot can be saved into persistent storage and SPL is +informed to load it before running the kernel. + +To boot the kernel, these steps under a Falcon-aware U-Boot are required: + +1. Boot the board into U-Boot. +Use the "spl export" command to generate the kernel parameters area or the DT. +U-Boot runs as when it boots the kernel, but stops before passing the control +to the kernel. + +2. Save the prepared snapshot into persistent media. +The address where to save it must be configured into board configuration +file (CONFIG_CMD_SPL_NAND_OFS for NAND). + +3. Boot the board into Falcon Mode. SPL will load the kernel and copy +the parameters area to the required address. + +It is required to implement a custom mechanism to select if SPL loads U-Boot +or another image. + +The value of a GPIO is a simple way to operate the selection, as well as +reading a character from the SPL console if CONFIG_SPL_CONSOLE is set. + +Falcon Mode is generally activated by setting CONFIG_SPL_OS_BOOT. This tells +SPL that U-Boot is not the only available image that SPL is able to start. + +Configuration +---------------------------- +CONFIG_CMD_SPL Enable the "spl export" command. + The command "spl export" is then available in U-Boot + mode +CONFIG_SYS_SPL_ARGS_ADDR Address in RAM where the parameters must be + copied by SPL. + In most cases, it is <start_of_ram> + 0x100 + +CONFIG_SYS_NAND_SPL_KERNEL_OFFS Offset in NAND where the kernel is stored + +CONFIG_CMD_SPL_NAND_OFS Offset in NAND where the parameters area was saved. + +CONFIG_CMD_SPL_WRITE_SIZE Size of the parameters area to be copied + +CONFIG_SPL_OS_BOOT Activate Falcon Mode. + A board should implement the following functions: + +Function that a board must implement +------------------------------------ + +void spl_board_prepare_for_linux(void) : optional + Called from SPL before starting the kernel + +spl_start_uboot() : required + Returns "0" if SPL starts the kernel, "1" if U-Boot + must be started. + + +Using spl command +----------------- + +spl - SPL configuration + +Usage: + +spl export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ] + +img : "atags" or "fdt" +kernel_addr : kernel is loaded as part of the boot process, but it is not started. + This is the address where a kernel image is stored. +initrd_addr : Address of initial ramdisk + can be set to "-" if fdt_addr without initrd img is used +fdt_addr : in case of fdt, the address of the device tree. + +The spl puts its result at a self gained position. The position is defined at compile +time or when generating the uImage but not at command line for 'spl export' +(see spl_export(): gd->bd->bi_boot_params vs. images.ft_addr). + +spl export' does not write directly to a storage media. This command is intended to save +the prepared information in RAM. This information must then be transferred to a final destination +where the SPL will load it, that is defined at compile time +(CONFIG_CMD_SPL_NAND_OFS in case of NAND). + +The user is responsible to save the data into the required media, as described +on the following example. + +Usage on the twister board: +-------------------------------- + +Using mtd names with the following (default) configuration +for mtdparts: + +device nand0 <omap2-nand.0>, # parts = 9 + #: name size offset mask_flags + 0: MLO 0x00080000 0x00000000 0 + 1: u-boot 0x00100000 0x00080000 0 + 2: env1 0x00040000 0x00180000 0 + 3: env2 0x00040000 0x001c0000 0 + 4: kernel 0x00600000 0x00200000 0 + 5: bootparms 0x00040000 0x00800000 0 + 6: splashimg 0x00200000 0x00840000 0 + 7: mini 0x02800000 0x00a40000 0 + 8: rootfs 0x1cdc0000 0x03240000 0 + + +twister => nand read 82000000 kernel + +NAND read: device 0 offset 0x200000, size 0x600000 + 6291456 bytes read: OK + +Now the kernel is in RAM at address 0x82000000 + +twister => spl export atags 0x82000000 +## Booting kernel from Legacy Image at 82000000 ... + Image Name: Linux-3.5.0-rc4-14089-gda0b7f4 + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 3654808 Bytes = 3.5 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK + Loading Kernel Image ... OK +OK +cmdline subcommand not supported +bdt subcommand not supported +Argument image is now in RAM at: 0x80000100 + +The result can be checked at address 0x80000100: + +twister => md 0x80000100 +80000100: 00000005 54410001 00000000 00000000 ......AT........ +80000110: 00000000 00000067 54410009 746f6f72 ....g.....ATroot +80000120: 65642f3d 666e2f76 77722073 73666e20 =/dev/nfs rw nfs + +The parameters generated with this step can be saved into NAND at the offset +0x800000 (value for twister for CONFIG_CMD_SPL_NAND_OFS) + +nand erase.part bootparms +nand write 0x80000100 bootparms 0x4000 + +Now the parameters are stored into the NAND flash at the address +CONFIG_CMD_SPL_NAND_OFS (=0x800000). + +Next time, the board can be started into Falcon Mode moving the +setting the gpio (on twister gpio 55 is used) to kernel mode. + +The kernel is loaded directly by the SPL without passing through U-Boot. + +Falcon Mode was presented at the RMLL 2012. Slides are available at: + +http://schedule2012.rmll.info/IMG/pdf/LSM2012_UbootFalconMode_Babic.pdf
diff --git a/common/cmd_spl.c b/common/cmd_spl.c index 9ec054a..b3d9834 100644 --- a/common/cmd_spl.c +++ b/common/cmd_spl.c @@ -182,7 +182,11 @@ static int do_spl(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
U_BOOT_CMD( spl, 6 , 1, do_spl, "SPL configuration", - "export <img=atags|fdt> [kernel_addr] [initrd_addr] " - "[fdt_addr if <img> = fdt] - export a kernel parameter image\n" - "\t initrd_img can be set to "-" if fdt_addr without initrd img is" - "used"); + "export <img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr]\n" + "\timg\t\t"atags" or "fdt"\n" + "\tkernel_addr\taddress where a kernel image is stored.\n" + "\t\t\tkernel is loaded as part of the boot process, but it is not started.\n" + "\tinitrd_addr\taddress of initial ramdisk\n" + "\t\t\tcan be set to "-" if fdt_addr without initrd_addr is used.\n" + "\tfdt_addr\tin case of fdt, the address of the device tree.\n" + );
Hi Stefano,
Sorry for bumping in at v4. Below are some of my comments.
Signed-off-by: Stefano Babicsbabic@denx.de
Changes in v4:
<snip>
s/an overview/an overview of/
Rephrase the above line as, and can generally be seen ....
Rephrase ..
SPL mainly initializes the RAM controller, and then copies U-boot image to the main memory.
Already it is mentioned that 'a new command is added'. The above line is redundant then. Please rephrase it.
copy the parameters which is saved in the persistent media to the ....
mode
copied by SPL.
In most cases, it is<start_of_ram> + 0x100
A space in between is and '<'
Can the above be renamed to include the word 'PARAMS'? But becomes lengthy. Any suggestions?
Is there a big difference between the line above and the one below?
must be started.
+Usage:
+spl export<img=atags|fdt> [kernel_addr] [initrd_addr] [fdt_addr ]
^ [1] Final destination? How is it getting transferred? Shall lines/content [1] and [2] merged?
^ [2]
+device nand0<omap2-nand.0>, # parts = 9
If the offset is known at compile time, why should the end user use the above commands to write it? Can't it be automated? Just an idea.
Regards, Vikram
Dear Vikram Narayanan,
On 23.11.12 19:10, Vikram Narayanan wrote:
<snip>
No, please read http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/102326 or http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/147205
Best regards
Andreas Bießmann
Hello Andreas,
<snip>
Thanks. Clarified.
Regards, Vikram
On 23/11/2012 19:10, Vikram Narayanan wrote:
Hi Stefano,
No problems, all reviews are welcome ! I fix your comments in V5.
No, it's not - Andreas have already given links to previous threads where this issue was discussed.
Could this be updated and resend? This is an interesting feature which lacks documentation currently.
Regards,
Hi Otavio,
you are right, and thanks to point out that the documentation is not yet merged. I will push a V5 as I promised with fixes for the last comments.
Regards, Stefano
participants (6)
Andreas Bießmann
Otavio Salvador
Stefano Babic
Thomas Weber
Thomas Weber
Vikram Narayanan
