[U-Boot] [PATCH] ARM: uniphier: fix various sparse warnings
Fix warnings reported by sparse: - ... was not declared. Should it be static?" - cast to restricted __be32
While fixing those, the type conflict of cci500_init() was found.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/arm64/arm-cci500.c | 2 ++ arch/arm/mach-uniphier/arm64/smp_kick_cpus.c | 2 ++ arch/arm/mach-uniphier/board_init.c | 2 +- arch/arm/mach-uniphier/clk/pll-pxs3.c | 2 ++ arch/arm/mach-uniphier/dram/umc-ld11.c | 14 +++++++------- arch/arm/mach-uniphier/dram/umc-pxs2.c | 2 +- arch/arm/mach-uniphier/dram_init.c | 1 + arch/arm/mach-uniphier/init.h | 3 ++- drivers/clk/uniphier/clk-uniphier-core.c | 2 +- drivers/reset/reset-uniphier.c | 18 +++++++++--------- 10 files changed, 28 insertions(+), 20 deletions(-)
diff --git a/arch/arm/mach-uniphier/arm64/arm-cci500.c b/arch/arm/mach-uniphier/arm64/arm-cci500.c index f18595dc1311..bf0fad459bbd 100644 --- a/arch/arm/mach-uniphier/arm64/arm-cci500.c +++ b/arch/arm/mach-uniphier/arm64/arm-cci500.c @@ -11,6 +11,8 @@ #include <linux/io.h> #include <linux/sizes.h>
+#include "../init.h" + #define CCI500_BASE 0x5FD00000 #define CCI500_SLAVE_OFFSET 0x1000
diff --git a/arch/arm/mach-uniphier/arm64/smp_kick_cpus.c b/arch/arm/mach-uniphier/arm64/smp_kick_cpus.c index 4f08963118a3..8e5b198c96ce 100644 --- a/arch/arm/mach-uniphier/arm64/smp_kick_cpus.c +++ b/arch/arm/mach-uniphier/arm64/smp_kick_cpus.c @@ -8,6 +8,8 @@ #include <linux/io.h> #include <linux/sizes.h>
+#include "../init.h" + #define UNIPHIER_SMPCTRL_ROM_RSV0 0x59801200
void uniphier_smp_setup(void); diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index e05d6bffd5ce..ca910f6d7254 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -21,7 +21,7 @@ static void uniphier_setup_xirq(void) { const void *fdt = gd->fdt_blob; int soc_node, aidet_node; - const u32 *val; + const fdt32_t *val; unsigned long aidet_base; u32 tmp;
diff --git a/arch/arm/mach-uniphier/clk/pll-pxs3.c b/arch/arm/mach-uniphier/clk/pll-pxs3.c index e29d9d000142..201d3517a86a 100644 --- a/arch/arm/mach-uniphier/clk/pll-pxs3.c +++ b/arch/arm/mach-uniphier/clk/pll-pxs3.c @@ -2,6 +2,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include "../init.h" + void uniphier_pxs3_pll_init(void) { } diff --git a/arch/arm/mach-uniphier/dram/umc-ld11.c b/arch/arm/mach-uniphier/dram/umc-ld11.c index 69aa4f2eebe3..9e2021a627e5 100644 --- a/arch/arm/mach-uniphier/dram/umc-ld11.c +++ b/arch/arm/mach-uniphier/dram/umc-ld11.c @@ -28,11 +28,11 @@ enum dram_size { };
/* PHY */ -const int rof_pos_shift_pre[RANK_BLOCKS_TR][2] = { {0, 0}, {0, 0} }; -const int rof_neg_shift_pre[RANK_BLOCKS_TR][2] = { {0, 0}, {0, 0} }; -const int rof_pos_shift[RANK_BLOCKS_TR][2] = { {-35, -35}, {-35, -35} }; -const int rof_neg_shift[RANK_BLOCKS_TR][2] = { {-17, -17}, {-17, -17} }; -const int tof_shift[RANK_BLOCKS_TR][2] = { {-50, -50}, {-50, -50} }; +static const int rof_pos_shift_pre[RANK_BLOCKS_TR][2] = { {0, 0}, {0, 0} }; +static const int rof_neg_shift_pre[RANK_BLOCKS_TR][2] = { {0, 0}, {0, 0} }; +static const int rof_pos_shift[RANK_BLOCKS_TR][2] = { {-35, -35}, {-35, -35} }; +static const int rof_neg_shift[RANK_BLOCKS_TR][2] = { {-17, -17}, {-17, -17} }; +static const int tof_shift[RANK_BLOCKS_TR][2] = { {-50, -50}, {-50, -50} };
/* Register address */ #define PHY_ZQ0CR1 0x00000184 @@ -65,7 +65,7 @@ const int tof_shift[RANK_BLOCKS_TR][2] = { {-50, -50}, {-50, -50} }; #define PHY_DSWBD_MASK 0x3F000000 /* bit[29:24] */ #define PHY_DSDQOE_MASK 0x00000FFF
-static void ddrphy_maskwritel(u32 data, u32 mask, void *addr) +static void ddrphy_maskwritel(u32 data, u32 mask, void __iomem *addr) { u32 value;
@@ -73,7 +73,7 @@ static void ddrphy_maskwritel(u32 data, u32 mask, void *addr) writel(value, addr); }
-static u32 ddrphy_maskreadl(u32 mask, void *addr) +static u32 ddrphy_maskreadl(u32 mask, void __iomem *addr) { return readl(addr) & mask; } diff --git a/arch/arm/mach-uniphier/dram/umc-pxs2.c b/arch/arm/mach-uniphier/dram/umc-pxs2.c index 7fa29f119d08..8068ef13882e 100644 --- a/arch/arm/mach-uniphier/dram/umc-pxs2.c +++ b/arch/arm/mach-uniphier/dram/umc-pxs2.c @@ -436,7 +436,7 @@ static void umc_set_system_latency(void __iomem *dc_base, int phy_latency) }
/* enable/disable auto refresh */ -void umc_refresh_ctrl(void __iomem *dc_base, int enable) +static void umc_refresh_ctrl(void __iomem *dc_base, int enable) { u32 tmp;
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index f79b7cf3ca67..6eb8d2650424 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -7,6 +7,7 @@ */
#include <common.h> +#include <fdt_support.h> #include <fdtdec.h> #include <linux/errno.h> #include <linux/sizes.h> diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index d413d00f951b..154918b18966 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -87,6 +87,7 @@ int uniphier_pro5_dpll_init(const struct uniphier_board_data *bd); int uniphier_pxs2_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld11_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld20_dpll_init(const struct uniphier_board_data *bd); +int uniphier_pxs3_dpll_init(const struct uniphier_board_data *bd);
void uniphier_sld3_early_clk_init(void); void uniphier_ld11_early_clk_init(void); @@ -126,7 +127,7 @@ int uniphier_have_internal_stm(void); int uniphier_boot_from_backend(void); int uniphier_pin_init(const char *pinconfig_name); void uniphier_smp_kick_all_cpus(void); -void cci500_init(int nr_slaves); +void cci500_init(unsigned int nr_slaves);
#undef pr_warn #define pr_warn(fmt, args...) printf(fmt, ##args) diff --git a/drivers/clk/uniphier/clk-uniphier-core.c b/drivers/clk/uniphier/clk-uniphier-core.c index d88bd62812d3..0fb48541b9b7 100644 --- a/drivers/clk/uniphier/clk-uniphier-core.c +++ b/drivers/clk/uniphier/clk-uniphier-core.c @@ -121,7 +121,7 @@ static ulong uniphier_clk_set_rate(struct clk *clk, ulong rate) return best_rate; }
-const struct clk_ops uniphier_clk_ops = { +static const struct clk_ops uniphier_clk_ops = { .enable = uniphier_clk_enable, .get_rate = uniphier_clk_get_rate, .set_rate = uniphier_clk_set_rate, diff --git a/drivers/reset/reset-uniphier.c b/drivers/reset/reset-uniphier.c index e98df43bdb81..17e971a427f9 100644 --- a/drivers/reset/reset-uniphier.c +++ b/drivers/reset/reset-uniphier.c @@ -56,12 +56,12 @@ struct uniphier_reset_data { #define UNIPHIER_PRO4_SYS_RESET_USB3(id, ch) \ UNIPHIER_RESETX((id), 0x2000 + 0x4 * (ch), 17)
-const struct uniphier_reset_data uniphier_sld3_sys_reset_data[] = { +static const struct uniphier_reset_data uniphier_sld3_sys_reset_data[] = { UNIPHIER_SLD3_SYS_RESET_STDMAC(8), /* Ether, HSC, MIO */ UNIPHIER_RESET_END, };
-const struct uniphier_reset_data uniphier_pro4_sys_reset_data[] = { +static const struct uniphier_reset_data uniphier_pro4_sys_reset_data[] = { UNIPHIER_SLD3_SYS_RESET_STDMAC(8), /* HSC, MIO, RLE */ UNIPHIER_PRO4_SYS_RESET_GIO(12), /* Ether, SATA, USB3 */ UNIPHIER_PRO4_SYS_RESET_USB3(14, 0), @@ -69,7 +69,7 @@ const struct uniphier_reset_data uniphier_pro4_sys_reset_data[] = { UNIPHIER_RESET_END, };
-const struct uniphier_reset_data uniphier_pro5_sys_reset_data[] = { +static const struct uniphier_reset_data uniphier_pro5_sys_reset_data[] = { UNIPHIER_SLD3_SYS_RESET_STDMAC(8), /* HSC */ UNIPHIER_PRO4_SYS_RESET_GIO(12), /* PCIe, USB3 */ UNIPHIER_PRO4_SYS_RESET_USB3(14, 0), @@ -77,7 +77,7 @@ const struct uniphier_reset_data uniphier_pro5_sys_reset_data[] = { UNIPHIER_RESET_END, };
-const struct uniphier_reset_data uniphier_pxs2_sys_reset_data[] = { +static const struct uniphier_reset_data uniphier_pxs2_sys_reset_data[] = { UNIPHIER_SLD3_SYS_RESET_STDMAC(8), /* HSC, RLE */ UNIPHIER_PRO4_SYS_RESET_USB3(14, 0), UNIPHIER_PRO4_SYS_RESET_USB3(15, 1), @@ -91,12 +91,12 @@ const struct uniphier_reset_data uniphier_pxs2_sys_reset_data[] = { UNIPHIER_RESET_END, };
-const struct uniphier_reset_data uniphier_ld11_sys_reset_data[] = { +static const struct uniphier_reset_data uniphier_ld11_sys_reset_data[] = { UNIPHIER_LD11_SYS_RESET_STDMAC(8), /* HSC, MIO */ UNIPHIER_RESET_END, };
-const struct uniphier_reset_data uniphier_ld20_sys_reset_data[] = { +static const struct uniphier_reset_data uniphier_ld20_sys_reset_data[] = { UNIPHIER_LD11_SYS_RESET_STDMAC(8), /* HSC */ UNIPHIER_LD20_SYS_RESET_GIO(12), /* PCIe, USB3 */ UNIPHIER_RESETX(16, 0x200c, 12), /* USB30-PHY0 */ @@ -125,7 +125,7 @@ const struct uniphier_reset_data uniphier_ld20_sys_reset_data[] = { #define UNIPHIER_MIO_RESET_DMAC(id) \ UNIPHIER_RESETX((id), 0x110, 17)
-const struct uniphier_reset_data uniphier_mio_reset_data[] = { +static const struct uniphier_reset_data uniphier_mio_reset_data[] = { UNIPHIER_MIO_RESET_SD(0, 0), UNIPHIER_MIO_RESET_SD(1, 1), UNIPHIER_MIO_RESET_SD(2, 2), @@ -155,7 +155,7 @@ const struct uniphier_reset_data uniphier_mio_reset_data[] = { #define UNIPHIER_PERI_RESET_FI2C(id, ch) \ UNIPHIER_RESETX((id), 0x114, 24 + (ch))
-const struct uniphier_reset_data uniphier_ld4_peri_reset_data[] = { +static const struct uniphier_reset_data uniphier_ld4_peri_reset_data[] = { UNIPHIER_PERI_RESET_UART(0, 0), UNIPHIER_PERI_RESET_UART(1, 1), UNIPHIER_PERI_RESET_UART(2, 2), @@ -168,7 +168,7 @@ const struct uniphier_reset_data uniphier_ld4_peri_reset_data[] = { UNIPHIER_RESET_END, };
-const struct uniphier_reset_data uniphier_pro4_peri_reset_data[] = { +static const struct uniphier_reset_data uniphier_pro4_peri_reset_data[] = { UNIPHIER_PERI_RESET_UART(0, 0), UNIPHIER_PERI_RESET_UART(1, 1), UNIPHIER_PERI_RESET_UART(2, 2),
2017-06-22 16:42 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier.
Masahiro Yamada
