[U-Boot] Device tree & PCI/ECAM questions
Hi all,
I am working on several drivers for our Octeon-TX/Thunder chips which talk to devices connected to the ECAM bus through another sub-bus and am having issues regarding the device tree.
We have a "PCI" driver to handle the ECAM and I created a simple-bus stub for our MRML bus which connects low-speed devices to the ECAM bus and all of the devices show up in the device tree.
My problem is that the devices also enumerated via PCI.
I have something like the following:
static int cavium_pci_mmc_probe(struct udevice *dev) { debug("%s: Entry\n", __func__); pci_dev_t bdf = dm_pci_get_bdf(dev); struct cavium_mmc_host *host = dev_get_priv(dev); size_t size; uint64_t base_addr = dm_pci_map_bar(dev, 0, &size, PCI_REGION_MEM); int rc = 0;
host->base_addr = base_addr; dev->req_seq = PCI_FUNC(bdf);
debug("%s(%s): ", __func__, dev->name); debug(" platdata: %p\n" " parent platdata: %p\n" " uclass platdata: %p\n" " base address: %lx\n" " of_offset: %d\n" " parent: %p\n" " priv: %p\n" " uclass: %p\n" " req_seq: %d\n" " seq: %d\n", dev->platdata, dev->parent_platdata, dev->uclass_platdata, base_addr, dev->of_offset, dev->parent, dev->priv, dev->uclass, dev->req_seq, dev->seq);
if (dev->of_offset >= 0) rc = process_node(dev, gd->fdt_blob, dev->of_offset);
return rc; }
static const struct udevice_id cavium_mmc_ids[] = { { .compatible = "cavium,thunder-8890-mmc" }, { .compatible = "cavium,mmc" }, { }, };
static const struct udevice_id cavium_mmc_slot_ids[] = { { .compatible = "cavium,thunder-8890-mmc-slot" }, { }, };
U_BOOT_DRIVER(cavium_pci_mmc) = { .name = "mmc_cavium", .id = UCLASS_MMC, .of_match = of_match_ptr(cavium_mmc_ids), .ofdata_to_platdata = cavium_mmc_ofdata_to_platdata, .probe = cavium_pci_mmc_probe, .priv_auto_alloc_size = sizeof(struct cavium_mmc_host), .ops = NULL, };
static struct pci_device_id cavium_pci_mmc_supported[] = { { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_THUNDER_MMC) }, {}, };
U_BOOT_PCI_DEVICE(cavium_pci_mmc, cavium_pci_mmc_supported);
The problem I'm seeing is that in the probe function the of_offset field is always -1. Shouldn't it resolve this information via the compatible string in the device tree? How should I go about setting it up so that not only things like the base address get resolved but also the of_offset field since all of the slot configuration comes from the device tree.
In our case we have a single MMC device on the MRML bus connected to the ECAM bus (which looks like a PCI bus) which supports multiple slots with one set of registers.
-Aaron
On Tue, Nov 1, 2016 at 6:49 AM, Aaron Williams Aaron.Williams@caviumnetworks.com wrote:
Hi all,
host->base_addr = base_addr; dev->req_seq = PCI_FUNC(bdf); debug("%s(%s): ", __func__, dev->name); debug(" platdata: %p\n" " parent platdata: %p\n" " uclass platdata: %p\n" " base address: %lx\n" " of_offset: %d\n" " parent: %p\n" " priv: %p\n" " uclass: %p\n" " req_seq: %d\n" " seq: %d\n", dev->platdata, dev->parent_platdata, dev->uclass_platdata, base_addr, dev->of_offset, dev->parent, dev->priv, dev->uclass, dev->req_seq, dev->seq); if (dev->of_offset >= 0) rc = process_node(dev, gd->fdt_blob, dev->of_offset); return rc;
I think you're not using dt?
This look strange to me, but I am assuming PCI dev hierarchy may require u-boot,dm-pre-reloc on dt have you tried .flags = DM_FLAG_PRE_RELOC?
thanks!
Hi Jagen,
Hi all,
I'm using the dt and some of our other code uses it, though not specifically for the drivers. It's used for the serial interface, for example.
thanks!
I think I see the problem. The problem is that we have this MRML bus which is a sort of PCI bridge for low-speed devices but we don't have a proper driver for this. When scanning the devices, they show up in the parent ECAM bus and not on the MRML bus so I'm guessing I need to create a PCI bridge driver for this.
-Aaron
Aaron Williams
Jagan Teki
