[U-Boot] [PATCH v2] efi_loader: console: Correctly report modes
Add support for EFI console modes. Mode 0 is always 80x25 and present by EFI specification. Mode 1 is always 80x50 and not mandatory. Mode 2 and above is freely usable.
If the terminal can handle mode 1, we mark it as supported. If the terminal size is greater than mode 0 and different than mode 1, we install it as mode 2.
Modes can be switch with cout_set_mode.
Changes in V2: Add mode switch Report only the modes that we support
Signed-off-by: Emmanuel Vadot manu@bidouilliste.com --- lib/efi_loader/efi_console.c | 78 ++++++++++++++++++++++++++++++++++++-------- 1 file changed, 64 insertions(+), 14 deletions(-)
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 2e0228c..f4adc9e 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -9,11 +9,41 @@ #include <common.h> #include <efi_loader.h>
-/* If we can't determine the console size, default to 80x24 */ -static int console_columns = 80; -static int console_rows = 24; static bool console_size_queried;
+#define EFI_MAX_COUT_MODE 2 + +struct cout_mode { + unsigned long number; + unsigned long columns; + unsigned long rows; + int present; +}; + +static struct cout_mode efi_cout_modes[] = { + /* EFI Mode 0 is 80x25 and always present */ + { + .number = 0, + .columns = 80, + .rows = 25, + .present = 1, + }, + /* EFI Mode 1 is always 80x50 */ + { + .number = 1, + .columns = 80, + .rows = 50, + .present = 0, + }, + /* Value are unknown until we query the console */ + { + .number = 2, + .columns = 0, + .rows = 0, + .present = 0, + }, +}; + const efi_guid_t efi_guid_console_control = CONSOLE_CONTROL_GUID;
#define cESC '\x1b' @@ -56,6 +86,7 @@ const struct efi_console_control_protocol efi_console_control = { .lock_std_in = efi_cin_lock_std_in, };
+/* Default to mode 0 */ static struct simple_text_output_mode efi_con_mode = { .max_mode = 0, .mode = 0, @@ -140,12 +171,12 @@ static efi_status_t EFIAPI efi_cout_output_string( if (ch == '\n') { efi_con_mode.cursor_column = 1; efi_con_mode.cursor_row++; - } else if (efi_con_mode.cursor_column > console_columns) { + } else if (efi_con_mode.cursor_column > efi_cout_modes[efi_con_mode.mode].columns) { efi_con_mode.cursor_column = 1; efi_con_mode.cursor_row++; } - if (efi_con_mode.cursor_row > console_rows) { - efi_con_mode.cursor_row = console_rows; + if (efi_con_mode.cursor_row > efi_cout_modes[efi_con_mode.mode].rows) { + efi_con_mode.cursor_row = efi_cout_modes[efi_con_mode.mode].rows; } }
@@ -191,15 +222,32 @@ static efi_status_t EFIAPI efi_cout_query_mode( goto out; }
- console_columns = n[2]; - console_rows = n[1]; + /* Test if we can have Mode 1 */ + if (n[2] >= 80 && n[1] >= 50) { + efi_cout_modes[1].present = 1; + efi_con_mode.max_mode = 1; + } + + /* Install our mode as mode 2 if it is different than mode 0 or 1 and set it to the default one */ + if ((n[2] != 80 && n[1] != 25) || (n[2] != 80 && n[1] != 50)) { + efi_cout_modes[EFI_MAX_COUT_MODE].columns = n[2]; + efi_cout_modes[EFI_MAX_COUT_MODE].rows = n[1]; + efi_cout_modes[EFI_MAX_COUT_MODE].present = 1; + efi_con_mode.max_mode = EFI_MAX_COUT_MODE; + efi_con_mode.mode = EFI_MAX_COUT_MODE; + } }
+ if (mode_number > efi_con_mode.max_mode) + return EFI_EXIT(EFI_UNSUPPORTED); + if (efi_cout_modes[mode_number].present != 1) + return EFI_EXIT(EFI_UNSUPPORTED); + out: if (columns) - *columns = console_columns; + *columns = efi_cout_modes[mode_number].columns; if (rows) - *rows = console_rows; + *rows = efi_cout_modes[mode_number].rows;
return EFI_EXIT(EFI_SUCCESS); } @@ -210,11 +258,13 @@ static efi_status_t EFIAPI efi_cout_set_mode( { EFI_ENTRY("%p, %ld", this, mode_number);
- /* We only support text output for now */ - if (mode_number == EFI_CONSOLE_MODE_TEXT) - return EFI_EXIT(EFI_SUCCESS);
- return EFI_EXIT(EFI_UNSUPPORTED); + if (mode_number > efi_con_mode.max_mode) + return EFI_EXIT(EFI_UNSUPPORTED); + + efi_con_mode.mode = mode_number; + + return EFI_EXIT(EFI_SUCCESS); }
static efi_status_t EFIAPI efi_cout_set_attribute(
+struct cout_mode {
- unsigned long number;
- unsigned long columns;
- unsigned long rows;
- int present;
- /* EFI Mode 0 is 80x25 and always present */
.number = 0,
.columns = 80,
.rows = 25,
.present = 1,
- /* EFI Mode 1 is always 80x50 */
.number = 1,
.columns = 80,
.rows = 50,
.present = 0,
- /* Value are unknown until we query the console */
.number = 2,
.columns = 0,
.rows = 0,
.present = 0,
Have you sent this patch through checkpatch.pl? The line above is wider than 80 characters, right?
Just create an interim variable (struct cout_mode *mode = &efi_cout_modes[efi_con_mode]?) and use that instead. That makes the code easier to read and keeps lines short :).
} }efi_con_mode.cursor_row = efi_cout_modes[efi_con_mode.mode].rows;
From the EFI Spec:
Mode: Current Mode of the graphics device. Valid mode numbers are 0 to MaxMode -1.
So EFI_MAX_COUT_MODE should be 3 and you want above, right? Just define a new constant for the "special" mode (2).
This needs to be >=.
- if (efi_cout_modes[mode_number].present != 1)
out: if (columns)
if (rows)*columns = efi_cout_modes[mode_number].columns;
- if (mode_number > efi_con_mode.max_mode)
Alex
- efi_con_mode.mode = mode_number;
Alexander Graf
Emmanuel Vadot
