[U-Boot-Users] What methods of software authentication does U-Boot support?
Goal:
U-Boot will run only software that has been authenticated to be from the system's producer.
--- A Potential Authentication Method ---
The producer of the system generates a cryptographic [private-key, public-key] pair, storing the public-key on the same media as U-Boot (i.e. NOR flash; perhaps as a read-only environment variable) on all systems and keeping the private-key hidden at a secure site. A hash of the software is generated, encrypted with the private key and shipped with the software.
U-Boot reads the private-key encrypted hash and decodes it with its public-key. U-Boot loads the software and generates the hash. If both hashes match, the software is authenticated and U-Boot executes the authenticated software.
--- Comment ---
U-Boot obviously supports loading and verification of the generated hash, but I haven't been able to locate public-key cryptographic or other authentication support in U-Boot. Perhaps, it is available as a loadable (stand-alone) module?
Any comments or suggestions?
Sincerely,
Ken Fuchs
On Fri, 18 Apr 2008 12:01:38 -0500 Ken.Fuchs@bench.com wrote:
Goal:
--- Comment ---
this patch taps into openssl:
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/23977
or you might want to reuse some of linux' crypto library code.
Kim
Seems it's time to start a discussion to switch to GPL v3...
Be careful. Linking against openssl is not possible because the openssl licence is not compatible with GPL; see for example http://www.gnome.org/~markmc/openssl-and-the-gpl.html
For a u-boot friendly version of RSA look at http://xyssl.org/code/source/rsa/
I have not used it as the client put the secure(authenticated) image thing on hold but it was the best I could find in the limited time I put into it.
Ken.Fuchs@bench.com
Kenneth Johansson
Kim Phillips
