[U-Boot-Users] [PATCH] Update MPC8544DS to use libfdt
Updated the MPC8544DS config to use libfdt and assume use of aliases for ethernet, pci, and serial for the various fixups that are done.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
Note, this patch is also in my git tree: git.kernel.org:/pub/scm/boot/u-boot/galak/u-boot.git mpc85xx
and requires the various patches I've posted to fdt.
board/freescale/mpc8544ds/mpc8544ds.c | 87 ++++++++++++++++++--------------- include/configs/MPC8544DS.h | 7 +-- 2 files changed, 48 insertions(+), 46 deletions(-)
diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index b6c9e93..75a2b4b 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -29,14 +29,11 @@ #include <asm/io.h> #include <spd.h> #include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h>
#include "../common/pixis.h"
-#if defined(CONFIG_OF_FLAT_TREE) -#include <ft_build.h> -extern void ft_cpu_setup(void *blob, bd_t *bd); -#endif - #if defined(CONFIG_DDR_ECC) && !defined(CONFIG_ECC_INIT_VIA_DDRCONTROLLER) extern void ddr_enable_ecc(unsigned int dram_size); #endif @@ -508,51 +505,61 @@ get_board_sys_clk(ulong dummy) return val; }
-#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) +#if defined(CONFIG_OF_BOARD_SETUP) + void ft_board_setup(void *blob, bd_t *bd) { - u32 *p; - int len; + int node, tmp[2]; + const char *path;
- ft_cpu_setup(blob, bd); + fdt_fixup_ethernet(blob, bd);
- p = ft_get_prop(blob, "/memory/reg", &len); - if (p != NULL) { - *p++ = cpu_to_be32(bd->bi_memstart); - *p = cpu_to_be32(bd->bi_memsize); - } + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "timebase-frequency", bd->bi_busfreq / 8, 1); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "bus-frequency", bd->bi_busfreq, 1); + do_fixup_by_prop_u32(blob, "device_type", "cpu", 4, + "clock-frequency", bd->bi_busfreq, 1); + do_fixup_by_prop_u32(blob, "device_type", "soc", 4, + "bus-frequency", bd->bi_busfreq, 1); + + do_fixup_by_compat_u32(blob, "ns16550", + "clock-frequency", bd->bi_busfreq, 1); + + fdt_fixup_memory(blob, bd->bi_memstart, bd->bi_memsize); + + node = fdt_path_offset(blob, "/aliases"); + tmp[0] = 0; + if (node >= 0) { #ifdef CONFIG_PCI1 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pci@8000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pci1_hose.last_busno - pci1_hose.first_busno; - debug("PCI@8000 first_busno=%d last_busno=%d\n",p[0],p[1]); - } -#endif -#ifdef CONFIG_PCIE1 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pcie@a000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; - debug("PCI@a000 first_busno=%d last_busno=%d\n",p[0],p[1]); - } + path = fdt_getprop(blob, node, "pci0", NULL); + if (path) { + tmp[1] = pci1_hose.last_busno - pci1_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } #endif #ifdef CONFIG_PCIE2 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pcie@9000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pcie2_hose.last_busno - pcie2_hose.first_busno; - debug("PCI@9000 first_busno=%d last_busno=%d\n",p[0],p[1]); - } + path = fdt_getprop(blob, node, "pci1", NULL); + if (path) { + tmp[1] = pcie2_hose.last_busno - pcie2_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } +#endif +#ifdef CONFIG_PCIE1 + path = fdt_getprop(blob, node, "pci2", NULL); + if (path) { + tmp[1] = pcie1_hose.last_busno - pcie1_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } #endif #ifdef CONFIG_PCIE3 - p = (u32 *)ft_get_prop(blob, "/" OF_SOC "/pcie@b000/bus-range", &len); - if (p != NULL) { - p[0] = 0; - p[1] = pcie3_hose.last_busno - pcie3_hose.first_busno;; - debug("PCI@b000 first_busno=%d last_busno=%d\n",p[0],p[1]); - } + path = fdt_getprop(blob, node, "pci3", NULL); + if (path) { + tmp[1] = pcie3_hose.last_busno - pcie3_hose.first_busno; + do_fixup_by_path(blob, path, "bus-range", &tmp, 8, 1); + } #endif + } } #endif diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 13e2a2c..6fedfb4 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -251,14 +251,9 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #endif
/* pass open firmware flat tree */ -#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
-#define OF_CPU "PowerPC,8544@0" -#define OF_SOC "soc8544@e0000000" -#define OF_TBCLK (bd->bi_busfreq / 8) -#define OF_STDOUT_PATH "/soc8544@e0000000/serial@4500" - /* I2C */ #define CONFIG_FSL_I2C /* Use FSL common I2C driver */ #define CONFIG_HARD_I2C /* I2C with hardware support */
Kumar Gala
