[U-Boot] Slow tftp boot with Ubuntu 12.04 tftp server
Hi
I am using an Advantech TMX320TCI6614 EVM to develop code for an ARM core on a TI C66x device. The ARM core runs:
U-Boot 2011.06-00002-gc4611c1-dirty (May 30 2012 - 15:38:01)
I have booted this target card for several months from a tftp server running under Ubuntu 10.04, with no problems. But, this week, I have tried to move to a tftp server that runs on a different machine running Ubuntu 12.04 LTS.
Since moving to Ubuntu 12.04 the tftp download is very slow, although it does succeed eventually. I have tried getting the boot files using a tftp client running on another Ubuntu host and the download is fast.
Please can anyone suggest a reason for the slow download when using the EVM with the 12.04 server?
Best regards
David
I would like to give some more information about my problem. u-boot's tftp transfers do eventually complete and the evm boots. I can then execute tftp get commands from Linux on the evm and these execute quickly. So the problem definitely has to do with the way u-boot uses tftp.
BR
David
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of David Aldrich Sent: 17 January 2013 11:19 To: u-boot@lists.denx.de Subject: [U-Boot] Slow tftp boot with Ubuntu 12.04 tftp server
Hi
Best regards
David
Click https://www.mailcontrol.com/sr/gy6n!KN6KZHGX2PQPOmvUi5k6UwC82173 j1nKEDGDxQEKt0qtqc7COBYlPdIuP1TMPbtT3ZYZ55kxH4nYzTQYQ== to report this email as spam.
Could you remove CONFIG_USB_KEYBOARD setting from your configuration file (.h under include/configs) and recompile to see whether problem disappears?
If yes, this is the problem I'm working on. Otherwise it's another issue.
BR
David
Hi
Best regards
David
--nvpublic
On Thu, Jan 17, 2013 at 8:29 AM, David Aldrich David.Aldrich@emea.nec.comwrote:
I have experienced similar issues. It seems that once U-Boot's TFTP client has trouble with one packet that it tends to have a lot more trouble thereafter. For example, if the file I try to TFTP doesn't exist when I start the transfer, it retries until the file does exist at which time it starts the transfer (so far, so good), but the file transfer is then very slow. If I press CTRL-C to stop it then start it again, it runs quickly.
I have also had problems using TFTP from U-Boot through Ethernet hubs that seem to work well for everything else. Replacing the hubs with switches solved the problem in multiple cases.
I haven't tried to capture the packets and troubleshoot it, but it seems like there is something non-optimal in the timing.
Steve
On Thu, Jan 17, 2013 at 5:19 AM, David Aldrich David.Aldrich@emea.nec.comwrote:
Hi
TFTP is a very simple protocol and proceeds in lock step - get a request, send a block, wait for an ack of the last block, send the next block, etc. If either side times out, it will retry, but it can take quite a while. I would suggest to do some logging on the tftp server side or run wireshark or tcpdump and look for retries.
Am 17.01.2013 12:19, schrieb David Aldrich:
Hi
Try setting the max. blocksize explicit, e.g. I'm using -B 1460 here. It depends on the used tftp-server.
Regards,
Alexander
Hi Alexander
Thanks for your reply. Please will you confirm the exact syntax? I tried:
# tftp -B 1460 0x80000200 tci6614-evm.dtb tftpboot - boot image via network using TFTP protocol
Usage: tftpboot [loadAddress] [[hostIPaddr:]bootfilename]
I also tried:
setenv tftpblocksize 1460
but that made no difference.
What is the correct way of specifying the block size please?
David
Am 18.01.2013 11:16, schrieb David Aldrich:
Hi Alexander
I also tried:
That -B n is an option for the server, which is in my case (not Ubuntu) called in.tftpd and comes from the package tftpd-hpa (a Linux port of the OpenBSD TFTP server).
So you have to change that on your Ubuntu box.
Regards,
Alexander
participants (5)
Alexander Holler
Andrew Dyer
David Aldrich
Jim Lin
Steve Strobel
