[U-Boot] [PATCH 0/2] Revert "ARM: set GD_FLG_RELOC for boards skipping relocation to RAM"
This reverts commit f96b44cef897bd372beb86dde1b33637c119d84d.
diff --git a/lib_arm/board.c b/lib_arm/board.c index 5ade882..47e834c 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -220,18 +220,6 @@ static int init_func_i2c (void) } #endif
-#ifdef CONFIG_SKIP_RELOCATE_UBOOT -/* - * This routine sets the relocation done flag, because even if - * relocation is skipped, the flag is used by other generic code. - */ -static int reloc_init(void) -{ - gd->flags |= GD_FLG_RELOC; - return 0; -} -#endif - /* * Breathe some life into the board... * @@ -261,11 +249,6 @@ int print_cpuinfo (void); /* test-only */
init_fnc_t *init_sequence[] = { cpu_init, /* basic cpu dependent setup */ -#if defined(CONFIG_SKIP_RELOCATE_UBOOT) - reloc_init, /* Set the relocation done flag, must - do this AFTER cpu_init(), but as soon - as possible */ -#endif board_init, /* basic board dependent setup */ interrupt_init, /* set up exceptions */ env_init, /* initialize environment */
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/lib_arm/board.c b/lib_arm/board.c index 47e834c..f02fdc8 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -290,6 +290,8 @@ void start_armboot (void) gd->bd = (bd_t*)((char*)gd - sizeof(bd_t)); memset (gd->bd, 0, sizeof (bd_t));
+ gd->flags |= GD_FLG_RELOC; + monitor_flash_len = _bss_start - _armboot_start;
for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) {
Switch to the standard CFG_HZ=1000 value, while at it, minor white-space cleanup, remove CFG_CLKS_IN_HZ from config-headers. Tested on mx31ads, provides 2% or 0.4% precision depending on the CONFIG_MX31_TIMER_HIGH_PRECISION flag. Measured with stop-watch on 100s boot-delay.
Signed-off-by: Guennadi Liakhovetski lg@denx.de
diff --git a/cpu/arm1136/mx31/interrupts.c b/cpu/arm1136/mx31/interrupts.c index 6e08c71..7eaa90b 100644 --- a/cpu/arm1136/mx31/interrupts.c +++ b/cpu/arm1136/mx31/interrupts.c @@ -27,30 +27,49 @@ #define TIMER_BASE 0x53f90000 /* General purpose timer 1 */
/* General purpose timers registers */ -#define GPTCR __REG(TIMER_BASE) /* Control register */ -#define GPTPR __REG(TIMER_BASE + 0x4) /* Prescaler register */ -#define GPTSR __REG(TIMER_BASE + 0x8) /* Status register */ -#define GPTCNT __REG(TIMER_BASE + 0x24) /* Counter register */ +#define GPTCR __REG(TIMER_BASE) /* Control register */ +#define GPTPR __REG(TIMER_BASE + 0x4) /* Prescaler register */ +#define GPTSR __REG(TIMER_BASE + 0x8) /* Status register */ +#define GPTCNT __REG(TIMER_BASE + 0x24) /* Counter register */
/* General purpose timers bitfields */ -#define GPTCR_SWR (1<<15) /* Software reset */ -#define GPTCR_FRR (1<<9) /* Freerun / restart */ -#define GPTCR_CLKSOURCE_32 (4<<6) /* Clock source */ -#define GPTCR_TEN (1) /* Timer enable */ +#define GPTCR_SWR (1 << 15) /* Software reset */ +#define GPTCR_FRR (1 << 9) /* Freerun / restart */ +#define GPTCR_CLKSOURCE_32 (4 << 6) /* Clock source */ +#define GPTCR_TEN (1) /* Timer enable */ + +/* "time" is measured in 1 / CFG_HZ seconds, "tick" is internal timer period */ +#ifdef CONFIG_MX31_TIMER_HIGH_PRECISION +/* ~0.4% error - measured with stop-watch on 100s boot-delay */ +#define TICK_TO_TIME(t) ((t) * CFG_HZ / CONFIG_MX31_CLK32) +#define TIME_TO_TICK(t) ((unsigned long long)(t) * CONFIG_MX31_CLK32 / CFG_HZ) +#define US_TO_TICK(t) (((unsigned long long)(t) * CONFIG_MX31_CLK32 + \ + 999999) / 1000000) +#else +/* ~2% error */ +#define TICK_PER_TIME ((CONFIG_MX31_CLK32 + CFG_HZ / 2) / CFG_HZ) +#define US_PER_TICK (1000000 / CONFIG_MX31_CLK32) +#define TICK_TO_TIME(t) ((t) / TICK_PER_TIME) +#define TIME_TO_TICK(t) ((unsigned long long)(t) * TICK_PER_TIME) +#define US_TO_TICK(t) (((t) + US_PER_TICK - 1) / US_PER_TICK) +#endif
static ulong timestamp; static ulong lastinc;
/* nothing really to do with interrupts, just starts up a counter. */ +/* The 32768Hz 32-bit timer overruns in 131072 seconds */ int interrupt_init (void) { int i;
/* setup GP Timer 1 */ GPTCR = GPTCR_SWR; - for ( i=0; i<100; i++) GPTCR = 0; /* We have no udelay by now */ + for (i = 0; i < 100; i++) + GPTCR = 0; /* We have no udelay by now */ GPTPR = 0; /* 32Khz */ - GPTCR |= GPTCR_CLKSOURCE_32 | GPTCR_TEN; /* Freerun Mode, PERCLK1 input */ + /* Freerun Mode, PERCLK1 input */ + GPTCR |= GPTCR_CLKSOURCE_32 | GPTCR_TEN;
return 0; } @@ -67,7 +86,7 @@ void reset_timer(void) reset_timer_masked(); }
-ulong get_timer_masked (void) +unsigned long long get_ticks (void) { ulong now = GPTCNT; /* current tick value */
@@ -80,6 +99,17 @@ ulong get_timer_masked (void) return timestamp; }
+ulong get_timer_masked (void) +{ + /* + * get_ticks() returns a long long (64 bit), it wraps in + * 2^64 / CONFIG_MX31_CLK32 = 2^64 / 2^15 = 2^49 ~ 5 * 10^14 (s) ~ + * 5 * 10^9 days... and get_ticks() * CFG_HZ wraps in + * 5 * 10^6 days - long enough. + */ + return TICK_TO_TIME(get_ticks()); +} + ulong get_timer (ulong base) { return get_timer_masked () - base; @@ -87,29 +117,20 @@ ulong get_timer (ulong base)
void set_timer (ulong t) { + timestamp = TIME_TO_TICK(t); }
/* delay x useconds AND perserve advance timstamp value */ void udelay (unsigned long usec) { - ulong tmo, tmp; - - if (usec >= 1000) { /* if "big" number, spread normalization to seconds */ - tmo = usec / 1000; /* start to normalize for usec to ticks per sec */ - tmo *= CFG_HZ; /* find number of "ticks" to wait to achieve target */ - tmo /= 1000; /* finish normalize. */ - } else { /* else small number, don't kill it prior to HZ multiply */ - tmo = usec * CFG_HZ; - tmo /= (1000*1000); - } - - tmp = get_timer (0); /* get current timestamp */ - if ( (tmo + tmp + 1) < tmp )/* if setting this forward will roll time stamp */ - reset_timer_masked (); /* reset "advancing" timestamp to 0, set lastinc value */ - else - tmo += tmp; /* else, set advancing stamp wake up time */ - while (get_timer_masked () < tmo)/* loop till event */ - /*NOP*/; + unsigned long long tmp; + ulong tmo; + + tmo = US_TO_TICK(usec); + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp) /* loop till event */ + /*NOP*/; }
void reset_cpu (ulong addr) diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index 60916b9..9a655aa 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -122,11 +122,9 @@ #define CFG_MEMTEST_START 0 /* memtest works on */ #define CFG_MEMTEST_END 0x10000
-#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CFG_LOAD_ADDR 0 /* default load address */
-#define CFG_HZ 32000 +#define CFG_HZ 1000
#define CONFIG_CMDLINE_EDITING 1
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index bf2a8dd..1540203 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -126,7 +126,7 @@
diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index b904d81..04790fd 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -139,11 +139,9 @@ #define CFG_MEMTEST_START 0 /* memtest works on */ #define CFG_MEMTEST_END 0x10000
-#undef CFG_CLKS_IN_HZ /* everything, incl board info, in Hz */ - #define CFG_LOAD_ADDR CONFIG_LOADADDR
-#define CFG_HZ CONFIG_MX31_CLK32 /* use 32kHz clock as source */ +#define CFG_HZ 1000
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 1221553118-15819-3-git-send-email-plagnioj@jcrosoft.com you wrote:
Why are you reposting this?
And, even worse, why are you reposting a patch which you here attribute to Guennady (without adding your own Signed-off-by line), but this is actually not the original patch as submitted by Guennadi but a modified version where you meddled with whitespaces (corrupting Guennadi's nice alignment of the comments)? I see that you also cleaned up some coding style violations (like trailing white space), but not all of them (like '^ \t' pattern). And you added comments.
You must not modify other people's patches without recording the fact that you did so. If you change their code, you have to record this fact at least by adding your own Signed-off-by: line to the patch.
Please clean this up before resending a pull request.
In message 1221553118-15819-2-git-send-email-plagnioj@jcrosoft.com you wrote:
Maybe you should add a little explanation of what you are doing here, and why, etc. ?
In message 1221553118-15819-1-git-send-email-plagnioj@jcrosoft.com you wrote:
And what exactly is the reason to revert this patch?
Please explain.
Subject: Re: [U-Boot] [PATCH 0/2]
Normally, such a subject means that message No. '0' contains some explanation about the following patch series, followed by two relates patches numbered '1' and '2'.
I find it pretty confusing that you here send not 2, but 3 patches, the first two of which are related, while the third one is completely unrelated.
Please do not do this. Please stick to the standard rules.
