[U-Boot] [PATCH] sunxi: configs/sunxi-common.h: Enable CONFIG_CMD_PART
The recent changes to config_distro_bootcmd.h require CONFIG_CMD_PART to be defined, as the default bootcmd not uses the "part" command.
This fixes sunxi boards not booting with v2015.04-rc1.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- include/configs/sunxi-common.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index bf60dcb..9e145f0 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -144,6 +144,9 @@ #define CONFIG_CMD_MEMORY #define CONFIG_CMD_SETEXPR
+#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART + #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG
^w
Shouldn't config_distro_bootcmd.h (or perhaps config_distro_defaults.h) enable CMD_PART then? (adding some relevant CCs)
Ian.
^w
I was thinking the same myself, but I was not sure, so I thought lets go with a quick fix for now and discuss this further on the list :)
A quick grep shows that config_distro_bootcmd.h is only included from headers under include/configs/*.h, so enabling it there should get it defined early enough for it to be properly picked up, so from my pov yes that is a better solution.
Regards,
Hans
p.s.
Have you seen my reply to your review of "[PATCH 1/2] sunxi: video: Do not use CONFIG_SYS_MEM_TOP_HIDE for the framebuffer" ? I'm waiting on input from you there on the fdt_fixup_memory_banks() thingie, which I would prefer to keep as is. An "Acked-by" under the condition that I fix up the Linux specific comments would be welcome :)
Ian.
- #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG
^w
That sounds like the correct solution to me.
Hans de Goede
Ian Campbell
Stephen Warren
