[U-Boot] [PATCH 1/2] Move uninitialized_var() macro from ubi_uboot.h to compiler.h
This is needed so that we could use this macro for non-UBI code.
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com --- include/compiler.h | 3 +++ include/ubi_uboot.h | 4 +--- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/include/compiler.h b/include/compiler.h index 272fd3c..e602cce 100644 --- a/include/compiler.h +++ b/include/compiler.h @@ -122,4 +122,7 @@ typedef unsigned int uintptr_t;
#endif
+/* compiler options */ +#define uninitialized_var(x) x = x + #endif diff --git a/include/ubi_uboot.h b/include/ubi_uboot.h index 74312ab..60f6a5f 100644 --- a/include/ubi_uboot.h +++ b/include/ubi_uboot.h @@ -15,6 +15,7 @@ #define __UBOOT_UBI_H
#include <common.h> +#include <compiler.h> #include <malloc.h> #include <div64.h> #include <linux/crc32.h> @@ -51,9 +52,6 @@ do { \ #undef CONFIG_MTD_UBI_DEBUG_MSG_BLD #define CONFIG_MTD_UBI_DEBUG_DISABLE_BGT
-/* compiler options */ -#define uninitialized_var(x) x = x - /* build.c */ #define get_device(...) #define put_device(...)
Dear Anton Vorontsov,
#endif
Please excuse my ignorance, but where and what for is such a definition useful?
#endif
It's used to avoid GCC warnings, i.e. when GCC isn't smart enough to see that some variable isn't actually used uninitialized.
~/linux-2.6$ git grep uninitialized_var drivers/ | wc -l 94
We can fix the warnings by assigning some value to a variable at declaration, but the advantage of 'x = x' trick is that it doesn't generate any code.
Thanks,
#endif
You seem to be grepping the linux source tree. The whole U-boot codebase contains only 10 of them.
I'm not quite sure that would be noticeable given the number of uses (I don't have any opinion as to whether we should initialize them properly, though).
Regards,
On Tue, Sep 01, 2009 at 08:52:33PM +0200, Albin Tonnerre wrote: [...]
Yes, which is a great source of best practices.
Thanks,
except you didnt filter drivers/staging/ thus negating any results you might try to use to back up arguments -mike
Argh... what a clev^H^H^H^Hdirty trick.
Thanks for the explanation.
However, in this case it seems to make sense to me to explicitly initialize the return code with zero.
The warning is bogus, so silence it by initializing the 'ret' variable.
Well, I don't see any advantages of this, but here it is anyway.
Thanks.
p.s. Timur, since the patch has changed, I couldn't preserve your previous Ack.
board/freescale/common/sys_eeprom.c | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index c0fff68..661015e 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -204,7 +204,8 @@ static void update_crc(void) */ static int prog_eeprom(void) { - int ret, i; + int ret = 0; /* shut up gcc */ + int i; void *p; #ifdef CONFIG_SYS_EEPROM_BUS_NUM unsigned int bus;
Thanks.
applied to 85xx.
- k
Applied, thanks.
participants (6)
Albin Tonnerre
Anton Vorontsov
Kumar Gala
Mike Frysinger
Timur Tabi
