[U-Boot] [PATCH v3 0/4] Add Rock960 and Ficus 96Board support
This patchset adds support for Rock960 and Ficus 96Boards from Vamrs. Since both boards share most of the configurations, a common Rock960 family support is added with common support and the actual boards are based on this.
The previous version of the patchseries were adding Rock960 [1] and Ficus [2] board support individually, but this series fuses them together based on the common board support as per Linux kernel.
[1] https://patchwork.ozlabs.org/cover/963239/ [2] https://lists.denx.de/pipermail/u-boot/2018-August/339059.html
This patchseries has been tested on Rock960 v1.2 board and expecting Ezequiel to do the testing for Ficus.
PS: I have explicitly removed the previous Ack's for the Ficus board since there has been a heavy modification done on these patches.
Thanks, Mani
Manivannan Sadhasivam (4): arm: dts: rockchip: add some common pin-settings to rk3399 rockchip: rk3399: Add common Rock960 family from Vamrs rockchip: rk3399: Add Rock960 CE board support rockchip: rk3399: Add Ficus EE board support
arch/arm/dts/Makefile | 2 + arch/arm/dts/rk3399-ficus.dts | 78 + arch/arm/dts/rk3399-rock960.dts | 45 + arch/arm/dts/rk3399-rock960.dtsi | 506 ++++++ .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 1536 +++++++++++++++++ arch/arm/dts/rk3399.dtsi | 55 +- arch/arm/mach-rockchip/rk3399/Kconfig | 26 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 152 ++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 + configs/ficus-rk3399_defconfig | 71 + configs/rock960-rk3399_defconfig | 69 + include/configs/rock960_rk3399.h | 15 + 15 files changed, 2626 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3399-ficus.dts create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 arch/arm/dts/rk3399-rock960.dtsi create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/ficus-rk3399_defconfig create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
Those pins would be used by many boards.
Commit grabbed from Linux:
commit b41023282d07b61a53e2c9b9508912b1e7ce7b4f Author: Randy Li ayaka@soulik.info Date: Thu Jun 21 21:32:10 2018 +0800
arm64: dts: rockchip: add some common pin-settings to rk3399
Signed-off-by: Randy Li ayaka@soulik.info Signed-off-by: Heiko Stuebner heiko@sntech.de
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Signed-off-by: Randy Li ayaka@soulik.info Signed-off-by: Heiko Stuebner heiko@sntech.de Signed-off-by: Ezequiel Garcia ezequiel@collabora.com ---
Changes in v3: None
Changes in v2: None
arch/arm/dts/rk3399.dtsi | 55 +++++++++++++++++++++++++++++++++++----- 1 file changed, 49 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi index 83c257b1228..8349451b03d 100644 --- a/arch/arm/dts/rk3399.dtsi +++ b/arch/arm/dts/rk3399.dtsi @@ -1602,19 +1602,49 @@ drive-strength = <12>; };
+ pcfg_pull_none_13ma: pcfg-pull-none-13ma { + bias-disable; + drive-strength = <13>; + }; + + pcfg_pull_none_18ma: pcfg-pull-none-18ma { + bias-disable; + drive-strength = <18>; + }; + + pcfg_pull_none_20ma: pcfg-pull-none-20ma { + bias-disable; + drive-strength = <20>; + }; + + pcfg_pull_up_2ma: pcfg-pull-up-2ma { + bias-pull-up; + drive-strength = <2>; + }; + pcfg_pull_up_8ma: pcfg-pull-up-8ma { bias-pull-up; drive-strength = <8>; };
+ pcfg_pull_up_18ma: pcfg-pull-up-18ma { + bias-pull-up; + drive-strength = <18>; + }; + + pcfg_pull_up_20ma: pcfg-pull-up-20ma { + bias-pull-up; + drive-strength = <20>; + }; + pcfg_pull_down_4ma: pcfg-pull-down-4ma { bias-pull-down; drive-strength = <4>; };
- pcfg_pull_up_2ma: pcfg-pull-up-2ma { - bias-pull-up; - drive-strength = <2>; + pcfg_pull_down_8ma: pcfg-pull-down-8ma { + bias-pull-down; + drive-strength = <8>; };
pcfg_pull_down_12ma: pcfg-pull-down-12ma { @@ -1622,9 +1652,22 @@ drive-strength = <12>; };
- pcfg_pull_none_13ma: pcfg-pull-none-13ma { - bias-disable; - drive-strength = <13>; + pcfg_pull_down_18ma: pcfg-pull-down-18ma { + bias-pull-down; + drive-strength = <18>; + }; + + pcfg_pull_down_20ma: pcfg-pull-down-20ma { + bias-pull-down; + drive-strength = <20>; + }; + + pcfg_output_high: pcfg-output-high { + output-high; + }; + + pcfg_output_low: pcfg-output-low { + output-low; };
clock {
On Thu, Sep 27, 2018 at 8:03 PM Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
arm64: dts: rockchip: add some common pin-settings to rk3399 Those pins would be used by many boards. Signed-off-by: Randy Li <ayaka@soulik.info> Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Peter Robinson pbrobinson@gmail.com
Tested on both a Rock960 and a Firefly3399
Changes in v3: None
Changes in v2: None
bias-disable;
bias-disable;
bias-disable;
bias-pull-up;
bias-pull-up;
bias-pull-up;
bias-pull-up;
bias-pull-down;
drive-strength = <8>; }; pcfg_pull_down_12ma: pcfg-pull-down-12ma {
bias-disable;
bias-pull-down;
bias-pull-down;
output-high;
output-low; }; clock {
-- 2.17.1
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Signed-off-by: Randy Li ayaka@soulik.info Signed-off-by: Heiko Stuebner heiko@sntech.de Signed-off-by: Ezequiel Garcia ezequiel@collabora.com Tested-by: Peter Robinson pbrobinson@gmail.com
Changes in v3: None
Changes in v2: None
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Signed-off-by: Randy Li ayaka@soulik.info Signed-off-by: Heiko Stuebner heiko@sntech.de Signed-off-by: Ezequiel Garcia ezequiel@collabora.com Tested-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3: None
Changes in v2: None
Applied to u-boot-rockchip, thanks!
Rock960 is a family of boards based on Rockchip RK3399 SoC from Vamrs. It consists of Rock960 (Consumer Edition) and Ficus (Enterprise Edition) 96Boards.
Below are some of the key differences between both Rock960 and Ficus boards:
1. Different host enable GPIO for USB 2. Different power and reset GPIO for PCI-E 3. No Ethernet port on Rock960
The common board support will be utilized by both boards. The device tree has been organized in such a way that only the properties which differ between both boards are placed in the board specific dts and the reset of the nodes are placed in common dtsi file.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org [Added instructions for SD card boot] Signed-off-by: Ezequiel Garcia ezequiel@collabora.com ---
Changes in v3: Added instruction for copying prebuilt bl31.elf for SPL
Changes in v2: None
arch/arm/dts/rk3399-rock960.dtsi | 506 ++++++++++++++++++++ arch/arm/mach-rockchip/rk3399/Kconfig | 26 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 152 ++++++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 ++ include/configs/rock960_rk3399.h | 15 + 8 files changed, 776 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dtsi create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 include/configs/rock960_rk3399.h
diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi new file mode 100644 index 00000000000..51644d6d02d --- /dev/null +++ b/arch/arm/dts/rk3399-rock960.dtsi @@ -0,0 +1,506 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2018 Linaro Ltd. + */ + +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include "rk3399.dtsi" + +/ { + vcc1v8_s0: vcc1v8-s0 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8_s0"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + vcc_sys: vcc-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vcc3v3_pcie: vcc3v3-pcie-regulator { + compatible = "regulator-fixed"; + enable-active-high; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_drv>; + regulator-boot-on; + regulator-name = "vcc3v3_pcie"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc3v3_sys>; + }; + + vcc5v0_host: vcc5v0-host-regulator { + compatible = "regulator-fixed"; + enable-active-high; + pinctrl-names = "default"; + pinctrl-0 = <&host_vbus_drv>; + regulator-name = "vcc5v0_host"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&vcc_sys>; + }; + + vdd_log: vdd-log { + compatible = "pwm-regulator"; + pwms = <&pwm2 0 25000 0>; + regulator-name = "vdd_log"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + }; + +}; + +&cpu_l0 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l1 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l2 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_l3 { + cpu-supply = <&vdd_cpu_l>; +}; + +&cpu_b0 { + cpu-supply = <&vdd_cpu_b>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_b>; +}; + +&emmc_phy { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <400000>; + i2c-scl-rising-time-ns = <168>; + i2c-scl-falling-time-ns = <4>; + status = "okay"; + + vdd_cpu_b: regulator@40 { + compatible = "silergy,syr827"; + reg = <0x40>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_b"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + status = "okay"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: regulator@41 { + compatible = "silergy,syr828"; + reg = <0x41>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_gpu"; + regulator-min-microvolt = <712500>; + regulator-max-microvolt = <1500000>; + regulator-ramp-delay = <1000>; + regulator-always-on; + regulator-boot-on; + vin-supply = <&vcc_sys>; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + #clock-cells = <1>; + clock-output-names = "xin32k", "rk808-clkout2"; + + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc_sys>; + vcc10-supply = <&vcc_sys>; + vcc11-supply = <&vcc_sys>; + vcc12-supply = <&vcc3v3_sys>; + vddio-supply = <&vcc_1v8>; + + regulators { + vdd_center: DCDC_REG1 { + regulator-name = "vdd_center"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_l: DCDC_REG2 { + regulator-name = "vdd_cpu_l"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG4 { + regulator-name = "vcc_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc1v8_dvp: LDO_REG1 { + regulator-name = "vcc1v8_dvp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_hdmi: LDO_REG2 { + regulator-name = "vcca1v8_hdmi"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca_1v8: LDO_REG3 { + regulator-name = "vcca_1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_sd: LDO_REG4 { + regulator-name = "vcc_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc3v0_sd: LDO_REG5 { + regulator-name = "vcc3v0_sd"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc_1v5: LDO_REG6 { + regulator-name = "vcc_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1500000>; + }; + }; + + vcca0v9_hdmi: LDO_REG7 { + regulator-name = "vcca0v9_hdmi"; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vcc_3v0: LDO_REG8 { + regulator-name = "vcc_3v0"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3000000>; + }; + }; + + vcc3v3_s3: SWITCH_REG1 { + regulator-name = "vcc3v3_s3"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_s0: SWITCH_REG2 { + regulator-name = "vcc3v3_s0"; + regulator-always-on; + regulator-boot-on; + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; +}; + +&i2c2 { + status = "okay"; +}; + +&i2c3 { + status = "okay"; +}; + +&i2c4 { + status = "okay"; +}; + +&io_domains { + bt656-supply = <&vcc1v8_s0>; /* bt656_gpio2ab_ms */ + audio-supply = <&vcc1v8_s0>; /* audio_gpio3d4a_ms */ + sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */ + gpio1830-supply = <&vcc_3v0>; /* gpio1833_gpio4cd_ms */ + status = "okay"; +}; + +&pcie_phy { + status = "okay"; +}; + +&pcie0 { + num-lanes = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&pcie_clkreqn_cpm>; + vpcie3v3-supply = <&vcc3v3_pcie>; + status = "okay"; +}; + +&pmu_io_domains { + pmu1830-supply = <&vcc_1v8>; + status = "okay"; +}; + +&pinctrl { + sdmmc { + sdmmc_bus1: sdmmc-bus1 { + rockchip,pins = + <4 8 RK_FUNC_1 &pcfg_pull_up_8ma>; + }; + + sdmmc_bus4: sdmmc-bus4 { + rockchip,pins = + <4 8 RK_FUNC_1 &pcfg_pull_up_8ma>, + <4 9 RK_FUNC_1 &pcfg_pull_up_8ma>, + <4 10 RK_FUNC_1 &pcfg_pull_up_8ma>, + <4 11 RK_FUNC_1 &pcfg_pull_up_8ma>; + }; + + sdmmc_clk: sdmmc-clk { + rockchip,pins = + <4 12 RK_FUNC_1 &pcfg_pull_none_18ma>; + }; + + sdmmc_cmd: sdmmc-cmd { + rockchip,pins = + <4 13 RK_FUNC_1 &pcfg_pull_up_8ma>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + vsel1_gpio: vsel1-gpio { + rockchip,pins = + <1 17 RK_FUNC_GPIO &pcfg_pull_down>; + }; + + vsel2_gpio: vsel2-gpio { + rockchip,pins = + <1 14 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + clock-frequency = <100000000>; + clock-freq-min-max = <100000 100000000>; + cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; + disable-wp; + sd-uhs-sdr104; + vqmmc-supply = <&vcc_sd>; + card-detect-delay = <800>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer &uart0_cts>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&u2phy0 { + status = "okay"; +}; + +&u2phy1 { + status = "okay"; +}; + +&u2phy0_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&u2phy1_host { + phy-supply = <&vcc5v0_host>; + status = "okay"; +}; + +&u2phy0_otg { + status = "okay"; +}; + +&u2phy1_otg { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&vopb { + status = "okay"; +}; + +&vopl { + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig index 415466a49bb..8f18e33c76f 100644 --- a/arch/arm/mach-rockchip/rk3399/Kconfig +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -28,6 +28,31 @@ config TARGET_PUMA_RK3399 * HDMI, eDP, MIPI-DSI, MIPI-DSI/CSI and MIPI-CSI * SPI, I2C, I2S, UART, GPIO, ...
+config TARGET_ROCK960_RK3399 + bool "Vamrs Limited Rock960 board family" + help + Support for Rock960 board family by Vamrs Limited. This board + family consists of Rock960 (Consumer Edition) and Ficus + (Enterprise Edition) 96Boards. + + Common features implemented on both boards: + * Rockchip RK3399 SoC (2xCortex A72, 4xCortex A53, ARM Mali T860MP4) + * 16/32GB eMMC, uSD slot + * HDMI/DP/MIPI + * 20-pin low speed and 40-pin high speed expanders, 6 LED, 3 buttons + + Additional features of Rock960: + * 2GiB/4GiB LPDDR3 RAM + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + + Additional features of Ficus: + * 2GiB/4GiB DDR3 RAM + * Ethernet + * Dual SATA + * 2x USB 3.0 type A, 2x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + endchoice
config SYS_SOC @@ -38,5 +63,6 @@ config SYS_MALLOC_F_LEN
source "board/rockchip/evb_rk3399/Kconfig" source "board/theobroma-systems/puma_rk3399/Kconfig" +source "board/vamrs/rock960_rk3399/Kconfig"
endif diff --git a/board/vamrs/rock960_rk3399/Kconfig b/board/vamrs/rock960_rk3399/Kconfig new file mode 100644 index 00000000000..cacc53f3780 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_ROCK960_RK3399 + +config SYS_BOARD + default "rock960_rk3399" + +config SYS_VENDOR + default "vamrs" + +config SYS_CONFIG_NAME + default "rock960_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/vamrs/rock960_rk3399/MAINTAINERS b/board/vamrs/rock960_rk3399/MAINTAINERS new file mode 100644 index 00000000000..9f3fe75f4fb --- /dev/null +++ b/board/vamrs/rock960_rk3399/MAINTAINERS @@ -0,0 +1,6 @@ +ROCK960-RK3399 +M: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +S: Maintained +F: board/rockchip/rock960_rk3399 +F: include/configs/rock960_rk3399.h +F: configs/rock960-rk3399_defconfig diff --git a/board/vamrs/rock960_rk3399/Makefile b/board/vamrs/rock960_rk3399/Makefile new file mode 100644 index 00000000000..6c3e475b3a8 --- /dev/null +++ b/board/vamrs/rock960_rk3399/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org +# + +obj-y += rock960-rk3399.o diff --git a/board/vamrs/rock960_rk3399/README b/board/vamrs/rock960_rk3399/README new file mode 100644 index 00000000000..d14399090e2 --- /dev/null +++ b/board/vamrs/rock960_rk3399/README @@ -0,0 +1,152 @@ +Contents +======== + +1. Introduction +2. Get the Source and prebuild binary +3. Compile the U-Boot +4. Compile the rkdeveloptool +5. Package the image + 5.1. Package the image for U-Boot SPL(option 1) + 5.2. Package the image for Rockchip miniloader(option 2) +6. Bootloader storage options +7. Flash the image to eMMC + 7.1. Flash the image with U-Boot SPL(option 1) + 7.2. Flash the image with Rockchip miniloader(option 2) +8. Create a bootable SD/MMC +9. And that is it + +Introduction +============ + +Rock960 board family consists of Rock960 (Consumer Edition) and +Ficus (Enterprise Edition) 96Boards featuring Rockchip RK3399 SoC. + +Common features implemented on both boards: + * CPU: ARMv8 64bit Big-Little architecture, + * Big: dual-core Cortex-A72 + * Little: quad-core Cortex-A53 + * IRAM: 200KB + * eMMC: 16/32GB eMMC 5.1 + * PMU: RK808 + * SD/MMC + * Display: HDMI/DP/MIPI + * Low Speed Expansion Connector + * High Speed Expansion Connector + +Additional features of Rock960: + * DRAM: 2GB/4GB LPDDR3 @ 1866MHz + * 1x USB 3.0 type A, 1x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + +Additional features of Ficus: + * DRAM: 2GB/4GB DDR3 @ 1600MHz + * Ethernet + * 2x USB 3.0 type A, 2x USB 2.0 type A (host mode only), + 1x USB 3.0 type C OTG + +Here is the step-by-step to boot to U-Boot on Rock960 boards. + +Get the Source and prebuild binary +================================== + + > git clone https://github.com/96rocks/rkbin.git + > git clone https://github.com/rockchip-linux/rkdeveloptool.git + +Compile the U-Boot +================== + + > cd ../u-boot + > cp ../rkbin/rk33/rk3399_bl31_v1.00.elf ./bl31.elf + > export ARCH=arm64 + > export CROSS_COMPILE=aarch64-linux-gnu- + > make rock960-rk3399_defconfig + > make + > make u-boot.itb + +Compile the rkdeveloptool +========================= + +Follow instructions in latest README + > cd ../rkdeveloptool + > autoreconf -i + > ./configure + > make + > sudo make install + +Package the image +================= + +Package the image for U-Boot SPL(option 1) +-------------------------------- + > cd .. + > tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin idbspl.img + + Get idbspl.img in this step. + +Package the image for Rockchip miniloader(option 2) +------------------------------------------ + > cd ../rkbin + > ./tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img 0x200000 + + > ../u-boot/tools/mkimage -n rk3399 -T rksd -d rk3399_ddr_933MHz_v1.08.bin idbloader.img + > cat ./rk33/rk3399_miniloader_v1.06.bin >> idbloader.img + + Get uboot.img and idbloader.img in this step. + +Bootloader storage options +========================== + +There are a few different storage options for the bootloader. +This document explores two of these: eMMC and removable SD/MMC. + +Flash the image to eMMC +======================= + +Flash the image with U-Boot SPL(option 1) +------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 64 u-boot/idbspl.img + > rkdeveloptool wl 0x4000 u-boot/u-boot.itb + > rkdeveloptool rd + +Flash the image with Rockchip miniloader(option 2) +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then: + > rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin + > rkdeveloptool wl 0x40 idbloader.img + > rkdeveloptool wl 0x4000 uboot.img + > rkdeveloptool wl 0x6000 ./img/rk3399/trust.img + > rkdeveloptool rd + +Create a bootable SD/MMC +======================== + +The idbspl.img contains the first stage, and the u-boot.img the second stage. +As explained in the Rockchip partition table reference [1], the first stage +(aka loader1) start sector is 64, and the second stage start sector is 16384. + +Each sector is 512 bytes, which means the first stage offset is 32 KiB, +and the second stage offset is 8 MiB. + +Note: the second stage location is actually not as per the spec, +but defined by the SPL. Mainline SPL defines an 8 MiB offset for the second +stage. + +Assuming the SD card is exposed by device /dev/mmcblk0, the commands +to write the two stages are: + + > dd if=idbspl.img of=/dev/mmcblk0 bs=1k seek=32 + > dd if=u-boot.itb of=/dev/mmcblk0 bs=1k seek=8192 + +Setting up the kernel and rootfs is beyond the scope of this document. + +And that is it +============== + +You should be able to get U-Boot log in console/UART2(baurdrate 1500000) + +For more detail, please reference [2]. + +[1] http://opensource.rock-chips.com/wiki_Partitions +[2] http://opensource.rock-chips.com/wiki_Boot_option diff --git a/board/vamrs/rock960_rk3399/rock960-rk3399.c b/board/vamrs/rock960_rk3399/rock960-rk3399.c new file mode 100644 index 00000000000..d3775b22191 --- /dev/null +++ b/board/vamrs/rock960_rk3399/rock960-rk3399.c @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <dm/uclass-internal.h> +#include <asm/arch/periph.h> +#include <power/regulator.h> +#include <spl.h> + +int board_init(void) +{ + int ret; + + ret = regulators_enable_boot_on(false); + if (ret) + debug("%s: Cannot enable boot on regulator\n", __func__); + + return 0; +} + +void spl_board_init(void) +{ + struct udevice *pinctrl; + int ret; + + ret = uclass_get_device(UCLASS_PINCTRL, 0, &pinctrl); + if (ret) { + debug("%s: Cannot find pinctrl device\n", __func__); + goto err; + } + + /* Enable debug UART */ + ret = pinctrl_request_noflags(pinctrl, PERIPH_ID_UART_DBG); + if (ret) { + debug("%s: Failed to set up console UART\n", __func__); + goto err; + } + + preloader_console_init(); + return; +err: + printf("%s: Error %d\n", __func__, ret); + + /* No way to report error here */ + hang(); +} diff --git a/include/configs/rock960_rk3399.h b/include/configs/rock960_rk3399.h new file mode 100644 index 00000000000..746d24cbff5 --- /dev/null +++ b/include/configs/rock960_rk3399.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +#ifndef __ROCK960_RK3399_H +#define __ROCK960_RK3399_H + +#include <configs/rk3399_common.h> + +#define CONFIG_SYS_MMC_ENV_DEV 1 + +#define SDRAM_BANK_SIZE (2UL << 30) + +#endif
On 27 September 2018 at 12:02, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
- Different host enable GPIO for USB
- Different power and reset GPIO for PCI-E
- No Ethernet port on Rock960
Changes in v2: None
Could you also add a note to README.rockchip? Some of your docs seem to duplicate what is there.
Hi Simon,
Changes in v2: None
Thanks for your review!
You mean, I should skip the duplicate instructions and add a pointer to relevant sections in Rockchip README?
Regards, Mani
On 02.10.2018, at 16:01, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
Hi Simon,
Changes in v2: None
I also had had a similar comment on an earlier series: we should avoid just copying these instructions verbatim into every new board: if these are indeed identical to Rockchip’s EVB (i.e. if the board-vendor completely relies on the chip-vendor's tools), they should reference back to the EVB’s README instead of duplicating the content.
Regards, Mani
Hi Simon,
Changes in v2: None
Yes, I agree here. The instructions are almost 100% SoC-specific, not board specific. Having a doc per SoC is the way to go, IMO.
Philipp: do you think it's acceptable that this is done as follow-up patches?
Thanks! Eze
Hi Simon,
Changes in v2: None
That’s not entirely true: on the RK3399-Q7 we have very different instructions, as we have our own tooling and maintain a number of components specifically for the board. In other words: many boards will want to reference back to the EVB’s instructions, but not all of them … and the instructions are not entirely SoC specific, but most vendors choose to do things exactly the same as for the EVB.
Just rewrite the README to point it to the one in the EVB-directory and this can go in with the next batch of patches...
Thanks! Eze
Hi Simon,
Changes in v2: None
Agree! Even we are working on customizing the instructions for Rock960 family boards. The current instructions in README is just an intial reference to get the board up and running. But I admit that it is a dup of EVB mostly.
Cool. Then I will modify the instructions and push out as an incremental patchset once this series gets in.
Thanks, Mani
Thanks! Eze
Tested on a Rock960.
Changes in v2: None
- Copyright (c) 2018 Linaro Ltd.
vcc_sys: vcc-sys {
enable-active-high;
regulator-boot-on;
enable-active-high;
vdd_log: vdd-log {
regulator-boot-on;
+&cpu_l0 {
+&cpu_l1 {
+&cpu_l2 {
+&cpu_l3 {
+&cpu_b0 {
+&cpu_b1 {
+&emmc_phy {
status = "okay";
+&hdmi {
status = "okay";
+&i2c0 {
status = "okay";
reg = <0x40>;
regulator-boot-on;
status = "okay";
reg = <0x41>;
regulator-boot-on;
rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_sd: LDO_REG4 {
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2c1 {
status = "okay";
+&i2c2 {
status = "okay";
+&i2c3 {
status = "okay";
+&i2c4 {
status = "okay";
+&io_domains {
status = "okay";
+&pcie_phy {
status = "okay";
+&pcie0 {
num-lanes = <4>;
status = "okay";
+&pmu_io_domains {
status = "okay";
+&pinctrl {
sdmmc {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
pmic {
rockchip,pins =
rockchip,pins =
rockchip,pins =
+&pwm2 {
status = "okay";
+&pwm3 {
status = "okay";
+&sdhci {
bus-width = <8>;
mmc-hs400-1_8v;
non-removable;
status = "okay";
+&sdmmc {
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
disable-wp;
sd-uhs-sdr104;
status = "okay";
+&uart0 {
status = "okay";
+&uart2 {
status = "okay";
+&u2phy0 {
status = "okay";
+&u2phy1 {
status = "okay";
+&u2phy0_host {
status = "okay";
+&u2phy1_host {
status = "okay";
+&u2phy0_otg {
status = "okay";
+&u2phy1_otg {
status = "okay";
+&usb_host0_ehci {
status = "okay";
+&usb_host0_ohci {
status = "okay";
+&usb_host1_ehci {
status = "okay";
+&usb_host1_ohci {
status = "okay";
+&vopb {
status = "okay";
+&vopl {
status = "okay";
help
* HDMI/DP/MIPI
* Ethernet
* Dual SATA
endchoice
+config SYS_BOARD
+config SYS_VENDOR
default "vamrs"
def_bool y
- 5.1. Package the image for U-Boot SPL(option 1)
- 5.2. Package the image for Rockchip miniloader(option 2)
- 7.1. Flash the image with U-Boot SPL(option 1)
- 7.2. Flash the image with Rockchip miniloader(option 2)
* IRAM: 200KB
* PMU: RK808
* SD/MMC
* Ethernet
git clone https://github.com/96rocks/rkbin.git git clone https://github.com/rockchip-linux/rkdeveloptool.git+Compile the U-Boot +==================
cd ../u-boot cp ../rkbin/rk33/rk3399_bl31_v1.00.elf ./bl31.elf export ARCH=arm64 export CROSS_COMPILE=aarch64-linux-gnu- make rock960-rk3399_defconfig make make u-boot.itb+Compile the rkdeveloptool +=========================
cd ../rkdeveloptool autoreconf -i ./configure make sudo make install+Package the image +=================
cd .. tools/mkimage -n rk3399 -T rksd -d spl/u-boot-spl.bin idbspl.img- Get idbspl.img in this step.
cd ../rkbin ./tools/loaderimage --pack --uboot u-boot/u-boot-dtb.bin uboot.img 0x200000 ../u-boot/tools/mkimage -n rk3399 -T rksd -d rk3399_ddr_933MHz_v1.08.bin idbloader.img cat ./rk33/rk3399_miniloader_v1.06.bin >> idbloader.img- Get uboot.img and idbloader.img in this step.
rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin rkdeveloptool wl 64 u-boot/idbspl.img rkdeveloptool wl 0x4000 u-boot/u-boot.itb rkdeveloptool rd+Flash the image with Rockchip miniloader(option 2) +---------------------------------------- +Power on(or reset with RESET KEY) with MASKROM KEY preesed, and then:
rkdeveloptool db rkbin/rk33/rk3399_loader_v1.08.106.bin rkdeveloptool wl 0x40 idbloader.img rkdeveloptool wl 0x4000 uboot.img rkdeveloptool wl 0x6000 ./img/rk3399/trust.img rkdeveloptool rd+Create a bootable SD/MMC +========================
dd if=idbspl.img of=/dev/mmcblk0 bs=1k seek=32 dd if=u-boot.itb of=/dev/mmcblk0 bs=1k seek=8192+Setting up the kernel and rootfs is beyond the scope of this document.
- Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
int ret;
if (ret)
int ret;
if (ret) {
goto err;
if (ret) {
goto err;
return;
+err:
hang();
2.17.1
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org [Added instructions for SD card boot] Signed-off-by: Ezequiel Garcia ezequiel@collabora.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com
Changes in v2: None
Add board support for Rock960 CE board from Vamrs. This board utilizes common Rock960 family support.
Following peripherals are tested and known to work: * USB 2.0 * MMC
This commit also adds DDR configuration for LPDDR3-2GiB-1600MHz which is being used on the board.
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org ---
Changes in v3:
* Add config options for USB to Ethernet and USB2 PHY
Changes in v2:
* Added missing config options for USB/uSD * Fixed the commit description for DDR speed
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-rock960.dts | 45 + .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 1536 +++++++++++++++++ configs/rock960-rk3399_defconfig | 69 + 4 files changed, 1651 insertions(+) create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi create mode 100644 configs/rock960-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ebfa2272627..9b891826b73 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -51,6 +51,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3399-puma-ddr1333.dtb \ rk3399-puma-ddr1600.dtb \ rk3399-puma-ddr1866.dtb \ + rk3399-rock960.dtb \ rv1108-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-nanopi-k2.dtb \ diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts new file mode 100644 index 00000000000..25c58b42611 --- /dev/null +++ b/arch/arm/dts/rk3399-rock960.dts @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +/dts-v1/; +#include "rk3399-rock960.dtsi" +#include "rk3399-sdram-lpddr3-2GB-1600.dtsi" + +/ { + model = "96boards Rock960"; + compatible = "vamrs,rock960", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&pcie0 { + ep-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; +}; + +&pinctrl { + pcie { + pcie_drv: pcie-drv { + rockchip,pins = + <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + host_vbus_drv: host-vbus-drv { + rockchip,pins = + <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&vcc3v3_pcie { + gpio = <&gpio2 5 GPIO_ACTIVE_HIGH>; +}; + +&vcc5v0_host { + gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; +}; diff --git a/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi b/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi new file mode 100644 index 00000000000..d14e833d228 --- /dev/null +++ b/arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi @@ -0,0 +1,1536 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * (C) Copyright 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org + */ + +&dmc { + rockchip,sdram-params = < + 0x1 + 0xa + 0x3 + 0x2 + 0x2 + 0x0 + 0xf + 0xf + 1 + 0x1d191519 + 0x14040808 + 0x00000002 + 0x00006226 + 0x00000054 + 0x00000000 + 0x1 + 0xa + 0x3 + 0x2 + 0x2 + 0x0 + 0xf + 0xf + 1 + 0x1d191519 + 0x14040808 + 0x00000002 + 0x00006226 + 0x00000054 + 0x00000000 + 800 + 6 + 2 + 9 + 1 + 0x00000700 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000050 + 0x00027100 + 0x00000320 + 0x00001f40 + 0x00000050 + 0x00027100 + 0x00000320 + 0x00001f40 + 0x00000050 + 0x00027100 + 0x00000320 + 0x01001f40 + 0x00000000 + 0x00000101 + 0x00020100 + 0x000000a0 + 0x00000190 + 0x00000000 + 0x06180000 + 0x00061800 + 0x04000618 + 0x33080004 + 0x280f0622 + 0x22330800 + 0x00280f06 + 0x06223308 + 0x0600280f + 0x00000a0a + 0x0600dac0 + 0x0a0a060c + 0x0600dac0 + 0x0a0a060c + 0x0600dac0 + 0x0203000c + 0x0f0c0f00 + 0x040c0f0c + 0x14000a0a + 0x03030a0a + 0x00010003 + 0x031b1b1b + 0x00111111 + 0x00000000 + 0x03010000 + 0x0c2800a8 + 0x0c2800a8 + 0x0c2800a8 + 0x00000000 + 0x00060006 + 0x00140006 + 0x00140014 + 0x000f0f0f + 0x00000000 + 0x00000000 + 0x00000000 + 0x00b00000 + 0x00b000b0 + 0x00b000b0 + 0x000000b0 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000301 + 0x00000001 + 0x00000000 + 0x00000000 + 0x01000000 + 0x80104002 + 0x00040003 + 0x00040005 + 0x00030000 + 0x00050004 + 0x00000004 + 0x00040003 + 0x00040005 + 0x30a00000 + 0x00001850 + 0x185030a0 + 0x30a00000 + 0x00001850 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02020200 + 0x00020202 + 0x00030200 + 0x00040700 + 0x00000302 + 0x02000407 + 0x00000003 + 0x00030f04 + 0x00070004 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x20040020 + 0x00200400 + 0x01000400 + 0x00000b80 + 0x00000000 + 0x00000001 + 0x00000002 + 0x0000000e + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00a00000 + 0x00c80050 + 0x00c80000 + 0x005000a0 + 0x000000c8 + 0x00a000c8 + 0x00c80050 + 0x00c80000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00430000 + 0x0000001a + 0x001a0043 + 0x00430000 + 0x0000001a + 0x00010001 + 0x07000001 + 0x00000707 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00430000 + 0x0000001a + 0x001a0043 + 0x00430000 + 0x0000001a + 0x00010001 + 0x07000001 + 0x00000707 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000000 + 0x00000000 + 0x18151100 + 0x0000000c + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00032003 + 0x00480120 + 0x00000000 + 0x01200320 + 0x00000048 + 0x00032000 + 0x00480120 + 0x00000000 + 0x00280000 + 0x00280028 + 0x01010100 + 0x01000202 + 0x0a000002 + 0x01000f0f + 0x00000000 + 0x00000000 + 0x00010003 + 0x00000c03 + 0x00000100 + 0x00010000 + 0x01000000 + 0x00010000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x03030301 + 0x01010808 + 0x03030001 + 0x0a0a0a03 + 0x02080808 + 0x02050103 + 0x02050103 + 0x00050103 + 0x00020202 + 0x05020500 + 0x00020502 + 0x00000000 + 0x00000000 + 0x0d000001 + 0x00010028 + 0x00010000 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010100 + 0x01000000 + 0x00000001 + 0x00000303 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x00010300 + 0x03000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00ffff00 + 0x1e1e0000 + 0x0800001e + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x1850050a + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x1850050a + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x0202050a + 0x03030202 + 0x00000018 + 0x00000000 + 0x00000000 + 0x00001403 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030000 + 0x000e0020 + 0x000e0020 + 0x000e0020 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00070007 + 0x00050007 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000101 + 0x01010101 + 0x01000101 + 0x01000100 + 0x00010001 + 0x00010002 + 0x00020100 + 0x00000002 + 0x00000700 + 0x00000000 + 0x000030a0 + 0x00001850 + 0x000030a0 + 0x00001850 + 0x000030a0 + 0x18501850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00010000 + 0x00000007 + 0x81000001 + 0x0f0003f0 + 0x3fffffff + 0x0f0000a0 + 0x377ff000 + 0x0f000020 + 0x377ff000 + 0x0f000030 + 0x377ff000 + 0x0f0000b0 + 0x377ff000 + 0x0f000100 + 0x377ff000 + 0x0f000110 + 0x377ff000 + 0x0f000010 + 0x377ff000 + 0x03000101 + 0x042e2e2e + 0x06180006 + 0x00061800 + 0x00000018 + 0x0c2800a8 + 0x0c2800a8 + 0x0c2800a8 + 0x00000500 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04040000 + 0x0d000004 + 0x00000128 + 0x00000000 + 0x00030003 + 0x00000018 + 0x00000000 + 0x00000000 + 0x03060002 + 0x03010301 + 0x01080801 + 0x04020201 + 0x01080804 + 0x00000000 + 0x03030000 + 0x0a0a0a03 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030300 + 0x00000014 + 0x00000000 + 0x01010300 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000101 + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x0a0a0001 + 0x0505000a + 0x00000005 + 0x00000100 + 0x00030000 + 0x17030000 + 0x000e0020 + 0x000e0020 + 0x000e0020 + 0x00000000 + 0x00000000 + 0x00000100 + 0x140a0000 + 0x000a030a + 0x03000a03 + 0x010a000a + 0x00000100 + 0x01000000 + 0x00000000 + 0x00000100 + 0x1e1a0000 + 0x10010204 + 0x07070705 + 0x20000202 + 0x00201000 + 0x00201000 + 0x04041000 + 0x10100100 + 0x00010110 + 0x004b004a + 0x1a030000 + 0x0102041e + 0x34000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00004300 + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0043004d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0000434d + 0x0001001a + 0x004d4d07 + 0x001a0043 + 0x4d070001 + 0x0100004d + 0x00c800c8 + 0x060400c8 + 0x0c060f11 + 0x2200d890 + 0x0a0c2005 + 0x0f11060a + 0x00000c06 + 0x2200d890 + 0x0a0c2005 + 0x0f11060a + 0x00000c06 + 0x2200d890 + 0x0a0c2005 + 0x0200020a + 0x02000200 + 0x02000200 + 0x02000200 + 0x02000200 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000300 + 0x00185000 + 0x0000f320 + 0x00001850 + 0x0000f320 + 0x00001850 + 0x0000f320 + 0x08000000 + 0x00000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004c008 + 0x000000b3 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x00665555 + 0x00010f00 + 0x05010200 + 0x00000003 + 0x001700c0 + 0x00cc0101 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x08000000 + 0x0c00c007 + 0x00000100 + 0x00000100 + 0x55555555 + 0xaaaaaaaa + 0x55555555 + 0xaaaaaaaa + 0x00005555 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02700270 + 0x02700270 + 0x02700270 + 0x02700270 + 0x00000270 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00b30080 + 0x00000003 + 0x00000000 + 0x00020000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0013150 + 0x020000c0 + 0x00100001 + 0x07054208 + 0x000f0c18 + 0x01000140 + 0x00000c20 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00806420 + 0x00917531 + 0x00806420 + 0x01917531 + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x0a418820 + 0x103f0000 + 0x0000003f + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00008eca + 0x00009fdb + 0x00008eca + 0x01009fdb + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x0004a0e6 + 0x080f0000 + 0x0000000f + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00008eca + 0x00009fdb + 0x00008eca + 0x01009fdb + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x1ee6b16a + 0x10000000 + 0x00000000 + 0x00038055 + 0x03800380 + 0x03800380 + 0x00000380 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x01000005 + 0x04000f00 + 0x00020040 + 0x00020055 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000050 + 0x00000000 + 0x00010100 + 0x00000601 + 0x00000000 + 0x00006400 + 0x01221102 + 0x00000000 + 0x00051f00 + 0x051f051f + 0x051f051f + 0x00030003 + 0x03000300 + 0x00000300 + 0x01221102 + 0x00000000 + 0x00000000 + 0x03020000 + 0x00000001 + 0x00000011 + 0x00000011 + 0x00000400 + 0x00000000 + 0x00000011 + 0x00000011 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000011 + 0x00004410 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04000000 + 0x00000000 + 0x00000000 + 0x00000508 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0xe4000000 + 0x00000000 + 0x00000000 + 0x01010000 + 0x00000000 + >; +}; diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig new file mode 100644 index 00000000000..bb10ee9a435 --- /dev/null +++ b/configs/rock960-rk3399_defconfig @@ -0,0 +1,69 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_TARGET_ROCK960_RK3399=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_BAUDRATE=1500000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock960.dtb" +CONFIG_SYS_PROMPT="rock960 => " +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3399=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_ROCKCHIP_USB2_PHY=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
On 27 September 2018 at 12:03, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
- USB 2.0
- MMC
Changes in v3:
- Add config options for USB to Ethernet and USB2 PHY
Changes in v2:
- Added missing config options for USB/uSD
- Fixed the commit description for DDR speed
- USB 2.0
- MMC
Tested on a Rock960
Changes in v3:
Changes in v2:
chosen {
+&pcie0 {
+&pinctrl {
pcie {
rockchip,pins =
usb2 {
rockchip,pins =
+&vcc3v3_pcie {
+&vcc5v0_host {
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- (C) Copyright 2018 Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
+&dmc {
0x1
0xa
0x3
0x2
0x2
0x0
0xf
0xf
1
0x1d191519
0x14040808
0x00000002
0x00006226
0x00000054
0x00000000
0x1
0xa
0x3
0x2
0x2
0x0
0xf
0xf
1
0x1d191519
0x14040808
0x00000002
0x00006226
0x00000054
0x00000000
800
6
2
9
1
0x00000700
0x00000000
0x00000000
0x00000000
0x00000000
0x00000050
0x00027100
0x00000320
0x00001f40
0x00000050
0x00027100
0x00000320
0x00001f40
0x00000050
0x00027100
0x00000320
0x01001f40
0x00000000
0x00000101
0x00020100
0x000000a0
0x00000190
0x00000000
0x06180000
0x00061800
0x04000618
0x33080004
0x280f0622
0x22330800
0x00280f06
0x06223308
0x0600280f
0x00000a0a
0x0600dac0
0x0a0a060c
0x0600dac0
0x0a0a060c
0x0600dac0
0x0203000c
0x0f0c0f00
0x040c0f0c
0x14000a0a
0x03030a0a
0x00010003
0x031b1b1b
0x00111111
0x00000000
0x03010000
0x0c2800a8
0x0c2800a8
0x0c2800a8
0x00000000
0x00060006
0x00140006
0x00140014
0x000f0f0f
0x00000000
0x00000000
0x00000000
0x00b00000
0x00b000b0
0x00b000b0
0x000000b0
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000301
0x00000001
0x00000000
0x00000000
0x01000000
0x80104002
0x00040003
0x00040005
0x00030000
0x00050004
0x00000004
0x00040003
0x00040005
0x30a00000
0x00001850
0x185030a0
0x30a00000
0x00001850
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02020200
0x00020202
0x00030200
0x00040700
0x00000302
0x02000407
0x00000003
0x00030f04
0x00070004
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00010000
0x20040020
0x00200400
0x01000400
0x00000b80
0x00000000
0x00000001
0x00000002
0x0000000e
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00a00000
0x00c80050
0x00c80000
0x005000a0
0x000000c8
0x00a000c8
0x00c80050
0x00c80000
0x00000000
0x00000000
0x00000000
0x00430000
0x0000001a
0x001a0043
0x00430000
0x0000001a
0x00010001
0x07000001
0x00000707
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00430000
0x0000001a
0x001a0043
0x00430000
0x0000001a
0x00010001
0x07000001
0x00000707
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x01000000
0x00000000
0x00000000
0x18151100
0x0000000c
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00032003
0x00480120
0x00000000
0x01200320
0x00000048
0x00032000
0x00480120
0x00000000
0x00280000
0x00280028
0x01010100
0x01000202
0x0a000002
0x01000f0f
0x00000000
0x00000000
0x00010003
0x00000c03
0x00000100
0x00010000
0x01000000
0x00010000
0x00000001
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00010000
0x03030301
0x01010808
0x03030001
0x0a0a0a03
0x02080808
0x02050103
0x02050103
0x00050103
0x00020202
0x05020500
0x00020502
0x00000000
0x00000000
0x0d000001
0x00010028
0x00010000
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00010100
0x01000000
0x00000001
0x00000303
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x00010300
0x03000100
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00ffff00
0x1e1e0000
0x0800001e
0x00001850
0x00000200
0x00000200
0x00000200
0x00000200
0x00001850
0x0000f320
0x1850050a
0x00000200
0x00000200
0x00000200
0x00000200
0x00001850
0x0000f320
0x1850050a
0x00000200
0x00000200
0x00000200
0x00000200
0x00001850
0x0000f320
0x0202050a
0x03030202
0x00000018
0x00000000
0x00000000
0x00001403
0x00000000
0x00000000
0x00000000
0x00030000
0x000e0020
0x000e0020
0x000e0020
0x00000000
0x00000000
0x01000000
0x00070007
0x00050007
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x01000101
0x01010101
0x01000101
0x01000100
0x00010001
0x00010002
0x00020100
0x00000002
0x00000700
0x00000000
0x000030a0
0x00001850
0x000030a0
0x00001850
0x000030a0
0x18501850
0x00000200
0x00000200
0x00000200
0x00000200
0x00001850
0x00000200
0x00000200
0x00000200
0x00000200
0x00001850
0x00000200
0x00000200
0x00000200
0x00000200
0x00010000
0x00000007
0x81000001
0x0f0003f0
0x3fffffff
0x0f0000a0
0x377ff000
0x0f000020
0x377ff000
0x0f000030
0x377ff000
0x0f0000b0
0x377ff000
0x0f000100
0x377ff000
0x0f000110
0x377ff000
0x0f000010
0x377ff000
0x03000101
0x042e2e2e
0x06180006
0x00061800
0x00000018
0x0c2800a8
0x0c2800a8
0x0c2800a8
0x00000500
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04040000
0x0d000004
0x00000128
0x00000000
0x00030003
0x00000018
0x00000000
0x00000000
0x03060002
0x03010301
0x01080801
0x04020201
0x01080804
0x00000000
0x03030000
0x0a0a0a03
0x00000000
0x00000000
0x00000000
0x00030300
0x00000014
0x00000000
0x01010300
0x00000000
0x00000000
0x01000000
0x00000101
0x55555a5a
0x55555a5a
0x55555a5a
0x55555a5a
0x0a0a0001
0x0505000a
0x00000005
0x00000100
0x00030000
0x17030000
0x000e0020
0x000e0020
0x000e0020
0x00000000
0x00000000
0x00000100
0x140a0000
0x000a030a
0x03000a03
0x010a000a
0x00000100
0x01000000
0x00000000
0x00000100
0x1e1a0000
0x10010204
0x07070705
0x20000202
0x00201000
0x00201000
0x04041000
0x10100100
0x00010110
0x004b004a
0x1a030000
0x0102041e
0x34000000
0x00000000
0x00000000
0x00000000
0x00004300
0x0001001a
0x004d4d07
0x001a0043
0x4d070001
0x0000434d
0x0001001a
0x004d4d07
0x001a0043
0x4d070001
0x0000434d
0x0001001a
0x004d4d07
0x001a0043
0x4d070001
0x0043004d
0x0001001a
0x004d4d07
0x001a0043
0x4d070001
0x0000434d
0x0001001a
0x004d4d07
0x001a0043
0x4d070001
0x0000434d
0x0001001a
0x004d4d07
0x001a0043
0x4d070001
0x0100004d
0x00c800c8
0x060400c8
0x0c060f11
0x2200d890
0x0a0c2005
0x0f11060a
0x00000c06
0x2200d890
0x0a0c2005
0x0f11060a
0x00000c06
0x2200d890
0x0a0c2005
0x0200020a
0x02000200
0x02000200
0x02000200
0x02000200
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x01000300
0x00185000
0x0000f320
0x00001850
0x0000f320
0x00001850
0x0000f320
0x08000000
0x00000100
0x00000000
0x00000000
0x00000000
0x00000000
0x00000002
0x76543210
0x0004c008
0x000000b3
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x05010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00b30080
0x00000003
0x00000000
0x00020000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07054208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x76543210
0x0004c008
0x000000b3
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x05010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00b30080
0x00000003
0x00000000
0x00020000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07054208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x76543210
0x0004c008
0x000000b3
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x05010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00b30080
0x00000003
0x00000000
0x00020000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07054208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x76543210
0x0004c008
0x000000b3
0x00000000
0x00000000
0x00010000
0x01665555
0x00665555
0x00010f00
0x05010200
0x00000003
0x001700c0
0x00cc0101
0x00030066
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x04080000
0x04080400
0x08000000
0x0c00c007
0x00000100
0x00000100
0x55555555
0xaaaaaaaa
0x55555555
0xaaaaaaaa
0x00005555
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00200000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x02700270
0x02700270
0x02700270
0x02700270
0x00000270
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00800080
0x00b30080
0x00000003
0x00000000
0x00020000
0x00000200
0x00000000
0x51315152
0xc0013150
0x020000c0
0x00100001
0x07054208
0x000f0c18
0x01000140
0x00000c20
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000001
0x00000000
0x00000000
0x00000000
0x00400320
0x00000040
0x00806420
0x00917531
0x00806420
0x01917531
0x00020003
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x0a418820
0x103f0000
0x0000003f
0x00038055
0x03800380
0x03800380
0x00000380
0x42080010
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00800000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000001
0x00000000
0x00000000
0x00000000
0x00400320
0x00000040
0x00008eca
0x00009fdb
0x00008eca
0x01009fdb
0x00020003
0x00000000
0x00000000
0x00000000
0x000556aa
0x000aaaaa
0x000aa955
0x00055555
0x000b3133
0x0004cd33
0x0004cecc
0x000b32cc
0x0004a0e6
0x080f0000
0x0000000f
0x00038055
0x03800380
0x03800380
0x00000380
0x42080010
0x00000003
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
- USB 2.0
- MMC
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com
Changes in v3:
Changes in v2:
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
- USB 2.0
- MMC
Changes in v3:
Changes in v2:
What's the status of this series?
Thanks, Eze
- USB 2.0
- MMC
Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v3:
Changes in v2:
Applied to u-boot-rockchip, thanks!
Add board support for Ficus EE board from Vamrs. This board utilizes common Rock960 family support.
Following peripherals are tested and known to work: * Gigabit Ethernet * USB 2.0 * MMC
Signed-off-by: Ezequiel Garcia ezequiel@collabora.com [Reworked based on common Rock960 family support] Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org ---
Changes in v3: Modified the DRAM config header from LPDDR3 to DDR3
Changes in v2: None
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-ficus.dts | 78 ++++++++++++++++++++++++++++++++++ configs/ficus-rk3399_defconfig | 71 +++++++++++++++++++++++++++++++ 3 files changed, 150 insertions(+) create mode 100644 arch/arm/dts/rk3399-ficus.dts create mode 100644 configs/ficus-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9b891826b73..e2bd9822aa2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -42,6 +42,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-veyron-minnie.dtb \ rk3288-vyasa.dtb \ rk3328-evb.dtb \ + rk3399-ficus.dtb \ rk3368-lion.dtb \ rk3368-sheep.dtb \ rk3368-geekbox.dtb \ diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts new file mode 100644 index 00000000000..4af0e4e3834 --- /dev/null +++ b/arch/arm/dts/rk3399-ficus.dts @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd. + * + * Schematics available at https://dl.vamrs.com/products/ficus/docs/hw + */ + +/dts-v1/; +#include "rk3399-rock960.dtsi" +#include "rk3399-sdram-ddr3-1600.dtsi" + +/ { + model = "96boards RK3399 Ficus"; + compatible = "vamrs,ficus", "rockchip,rk3399"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; + + clkin_gmac: external-gmac-clock { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "clkin_gmac"; + #clock-cells = <0>; + }; +}; + +&gmac { + assigned-clocks = <&cru SCLK_RMII_SRC>; + assigned-clock-parents = <&clkin_gmac>; + clock_in_out = "input"; + phy-supply = <&vcc3v3_sys>; + phy-mode = "rgmii"; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 10000 50000>; + tx_delay = <0x28>; + rx_delay = <0x11>; + status = "okay"; +}; + +&pcie0 { + ep-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>; +}; + +&pinctrl { + gmac { + rgmii_sleep_pins: rgmii-sleep-pins { + rockchip,pins = + <3 15 RK_FUNC_GPIO &pcfg_output_low>; + }; + }; + + pcie { + pcie_drv: pcie-drv { + rockchip,pins = + <1 24 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb2 { + host_vbus_drv: host-vbus-drv { + rockchip,pins = + <4 27 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&vcc3v3_pcie { + gpio = <&gpio1 24 GPIO_ACTIVE_HIGH>; +}; + +&vcc5v0_host { + gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>; +}; diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig new file mode 100644 index 00000000000..e890bc25238 --- /dev/null +++ b/configs/ficus-rk3399_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_ROCK960_RK3399=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x4000 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEFAULT_DEVICE_TREE="rk3399-ficus" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-rockchip/make_fit_atf.py" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 +CONFIG_SPL_ATF=y +CONFIG_SPL_ATF_NO_PLATFORM_PARAM=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3399=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
- Gigabit Ethernet
- USB 2.0
- MMC
Changes in v2: None
- Gigabit Ethernet
- USB 2.0
- MMC
Signed-off-by: Ezequiel Garcia ezequiel@collabora.com [Reworked based on common Rock960 family support] Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Simon Glass sjg@chromium.org
Changes in v2: None
- Gigabit Ethernet
- USB 2.0
- MMC
Changes in v2: None
Two months have passed... guys, what's the problem with this series?
Regards, Ezequiel
Peter (Robinson) already asked: I had lost this series one during a rebase screw-up and will send out the PR as soon as it’s through Travis-CI.
Thanks, Philipp.
- Gigabit Ethernet
- USB 2.0
- MMC
Changes in v2: None
Regards, Ezequiel
Thanks for the quick reply.
Should you need anything from me or Mani, please let us know.
Thanks! Eze
Ezequiel,
After sorting my git tree out, this is now waiting for a USB fix to be either waved through by Marek (so I can apply it) or being applied by Marek. The series does not pass Travis without this (and I darkly remember that I ran into the same issue about 5 weeks back)…
It’s on u-boot-rockchip/master (together with the USB change), but I can’t send out the PR until the USB side is sorted.
Cheers, Philipp.
- Gigabit Ethernet
- USB 2.0
- MMC
Signed-off-by: Ezequiel Garcia ezequiel@collabora.com [Reworked based on common Rock960 family support] Signed-off-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v2: None
On 27/09/2018 21:02, Manivannan Sadhasivam wrote:
This patchset adds support for Rock960 and Ficus 96Boards from Vamrs. Since both boards share most of the configurations, a common Rock960 family support is added with common support and the actual boards are based on this.
The previous version of the patchseries were adding Rock960 [1] and Ficus [2] board support individually, but this series fuses them together based on the common board support as per Linux kernel.
[1] https://patchwork.ozlabs.org/cover/963239/ [2] https://lists.denx.de/pipermail/u-boot/2018-August/339059.html
This patchseries has been tested on Rock960 v1.2 board and expecting Ezequiel to do the testing for Ficus.
PS: I have explicitly removed the previous Ack's for the Ficus board since there has been a heavy modification done on these patches.
With this series I was able to boot the rock960 board (4GB/32GB) and tftp load a kernel following the instructions given in the documentation.
Tested-by: Daniel Lezcano daniel.lezcano@linaro.org
Manivannan Sadhasivam (4): arm: dts: rockchip: add some common pin-settings to rk3399 rockchip: rk3399: Add common Rock960 family from Vamrs rockchip: rk3399: Add Rock960 CE board support rockchip: rk3399: Add Ficus EE board support
arch/arm/dts/Makefile | 2 + arch/arm/dts/rk3399-ficus.dts | 78 + arch/arm/dts/rk3399-rock960.dts | 45 + arch/arm/dts/rk3399-rock960.dtsi | 506 ++++++ .../arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi | 1536 +++++++++++++++++ arch/arm/dts/rk3399.dtsi | 55 +- arch/arm/mach-rockchip/rk3399/Kconfig | 26 + board/vamrs/rock960_rk3399/Kconfig | 15 + board/vamrs/rock960_rk3399/MAINTAINERS | 6 + board/vamrs/rock960_rk3399/Makefile | 6 + board/vamrs/rock960_rk3399/README | 152 ++ board/vamrs/rock960_rk3399/rock960-rk3399.c | 50 + configs/ficus-rk3399_defconfig | 71 + configs/rock960-rk3399_defconfig | 69 + include/configs/rock960_rk3399.h | 15 + 15 files changed, 2626 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3399-ficus.dts create mode 100644 arch/arm/dts/rk3399-rock960.dts create mode 100644 arch/arm/dts/rk3399-rock960.dtsi create mode 100644 arch/arm/dts/rk3399-sdram-lpddr3-2GB-1600.dtsi create mode 100644 board/vamrs/rock960_rk3399/Kconfig create mode 100644 board/vamrs/rock960_rk3399/MAINTAINERS create mode 100644 board/vamrs/rock960_rk3399/Makefile create mode 100644 board/vamrs/rock960_rk3399/README create mode 100644 board/vamrs/rock960_rk3399/rock960-rk3399.c create mode 100644 configs/ficus-rk3399_defconfig create mode 100644 configs/rock960-rk3399_defconfig create mode 100644 include/configs/rock960_rk3399.h
Thanks, Mani
Is there any update on this patchset? AFAIK everyone is happy to get this merged!
Thanks, Mani
-- 2.17.1
On 26.10.2018, at 19:17, Manivannan Sadhasivam manivannan.sadhasivam@linaro.org wrote:
Thanks, Mani
It’s on pretty high up my list for the next merge window, but I didn’t get it into the current version.
Thanks, Philipp.
Thanks, Mani
-- 2.17.1
Thanks, Mani
So there goes another merge window. Any progress here?
Alex
Thanks, Mani
It’s on u-boot-rockchip/master, but waiting for a USB change to be merged for the PR. Surprisingly it failed in Travis-CI for the Rock960 board…
Thanks, Philipp.
On 06.12.2018, at 15:57, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
On 06.12.2018, at 08:53, Alexander Graf <agraf@suse.de mailto:agraf@suse.de> wrote:
On 26.10.2018, at 19:17, Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org mailto:manivannan.sadhasivam@linaro.org> wrote:
[1] https://patchwork.ozlabs.org/cover/963239/ https://patchwork.ozlabs.org/cover/963239/ [2] https://lists.denx.de/pipermail/u-boot/2018-August/339059.html https://lists.denx.de/pipermail/u-boot/2018-August/339059.html
Thanks, Mani
And I just saw Marek’s mail in my backlog from last night, so I can indeed send out the PR now.
Thanks, Mani
So, I'm going to call out here that this new board is entirely missing a MAINTAINERS file. Causing ./tools/genboardscfg.py to complain about new defconfigs without a MAINTAINER. I'm gonna fix it now, but, grumble. I know checkpatch.pl does complain "Hey, new file, do you need to update MAINTAINERS" from Linux.
Thanks, Mani
Hi Tom,
Sorry for that! It was my bad to left MAINTAINERS entry for Ficus board. Since there are two boards (Rock960 and Ficus) sharing common board support, I forgot to update the later one.
Regards, Mani
-- Tom
Thanks, Mani
Hi Tom,
Not a huge problem, really. I've now become motivated enough to write a .travis.yml test for this problem and thus pushing the problem visibly up the chain like I should have months ago :)
participants (8)
Alexander Graf
Daniel Lezcano
Ezequiel Garcia
Peter Robinson
Philipp Tomsich
