[U-Boot] [PATCH v2] CPCI750: Add CPCI-HD/2 support
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750. As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3, the device must be swaped. Signed-off-by: Reinhard Arlt reinhard.arlt@esd.eu
diff --git a/board/esd/cpci750/ide.c b/board/esd/cpci750/ide.c index a3bd1b7..aa001df 100644 --- a/board/esd/cpci750/ide.c +++ b/board/esd/cpci750/ide.c @@ -31,6 +31,18 @@ #include <pci.h>
extern ulong ide_bus_offset[CONFIG_SYS_IDE_MAXBUS]; +int cpci_hd_type; + +int ata_device(int dev) +{ + int retval; + + retval = (dev & 1) << 4; + if (cpci_hd_type == 2) + retval ^= 1 << 4; + return retval; +} +
int ide_preinit (void) { @@ -39,14 +51,21 @@ int ide_preinit (void) int l;
status = 1; + cpci_hd_type = 0; if (CPCI750_SLAVE_TEST != 0) return status; for (l = 0; l < CONFIG_SYS_IDE_MAXBUS; l++) { ide_bus_offset[l] = -ATA_STATUS; } devbusfn = pci_find_device (0x1103, 0x0004, 0); - if (devbusfn == -1) + if (devbusfn != -1) { + cpci_hd_type = 1; + } else { devbusfn = pci_find_device (0x1095, 0x3114, 0); + if (devbusfn != -1) { + cpci_hd_type = 2; + } + } if (devbusfn != -1) { ulong *ide_bus_offset_ptr;
diff --git a/include/ata.h b/include/ata.h index b51475d..3b2d737 100644 --- a/include/ata.h +++ b/include/ata.h @@ -82,7 +82,9 @@ /* * Device / Head Register Bits */ +#ifndef ATA_DEVICE #define ATA_DEVICE(x) ((x & 1)<<4) +#endif /* ATA_DEVICE */ #define ATA_LBA 0xE0
/* diff --git a/include/configs/CPCI750.h b/include/configs/CPCI750.h index d735e61..a6af86c 100644 --- a/include/configs/CPCI750.h +++ b/include/configs/CPCI750.h @@ -187,6 +187,8 @@ #define CONFIG_SYS_I2C_MULTI_EEPROMS #define CONFIG_SYS_I2C_SPEED 80000 /* I2C speed default */
+#define CONFIG_PRAM 0 + #define CONFIG_SYS_GT_DUAL_CPU /* also for JTAG even with one cpu */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ @@ -241,11 +243,6 @@
#define CONFIG_SYS_TCLK 133000000
-/*#define CONFIG_SYS_750FX_HID0 0x8000c084*/ -#define CONFIG_SYS_750FX_HID0 0x80008484 -#define CONFIG_SYS_750FX_HID1 0x54800000 -#define CONFIG_SYS_750FX_HID2 0x00000000 - /* * Low Level Configuration Settings * (address mappings, register initial values, etc.) @@ -457,7 +454,11 @@ #define CONFIG_SYS_ATA_DATA_OFFSET 0x0000 /* Offset for data I/O */ #define CONFIG_SYS_ATA_REG_OFFSET 0x0000 /* Offset for normal register accesses */ #define CONFIG_SYS_ATA_ALT_OFFSET 0x0000 /* Offset for alternate registers */ - +#ifndef __ASSEMBLY__ +int ata_device(int dev); +#endif +#define ATA_DEVICE(dev) ata_device(dev) +#define CONFIG_ATAPI 1
/*---------------------------------------------------------------------- * Initial BAT mappings @@ -497,8 +498,8 @@ * IBAT4 and DBAT4 * FIXME: ingo disable BATs for Linux Kernel */ -#undef SETUP_HIGH_BATS_FX750 /* don't initialize BATS 4-7 */ -/*#define SETUP_HIGH_BATS_FX750*/ /* initialize BATS 4-7 */ +/* #undef SETUP_HIGH_BATS_FX750 */ /* don't initialize BATS 4-7 */ +#define SETUP_HIGH_BATS_FX750 /* initialize BATS 4-7 */
#ifdef SETUP_HIGH_BATS_FX750 #define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM1_BASE | BATL_PP_RW | BATL_CACHEINHIBIT) @@ -622,4 +623,6 @@ #define CPCI750_ECC_TEST (((in8(0xf0300000) & 0x02) == 0) ? 1 : 0) #define CONFIG_SYS_PLD_VER 0xf0e00000
+#define CONFIG_OF_LIBFDT 1 + #endif /* __CONFIG_H */
Dear Reinhard Arlt,
Applied, thanks.
Reinhard Arlt
