[U-Boot] [PATCH 1/5] atmel_lcdfb: Eliminate unneeded #include <asm/arch/hardware.h>
atmel_lcdfb doesn't actually need anything from asm/arch/hardware.h. It includes a file that does, asm/arch/gpio.h, but this file doesn't include <asm/arch/hardware.h> like it's supposed to.
Add the missing include to asm/arch/gpio.h and remove the workaround from the atmel_lcdfb driver. This makes the driver compile on avr32.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- drivers/video/atmel_lcdfb.c | 1 - include/asm-arm/arch-at91/gpio.h | 1 + 2 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c index b332a82..7f0dceb 100644 --- a/drivers/video/atmel_lcdfb.c +++ b/drivers/video/atmel_lcdfb.c @@ -24,7 +24,6 @@
#include <common.h> #include <asm/io.h> -#include <asm/arch/hardware.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> diff --git a/include/asm-arm/arch-at91/gpio.h b/include/asm-arm/arch-at91/gpio.h index c4d7b97..e2d375b 100644 --- a/include/asm-arm/arch-at91/gpio.h +++ b/include/asm-arm/arch-at91/gpio.h @@ -16,6 +16,7 @@ #include <asm/io.h> #include <asm/errno.h> #include <asm/arch/at91_pio.h> +#include <asm/arch/hardware.h>
#define PIN_BASE 32
If the board _didn't_ request INVLINE_INVERTED, we set INVLINE_INVERTED, otherwise we don't. WTF?
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- drivers/video/atmel_lcdfb.c | 5 +---- 1 files changed, 1 insertions(+), 4 deletions(-)
diff --git a/drivers/video/atmel_lcdfb.c b/drivers/video/atmel_lcdfb.c index 7f0dceb..3a51cc7 100644 --- a/drivers/video/atmel_lcdfb.c +++ b/drivers/video/atmel_lcdfb.c @@ -107,10 +107,7 @@ void lcd_ctrl_init(void *lcdbase) if (panel_info.vl_tft) value |= ATMEL_LCDC_DISTYPE_TFT;
- if (!(panel_info.vl_sync & ATMEL_LCDC_INVLINE_INVERTED)) - value |= ATMEL_LCDC_INVLINE_INVERTED; - if (!(panel_info.vl_sync & ATMEL_LCDC_INVFRAME_INVERTED)) - value |= ATMEL_LCDC_INVFRAME_INVERTED; + value |= panel_info.vl_sync; value |= (panel_info.vl_bpix << 5); lcdc_writel(panel_info.mmio, ATMEL_LCDC_LCDCON2, value);
lcd_printf() has a prototype in include/lcd.h but no implementation. Fix this by borrowing the lcd_printf() implementation from the cogent board code (which appears to use its own LCD framework.)
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- common/lcd.c | 14 ++++++++++++++ 1 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 25f8664..82e557e 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -225,6 +225,20 @@ void lcd_puts (const char *s) } }
+/*----------------------------------------------------------------------*/ + +void lcd_printf(const char *fmt, ...) +{ + va_list args; + char buf[CFG_PBSIZE]; + + va_start(args, fmt); + vsprintf(buf, fmt, args); + va_end(args); + + lcd_puts(buf); +} + /************************************************************************/ /* ** Low-Level Graphics Routines */ /************************************************************************/
This allows the logo/info rendering routines to use the regular lcd_putc/lcd_puts/lcd_printf calls.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- common/lcd.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 82e557e..6ad2133 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -440,6 +440,7 @@ static int lcd_init (void *lcdbase) debug ("[LCD] Initializing LCD frambuffer at %p\n", lcdbase);
lcd_ctrl_init (lcdbase); + lcd_is_enabled = 1; lcd_clear (NULL, 1, 1, NULL); /* dummy args */ lcd_enable ();
@@ -450,7 +451,6 @@ static int lcd_init (void *lcdbase) #else console_row = 1; /* leave 1 blank line below logo */ #endif - lcd_is_enabled = 1;
return 0; }
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery.
Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult.
Signed-off-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com --- board/atmel/at91cap9adk/at91cap9adk.c | 29 ++++++++++ board/atmel/at91sam9261ek/at91sam9261ek.c | 29 ++++++++++ board/atmel/at91sam9263ek/at91sam9263ek.c | 29 ++++++++++ board/atmel/at91sam9rlek/at91sam9rlek.c | 29 ++++++++++ board/lwmon/lwmon.c | 29 ++++++++++ board/tqc/tqm8xx/tqm8xx.c | 26 +++++++++ common/lcd.c | 84 ++--------------------------- include/lcd.h | 2 + 8 files changed, 178 insertions(+), 79 deletions(-)
diff --git a/board/atmel/at91cap9adk/at91cap9adk.c b/board/atmel/at91cap9adk/at91cap9adk.c index c5082a0..31f468a 100644 --- a/board/atmel/at91cap9adk/at91cap9adk.c +++ b/board/atmel/at91cap9adk/at91cap9adk.c @@ -324,6 +324,35 @@ static void at91cap9_lcd_hw_init(void)
gd->fb_base = 0; } + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf ("%s\n", U_BOOT_VERSION); + lcd_printf ("(C) 2008 ATMEL Corp\n"); + lcd_printf ("at91support@atmel.com\n"); + lcd_printf ("%s CPU at %s MHz\n", + AT91_CPU_NAME, + strmhz(temp, AT91_MAIN_CLOCK)); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CFG_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20 ); +} +#endif /* CONFIG_LCD_INFO */ #endif
int board_init(void) diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 647aab5..5a48ee4 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -209,6 +209,35 @@ static void at91sam9261ek_lcd_hw_init(void)
gd->fb_base = AT91SAM9261_SRAM_BASE; } + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf ("%s\n", U_BOOT_VERSION); + lcd_printf ("(C) 2008 ATMEL Corp\n"); + lcd_printf ("at91support@atmel.com\n"); + lcd_printf ("%s CPU at %s MHz\n", + AT91_CPU_NAME, + strmhz(temp, AT91_MAIN_CLOCK)); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CFG_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20 ); +} +#endif /* CONFIG_LCD_INFO */ #endif
int board_init(void) diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 927fc91..84db2c5 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -258,6 +258,35 @@ static void at91sam9263ek_lcd_hw_init(void)
gd->fb_base = AT91SAM9263_SRAM0_BASE; } + +#ifdef CONFIG_LCD_INFO +#include <nand.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + ulong dram_size, nand_size; + int i; + char temp[32]; + + lcd_printf ("%s\n", U_BOOT_VERSION); + lcd_printf ("(C) 2008 ATMEL Corp\n"); + lcd_printf ("at91support@atmel.com\n"); + lcd_printf ("%s CPU at %s MHz\n", + AT91_CPU_NAME, + strmhz(temp, AT91_MAIN_CLOCK)); + + dram_size = 0; + for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) + dram_size += gd->bd->bi_dram[i].size; + nand_size = 0; + for (i = 0; i < CFG_MAX_NAND_DEVICE; i++) + nand_size += nand_info[i].size; + lcd_printf (" %ld MB SDRAM, %ld MB NAND\n", + dram_size >> 20, + nand_size >> 20 ); +} +#endif /* CONFIG_LCD_INFO */ #endif
int board_init(void) diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index 509e7c3..22115e5 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -181,6 +181,35 @@ static void at91sam9rlek_lcd_hw_init(void)
diff --git a/board/lwmon/lwmon.c b/board/lwmon/lwmon.c index 4a2d8e4..695eddd 100644 --- a/board/lwmon/lwmon.c +++ b/board/lwmon/lwmon.c @@ -759,6 +759,35 @@ static uchar *key_match (uchar *kbd_data) } #endif /* CONFIG_PREBOOT */
+#ifdef CONFIG_LCD_INFO +#include <lcd.h> +#include <version.h> + +void lcd_show_board_info(void) +{ + char temp[32]; + + lcd_printf ("%s (%s - %s)\n", U_BOOT_VERSION, __DATE__, __TIME__); + lcd_printf ("(C) 2008 DENX Software Engineering GmbH\n"); + lcd_printf (" Wolfgang DENK, wd@denx.de\n"); +#ifdef CONFIG_LCD_INFO_BELOW_LOGO + lcd_printf ("MPC823 CPU at %s MHz\n", + strmhz(temp, gd->cpu_clk)); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 3, + info, strlen(info)); + lcd_printf (" %ld MB RAM, %ld MB Flash\n", + gd->ram_size >> 20, + gd->bd->bi_flashsize >> 20 ); +#else + /* leave one blank line */ + lcd_printf ("\nMPC823 CPU at %s MHz, %ld MB RAM, %ld MB Flash\n", + strmhz(temp, gd->cpu_clk), + gd->ram_size >> 20, + gd->bd->bi_flashsize >> 20 ); +#endif /* CONFIG_LCD_INFO_BELOW_LOGO */ +} +#endif /* CONFIG_LCD_INFO */ + /*---------------Board Special Commands: PIC read/write ---------------*/
#if defined(CONFIG_CMD_BSP) diff --git a/board/tqc/tqm8xx/tqm8xx.c b/board/tqc/tqm8xx/tqm8xx.c index 96b6103..ea89d5a 100644 --- a/board/tqc/tqm8xx/tqm8xx.c +++ b/board/tqc/tqm8xx/tqm8xx.c @@ -504,6 +504,32 @@ int misc_init_r (void) } #endif /* CONFIG_NSCU */
+#ifdef CONFIG_LCD_INFO +#include <lcd.h> + +void lcd_show_board_info(void) +{ + lcd_printf ("%s (%s - %s)\n", U_BOOT_VERSION, __DATE__, __TIME__); + lcd_printf ("(C) 2008 DENX Software Engineering GmbH\n"); + lcd_printf (" Wolfgang DENK, wd@denx.de\n"); +#ifdef CONFIG_LCD_INFO_BELOW_LOGO + lcd_printf ("MPC823 CPU at %s MHz\n", + strmhz(temp, gd->cpu_clk)); + lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 3, + info, strlen(info)); + lcd_printf (" %ld MB RAM, %ld MB Flash\n", + gd->ram_size >> 20, + gd->bd->bi_flashsize >> 20 ); +#else + /* leave one blank line */ + lcd_printf ("\nMPC823 CPU at %s MHz, %ld MB RAM, %ld MB Flash\n", + strmhz(temp, gd->cpu_clk), + gd->ram_size >> 20, + gd->bd->bi_flashsize >> 20 ); +#endif /* CONFIG_LCD_INFO_BELOW_LOGO */ +} +#endif /* CONFIG_LCD_INFO */ + /* ---------------------------------------------------------------------------- */ /* TK885D specific initializaion */ /* ---------------------------------------------------------------------------- */ diff --git a/common/lcd.c b/common/lcd.c index 6ad2133..c97e5a4 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -52,7 +52,6 @@
#if defined(CONFIG_ATMEL_LCD) #include <atmel_lcdc.h> -#include <nand.h> #endif
/************************************************************************/ @@ -762,15 +761,6 @@ extern bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp);
static void *lcd_logo (void) { -#ifdef CONFIG_LCD_INFO - char info[80]; - char temp[32]; -#ifdef CONFIG_ATMEL_LCD - int i; - ulong dram_size, nand_size; -#endif -#endif /* CONFIG_LCD_INFO */ - #ifdef CONFIG_SPLASH_SCREEN char *s; ulong addr; @@ -800,75 +790,11 @@ static void *lcd_logo (void) bitmap_plot (0, 0); #endif /* CONFIG_LCD_LOGO */
-#ifdef CONFIG_MPC823 -# ifdef CONFIG_LCD_INFO - sprintf (info, "%s (%s - %s) ", U_BOOT_VERSION, __DATE__, __TIME__); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y, (uchar *)info, strlen(info)); - - sprintf (info, "(C) 2008 DENX Software Engineering GmbH"); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT, - (uchar *)info, strlen(info)); - - sprintf (info, " Wolfgang DENK, wd@denx.de"); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 2, - (uchar *)info, strlen(info)); -# ifdef CONFIG_LCD_INFO_BELOW_LOGO - sprintf (info, "MPC823 CPU at %s MHz", - strmhz(temp, gd->cpu_clk)); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 3, - info, strlen(info)); - sprintf (info, " %ld MB RAM, %ld MB Flash", - gd->ram_size >> 20, - gd->bd->bi_flashsize >> 20 ); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 4, - info, strlen(info)); -# else - /* leave one blank line */ - - sprintf (info, "MPC823 CPU at %s MHz, %ld MB RAM, %ld MB Flash", - strmhz(temp, gd->cpu_clk), - gd->ram_size >> 20, - gd->bd->bi_flashsize >> 20 ); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 4, - (uchar *)info, strlen(info)); - -# endif /* CONFIG_LCD_INFO_BELOW_LOGO */ -# endif /* CONFIG_LCD_INFO */ -#endif /* CONFIG_MPC823 */ - -#ifdef CONFIG_ATMEL_LCD -# ifdef CONFIG_LCD_INFO - sprintf (info, "%s", U_BOOT_VERSION); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y, (uchar *)info, strlen(info)); - - sprintf (info, "(C) 2008 ATMEL Corp"); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT, - (uchar *)info, strlen(info)); - - sprintf (info, "at91support@atmel.com"); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 2, - (uchar *)info, strlen(info)); - - sprintf (info, "%s CPU at %s MHz", - AT91_CPU_NAME, - strmhz(temp, AT91_MAIN_CLOCK)); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 3, - (uchar *)info, strlen(info)); - - dram_size = 0; - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) - dram_size += gd->bd->bi_dram[i].size; - nand_size = 0; - for (i = 0; i < CFG_MAX_NAND_DEVICE; i++) - nand_size += nand_info[i].size; - sprintf (info, " %ld MB SDRAM, %ld MB NAND", - dram_size >> 20, - nand_size >> 20 ); - lcd_drawchars (LCD_INFO_X, LCD_INFO_Y + VIDEO_FONT_HEIGHT * 4, - (uchar *)info, strlen(info)); -# endif /* CONFIG_LCD_INFO */ -#endif /* CONFIG_ATMEL_LCD */ - +#ifdef CONFIG_LCD_INFO + console_col = LCD_INFO_X / VIDEO_FONT_WIDTH; + console_row = LCD_INFO_Y / VIDEO_FONT_HEIGHT; + lcd_show_board_info(); +#endif /* CONFIG_LCD_INFO */
#if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) return ((void *)((ulong)lcd_base + BMP_LOGO_HEIGHT * lcd_line_length)); diff --git a/include/lcd.h b/include/lcd.h index 44ac8ef..ead9e1d 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -197,6 +197,8 @@ void lcd_putc (const char c); void lcd_puts (const char *s); void lcd_printf (const char *fmt, ...);
+/* Allow boards to customize the information displayed */ +void lcd_show_board_info(void);
/************************************************************************/ /* ** BITMAP DISPLAY SUPPORT */
Jean-Christophe, you ACKed this patch in http://lists.denx.de/pipermail/u-boot/2008-October/042389.html.
Should it go through u-boot-video repository or do you intend to pick it up?
Note that it needs some fixes: s/CFG_MAX_NAND_DEVICE/CONFIG_SYS_MAX_NAND_DEVICE
Best regards, Anatolij
Apply it I'll pull your tree when you've done
Best Regards, J.
Applied to u-boot-video/master repo. Thanks!
Also fixed by s/CFG_MAX_NAND_DEVICE/CONFIG_SYS_MAX_NAND_DEVICE as it is needed since commit 6d0f6bcf337c5261c08fabe12982178c2c489d76.
Applied to u-boot-video/master repo. Thanks.
Also fixed it by s/CFG_PBSIZE/CONFIG_SYS_PBSIZE as it is needed since commit 6d0f6bcf337c5261c08fabe12982178c2c489d76.
Dear Anatolij Gustschin,
Can you please send a pull request for u-boot-video soon?
Thanks in advance.
Hi Haavard,
- value |= panel_info.vl_sync;
What about
value |= panel_info.vl_sync & (ATMEL_LCDC_INVLINE_INVERTED | ATMEL_LCDC_INVFRAME_INVERTED);
[break lines where convenient] Apart from this being the formal equivalent to the original code, this would make it more clear what can go in, no?
Cheers Detlev
Detlev Zundel dzu@denx.de wrote:
What about
Well, there's also INVVD, INVCLK and INVDVAL which the original code doesn't care about at all. I'm not sure if all of them are suitable for the vl_sync field, but perhaps the field should be renamed.
In Linux, there's just a default_lcdcon2 field which the board code can use to set any flags it wants. I'm not sure if the driver should really bother too much about those flags anyway -- almost all of them depend on the type of display, how it's hooked up, etc.
Haavard
Applied to u-boot-video repository. Thanks.
Jean-Christophe ACKed this in
so I'm going to push it through u-boot-video repo.
participants (5)
Anatolij Gustschin
Detlev Zundel
Haavard Skinnemoen
Jean-Christophe PLAGNIOL-VILLARD
