[U-Boot] [PATCH v2] video: Armada XP: Move driver to DM_VIDEO
This patch moves the Armada XP video / LCD driver to DM_VIDEO. With this move, the legacy interface board_video_init() is removed from the theadorable board code (only user of this video driver). The support via DT will be added in a separate patch.
This patch also enables DM_VIDEO for the theadorable board, as this is needed to not break git bisect'ability.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Anatolij Gustschin agust@denx.de --- v2: - Add DM_VIDEO in theadorable_debug_defconfig in this patch
arch/arm/mach-mvebu/include/mach/cpu.h | 12 - board/theadorable/theadorable.c | 16 -- configs/theadorable_debug_defconfig | 3 +- drivers/video/mvebu_lcd.c | 321 +++++++++++++++---------- 4 files changed, 193 insertions(+), 159 deletions(-)
diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index 85d7dd1610..9e23043a48 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -158,18 +158,6 @@ int serdes_phy_config(void); */ int ddr3_init(void);
-struct mvebu_lcd_info { - u32 fb_base; - int x_res; - int y_res; - int x_fp; /* frontporch */ - int y_fp; - int x_bp; /* backporch */ - int y_bp; -}; - -int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info); - /* * get_ref_clk * diff --git a/board/theadorable/theadorable.c b/board/theadorable/theadorable.c index 1169d67746..acd46b0026 100644 --- a/board/theadorable/theadorable.c +++ b/board/theadorable/theadorable.c @@ -222,22 +222,6 @@ int board_eth_init(bd_t *bis) } #endif
-int board_video_init(void) -{ - struct mvebu_lcd_info lcd_info; - - /* Reserved memory area via CONFIG_SYS_MEM_TOP_HIDE */ - lcd_info.fb_base = gd->ram_size; - lcd_info.x_res = 240; - lcd_info.x_fp = 1; - lcd_info.x_bp = 45; - lcd_info.y_res = 320; - lcd_info.y_fp = 1; - lcd_info.y_bp = 3; - - return mvebu_lcd_register_init(&lcd_info); -} - #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index ac6dfd6844..a7d02e957a 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -71,6 +71,5 @@ CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_DM_VIDEO=y CONFIG_VIDEO_MVEBU=y -CONFIG_VIDEO=y -# CONFIG_VIDEO_SW_CURSOR is not set diff --git a/drivers/video/mvebu_lcd.c b/drivers/video/mvebu_lcd.c index 5bf0d01faa..dc6254514a 100644 --- a/drivers/video/mvebu_lcd.c +++ b/drivers/video/mvebu_lcd.c @@ -6,74 +6,96 @@ */
#include <common.h> -#include <video_fb.h> +#include <dm.h> +#include <video.h> #include <linux/mbus.h> #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h>
-#define MVEBU_LCD_WIN_CONTROL(w) (MVEBU_LCD_BASE + 0xf000 + ((w) << 4)) -#define MVEBU_LCD_WIN_BASE(w) (MVEBU_LCD_BASE + 0xf004 + ((w) << 4)) -#define MVEBU_LCD_WIN_REMAP(w) (MVEBU_LCD_BASE + 0xf00c + ((w) << 4)) - -#define MVEBU_LCD_CFG_DMA_START_ADDR_0 (MVEBU_LCD_BASE + 0x00cc) -#define MVEBU_LCD_CFG_DMA_START_ADDR_1 (MVEBU_LCD_BASE + 0x00dc) - -#define MVEBU_LCD_CFG_GRA_START_ADDR0 (MVEBU_LCD_BASE + 0x00f4) -#define MVEBU_LCD_CFG_GRA_START_ADDR1 (MVEBU_LCD_BASE + 0x00f8) -#define MVEBU_LCD_CFG_GRA_PITCH (MVEBU_LCD_BASE + 0x00fc) -#define MVEBU_LCD_SPU_GRA_OVSA_HPXL_VLN (MVEBU_LCD_BASE + 0x0100) -#define MVEBU_LCD_SPU_GRA_HPXL_VLN (MVEBU_LCD_BASE + 0x0104) -#define MVEBU_LCD_SPU_GZM_HPXL_VLN (MVEBU_LCD_BASE + 0x0108) -#define MVEBU_LCD_SPU_HWC_OVSA_HPXL_VLN (MVEBU_LCD_BASE + 0x010c) -#define MVEBU_LCD_SPU_HWC_HPXL_VLN (MVEBU_LCD_BASE + 0x0110) -#define MVEBU_LCD_SPUT_V_H_TOTAL (MVEBU_LCD_BASE + 0x0114) -#define MVEBU_LCD_SPU_V_H_ACTIVE (MVEBU_LCD_BASE + 0x0118) -#define MVEBU_LCD_SPU_H_PORCH (MVEBU_LCD_BASE + 0x011c) -#define MVEBU_LCD_SPU_V_PORCH (MVEBU_LCD_BASE + 0x0120) -#define MVEBU_LCD_SPU_BLANKCOLOR (MVEBU_LCD_BASE + 0x0124) -#define MVEBU_LCD_SPU_ALPHA_COLOR1 (MVEBU_LCD_BASE + 0x0128) -#define MVEBU_LCD_SPU_ALPHA_COLOR2 (MVEBU_LCD_BASE + 0x012c) -#define MVEBU_LCD_SPU_COLORKEY_Y (MVEBU_LCD_BASE + 0x0130) -#define MVEBU_LCD_SPU_COLORKEY_U (MVEBU_LCD_BASE + 0x0134) -#define MVEBU_LCD_SPU_COLORKEY_V (MVEBU_LCD_BASE + 0x0138) -#define MVEBU_LCD_CFG_RDREG4F (MVEBU_LCD_BASE + 0x013c) -#define MVEBU_LCD_SPU_SPI_RXDATA (MVEBU_LCD_BASE + 0x0140) -#define MVEBU_LCD_SPU_ISA_RXDATA (MVEBU_LCD_BASE + 0x0144) -#define MVEBU_LCD_SPU_DBG_ISA (MVEBU_LCD_BASE + 0x0148) - -#define MVEBU_LCD_SPU_HWC_RDDAT (MVEBU_LCD_BASE + 0x0158) -#define MVEBU_LCD_SPU_GAMMA_RDDAT (MVEBU_LCD_BASE + 0x015c) -#define MVEBU_LCD_SPU_PALETTE_RDDAT (MVEBU_LCD_BASE + 0x0160) -#define MVEBU_LCD_SPU_IOPAD_IN (MVEBU_LCD_BASE + 0x0178) -#define MVEBU_LCD_FRAME_COUNT (MVEBU_LCD_BASE + 0x017c) -#define MVEBU_LCD_SPU_DMA_CTRL0 (MVEBU_LCD_BASE + 0x0190) -#define MVEBU_LCD_SPU_DMA_CTRL1 (MVEBU_LCD_BASE + 0x0194) -#define MVEBU_LCD_SPU_SRAM_CTRL (MVEBU_LCD_BASE + 0x0198) -#define MVEBU_LCD_SPU_SRAM_WRDAT (MVEBU_LCD_BASE + 0x019c) -#define MVEBU_LCD_SPU_SRAM_PARA0 (MVEBU_LCD_BASE + 0x01a0) -#define MVEBU_LCD_SPU_SRAM_PARA1 (MVEBU_LCD_BASE + 0x01a4) -#define MVEBU_LCD_CFG_SCLK_DIV (MVEBU_LCD_BASE + 0x01a8) -#define MVEBU_LCD_SPU_CONTRAST (MVEBU_LCD_BASE + 0x01ac) -#define MVEBU_LCD_SPU_SATURATION (MVEBU_LCD_BASE + 0x01b0) -#define MVEBU_LCD_SPU_CBSH_HUE (MVEBU_LCD_BASE + 0x01b4) -#define MVEBU_LCD_SPU_DUMB_CTRL (MVEBU_LCD_BASE + 0x01b8) -#define MVEBU_LCD_SPU_IOPAD_CONTROL (MVEBU_LCD_BASE + 0x01bc) -#define MVEBU_LCD_SPU_IRQ_ENA_2 (MVEBU_LCD_BASE + 0x01d8) -#define MVEBU_LCD_SPU_IRQ_ISR_2 (MVEBU_LCD_BASE + 0x01dc) -#define MVEBU_LCD_SPU_IRQ_ENA (MVEBU_LCD_BASE + 0x01c0) -#define MVEBU_LCD_SPU_IRQ_ISR (MVEBU_LCD_BASE + 0x01c4) -#define MVEBU_LCD_ADLL_CTRL (MVEBU_LCD_BASE + 0x01c8) -#define MVEBU_LCD_CLK_DIS (MVEBU_LCD_BASE + 0x01cc) -#define MVEBU_LCD_VGA_HVSYNC_DELAY (MVEBU_LCD_BASE + 0x01d4) -#define MVEBU_LCD_CLK_CFG_0 (MVEBU_LCD_BASE + 0xf0a0) -#define MVEBU_LCD_CLK_CFG_1 (MVEBU_LCD_BASE + 0xf0a4) -#define MVEBU_LCD_LVDS_CLK_CFG (MVEBU_LCD_BASE + 0xf0ac) +#define MVEBU_LCD_WIN_CONTROL(w) (0xf000 + ((w) << 4)) +#define MVEBU_LCD_WIN_BASE(w) (0xf004 + ((w) << 4)) +#define MVEBU_LCD_WIN_REMAP(w) (0xf00c + ((w) << 4)) + +#define MVEBU_LCD_CFG_DMA_START_ADDR_0 0x00cc +#define MVEBU_LCD_CFG_DMA_START_ADDR_1 0x00dc + +#define MVEBU_LCD_CFG_GRA_START_ADDR0 0x00f4 +#define MVEBU_LCD_CFG_GRA_START_ADDR1 0x00f8 +#define MVEBU_LCD_CFG_GRA_PITCH 0x00fc +#define MVEBU_LCD_SPU_GRA_OVSA_HPXL_VLN 0x0100 +#define MVEBU_LCD_SPU_GRA_HPXL_VLN 0x0104 +#define MVEBU_LCD_SPU_GZM_HPXL_VLN 0x0108 +#define MVEBU_LCD_SPU_HWC_OVSA_HPXL_VLN 0x010c +#define MVEBU_LCD_SPU_HWC_HPXL_VLN 0x0110 +#define MVEBU_LCD_SPUT_V_H_TOTAL 0x0114 +#define MVEBU_LCD_SPU_V_H_ACTIVE 0x0118 +#define MVEBU_LCD_SPU_H_PORCH 0x011c +#define MVEBU_LCD_SPU_V_PORCH 0x0120 +#define MVEBU_LCD_SPU_BLANKCOLOR 0x0124 +#define MVEBU_LCD_SPU_ALPHA_COLOR1 0x0128 +#define MVEBU_LCD_SPU_ALPHA_COLOR2 0x012c +#define MVEBU_LCD_SPU_COLORKEY_Y 0x0130 +#define MVEBU_LCD_SPU_COLORKEY_U 0x0134 +#define MVEBU_LCD_SPU_COLORKEY_V 0x0138 +#define MVEBU_LCD_CFG_RDREG4F 0x013c +#define MVEBU_LCD_SPU_SPI_RXDATA 0x0140 +#define MVEBU_LCD_SPU_ISA_RXDATA 0x0144 +#define MVEBU_LCD_SPU_DBG_ISA 0x0148 + +#define MVEBU_LCD_SPU_HWC_RDDAT 0x0158 +#define MVEBU_LCD_SPU_GAMMA_RDDAT 0x015c +#define MVEBU_LCD_SPU_PALETTE_RDDAT 0x0160 +#define MVEBU_LCD_SPU_IOPAD_IN 0x0178 +#define MVEBU_LCD_FRAME_COUNT 0x017c +#define MVEBU_LCD_SPU_DMA_CTRL0 0x0190 +#define MVEBU_LCD_SPU_DMA_CTRL1 0x0194 +#define MVEBU_LCD_SPU_SRAM_CTRL 0x0198 +#define MVEBU_LCD_SPU_SRAM_WRDAT 0x019c +#define MVEBU_LCD_SPU_SRAM_PARA0 0x01a0 +#define MVEBU_LCD_SPU_SRAM_PARA1 0x01a4 +#define MVEBU_LCD_CFG_SCLK_DIV 0x01a8 +#define MVEBU_LCD_SPU_CONTRAST 0x01ac +#define MVEBU_LCD_SPU_SATURATION 0x01b0 +#define MVEBU_LCD_SPU_CBSH_HUE 0x01b4 +#define MVEBU_LCD_SPU_DUMB_CTRL 0x01b8 +#define MVEBU_LCD_SPU_IOPAD_CONTROL 0x01bc +#define MVEBU_LCD_SPU_IRQ_ENA_2 0x01d8 +#define MVEBU_LCD_SPU_IRQ_ISR_2 0x01dc +#define MVEBU_LCD_SPU_IRQ_ENA 0x01c0 +#define MVEBU_LCD_SPU_IRQ_ISR 0x01c4 +#define MVEBU_LCD_ADLL_CTRL 0x01c8 +#define MVEBU_LCD_CLK_DIS 0x01cc +#define MVEBU_LCD_VGA_HVSYNC_DELAY 0x01d4 +#define MVEBU_LCD_CLK_CFG_0 0xf0a0 +#define MVEBU_LCD_CLK_CFG_1 0xf0a4 +#define MVEBU_LCD_LVDS_CLK_CFG 0xf0ac
#define MVEBU_LVDS_PADS_REG (MVEBU_SYSTEM_REG_BASE + 0xf0)
+enum { + /* Maximum LCD size we support */ + LCD_MAX_WIDTH = 640, + LCD_MAX_HEIGHT = 480, + LCD_MAX_LOG2_BPP = VIDEO_BPP16, +}; + +struct mvebu_lcd_info { + u32 fb_base; + int x_res; + int y_res; + int x_fp; + int y_fp; + int x_bp; + int y_bp; +}; + +struct mvebu_video_priv { + uintptr_t regs; +}; + /* Setup Mbus Bridge Windows for LCD */ -static void mvebu_lcd_conf_mbus_registers(void) +static void mvebu_lcd_conf_mbus_registers(uintptr_t regs) { const struct mbus_dram_target_info *dram; int i; @@ -82,9 +104,9 @@ static void mvebu_lcd_conf_mbus_registers(void)
/* Disable windows, set size/base/remap to 0 */ for (i = 0; i < 6; i++) { - writel(0, MVEBU_LCD_WIN_CONTROL(i)); - writel(0, MVEBU_LCD_WIN_BASE(i)); - writel(0, MVEBU_LCD_WIN_REMAP(i)); + writel(0, regs + MVEBU_LCD_WIN_CONTROL(i)); + writel(0, regs + MVEBU_LCD_WIN_BASE(i)); + writel(0, regs + MVEBU_LCD_WIN_REMAP(i)); }
/* Write LCD bridge window registers */ @@ -92,14 +114,15 @@ static void mvebu_lcd_conf_mbus_registers(void) const struct mbus_dram_window *cs = dram->cs + i; writel(((cs->size - 1) & 0xffff0000) | (cs->mbus_attr << 8) | (dram->mbus_dram_target_id << 4) | 1, - MVEBU_LCD_WIN_CONTROL(i)); + regs + MVEBU_LCD_WIN_CONTROL(i));
- writel(cs->base & 0xffff0000, MVEBU_LCD_WIN_BASE(i)); + writel(cs->base & 0xffff0000, regs + MVEBU_LCD_WIN_BASE(i)); } }
/* Initialize LCD registers */ -int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) +static void mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info, + uintptr_t regs) { /* Local variable for easier handling */ int x = lcd_info->x_res; @@ -107,7 +130,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) u32 val;
/* Setup Mbus Bridge Windows */ - mvebu_lcd_conf_mbus_registers(); + mvebu_lcd_conf_mbus_registers(regs);
/* * Set LVDS Pads Control Register @@ -121,8 +144,8 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * end (currently 1GB-64MB but also may be 2GB-64MB). * See also the Window 0 settings! */ - writel(lcd_info->fb_base, MVEBU_LCD_CFG_GRA_START_ADDR0); - writel(lcd_info->fb_base, MVEBU_LCD_CFG_GRA_START_ADDR1); + writel(lcd_info->fb_base, regs + MVEBU_LCD_CFG_GRA_START_ADDR0); + writel(lcd_info->fb_base, regs + MVEBU_LCD_CFG_GRA_START_ADDR1);
/* * Set the LCD_CFG_GRA_PITCH Register @@ -132,14 +155,14 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 15-00: Line Length in Bytes * 240*2 (for RGB1555)=480=0x1E0 */ - writel(0x80100000 + 2 * x, MVEBU_LCD_CFG_GRA_PITCH); + writel(0x80100000 + 2 * x, regs + MVEBU_LCD_CFG_GRA_PITCH);
/* * Set the LCD_SPU_GRA_OVSA_HPXL_VLN Register * Bits 31-16: Vertical start of graphical overlay on screen * Bits 15-00: Horizontal start of graphical overlay on screen */ - writel(0x00000000, MVEBU_LCD_SPU_GRA_OVSA_HPXL_VLN); + writel(0x00000000, regs + MVEBU_LCD_SPU_GRA_OVSA_HPXL_VLN);
/* * Set the LCD_SPU_GRA_HPXL_VLN Register @@ -147,7 +170,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 15-00: Horizontal size of graphical overlay 240=0xF0 * Values before zooming */ - writel((y << 16) | x, MVEBU_LCD_SPU_GRA_HPXL_VLN); + writel((y << 16) | x, regs + MVEBU_LCD_SPU_GRA_HPXL_VLN);
/* * Set the LCD_SPU_GZM_HPXL_VLN Register @@ -155,21 +178,21 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 15-00: Horizontal size of graphical overlay 240=0xF0 * Values after zooming */ - writel((y << 16) | x, MVEBU_LCD_SPU_GZM_HPXL_VLN); + writel((y << 16) | x, regs + MVEBU_LCD_SPU_GZM_HPXL_VLN);
/* * Set the LCD_SPU_HWC_OVSA_HPXL_VLN Register * Bits 31-16: Vertical position of HW Cursor 320=0x140 * Bits 15-00: Horizontal position of HW Cursor 240=0xF0 */ - writel((y << 16) | x, MVEBU_LCD_SPU_HWC_OVSA_HPXL_VLN); + writel((y << 16) | x, regs + MVEBU_LCD_SPU_HWC_OVSA_HPXL_VLN);
/* * Set the LCD_SPU_HWC_OVSA_HPXL_VLN Register * Bits 31-16: Vertical size of HW Cursor * Bits 15-00: Horizontal size of HW Cursor */ - writel(0x00000000, MVEBU_LCD_SPU_HWC_HPXL_VLN); + writel(0x00000000, regs + MVEBU_LCD_SPU_HWC_HPXL_VLN);
/* * Set the LCD_SPU_HWC_OVSA_HPXL_VLN Register @@ -191,14 +214,14 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) */ val = ((y + lcd_info->y_fp + lcd_info->y_bp + 1) << 16) | (x + lcd_info->x_fp + lcd_info->x_bp + 1); - writel(val, MVEBU_LCD_SPUT_V_H_TOTAL); + writel(val, regs + MVEBU_LCD_SPUT_V_H_TOTAL);
/* * Set the LCD_SPU_V_H_ACTIVE Register * Bits 31-16: Screen active vertical lines 320=0x140 * Bits 15-00: Screen active horizontakl pixels 240=0x00F0 */ - writel((y << 16) | x, MVEBU_LCD_SPU_V_H_ACTIVE); + writel((y << 16) | x, regs + MVEBU_LCD_SPU_V_H_ACTIVE);
/* * Set the LCD_SPU_H_PORCH Register @@ -207,7 +230,8 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Note: The terms "front" and "back" for the Marvell seem to be * exactly opposite to the display. */ - writel((lcd_info->x_fp << 16) | lcd_info->x_bp, MVEBU_LCD_SPU_H_PORCH); + writel((lcd_info->x_fp << 16) | lcd_info->x_bp, + regs + MVEBU_LCD_SPU_H_PORCH);
/* * Set the LCD_SPU_V_PORCH Register @@ -216,14 +240,15 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Note: The terms "front" and "back" for the Marvell seem to be exactly * opposite to the display. */ - writel((lcd_info->y_fp << 16) | lcd_info->y_bp, MVEBU_LCD_SPU_V_PORCH); + writel((lcd_info->y_fp << 16) | lcd_info->y_bp, + regs + MVEBU_LCD_SPU_V_PORCH);
/* * Set the LCD_SPU_BLANKCOLOR Register * This should be black = 0 * For tests this is magenta=00FF00FF */ - writel(0x00FF00FF, MVEBU_LCD_SPU_BLANKCOLOR); + writel(0x00FF00FF, regs + MVEBU_LCD_SPU_BLANKCOLOR);
/* * Registers in the range of 0x0128 to 0x012C are colors for the cursor @@ -240,7 +265,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bit 8: FIFO watermark for DMA: 0=disable * Bits 07-00: Empty 8B FIFO entries to trigger DMA, default=0x80 */ - writel(0x00000780, MVEBU_LCD_CFG_RDREG4F); + writel(0x00000780, regs + MVEBU_LCD_CFG_RDREG4F);
/* * Set the LCD_SPU_DMACTRL 0 Register @@ -271,7 +296,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bit 01: Video YUV to RGB Conversion: 0=disable * Bit 00: Video Transfer: 0=disable */ - writel(0x88111100, MVEBU_LCD_SPU_DMA_CTRL0); + writel(0x88111100, regs + MVEBU_LCD_SPU_DMA_CTRL0);
/* * Set the LCD_SPU_DMA_CTRL1 Register @@ -288,7 +313,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 15-08: Configure Alpha: 0x00. * Bits 07-00: Reserved. */ - writel(0x20010000, MVEBU_LCD_SPU_DMA_CTRL1); + writel(0x20010000, regs + MVEBU_LCD_SPU_DMA_CTRL1);
/* * Set the LCD_SPU_SRAM_CTRL Register @@ -297,14 +322,14 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 11-08: SRAM address ID: 0=gamma_yr, 1=gammy_ug, 2=gamma_vb, * 3=palette, 15=cursor */ - writel(0x0000C000, MVEBU_LCD_SPU_SRAM_CTRL); + writel(0x0000C000, regs + MVEBU_LCD_SPU_SRAM_CTRL);
/* * LCD_SPU_SRAM_WRDAT register: 019C * LCD_SPU_SRAM_PARA0 register: 01A0 * LCD_SPU_SRAM_PARA1 register: 01A4 - Cursor control/Power settings */ - writel(0x00000000, MVEBU_LCD_SPU_SRAM_PARA1); + writel(0x00000000, regs + MVEBU_LCD_SPU_SRAM_PARA1);
/* Clock settings in the at 01A8 and in the range F0A0 see below */ @@ -314,21 +339,21 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 31-16: Brightness sign ext. 8-bit value +255 to -255: default=0 * Bits 15-00: Contrast sign ext. 8-bit value +255 to -255: default=0 */ - writel(0x00000000, MVEBU_LCD_SPU_CONTRAST); + writel(0x00000000, regs + MVEBU_LCD_SPU_CONTRAST);
/* * Set LCD_SPU_SATURATION * Bits 31-16: Multiplier signed 4.12 fixed point value * Bits 15-00: Saturation signed 4.12 fixed point value */ - writel(0x10001000, MVEBU_LCD_SPU_SATURATION); + writel(0x10001000, regs + MVEBU_LCD_SPU_SATURATION);
/* * Set LCD_SPU_HUE * Bits 31-16: Sine signed 2.14 fixed point value * Bits 15-00: Cosine signed 2.14 fixed point value */ - writel(0x00000000, MVEBU_LCD_SPU_CBSH_HUE); + writel(0x00000000, regs + MVEBU_LCD_SPU_CBSH_HUE);
/* * Set LCD_SPU_DUMB_CTRL @@ -348,7 +373,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Question: Do we have to disable Smart and Dumb LCD * and separately enable LVDS? */ - writel(0x6000080F, MVEBU_LCD_SPU_DUMB_CTRL); + writel(0x6000080F, regs + MVEBU_LCD_SPU_DUMB_CTRL);
/* * Set LCD_SPU_IOPAD_CTRL @@ -366,17 +391,17 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * 128 Bytes burst * Bits 03-00: LCD pins: ??? 0=24-bit Dump panel ?? */ - writel(0x000000C0, MVEBU_LCD_SPU_IOPAD_CONTROL); + writel(0x000000C0, regs + MVEBU_LCD_SPU_IOPAD_CONTROL);
/* * Set SUP_IRQ_ENA_2: Disable all interrupts */ - writel(0x00000000, MVEBU_LCD_SPU_IRQ_ENA_2); + writel(0x00000000, regs + MVEBU_LCD_SPU_IRQ_ENA_2);
/* * Set SUP_IRQ_ENA: Disable all interrupts. */ - writel(0x00000000, MVEBU_LCD_SPU_IRQ_ENA); + writel(0x00000000, regs + MVEBU_LCD_SPU_IRQ_ENA);
/* * Set up ADDL Control Register @@ -399,19 +424,19 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 05-00: Delay taps, 0x3F=Half Cycle, 0x00=No delay * Note: ADLL is used for a VGA interface with DAC - not used here */ - writel(0x00000000, MVEBU_LCD_ADLL_CTRL); + writel(0x00000000, regs + MVEBU_LCD_ADLL_CTRL);
/* * Set the LCD_CLK_DIS Register: * Bits 3 and 4 must be 1 */ - writel(0x00000018, MVEBU_LCD_CLK_DIS); + writel(0x00000018, regs + MVEBU_LCD_CLK_DIS);
/* * Set the LCD_VGA_HSYNC/VSYNC Delay Register: * Bits 03-00: Sets the delay for the HSYNC and VSYNC signals */ - writel(0x00000000, MVEBU_LCD_VGA_HVSYNC_DELAY); + writel(0x00000000, regs + MVEBU_LCD_VGA_HVSYNC_DELAY);
/* * Clock registers @@ -423,12 +448,12 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) /* * Disable PLL, see "LCD Clock Configuration 1 Register" below */ - writel(0x8FF40007, MVEBU_LCD_CLK_CFG_1); + writel(0x8FF40007, regs + MVEBU_LCD_CLK_CFG_1);
/* * Powerdown, see "LCD Clock Configuration 0 Register" below */ - writel(0x94000174, MVEBU_LCD_CLK_CFG_0); + writel(0x94000174, regs + MVEBU_LCD_CLK_CFG_0);
/* * Set the LCD_CFG_SCLK_DIV Register @@ -437,7 +462,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 15-01: Clock Divider: Bypass for LVDS=0x0001 * See page 475 in section 28.5. */ - writel(0x80000001, MVEBU_LCD_CFG_SCLK_DIV); + writel(0x80000001, regs + MVEBU_LCD_CFG_SCLK_DIV);
/* * Set the LCD Clock Configuration 0 Register: @@ -452,7 +477,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * N=28=0x1C => 0x1B * Bits 03-00: R1_CTRL (for N=28 => 0x4) */ - writel(0x940021B4, MVEBU_LCD_CLK_CFG_0); + writel(0x940021B4, regs + MVEBU_LCD_CLK_CFG_0);
/* * Set the LCD Clock Configuration 1 Register: @@ -465,7 +490,7 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Bits 12-00: PLL Full Divider [Note: Assumed to be the Post-Divider * M' for LVDS=7!] */ - writel(0x8FF40007, MVEBU_LCD_CLK_CFG_1); + writel(0x8FF40007, regs + MVEBU_LCD_CLK_CFG_1);
/* * Set the LVDS Clock Configuration Register: @@ -479,12 +504,12 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) * Note: Bits 0 and must be verified with the help of the * Interface/display */ - writel(0xC0000201, MVEBU_LCD_LVDS_CLK_CFG); + writel(0xC0000201, regs + MVEBU_LCD_LVDS_CLK_CFG);
/* * Power up PLL (Clock Config 0) */ - writel(0x140021B4, MVEBU_LCD_CLK_CFG_0); + writel(0x140021B4, regs + MVEBU_LCD_CLK_CFG_0);
/* wait 10 ms */ mdelay(10); @@ -492,40 +517,78 @@ int mvebu_lcd_register_init(struct mvebu_lcd_info *lcd_info) /* * Enable PLL (Clock Config 1) */ - writel(0x8FF60007, MVEBU_LCD_CLK_CFG_1); - - return 0; + writel(0x8FF60007, regs + MVEBU_LCD_CLK_CFG_1); }
-int __weak board_video_init(void) +static int mvebu_video_probe(struct udevice *dev) { - return -1; -} + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct mvebu_video_priv *priv = dev_get_priv(dev); + struct mvebu_lcd_info lcd_info; + struct display_timing timings; + u32 fb_start, fb_end; + int ret; + + priv->regs = dev_read_addr(dev); + if (priv->regs == FDT_ADDR_T_NONE) { + dev_err(dev, "failed to get LCD address\n"); + return -ENXIO; + }
-void *video_hw_init(void) -{ - static GraphicDevice mvebufb; - GraphicDevice *pGD = &mvebufb; - u32 val; + ret = ofnode_decode_display_timing(dev_ofnode(dev), 0, &timings); + if (ret) { + dev_err(dev, "failed to get any display timings\n"); + return -EINVAL; + }
- /* - * The board code needs to call mvebu_lcd_register_init() - * in its board_video_init() implementation, with the board - * specific parameters for its LCD. - */ - if (board_video_init() || !readl(MVEBU_LCD_CFG_GRA_START_ADDR0)) - return NULL; + /* Use DT timing (resolution) in internal info struct */ + lcd_info.fb_base = plat->base; + lcd_info.x_res = timings.hactive.typ; + lcd_info.x_fp = timings.hfront_porch.typ; + lcd_info.x_bp = timings.hback_porch.typ; + lcd_info.y_res = timings.vactive.typ; + lcd_info.y_fp = timings.vfront_porch.typ; + lcd_info.y_bp = timings.vback_porch.typ; + + /* Initialize the LCD controller */ + mvebu_lcd_register_init(&lcd_info, priv->regs); + + /* Enable dcache for the frame buffer */ + fb_start = plat->base & ~(MMU_SECTION_SIZE - 1); + fb_end = plat->base + plat->size; + fb_end = ALIGN(fb_end, 1 << MMU_SECTION_SHIFT); + mmu_set_region_dcache_behaviour(fb_start, fb_end - fb_start, + DCACHE_WRITEBACK); + video_set_flush_dcache(dev, true); + + uc_priv->xsize = lcd_info.x_res; + uc_priv->ysize = lcd_info.y_res; + uc_priv->bpix = VIDEO_BPP16; /* Uses RGB555 format */ + + return 0; +}
- /* Provide the necessary values for the U-Boot video IF */ - val = readl(MVEBU_LCD_SPU_V_H_ACTIVE); - pGD->winSizeY = val >> 16; - pGD->winSizeX = val & 0x0000ffff; - pGD->gdfBytesPP = 2; - pGD->gdfIndex = GDF_15BIT_555RGB; - pGD->frameAdrs = readl(MVEBU_LCD_CFG_GRA_START_ADDR0); +static int mvebu_video_bind(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev);
- debug("LCD: buffer at 0x%08x resolution %dx%d\n", pGD->frameAdrs, - pGD->winSizeX, pGD->winSizeY); + plat->size = LCD_MAX_WIDTH * LCD_MAX_HEIGHT * + (1 << LCD_MAX_LOG2_BPP) / 8;
- return pGD; + return 0; } + +static const struct udevice_id mvebu_video_ids[] = { + { .compatible = "marvell,armada-xp-lcd" }, + { } +}; + +U_BOOT_DRIVER(mvebu_video) = { + .name = "mvebu_video", + .id = UCLASS_VIDEO, + .of_match = mvebu_video_ids, + .bind = mvebu_video_bind, + .probe = mvebu_video_probe, + .priv_auto_alloc_size = sizeof(struct mvebu_video_priv), +};
This patch adds support to load 24bpp BMP files on 16bpp displays. This will be used by the theadorable board. The "old" bmp command did support this operartion mode and to not break compatibility with the move to DM_VIDEO, we need to add this support to the "new" bmp code.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Anatolij Gustschin agust@denx.de --- v2: - No change
drivers/video/video_bmp.c | 23 +++++++++++++++++------ 1 file changed, 17 insertions(+), 6 deletions(-)
diff --git a/drivers/video/video_bmp.c b/drivers/video/video_bmp.c index 2898b0b55d..193f37d275 100644 --- a/drivers/video/video_bmp.c +++ b/drivers/video/video_bmp.c @@ -229,11 +229,12 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, }
/* - * We support displaying 8bpp BMPs on 16bpp LCDs + * We support displaying 8bpp and 24bpp BMPs on 16bpp LCDs * and displaying 24bpp BMPs on 32bpp LCDs - * */ + */ if (bpix != bmp_bpix && !(bmp_bpix == 8 && bpix == 16) && + !(bmp_bpix == 24 && bpix == 16) && !(bmp_bpix == 24 && bpix == 32)) { printf("Error: %d bit/pixel mode, but BMP has %d bit/pixel\n", bpix, get_unaligned_le16(&bmp->header.bit_count)); @@ -318,12 +319,22 @@ int video_bmp_display(struct udevice *dev, ulong bmp_image, int x, int y, case 24: for (i = 0; i < height; ++i) { for (j = 0; j < width; j++) { - *(fb++) = *(bmap++); - *(fb++) = *(bmap++); - *(fb++) = *(bmap++); - *(fb++) = 0; + if (bpix == 16) { + /* 16bit 555RGB format */ + *(u16 *)fb = ((bmap[2] >> 3) << 10) | + ((bmap[1] >> 3) << 5) | + (bmap[0] >> 3); + bmap += 3; + fb += 2; + } else { + *(fb++) = *(bmap++); + *(fb++) = *(bmap++); + *(fb++) = *(bmap++); + *(fb++) = 0; + } } fb -= priv->line_length + width * (bpix / 8); + bmap += (padded_width - width) * 3; } break; #endif /* CONFIG_BMP_24BPP */
Acked-by: Anatolij Gustschin agust@denx.de
-- Anatolij
With the new DM_VIDEO support in the Armada XP LCD driver, this patch adds the needed DT node for the LCD controller to the theadorable dts file. This DT property is not added to the Armada XP dtsi files, as this LCD feature is pretty unusual for this SoC and I personally know of no other board that uses this controller.
This patch also enables CONFIG_BMP_16BPP/24BPP/32BPP, as the "old" bmp command supported these BMP files.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Anatolij Gustschin agust@denx.de --- v2: - Remove theadorable_debug_config change (its included in the video driver patch now) - Commit text reworded because of this
arch/arm/dts/armada-xp-theadorable.dts | 25 +++++++++++++++++++++++++ include/configs/theadorable.h | 4 ++++ 2 files changed, 29 insertions(+)
diff --git a/arch/arm/dts/armada-xp-theadorable.dts b/arch/arm/dts/armada-xp-theadorable.dts index 9b66ec678d..5695e9b758 100644 --- a/arch/arm/dts/armada-xp-theadorable.dts +++ b/arch/arm/dts/armada-xp-theadorable.dts @@ -159,6 +159,31 @@ spi-max-frequency = <27777777>; }; }; + + /* The LCD controller is only used on this board */ + lcd0: lcd-controller@e0000 { + compatible = "marvell,armada-xp-lcd"; + reg = <0xe0000 0x10000>; + status = "okay"; + u-boot,dm-pre-reloc; + + display-timings { + native-mode = <&timing0>; + timing0: panel0 { + hactive = <240>; + vactive = <320>; + hfront-porch = <1>; + hback-porch = <45>; + vfront-porch = <1>; + vback-porch = <3>; + + /* Some dummy parameters */ + clock-frequency = <0>; + hsync-len = <0>; + vsync-len = <0>; + }; + }; + }; }; }; }; diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 6837d55507..d0c75757ed 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -65,6 +65,10 @@ /* Enable LCD and reserve 512KB from top of memory*/ #define CONFIG_SYS_MEM_TOP_HIDE 0x80000
+#define CONFIG_BMP_16BPP +#define CONFIG_BMP_24BPP +#define CONFIG_BMP_32BPP + /* FPGA programming support */ #define CONFIG_FPGA_STRATIX_V
-- Anatolij
Applied to u-boot-marvell/master
Thanks, Stefan
-- Anatolij
Thanks, Stefan
Anatolij Gustschin
Stefan Roese
