Cannot build with SPI_SUNXI
Hi there,
I am trying to get an OLinuXino-A64 board with a SPI flash to work:
- U-Boot in the SPI flash, with TF-A, SPL and DTB - Linux in the SPI flash, loaded and run by U-Boot
I can build U-Boot with SPI_SUNXI_SPL just fine. It boots from the flash, and jumping to regular U-Boot works, too. However, the second U-Boot no longer recognizes the SPI bus. I figured out that there is a dedicated option `CONFIG_SPI_SUNXI`. Now when I activate that and try to build again, the linker is having trouble finding core device driver functions:
MKIMAGE u-boot-dtb.img COPY u-boot.bin CC spl/common/spl/spl.o CC spl/lib/display_options.o CC spl/drivers/spi/spi-sunxi.o AR spl/lib/built-in.o AR spl/common/spl/built-in.o AR spl/drivers/spi/built-in.o AR spl/drivers/built-in.o LD spl/u-boot-spl drivers/spi/spi-sunxi.o: In function `sun4i_spi_set_mode': /home/bob/build/racklet/olinuxino-a64/u-boot/drivers/spi/spi-sunxi.c:459: undefined reference to `dev_get_priv' drivers/spi/spi-sunxi.o: In function `sun4i_spi_set_cs': /home/bob/build/racklet/olinuxino-a64/u-boot/drivers/spi/spi-sunxi.c:167: undefined reference to `dev_get_priv' drivers/spi/spi-sunxi.o: In function `sun4i_spi_release_bus': /home/bob/build/racklet/olinuxino-a64/u-boot/drivers/spi/spi-sunxi.c:329: undefined reference to `dev_get_priv'
and so on.
I am using the U-Boot config and patch for SPI flash in DTS and defconfig in here: https://github.com/orangecms/arm-cpu/tree/main/olinuxino-a64
I'd be glad to get this to work; any hint is welcome. :)
Thanks and stay safe! Dan
Daniel Maslowski
# IT'S TINY, QUICK & ORANGE # # https://www.orangecms.org #
Twentmannstr. 56 D-45141 Essen Germany
On Sat, 12 Jun 2021 21:16:38 +0200 Daniel Maslowski info@orangecms.org wrote:
Please keep in mind that the latter is not really the idea of SPI flash usage on those boards: for holding proper kernels it's quite small, and updating is not easy. Also finding the kernel on there is non-standard. At the end of the day you probably need some rootfs anyway, so why not put the kernel on there, where it can be easily found and updated?
But to your question:
You don't need to activate that, it's already done by default in the A64 Kconfig. The only thing that's missing is some SPI *flash* chip support, so CONFIG_SPI_FLASH_WINBOND=y. Not really sure how you get to this error, do you manipulate the .config manually? Please note that keeping your private .config doesn't really work as nicely as in the kernel, so I'd always advise to do the required changes on top of what the current defconfig creates.
Adding the Winbond support builds fine for me, but didn't work in a quick test (on a Pine64-LTS): jedec_spi_nor flash@0: unrecognized JEDEC id bytes: 00, 00, 00 Need to have a look later, I am pretty sure this worked like this some time ago.
Cheers, Andre
and so on.
Daniel Maslowski
Andre Przywara
Daniel Maslowski
