[U-Boot] [PATCH 0/7] rockchip: migrate to use common TPL board file
Rockchip SoCs have very similar boot process, we can use TPL for all SoCs and all these SoCs can share the same board file. Migrate to use common board file to avoid unneccessary copy-paste for different SoCs.
Kever Yang (7): rockchip: add common tpl board file rockchip: rk322x: use common TPL board file rockchip: rk3288: use common SPL board file rockchip: rk3368: use common TPL board file rockchip: rk3399: use common secure_timer_init() for spl/tpl rockchip: rk3399: remove TPL_BOARD_INIT rockchip: rk3399: use common TPL board file
arch/arm/mach-rockchip/Kconfig | 14 ++- arch/arm/mach-rockchip/Makefile | 6 +- arch/arm/mach-rockchip/rk3288-board-tpl.c | 89 ------------------ arch/arm/mach-rockchip/rk3368-board-tpl.c | 74 --------------- arch/arm/mach-rockchip/rk3399-board-spl.c | 19 +--- arch/arm/mach-rockchip/rk3399-board-tpl.c | 91 ------------------- arch/arm/mach-rockchip/rk3399/rk3399.c | 29 ++++++ .../{rk322x-board-tpl.c => tpl.c} | 28 +++--- include/configs/rk3399_common.h | 1 + 9 files changed, 62 insertions(+), 289 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk3288-board-tpl.c delete mode 100644 arch/arm/mach-rockchip/rk3368-board-tpl.c delete mode 100644 arch/arm/mach-rockchip/rk3399-board-tpl.c rename arch/arm/mach-rockchip/{rk322x-board-tpl.c => tpl.c} (82%)
Rockchip SoCs have similar boot process, prefer to use TPL for DRAM init and back to bootrom, and SPL as Trust ATF/U-Boot loader. TPL common board is a basic TPL board init which can be shared for most of SoCs to avoid copy-pase for different SoCs.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/Kconfig | 9 ++++ arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/tpl.c | 86 +++++++++++++++++++++++++++++++++ 3 files changed, 96 insertions(+) create mode 100644 arch/arm/mach-rockchip/tpl.c
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 127a04e348..d5578e4b57 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -223,6 +223,15 @@ config TPL_ROCKCHIP_BACK_TO_BROM SPL will return to the boot rom, which will then load the U-Boot binary to keep going on.
+config TPL_ROCKCHIP_COMMON_BOARD + bool "" + depends on TPL + help + Rockchip SoCs have similar boot process, prefer to use TPL for DRAM + init and back to bootrom, and SPL as Trust ATF/U-Boot loader. TPL + common board is a basic TPL board init which can be shared for most + of SoCs to avoid copy-pase for different SoCs. + config ROCKCHIP_BOOT_MODE_REG hex "Rockchip boot mode flag register address" default 0 diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 9afbb055d5..2686e0c46c 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -8,6 +8,7 @@ # the stack-pointer is valid before switching to the U-Boot stack). obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o +obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o
obj-tpl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o diff --git a/arch/arm/mach-rockchip/tpl.c b/arch/arm/mach-rockchip/tpl.c new file mode 100644 index 0000000000..0ff2a197ed --- /dev/null +++ b/arch/arm/mach-rockchip/tpl.c @@ -0,0 +1,86 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <version.h> +#include <asm/io.h> +#include <asm/arch-rockchip/bootrom.h> + +#define TIMER_LOAD_COUNT_L 0x00 +#define TIMER_LOAD_COUNT_H 0x04 +#define TIMER_CONTROL_REG 0x10 +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +__weak void rockchip_stimer_init(void) +{ + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + +#ifndef CONFIG_ARM64 + asm volatile("mcr p15, 0, %0, c14, c0, 0" + : : "r"(COUNTER_FREQUENCY)); +#endif + + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + + TIMER_CONTROL_REG); +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + +#ifdef CONFIG_DEBUG_UART + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + printascii("\nU-Boot TPL " PLAIN_VERSION " (" U_BOOT_DATE " - " \ + U_BOOT_TIME ")\n"); +#endif + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + /* Init secure timer */ + rockchip_stimer_init(); + /* Init ARM arch timer in arch/arm/cpu/ */ + timer_init(); + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + printf("DRAM init failed: %d\n", ret); + return; + } +} + +void board_return_to_bootrom(void) +{ + back_to_bootrom(BROM_BOOT_NEXTSTAGE); +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_BOOTROM; +}
Use Common tpl.c instead of rk322x-board-tpl.c
arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/Makefile | 1 - arch/arm/mach-rockchip/rk322x-board-tpl.c | 80 ----------------------- 3 files changed, 1 insertion(+), 81 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk322x-board-tpl.c
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index d5578e4b57..14922e7725 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -59,6 +59,7 @@ config ROCKCHIP_RK322X select SPL_DRIVERS_MISC_SUPPORT imply SPL_SERIAL_SUPPORT imply TPL_SERIAL_SUPPORT + imply TPL_ROCKCHIP_COMMON_BOARD select ROCKCHIP_BROM_HELPER select TPL_LIBCOMMON_SUPPORT select TPL_LIBGENERIC_SUPPORT diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 2686e0c46c..b21742110e 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -12,7 +12,6 @@ obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o
obj-tpl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o -obj-tpl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o diff --git a/arch/arm/mach-rockchip/rk322x-board-tpl.c b/arch/arm/mach-rockchip/rk322x-board-tpl.c deleted file mode 100644 index a0d7bc9b05..0000000000 --- a/arch/arm/mach-rockchip/rk322x-board-tpl.c +++ /dev/null @@ -1,80 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2019 Rockchip Electronics Co., Ltd - */ - -#include <common.h> -#include <debug_uart.h> -#include <dm.h> -#include <ram.h> -#include <spl.h> -#include <asm/io.h> -#include <asm/arch-rockchip/bootrom.h> - -u32 spl_boot_device(void) -{ - return BOOT_DEVICE_MMC1; -} - -#define TIMER_LOAD_COUNT_L 0x00 -#define TIMER_LOAD_COUNT_H 0x04 -#define TIMER_CONTROL_REG 0x10 -#define TIMER_EN 0x1 -#define TIMER_FMODE BIT(0) -#define TIMER_RMODE BIT(1) - -void rockchip_stimer_init(void) -{ - /* If Timer already enabled, don't re-init it */ - u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - - if (reg & TIMER_EN) - return; - - asm volatile("mcr p15, 0, %0, c14, c0, 0" - : : "r"(COUNTER_FREQUENCY)); - - writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); - writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + - TIMER_CONTROL_REG); -} - -void board_init_f(ulong dummy) -{ - struct udevice *dev; - int ret; - - /* - * Debug UART can be used from here if required: - * - * debug_uart_init(); - * printch('a'); - * printhex8(0x1234); - * printascii("string"); - */ - debug_uart_init(); - printascii("TPL Init"); - - ret = spl_early_init(); - if (ret) { - debug("spl_early_init() failed: %d\n", ret); - hang(); - } - - /* Init secure timer */ - rockchip_stimer_init(); - /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ - timer_init(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) { - printf("DRAM init failed: %d\n", ret); - return; - } - -#if defined(CONFIG_TPL_ROCKCHIP_BACK_TO_BROM) && !defined(CONFIG_TPL_BOARD_INIT) - back_to_bootrom(BROM_BOOT_NEXTSTAGE); -#endif -}
arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/Makefile | 1 - arch/arm/mach-rockchip/rk3288-board-tpl.c | 89 ----------------------- 3 files changed, 1 insertion(+), 90 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk3288-board-tpl.c
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 14922e7725..6f4813ea7d 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -88,6 +88,7 @@ config ROCKCHIP_RK3288 imply TPL_OF_PLATDATA imply TPL_RAM imply TPL_REGMAP + imply TPL_ROCKCHIP_COMMON_BOARD imply TPL_SERIAL_SUPPORT imply TPL_SYSCON imply USB_FUNCTION_ROCKUSB diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index b21742110e..d01293bd25 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -10,7 +10,6 @@ obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o
-obj-tpl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-tpl.o
diff --git a/arch/arm/mach-rockchip/rk3288-board-tpl.c b/arch/arm/mach-rockchip/rk3288-board-tpl.c deleted file mode 100644 index 96de7927f0..0000000000 --- a/arch/arm/mach-rockchip/rk3288-board-tpl.c +++ /dev/null @@ -1,89 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2017 Amarula Solutions - */ - -#include <common.h> -#include <debug_uart.h> -#include <dm.h> -#include <ram.h> -#include <spl.h> -#include <version.h> -#include <asm/io.h> -#include <asm/arch-rockchip/bootrom.h> -#include <asm/arch-rockchip/clock.h> - -#define TIMER_LOAD_COUNT_L 0x00 -#define TIMER_LOAD_COUNT_H 0x04 -#define TIMER_CONTROL_REG 0x10 -#define TIMER_EN 0x1 -#define TIMER_FMODE BIT(0) -#define TIMER_RMODE BIT(1) - -void rockchip_stimer_init(void) -{ - asm volatile("mcr p15, 0, %0, c14, c0, 0" - : : "r"(COUNTER_FREQUENCY)); - - writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); - writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + - TIMER_CONTROL_REG); -} - -void board_init_f(ulong dummy) -{ - struct udevice *dev; - int ret; - -#ifdef CONFIG_DEBUG_UART - /* - * Debug UART can be used from here if required: - * - * debug_uart_init(); - * printch('a'); - * printhex8(0x1234); - * printascii("string"); - */ - debug_uart_init(); -#endif - ret = spl_early_init(); - if (ret) { - debug("spl_early_init() failed: %d\n", ret); - hang(); - } - - /* Init secure timer */ - rockchip_stimer_init(); - /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ - timer_init(); - - ret = rockchip_get_clk(&dev); - if (ret) { - debug("CLK init failed: %d\n", ret); - return; - } - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) { - debug("DRAM init failed: %d\n", ret); - return; - } -} - -void board_return_to_bootrom(void) -{ - back_to_bootrom(BROM_BOOT_NEXTSTAGE); -} - -u32 spl_boot_device(void) -{ - return BOOT_DEVICE_BOOTROM; -} - -void spl_board_init(void) -{ - puts("\nU-Boot TPL " PLAIN_VERSION " (" U_BOOT_DATE " - " \ - U_BOOT_TIME ")\n"); -}
Use common tpl.c instead of rk3368-board-tpl.c
arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/Makefile | 1 - arch/arm/mach-rockchip/rk3368-board-tpl.c | 74 ----------------------- 3 files changed, 1 insertion(+), 75 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk3368-board-tpl.c
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 6f4813ea7d..7d798f2d12 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -127,6 +127,7 @@ config ROCKCHIP_RK3368 imply SPL_SEPARATE_BSS imply SPL_SERIAL_SUPPORT imply TPL_SERIAL_SUPPORT + imply TPL_ROCKCHIP_COMMON_BOARD help The Rockchip RK3368 is a ARM-based SoC with a octa-core (organised into a big and little cluster with 4 cores each) Cortex-A53 including diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index d01293bd25..c1b1c31d02 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -10,7 +10,6 @@ obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o
-obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o obj-tpl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o diff --git a/arch/arm/mach-rockchip/rk3368-board-tpl.c b/arch/arm/mach-rockchip/rk3368-board-tpl.c deleted file mode 100644 index fdb1c3b365..0000000000 --- a/arch/arm/mach-rockchip/rk3368-board-tpl.c +++ /dev/null @@ -1,74 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH - */ - -#include <common.h> -#include <debug_uart.h> -#include <dm.h> -#include <ram.h> -#include <spl.h> -#include <asm/io.h> -#include <asm/arch-rockchip/bootrom.h> - -#define TIMER_LOAD_COUNT_L 0x00 -#define TIMER_LOAD_COUNT_H 0x04 -#define TIMER_CONTROL_REG 0x10 -#define TIMER_EN 0x1 -#define TIMER_FMODE BIT(0) -#define TIMER_RMODE BIT(1) - -__weak void rockchip_stimer_init(void) -{ - writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE); - writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + 4); - writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + - TIMER_CONTROL_REG); -} - -void board_init_f(ulong dummy) -{ - struct udevice *dev; - int ret; - -#ifdef CONFIG_DEBUG_UART - /* - * Debug UART can be used from here if required: - * - * debug_uart_init(); - * printch('a'); - * printhex8(0x1234); - * printascii("string"); - */ - debug_uart_init(); - printascii("U-Boot TPL board init\n"); -#endif - - ret = spl_early_init(); - if (ret) { - debug("spl_early_init() failed: %d\n", ret); - hang(); - } - - /* Init secure timer */ - rockchip_stimer_init(); - /* Init ARM arch timer in arch/arm/cpu/ */ - timer_init(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) { - debug("DRAM init failed: %d\n", ret); - return; - } -} - -void board_return_to_bootrom(void) -{ - back_to_bootrom(BROM_BOOT_NEXTSTAGE); -} - -u32 spl_boot_device(void) -{ - return BOOT_DEVICE_BOOTROM; -}
SPL/TPL share the same secure_timer_init(), update to use one copy source code and update to use CONFIG_ROCKCHIP_STIMER_BASE as base address.
arch/arm/mach-rockchip/rk3399-board-spl.c | 19 +-------------- arch/arm/mach-rockchip/rk3399-board-tpl.c | 18 +------------- arch/arm/mach-rockchip/rk3399/rk3399.c | 29 +++++++++++++++++++++++ include/configs/rk3399_common.h | 1 + 4 files changed, 32 insertions(+), 35 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index 2333694caa..38cd1b3df1 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -109,27 +109,10 @@ void spl_perform_fixups(struct spl_image_info *spl_image) "u-boot,spl-boot-device", boot_ofpath); }
-#define TIMER_CHN10_BASE 0xff8680a0 -#define TIMER_END_COUNT_L 0x00 -#define TIMER_END_COUNT_H 0x04 -#define TIMER_INIT_COUNT_L 0x10 -#define TIMER_INIT_COUNT_H 0x14 -#define TIMER_CONTROL_REG 0x1c - -#define TIMER_EN 0x1 -#define TIMER_FMODE (0 << 1) -#define TIMER_RMODE (1 << 1) - -void secure_timer_init(void) +__weak void secure_timer_init(void) { - writel(0xffffffff, TIMER_CHN10_BASE + TIMER_END_COUNT_L); - writel(0xffffffff, TIMER_CHN10_BASE + TIMER_END_COUNT_H); - writel(0, TIMER_CHN10_BASE + TIMER_INIT_COUNT_L); - writel(0, TIMER_CHN10_BASE + TIMER_INIT_COUNT_H); - writel(TIMER_EN | TIMER_FMODE, TIMER_CHN10_BASE + TIMER_CONTROL_REG); }
- void board_init_f(ulong dummy) { struct udevice *dev; diff --git a/arch/arm/mach-rockchip/rk3399-board-tpl.c b/arch/arm/mach-rockchip/rk3399-board-tpl.c index 4a301249b4..6b3e8ac1f4 100644 --- a/arch/arm/mach-rockchip/rk3399-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3399-board-tpl.c @@ -12,24 +12,8 @@ #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h>
void board_init_f(ulong dummy) diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index e1f9f8b8ef..007be81cc3 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -38,6 +38,35 @@ static struct mm_region rk3399_mem_map[] = {
struct mm_region *mem_map = rk3399_mem_map;
+#ifdef CONFIG_SPL_BUILD + +#define TIMER_END_COUNT_L 0x00 +#define TIMER_END_COUNT_H 0x04 +#define TIMER_INIT_COUNT_L 0x10 +#define TIMER_INIT_COUNT_H 0x14 +#define TIMER_CONTROL_REG 0x1c + +#define TIMER_EN 0x1 +#define TIMER_FMODE BIT(0) +#define TIMER_RMODE BIT(1) + +void secure_timer_init(void) +{ + /* If Timer already enabled, don't re-init it */ + u32 reg = readl(CONFIG_ROCKCHIP_STIMER_BASE + TIMER_CONTROL_REG); + + if (reg & TIMER_EN) + return; + + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_END_COUNT_L); + writel(0xffffffff, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_END_COUNT_H); + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_INIT_COUNT_L); + writel(0, CONFIG_ROCKCHIP_STIMER_BASE + TIMER_INIT_COUNT_H); + writel(TIMER_EN | TIMER_FMODE, CONFIG_ROCKCHIP_STIMER_BASE + \ + TIMER_CONTROL_REG); +} +#endif + int dram_init_banksize(void) { size_t max_size = min((unsigned long)gd->ram_size, gd->ram_top); diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index f31f2658bb..8df0180284 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -13,6 +13,7 @@ #define CONFIG_SKIP_LOWLEVEL_INIT
#define COUNTER_FREQUENCY 24000000 +#define CONFIG_ROCKCHIP_STIMER_BASE 0xff8680a0
#define CONFIG_SYS_NS16550_MEM32
RK3399 TPL do not need a dedicate board init, print the firmware info when debug init instead.
arch/arm/mach-rockchip/Kconfig | 1 - arch/arm/mach-rockchip/rk3399-board-tpl.c | 9 ++------- 2 files changed, 2 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 7d798f2d12..391b77293d 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -173,7 +173,6 @@ config ROCKCHIP_RK3399 imply TPL_LIBCOMMON_SUPPORT imply TPL_LIBGENERIC_SUPPORT imply TPL_SYS_MALLOC_SIMPLE - imply TPL_BOARD_INIT imply TPL_BOOTROM_SUPPORT imply TPL_DRIVERS_MISC_SUPPORT imply TPL_OF_CONTROL diff --git a/arch/arm/mach-rockchip/rk3399-board-tpl.c b/arch/arm/mach-rockchip/rk3399-board-tpl.c index 6b3e8ac1f4..728192b96a 100644 --- a/arch/arm/mach-rockchip/rk3399-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3399-board-tpl.c @@ -31,7 +31,8 @@ void board_init_f(ulong dummy) * printhex8(0x1234); * printascii("string"); */ - debug("U-Boot TPL board init\n"); + printascii("\nU-Boot TPL " PLAIN_VERSION " (" U_BOOT_DATE " - " + U_BOOT_TIME " " U_BOOT_TZ ")\n"); #endif ret = spl_early_init(); if (ret) { @@ -58,12 +59,6 @@ u32 spl_boot_device(void) return BOOT_DEVICE_BOOTROM; }
-void spl_board_init(void) -{ - puts("\nU-Boot TPL " PLAIN_VERSION " (" U_BOOT_DATE " - " - U_BOOT_TIME " " U_BOOT_TZ ")\n"); -} - #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) {
arch/arm/mach-rockchip/Kconfig | 1 + arch/arm/mach-rockchip/Makefile | 2 - arch/arm/mach-rockchip/rk3399-board-tpl.c | 70 ----------------------- 3 files changed, 1 insertion(+), 72 deletions(-) delete mode 100644 arch/arm/mach-rockchip/rk3399-board-tpl.c
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 391b77293d..b6c10f7a4b 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -182,6 +182,7 @@ config ROCKCHIP_RK3399 imply TPL_RAM imply TPL_CLK imply TPL_TINY_MEMSET + imply TPL_ROCKCHIP_COMMON_BOARD help The Rockchip RK3399 is a ARM-based SoC with a dual-core Cortex-A72 and quad-core Cortex-A53. diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index c1b1c31d02..a12b8d4434 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -10,8 +10,6 @@ obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o obj-tpl-$(CONFIG_TPL_ROCKCHIP_COMMON_BOARD) += tpl.o
-obj-tpl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-tpl.o - obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o spl-boot-order.o diff --git a/arch/arm/mach-rockchip/rk3399-board-tpl.c b/arch/arm/mach-rockchip/rk3399-board-tpl.c deleted file mode 100644 index 728192b96a..0000000000 --- a/arch/arm/mach-rockchip/rk3399-board-tpl.c +++ /dev/null @@ -1,70 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2019 Rockchip Electronics Co., Ltd - */ - -#include <common.h> -#include <debug_uart.h> -#include <dm.h> -#include <ram.h> -#include <spl.h> -#include <version.h> -#include <asm/io.h> -#include <asm/arch-rockchip/bootrom.h> - -__weak void secure_timer_init(void) -{ -} - -void board_init_f(ulong dummy) -{ - struct udevice *dev; - int ret; - -#ifdef CONFIG_DEBUG_UART - debug_uart_init(); - /* - * Debug UART can be used from here if required: - * - * debug_uart_init(); - * printch('a'); - * printhex8(0x1234); - * printascii("string"); - */ - printascii("\nU-Boot TPL " PLAIN_VERSION " (" U_BOOT_DATE " - " - U_BOOT_TIME " " U_BOOT_TZ ")\n"); -#endif - ret = spl_early_init(); - if (ret) { - debug("spl_early_init() failed: %d\n", ret); - hang(); - } - - secure_timer_init(); - - ret = uclass_get_device(UCLASS_RAM, 0, &dev); - if (ret) { - pr_err("DRAM init failed: %d\n", ret); - return; - } -} - -void board_return_to_bootrom(void) -{ - back_to_bootrom(BROM_BOOT_NEXTSTAGE); -} - -u32 spl_boot_device(void) -{ - return BOOT_DEVICE_BOOTROM; -} - -#ifdef CONFIG_SPL_LOAD_FIT -int board_fit_config_name_match(const char *name) -{ - /* Just empty function now - can't decide what to choose */ - debug("%s: %s\n", __func__, name); - - return 0; -} -#endif
Kever Yang
