[U-Boot] [PATCH] configs: rockpro64-rk3399: Enable CONFIG_MISC_INIT_R and ROCKCHIP_EFUSE
This enables reading the cpuid from e-fuse, and deriving a static MAC address from it. Without this, the ethernet interface on the rockpro64 can't be used to boot.
Signed-off-by: Hugh Cole-Baker sigmaris@gmail.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com --- configs/rockpro64-rk3399_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 40ebad5abb..22b8bc503b 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -9,6 +9,7 @@ CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rockpro64.dtb" +CONFIG_MISC_INIT_R=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set @@ -28,6 +29,8 @@ CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent CONFIG_ENV_IS_IN_MMC=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_ROCKCHIP_EFUSE=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks,
- Kever
Hugh Cole-Baker
Kever Yang
