[PATCH] doc/sandbox: improve formatting of command line options
Show the command line options in bold.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/arch/sandbox.rst | 28 ++++++++++++++-------------- 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index ee720c5a09..60ee1e0741 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -99,37 +99,37 @@ Command-line Options Various options are available, mostly for test purposes. Use -h to see available options. Some of these are described below:
-* -t, --terminal <arg> - - The terminal is normally in what is called 'raw-with-sigs' mode. This means +-t, --terminal <arg> + The terminal is normally in what is called 'raw-with-sigs' mode. This means that you can use arrow keys for command editing and history, but if you press Ctrl-C, U-Boot will exit instead of handling this as a keypress. Other options are 'raw' (so Ctrl-C is handled within U-Boot) and 'cooked' (where the terminal is in cooked mode and cursor keys will not work, Ctrl-C will exit).
-* -l - - Show the LCD emulation window. +-l + Show the LCD emulation window.
-* -d <device_tree> - - A device tree binary file can be provided with -d. If you edit the source +-d <device_tree> + A device tree binary file can be provided with -d. If you edit the source (it is stored at arch/sandbox/dts/sandbox.dts) you must rebuild U-Boot to recreate the binary file.
-* -D - - To use the default device tree, use -D. +-D + To use the default device tree, use -D.
-* -T - - To use the test device tree, use -T. +-T + To use the test device tree, use -T.
-* -c [<cmd>;]<cmd> - - To execute commands directly, use the -c option. You can specify a single +-c [<cmd>;]<cmd> + To execute commands directly, use the -c option. You can specify a single command, or multiple commands separated by a semicolon, as is normal in U-Boot. Be careful with quoting as the shell will normally process and swallow quotes. When -c is used, U-Boot exits after the command is complete, but you can force it to go to interactive mode instead with -i.
-* -i - - Go to interactive mode after executing the commands specified by -c. +-i + Go to interactive mode after executing the commands specified by -c.
Environment Variables --------------------- -- 2.29.2
Applied to u-boot-dm, thanks!
