[U-Boot] Pull request - net
Wolfgang,
The following changes since commit 31f30c9eb60d9ab0bd702e31f66345f99b34bdc6: Mike Frysinger (1): add %.c->%.i and %.c->%.s rules
git://git.denx.de/u-boot-net master
Ben Warren (4): Moved Davinci Ethernet driver to drivers/net Initial cleanup of Davinci Ethernet driver Switched davinci_emac Ethernet driver to use newer API Remove support for non-CONFIG_NET_MULTI on PPC4xx EMAC
Norbert van Bolhuis (1): A VLAN tagged DHCP request/discover is 4 bytes short
Prafulla Wadaskar (2): Marvell MV88E61XX Switch Driver support net: Add Marvell Kirkwood gigabit ethernet driver
Remy Bohmer (1): Convert DM9000 driver for CONFIG_NET_MULTI
Richard Retanubun (1): Subject: [PATCH] [repost] Standardize the use of MCFFEC_TOUT_LOOP as a udelay(1) loop counter.
Zach LeRoy (1): tsec: Add support for BCM5482S PHY
s-paulraj@ti.com (1): DaVinci Network Driver Updates
board/atmel/at91sam9261ek/at91sam9261ek.c | 7 + board/davinci/common/misc.h | 1 - board/davinci/dvevm/dvevm.c | 3 - board/davinci/schmoogie/schmoogie.c | 3 - board/davinci/sffsdr/sffsdr.c | 3 - board/davinci/sonata/sonata.c | 3 - board/freescale/m5253demo/m5253demo.c | 9 + board/scb9328/scb9328.c | 8 + board/trizepsiv/conxs.c | 8 + cpu/arm926ejs/davinci/Makefile | 2 +- cpu/arm926ejs/davinci/cpu.c | 12 + drivers/net/4xx_enet.c | 54 -- drivers/net/Makefile | 2 + .../davinci/ether.c => drivers/net/davinci_emac.c | 214 +++---- drivers/net/dm9000x.c | 44 +- drivers/net/kirkwood_egiga.c | 664 ++++++++++++++++++++ drivers/net/kirkwood_egiga.h | 503 +++++++++++++++ drivers/net/mcfmii.c | 2 +- drivers/net/phy/Makefile | 1 + drivers/net/phy/mv88e61xx.c | 413 ++++++++++++ drivers/net/phy/mv88e61xx.h | 62 ++ drivers/net/tsec.c | 41 ++ include/asm-arm/arch-davinci/emac_defs.h | 32 +- include/configs/M5253DEMO.h | 1 + include/configs/at91sam9261ek.h | 1 + include/configs/davinci_dvevm.h | 1 + include/configs/davinci_schmoogie.h | 1 + include/configs/davinci_sffsdr.h | 1 + include/configs/davinci_sonata.h | 1 + include/configs/scb9328.h | 1 + include/configs/trizepsiv.h | 1 + include/netdev.h | 50 ++ include/tsec.h | 2 + net/bootp.c | 4 +- net/eth.c | 8 - 35 files changed, 1944 insertions(+), 219 deletions(-) rename cpu/arm926ejs/davinci/ether.c => drivers/net/davinci_emac.c (93%) create mode 100644 drivers/net/kirkwood_egiga.c create mode 100644 drivers/net/kirkwood_egiga.h create mode 100644 drivers/net/phy/mv88e61xx.c create mode 100644 drivers/net/phy/mv88e61xx.h
Dear Ben Warren,
In message 4A35F5A0.4030501@gmail.com you wrote:
Wolfgang,
Done, thanks.
Ben Warren
