[U-Boot] CPU up timeout. CPU up mask is 1 should be 3
Hello,
I'm using u-boot.bin built from u-boot-2009.11-cloud. I have single core boards that run this same u-boot.bin but I don't see the "CPU up timeout." message in the u-boot start up screen.
//dual core u-boot U-Boot 2009.11 (Oct 10 2016 - 19:17:09)
CPU0: P2020, Version: 2.1, (0x80e20021) Core: E500, Version: 5.1, (0x80211051) Clock Configuration: CPU0:1200 MHz, CPU1:1200 MHz, CCB:600 MHz, DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:75 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled PCMM: P2020 I2C: ready SPI: ready DRAM: Configuring DDR for 800 MT/s data rate DDR: 256 MB FLASH: 64 MB L2: 512 KB enabled CPU up timeout. CPU up mask is 1 should be 3 MMC: FSL_ESDHC: 0 EEPROM: Invalid ID (4b 41 53 00) In: serial Out: serial Err: serial Net: eTSEC1: No support for PHY id 221560; assuming generic eTSEC2: No support for PHY id ffffffff; assuming generic eTSEC3: No support for PHY id 221560; assuming generic eTSEC1, eTSEC2, eTSEC3 Hit any key to stop autoboot: 0
//single core u-boot U-Boot 2009.11 (Apr 12 2013 - 09:40:13)
CPU: P2010, Version: 2.1, (0x80e30021) Core: E500, Version: 5.1, (0x80211051) Clock Configuration: CPU0:1200 MHz, CCB:600 MHz, DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:75 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled PCMM: P2010 I2C: ready SPI: ready DRAM: Configuring DDR for 800 MT/s data rate DDR: 256 MB FLASH: 64 MB L2: 512 KB enabled MMC: FSL_ESDHC: 0 *** Warning - bad CRC, using default environment
EEPROM: Invalid ID (ff ff ff ff) In: serial Out: serial Err: serial Net: eTSEC1: No support for PHY id 221556; assuming generic eTSEC2: No support for PHY id ffffffff; assuming generic eTSEC3: No support for PHY id 221556; assuming generic eTSEC1, eTSEC2, eTSEC3 Hit any key to stop autoboot: 0
Do I need to modify something in my u-boot code to enable the second core?
~Thanks, Carol
Carol Wesolowski Software Engineer Kollmorgen 33 South La Patera Lane Santa Barbara, CA 93117 T: +1.805.696.1248 carol.wesolowski@Kollmorgen.commailto:carol.wesolowski@Kollmorgen.com www.Kollmorgen.comhttp://www.kollmorgen.com/
Please be advised that this email may contain confidential information. If you are not the intended recipient, please notify us by email by replying to the sender and delete this message. The sender disclaims that the content of this email constitutes an offer to enter into, or the acceptance of, any agreement; provided that the foregoing does not invalidate the binding effect of any digital or other electronic reproduction of a manual signature that is included in any attachment.
Wesolowski, Carol
