[U-Boot] [PATCH 07/19] 44x_spd_ddr.c: Fix GCC 4.6 build warnings
Fix: 44x_spd_ddr.c: In function 'program_cfg0': 44x_spd_ddr.c:384:16: warning: variable 'dimm_64bit' set but not used [-Wunused-but-set-variable] 44x_spd_ddr.c:383:16: warning: variable 'dimm_32bit' set but not used [-Wunused-but-set-variable]
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c | 4 ---- 1 files changed, 0 insertions(+), 4 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c index e05daf2..8a20a2b 100644 --- a/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c +++ b/arch/powerpc/cpu/ppc4xx/44x_spd_ddr.c @@ -380,8 +380,6 @@ static void program_cfg0(unsigned long *dimm_populated, unsigned char ecc; unsigned char attributes; unsigned long data_width; - unsigned long dimm_32bit; - unsigned long dimm_64bit;
/* * get Memory Controller Options 0 data @@ -423,10 +421,8 @@ static void program_cfg0(unsigned long *dimm_populated, (unsigned long)spd_read(iic0_dimm_addr[dimm_num],6) + (((unsigned long)spd_read(iic0_dimm_addr[dimm_num],7)) << 8); if (data_width == 64 || data_width == 72) { - dimm_64bit = TRUE; cfg0 |= SDRAM_CFG0_DMWD_64; } else if (data_width == 32 || data_width == 40) { - dimm_32bit = TRUE; cfg0 |= SDRAM_CFG0_DMWD_32; } else { printf("WARNING: DIMM with datawidth of %lu bits.\n",
Dear Stefan Roese,
Applied, thanks.
Stefan Roese
