[U-Boot] [PATCH] apalis_imx6: fix broken fsl_esdhc_imx conversion
Commit e37ac717d796 ("Convert to use fsl_esdhc_imx for i.MX platforms") converted FSL_ESDHC to FSL_ESDHC_IMX, but the config check for apalis_imx6 wasn't updated accordantly.
Signed-off-by: Ricardo Salveti ricardo@foundries.io --- board/toradex/apalis_imx6/apalis_imx6.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index ef668fcedc..89680da53f 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -93,7 +93,7 @@ iomux_v3_cfg_t const uart1_pads_dte[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) /* Apalis MMC1 */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -290,7 +290,7 @@ int board_ehci_hcd_init(int port) } #endif
-#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) /* use the following sequence: eMMC, MMC1, SD1 */ struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR},
Subject: [PATCH] apalis_imx6: fix broken fsl_esdhc_imx conversion
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.23.0
Acked-by: Max Krummenacher max.krummenacher@toradex.com
Thanks for fixing this.
I only found two locations where the conversion from FSL_ESDHC to FSL_ESDHC_IMX failed, the one fixed with this patch and of the same pattern one in the colibri_imx6.c board file.
Do you anyway plan to send a similar patch set for Colibri iMX6? Otherwise I will prepare a fixup patch for the specific issue addressed here for Colibri iMX6.
Max
On Tue, Sep 3, 2019 at 9:58 AM Max Krummenacher < max.krummenacher@toradex.com> wrote:
Indeed, no worries, I will send a similar one fixing colibri as well.
Thanks,
Max Krummenacher
Peng Fan
Ricardo Salveti
