[U-Boot] [PATCH 1/3] sunxi: Add EMAC ethernet0 alias for H3 dtsi
The sunxi ethernet address generation code looks for ethernet[0-3] aliases to find ethernet controllers to generate MAC addresses for.
Without a valid address, the driver fails to register.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/dts/sun8i-h3.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/sun8i-h3.dtsi b/arch/arm/dts/sun8i-h3.dtsi index 72c0920466a7..84e52b9cdb29 100644 --- a/arch/arm/dts/sun8i-h3.dtsi +++ b/arch/arm/dts/sun8i-h3.dtsi @@ -48,6 +48,10 @@ / { interrupt-parent = <&gic>;
+ aliases { + ethernet0 = <&emac>; + }; + cpus { #address-cells = <1>; #size-cells = <0>;
The sun8i_emac driver erroneously configures the AHB2 clock when it assumes it is configuring the AXI gates, which is not even documented or ever appeared in either the WiP kernel driver or Allwinner's original driver.
As a result, AHB2 clock mux is set to an invalid setting, making the EPHY unusable.
Fixes: a29710c525ff ("net: Add EMAC driver for H3/A83T/A64 SoCs.") Signed-off-by: Chen-Yu Tsai wens@csie.org --- drivers/net/sun8i_emac.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 4bed50d66808..508fbfea1977 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -599,9 +599,6 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) /* Set clock gating for emac */ setbits_le32(&ccm->ahb_gate0, BIT(AHB_GATE_OFFSET_GMAC));
- /* Set EMAC clock */ - setbits_le32(&ccm->axi_gate, (BIT(1) | BIT(0))); - /* De-assert EMAC */ setbits_le32(&ccm->ahb_reset0_cfg, BIT(AHB_RESET_OFFSET_GMAC)); }
In sun8i_emac_board_setup, the driver partially configures the syscon register for H3 EPHY. However, the settings are incomplete, and completely unusable. The correct settings are later set in sun8i_emac_set_syscon, but the incorrect CLK_SEL setting persists.
It is incorrect to use CLK_SEL to select 25 MHz, as the SoC does not have a 25 MHz clock the EPHY can use.
This patch removes the setting of the syscon register in board_setup, and also moves set_syscon above mdio_init. While mdio_init does not access the PHY, it is better to have the PHY parameters setup before the MDIO bus is registered.
Fixes: a29710c525ff ("net: Add EMAC driver for H3/A83T/A64 SoCs.") Signed-off-by: Chen-Yu Tsai wens@csie.org --- drivers/net/sun8i_emac.c | 10 +--------- 1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 508fbfea1977..7c088c311d1d 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -22,10 +22,6 @@ #include <miiphy.h> #include <net.h>
-#define SCTL_EMAC_TX_CLK_SRC_MII BIT(0) -#define SCTL_EMAC_EPIT_MII BIT(2) -#define SCTL_EMAC_CLK_SEL BIT(18) /* 25 Mhz */ - #define MDIO_CMD_MII_BUSY BIT(0) #define MDIO_CMD_MII_WRITE BIT(1)
@@ -589,9 +585,6 @@ static void sun8i_emac_board_setup(struct emac_eth_dev *priv) /* Set clock gating for ephy */ setbits_le32(&ccm->bus_gate4, BIT(AHB_GATE_OFFSET_EPHY));
- /* Set Tx clock source as MII with rate 25 MZ */ - setbits_le32(priv->sysctl_reg, SCTL_EMAC_TX_CLK_SRC_MII | - SCTL_EMAC_EPIT_MII | SCTL_EMAC_CLK_SEL); /* Deassert EPHY */ setbits_le32(&ccm->ahb_reset2_cfg, BIT(AHB_RESET_OFFSET_EPHY)); } @@ -693,12 +686,11 @@ static int sun8i_emac_eth_probe(struct udevice *dev) priv->mac_reg = (void *)pdata->iobase;
sun8i_emac_board_setup(priv); + sun8i_emac_set_syscon(priv);
sun8i_mdio_init(dev->name, priv); priv->bus = miiphy_get_dev_by_name(dev->name);
- sun8i_emac_set_syscon(priv); - return sun8i_phy_init(priv, dev); }
Thanks I've merged the entire series, note that I've also added a patch disabling the driver for now as it still has some issues, see the other mail I've send on this.
Regards,
Hans
- aliases {
- cpus { #address-cells = <1>; #size-cells = <0>;
Chen-Yu Tsai
Hans de Goede
