[U-Boot] v2012.10-rc2 is now released
Hey all,
I've tagged and pushed v2012.10-rc2. It's a little later than I had intended, but I think we're still largely on track for -rc3. That said, lets push -rc3 back to next monday and give a little more time between Albert's u-boot-arm PR being merged and the tag. Speaking of, that's what I expect for the big changes to be between now and then:
- Albert said he plans to have a PR ready by Thursday, that needs to go in. - It also NEEDS to have a resolution, for this release, for the ARMv7/unaligned access/gcc 4.7 (and linaro 4.6) thing. - Other pull requests of either fixes or things posted by the original merge window closure that hadn't been picked up yet AND are obviously correct or important bug fixes. Otherwise we can hold them off for the next branches.
As a reminder, the next branch is open and I haven't seen any pull requests for that yet, aside from Marek on some of the pre-reqs for DM work.
Hi Tom,
Am Montag 01 Oktober 2012, 18:59:18 schrieb Tom Rini:
Did you see this?
http://patchwork.ozlabs.org/patch/188165/
I don't know if the tag (for-rc) i used was right. In case you already saw this, i'm excusing for the noise ;)
On Mon, Oct 01, 2012 at 11:53:39PM +0200, Michael Walle wrote:
Hi Tom,
Did you see this?
I have this flagged locally if Albert and Prafulla don't pick it up in time.
Hi Tom,
On Mon, 1 Oct 2012 09:59:18 -0700, Tom Rini trini@ti.com wrote:
Hey all,
I am also expecting a Marvell pull request to come before thursday. Prafulla?
For 2012.07 there was a -mno-unaligned-access option added to all of armv7 in a last-minute attempt to get the release working while a solution was found, and after that no one seemed bothered enough to handle things.
For 2012.10 we still don't have a solution but we have a root cause and the long term solution is to get the compiler fixed, which implies doing a patch -- I've got this effort started. Meanwhile, I see no point in redoing for 2012.10 was was done for 2012.07, seeing how it ended up. Therefore I will add -mno-unaligned-access only to the files which require it. I'll send a patch later today for this.
I have see Tom's tegra pull. for my next. Priority for me right now is the release.
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: 02 October 2012 11:57 To: Tom Rini Cc: u-boot@lists.denx.de; Wolfgang Denk; Prafulla Wadaskar Subject: Re: v2012.10-rc2 is now released
Hi Tom,
Hey all,
said,
between
that's
go
in.
Hi Albert, I will provide the pull request today, (ASAP)
Regards... Prafulla . . .
Hey all,
We wanted to let you know that we tested this version on our CM-T35 and CM-T37 modules, and everything was in order. The tests included:
* Various network tests via Ethernet: DHCP, ping, downloading file with TFTP, switching between ethernet controllers. * NAND tests: writing (sw and hw ecc), reading, switching between ecc types in between writes. * Accessing an EEPROM via I2C, switching between I2C busses. * Reading from MMC card.
participants (5)
Albert ARIBAUD
Michael Walle
Nikita Kiryanov
Prafulla Wadaskar
