[PATCH 1/1] doc: Add reference to U-Boot project in conf.py
With the last update of conf.py the references to U-Boot where replaced by references to Linux.
Fix the project references in the generated documentation.
Reported by: Simon Glass sjg@chromium.org Fixes: 98f01cf7a22e ("doc: update Kernel documentation build system") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/conf.py | 24 +++++++++++++----------- 1 file changed, 13 insertions(+), 11 deletions(-)
diff --git a/doc/conf.py b/doc/conf.py index 3f456a18f5..eb74b86aef 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -147,9 +147,9 @@ source_suffix = '.rst' master_doc = 'index'
# General information about the project. -project = 'The Linux Kernel' -copyright = 'The kernel development community' -author = 'The kernel development community' +project = 'Das U-Boot' +copyright = 'The U-Boot development community' +author = 'The U-Boot development community'
# The version info for the project you're documenting, acts as replacement for # |version| and |release|, also used in various other places throughout the @@ -260,7 +260,7 @@ except ImportError:
# The name of an image file (relative to this directory) to place at the top # of the sidebar. -#html_logo = None +html_logo = '../tools/logos/u-boot_logo.svg'
# The name of an image file (within the static path) to use as favicon of the # docs. This file should be a Windows icon file (.ico) being 16x16 or 32x32 @@ -340,7 +340,7 @@ html_use_smartypants = False #html_search_scorer = 'scorer.js'
# Output file base name for HTML help builder. -htmlhelp_basename = 'TheLinuxKerneldoc' +htmlhelp_basename = 'TheUBootdoc'
# -- Options for LaTeX output ---------------------------------------------
@@ -470,6 +470,8 @@ if major == 1 and minor < 6: # author, documentclass [howto, manual, or own class]). # Sorted in alphabetical order latex_documents = [ + ('index', 'u-boot-hacker-manual.tex', 'U-Boot Hacker Manual', + 'The U-Boot development community', 'manual'), ]
# Add all other index files from Documentation/ subdirectories @@ -483,8 +485,8 @@ for fn in os.listdir('.'): break if not has: latex_documents.append((doc, fn + '.tex', - 'Linux %s Documentation' % fn.capitalize(), - 'The kernel development community', + 'U-Boot %s Documentation' % fn.capitalize(), + 'The U-Boot development community', 'manual'))
# The name of an image file (relative to this directory) to place at the top of @@ -513,7 +515,7 @@ for fn in os.listdir('.'): # One entry per manual page. List of tuples # (source start file, name, description, authors, manual section). man_pages = [ - (master_doc, 'thelinuxkernel', 'The Linux Kernel Documentation', + (master_doc, 'dasuboot', 'The U-Boot Documentation', [author], 1) ]
@@ -527,8 +529,8 @@ man_pages = [ # (source start file, target name, title, author, # dir menu entry, description, category) texinfo_documents = [ - (master_doc, 'TheLinuxKernel', 'The Linux Kernel Documentation', - author, 'TheLinuxKernel', 'One line description of project.', + (master_doc, 'DasUBoot', 'The U-Boot Documentation', + author, 'DasUBoot', 'One line description of project.', 'Miscellaneous'), ]
@@ -626,7 +628,7 @@ epub_exclude_files = ['search.html'] # multiple PDF files here actually tries to get the cross-referencing right # *between* PDF files. pdf_documents = [ - ('kernel-documentation', u'Kernel', u'Kernel', u'J. Random Bozo'), + ('uboot-documentation', u'U-Boot', u'U-Boot', u'J. Random Bozo'), ]
# kernel-doc extension configuration for running Sphinx directly (e.g. by Read -- 2.30.0
On Wed, Feb 17, 2021 at 1:41 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Wrong tag. Should be: "Reported-by"
Reported-by: Bin Meng bmeng.cn@gmail.com
See https://lists.denx.de/pipermail/u-boot/2021-February/439615.html
Otherwise: Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
