imx8m: composite clock wrong clock parent ?
I am working on a i.MX8MM based board and I got issue to make the Ethernet phy work. I noticed that the MDIO clock is not configured properly and the FEC outputs a 26,6MHz MDIO clock. That's because the clk_get_rate() call at line 1389 returns 24MHz whereas it should returns 266MHz as it is set in the device tree and configured in the SoC:
BIOS> md.l 0x30388880 1 30388880: 11000000
With some debug traces we can see that the enet_axi's parent is wrong:
fecmxc_probe 1388 clk_get_rate 447: clk clock-controller@30380000 clk_get_rate 447: clk enet1_root_clk clk_get_rate 447: clk enet_axi clk_get_parent_rate 489: clk enet_axi parent clock-osc-24m clk_get_parent_rate 489: clk enet1_root_clk parent enet_axi fecmxc_probe 1390
Is this a known issue ?
Regards,
Hi Sébastien,
On Mon, Feb 17, 2020 at 6:57 AM Sébastien Szymanski sebastien.szymanski@armadeus.com wrote:
It seems someone needs to work on a drivers/clk/imx/clk-imx8mq.c driver.
Regards,
Fabio Estevam
Subject: imx8m: composite clock wrong clock parent ?
There is an issue in current clk framework in U-Boot, it could not runtime set the parent of a clk, and I have not find time to work on this. I not check whether your issue is related the upper issue in CCF.
Regards, Peng.
Regards,
-- Sébastien Szymanski, Armadeus Systems Software engineer
Fabio Estevam
Peng Fan
Sébastien Szymanski
