[U-Boot] [PATCH 1/2] cmd: Move CONFIG_RANDOM_UUID to Kconfig
CONFIG_RANDOM_UUID is used by the GPT command to generate random UUID when none are provided.
Move that option to Kconfig.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- cmd/Kconfig | 7 +++++++ configs/evb-rv1108_defconfig | 1 + configs/rock_defconfig | 1 + include/configs/am57xx_evm.h | 1 - include/configs/dra7xx_evm.h | 1 - include/configs/edison.h | 1 - include/configs/odroid.h | 1 - include/configs/rockchip-common.h | 2 -- include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/vinco.h | 1 - include/configs/xilinx_zynqmp.h | 1 - scripts/config_whitelist.txt | 1 - 13 files changed, 9 insertions(+), 11 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index cd72ea8e56a9..5e2885bbaa95 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -591,10 +591,17 @@ config CMD_GPT bool "GPT (GUID Partition Table) command" select PARTITION_UUIDS select EFI_PARTITION + imply RANDOM_UUID help Enable the 'gpt' command to ready and write GPT style partition tables.
+config RANDOM_UUID + bool "GPT Random UUID generation" + help + Enable the generation of partitions with random UUIDs if none + are provided. + config CMD_GPT_RENAME bool "GPT partition renaming commands" depends on CMD_GPT diff --git a/configs/evb-rv1108_defconfig b/configs/evb-rv1108_defconfig index 3deea7c0dcb1..a43683041359 100644 --- a/configs/evb-rv1108_defconfig +++ b/configs/evb-rv1108_defconfig @@ -7,6 +7,7 @@ CONFIG_DEBUG_UART=y CONFIG_ENV_IS_NOWHERE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_CMD_IMLS is not set +CONFIG_RANDOM_UUID=y CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 2ad6a6c521da..b03856889981 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -14,6 +14,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 # CONFIG_CMD_IMLS is not set +CONFIG_RANDOM_UUID=y CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 9f07bba0c898..4de59a644fb6 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -72,7 +72,6 @@ #include <configs/ti_omap5_common.h>
/* Enhance our eMMC support / experience. */ -#define CONFIG_RANDOM_UUID #define CONFIG_HSMMC2_8BIT
/* CPSW Ethernet */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 1a58c6ef24f2..0d847808e021 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -100,7 +100,6 @@ #include <configs/ti_omap5_common.h>
/* CPSW Ethernet */ diff --git a/include/configs/edison.h b/include/configs/edison.h index 03aa70230619..bec79496441c 100644 --- a/include/configs/edison.h +++ b/include/configs/edison.h @@ -14,7 +14,6 @@ #define CONFIG_BOOTCOMMAND "run bootcmd"
/* DISK Partition support */ -#define CONFIG_RANDOM_UUID
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 563854d9bbbf..22686657b62a 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -175,7 +175,6 @@ "fdtaddr=40800000\0"
/* GPT */ -#define CONFIG_RANDOM_UUID
/* Security subsystem - enable hw_rand() */ #define CONFIG_EXYNOS_ACE_SHA diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 29a492dc5529..bd3364a81bd9 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -27,8 +27,6 @@ func(DHCP, dchp, na) #endif
-#define CONFIG_RANDOM_UUID - #ifdef CONFIG_ARM64 #define ROOT_UUID "B921B045-1DF0-41C3-AF44-4C6F280D3FAE;\0" #else diff --git a/include/configs/trats.h b/include/configs/trats.h index 3059d89ac90f..08cd7cf266a8 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -170,7 +170,6 @@ #define CONFIG_SYS_SPL_ARGS_ADDR CONFIG_SYS_SDRAM_BASE + 0x100
/* Security subsystem - enable hw_rand() */ #define CONFIG_EXYNOS_ACE_SHA diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 1f3ce9d94104..b523b6d1b8ae 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -151,7 +151,6 @@ "fdtaddr=40800000\0" \
/* Security subsystem - enable hw_rand() */ #define CONFIG_EXYNOS_ACE_SHA diff --git a/include/configs/vinco.h b/include/configs/vinco.h index adff1b6d7f71..a0c522c86781 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -59,7 +59,6 @@ #define CONFIG_SYS_MMC_CLK_OD 500000
/* For generating MMC partitions */ -#define CONFIG_RANDOM_UUID
#endif
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 77d7899deff4..3b1119f94e51 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -114,7 +114,6 @@ # define CONFIG_FASTBOOT_FLASH_MMC_DEV 0 # endif
-# define CONFIG_RANDOM_UUID # define PARTS_DEFAULT \ "partitions=uuid_disk=${uuid_gpt_disk};" \ "name=""boot"",size=16M,uuid=${uuid_gpt_boot};" \ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4689d6310f0c..50ac011a6bdd 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1903,7 +1903,6 @@ CONFIG_RAMDISK_ADDR CONFIG_RAMDISK_BOOT CONFIG_RAM_BOOT CONFIG_RAM_BOOT_PHYS -CONFIG_RANDOM_UUID CONFIG_RCAR_BOARD_STRING CONFIG_RD_LVL CONFIG_REALMODE_DEBUG
GPT is pretty common these days and can be useful for things like fastboot. Add a platform imply, so that users can still opt out if they wish so.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 9cfeedeebd95..efb4769a9ea1 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -680,6 +680,7 @@ config ARCH_SUNXI select USB_STORAGE if DISTRO_DEFAULTS select USB_KEYBOARD if DISTRO_DEFAULTS select USE_TINY_PRINTF + imply CMD_GPT imply FAT_WRITE imply PRE_CONSOLE_BUFFER imply SPL_GPIO_SUPPORT
On Thu, Aug 24, 2017 at 3:26 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
thanks!
Jagan Teki
Maxime Ripard
