[U-Boot] [PATCH 1/1 v2] ppc4xx: Reset and relock memory DLL after SDRAM_CLKTR change
After changing SDRAM_CLKTR phase value rerun the memory preload initialization sequence (INITPLR) to reset and relock the memory DLL. Changing the SDRAM_CLKTR memory clock phase coarse timing adjustment effects the phase relationship of the internal, to the PPC chip, and external, to the PPC chip, versions of MEMCLK_OUT.
Signed-off-by: Adam Graham agraham@amcc.com Signed-off-by: Victor Gallardo vgallardo@amcc.com --- v2: - fix commit text. line to long.
cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c | 21 +++++++++++++++++++++ 1 files changed, 21 insertions(+), 0 deletions(-)
diff --git a/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c b/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c index 83b9883..47ab39b 100644 --- a/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c +++ b/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c @@ -174,6 +174,23 @@ static inline void ecc_clear_status_reg(void) #endif }
+/* + * Reset and relock memory DLL after SDRAM_CLKTR change + */ +static inline void relock_memory_DLL(void) +{ + u32 reg; + + mtsdram(SDRAM_MCOPT2, SDRAM_MCOPT2_IPTR_EXECUTE); + + do { + mfsdram(SDRAM_MCSTAT, reg); + } while (!(reg & SDRAM_MCSTAT_MIC_COMP)); + + mfsdram(SDRAM_MCOPT2, reg); + mtsdram(SDRAM_MCOPT2, reg | SDRAM_MCOPT2_DCEN_ENABLE); +} + static int ecc_check_status_reg(void) { u32 ecc_status; @@ -981,6 +998,8 @@ u32 DQS_autocalibration(void)
mtsdram(SDRAM_CLKTR, clkp << 30);
+ relock_memory_DLL(); + putc('\b'); putc(slash[loopi++ % 8]);
@@ -1170,6 +1189,8 @@ u32 DQS_autocalibration(void)
mtsdram(SDRAM_CLKTR, tcal.clocks.clktr << 30);
+ relock_memory_DLL(); + mfsdram(SDRAM_RQDC, rqdc_reg); rqdc_reg &= ~(SDRAM_RQDC_RQFD_MASK); mtsdram(SDRAM_RQDC, rqdc_reg |
Applied ppc4xx/master. Thanks.
Best regards, Stefan
Adam,
Ups. I just gave this version another try on my 600MHz Kilauea board. And as it seems it definitely works better than without this patch, but it doesn't work reliably. :-(
Here some outputs after rebooting:
U-Boot 2008.10-rc2-02708-gf8a00de (Oct 8 2008 - 11:40:49)
CPU: AMCC PowerPC 405EX Rev. C at 600 MHz (PLB=200, OPB=100, EBC=100 MHz) Security support Bootstrap Option H - Boot ROM Location I2C (Addr 0x52) 16 kB I-Cache 16 kB D-Cache Board: Kilauea - AMCC PPC405EX Evaluation Board I2C: ready DTT1: FAILED DRAM: 256 MB
CPU: AMCC PowerPC 405EX Rev. C at 600 MHz (PLB=200, OPB=100, EBC=100 MHz) Security support Bootstrap Option H - Boot ROM Location I2C (Addr 0x52) 16 kB I-Cache 16 kB D-Cache Board: Kilauea - AMCC PPC405EX Evaluation Board I2C: ready DTT1: FAILED DRAM: 256 MB Memory error at 01cff924, wrote 00000200, read aaaa0200 !
This didn't happen with the temporary patch you sent out a few weeks ago. This error occurs often after pushing the reset button on the Kilauea. I suggest that you take another look at this issue on your 600MHz board. Perhaps make a long test by setting "bootcmd" to "reset". If the board still resets after running for some hours, then you should be safe.
BTW: I won't ask Wolfgang to pull for now.
Thanks.
Hi Stefan,
We will take a look.
Yes, we ran the test as you mentioned (bootcmd=reset) on both versions of the Kilauea board and let it run for 24 hours without any problems. Hopefully we can reproduce the problem you are seeing.
Thanks,
Victor Gallardo
________________________________
From: Stefan Roese [mailto:sr@denx.de] Sent: Wed 10/8/2008 2:47 AM To: u-boot@lists.denx.de Cc: Adam Graham; Victor Gallardo Subject: Re: [U-Boot] [PATCH 1/1 v2] ppc4xx: Reset and relock memory DLL after SDRAM_CLKTR change
Adam,
Thanks.
Adam Graham
Stefan Roese
Victor Gallardo
