[PATCH] sunxi: pinephone: detect existed magnetometer and fixup dtb
In newer 1.2 PinePhone board revisions LIS3MDL magnetometer was replaced by AF8133J. They use the same PB1 pin in different modes.
LIS3MDL uses it as an gpio input to handle interrupt. AF8133J uses it as an gpio output as a reset signal.
It wasn't possible at runtime to enable both device tree nodes and detect supported sensor at probe time.
AF8133J has reset pin (PB1) connected to the SoC. By default AF8133J is in a reset state and don't respond to probe request on I2C bus. Extra code would be needed to handle reset signal. Therefore this code uses LIS3MDL magnetometer instead of AF8133J.
Introducing new dts 1.2b with AF8133J sensor would require probing in SPL. That would lead to pulling in into SPL I2C controller driver, RSB controller driver, introducing new AXP803 driver to power-up sensors for probe. It's working, but SPL is pretty size-constrained on A64 and doesn't have much space. Therefore fdt fixup is done in U-Boot proper without introducing new board revision and new dts.
Signed-off-by: Andrey Skvortsov andrej.skvortzov@gmail.com Link: https://lore.kernel.org/all/20240908214718.36316-1-andrej.skvortzov@gmail.co... Link: https://lists.denx.de/pipermail/u-boot/2024-February/545700.html ---
This patch was discussed previously as RFC. [1] All relevant kernel device-tree changes are merged. [2]
1. https://lists.denx.de/pipermail/u-boot/2024-February/545700.html 2. https://lore.kernel.org/all/20240908214718.36316-1-andrej.skvortzov@gmail.co...
board/sunxi/board.c | 23 +++++++++++++++++++++++ configs/pinephone_defconfig | 1 + 2 files changed, 24 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 824c322a0dc..703081b403f 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -14,6 +14,7 @@ #include <dm.h> #include <env.h> #include <hang.h> +#include <i2c.h> #include <image.h> #include <init.h> #include <log.h> @@ -876,6 +877,27 @@ static void bluetooth_dt_fixup(void *blob) "local-bd-address", bdaddr, ETH_ALEN, 1); }
+#define PINEPHONE_LIS3MDL_I2C_ADDR 0x1E +#define PINEPHONE_LIS3MDL_I2C_BUS 1 /* I2C1 */ + +static void board_dt_fixup(void *blob) +{ + struct udevice *bus, *dev; + + if (IS_ENABLED(CONFIG_PINEPHONE_DT_SELECTION) && + !fdt_node_check_compatible(blob, 0, "pine64,pinephone-1.2")) { + if (!uclass_get_device_by_seq(UCLASS_I2C, PINEPHONE_LIS3MDL_I2C_BUS, &bus)) { + dm_i2c_probe(bus, PINEPHONE_LIS3MDL_I2C_ADDR, 0, &dev); + fdt_set_status_by_compatible( + blob, "st,lis3mdl-magn", + dev ? FDT_STATUS_OKAY : FDT_STATUS_DISABLED); + fdt_set_status_by_compatible( + blob, "voltafield,af8133j", + dev ? FDT_STATUS_DISABLED : FDT_STATUS_OKAY); + } + } +} + int ft_board_setup(void *blob, struct bd_info *bd) { int __maybe_unused r; @@ -889,6 +911,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) fdt_fixup_ethernet(blob);
bluetooth_dt_fixup(blob); + board_dt_fixup(blob);
#ifdef CONFIG_VIDEO_DT_SIMPLEFB r = sunxi_simplefb_setup(blob); diff --git a/configs/pinephone_defconfig b/configs/pinephone_defconfig index 9d39204a439..0f9ab0c4662 100644 --- a/configs/pinephone_defconfig +++ b/configs/pinephone_defconfig @@ -11,6 +11,7 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_PINEPHONE_DT_SELECTION=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_OF_LIST="sun50i-a64-pinephone-1.1 sun50i-a64-pinephone-1.2" +CONFIG_SYS_I2C_MVTWSI=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y
On Thu, 14 Nov 2024 01:28:48 +0300 Andrey Skvortsov andrej.skvortzov@gmail.com wrote:
Hi Andrey,
thanks for sending the patch and addressing this issue!
I wish board vendors would include a simple detectable revision encoding, like three GPIOs each pulled either to GND or VCC, to make detecting a board revision easier, but here we go ...
That's completely fine, I like this solution better. First: the less code we have in the SPL the better. And secondly: Yes, there is some natural DT selection in the SPL, courtesy of the FIT image, but it's quite wasteful, since we carry multiple almost identical DT copies.
So doing this kind of patching in U-Boot proper is the better solution - as long as U-Boot doesn't depend on the patch (as in eMMC vs. SPI).
Reviewed-by: Andre Przywara andre.przywara@arm.com
I took the freedom to improve the formatting/line breaks a bit.
Queued for the next PR.
Cheers, Andre
- https://lists.denx.de/pipermail/u-boot/2024-February/545700.html
- https://lore.kernel.org/all/20240908214718.36316-1-andrej.skvortzov@gmail.co...
- struct udevice *bus, *dev;
- if (IS_ENABLED(CONFIG_PINEPHONE_DT_SELECTION) &&
- board_dt_fixup(blob);
Andre Przywara
Andrey Skvortsov
