[U-Boot] [PATCH] ppc: Remove PCIPPC2 and PCIPPC6 boards
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files.
Signed-off-by: Stefan Roese sr@denx.de Cc: Guillaume Alexandre guillaume.alexandre@gespac.ch Cc: Wolfgang Denk wd@denx.de --- MAINTAINERS | 3 - arch/powerpc/cpu/74xx_7xx/cpu.c | 7 +- board/pcippc2/Makefile | 47 ---- board/pcippc2/cpc710.h | 96 ------- board/pcippc2/cpc710_init_ram.c | 232 --------------- board/pcippc2/cpc710_pci.c | 309 -------------------- board/pcippc2/cpc710_pci.h | 51 ---- board/pcippc2/flash.c | 573 -------------------------------------- board/pcippc2/fpga_serial.c | 125 --------- board/pcippc2/fpga_serial.h | 33 --- board/pcippc2/hardware.h | 48 ---- board/pcippc2/i2c.c | 257 ----------------- board/pcippc2/i2c.h | 36 --- board/pcippc2/ns16550.h | 41 --- board/pcippc2/pcippc2.c | 253 ----------------- board/pcippc2/pcippc2.h | 51 ---- board/pcippc2/pcippc2_fpga.c | 87 ------ board/pcippc2/pcippc2_fpga.h | 49 ---- board/pcippc2/sconsole.c | 162 ----------- board/pcippc2/sconsole.h | 48 ---- boards.cfg | 2 - doc/driver-model/UDM-pci.txt | 4 - doc/driver-model/UDM-watchdog.txt | 5 - drivers/rtc/mk48t59.c | 14 - include/configs/PCIPPC2.h | 251 ----------------- include/configs/PCIPPC6.h | 265 ------------------ 26 files changed, 3 insertions(+), 3046 deletions(-) delete mode 100644 board/pcippc2/Makefile delete mode 100644 board/pcippc2/cpc710.h delete mode 100644 board/pcippc2/cpc710_init_ram.c delete mode 100644 board/pcippc2/cpc710_pci.c delete mode 100644 board/pcippc2/cpc710_pci.h delete mode 100644 board/pcippc2/flash.c delete mode 100644 board/pcippc2/fpga_serial.c delete mode 100644 board/pcippc2/fpga_serial.h delete mode 100644 board/pcippc2/hardware.h delete mode 100644 board/pcippc2/i2c.c delete mode 100644 board/pcippc2/i2c.h delete mode 100644 board/pcippc2/ns16550.h delete mode 100644 board/pcippc2/pcippc2.c delete mode 100644 board/pcippc2/pcippc2.h delete mode 100644 board/pcippc2/pcippc2_fpga.c delete mode 100644 board/pcippc2/pcippc2_fpga.h delete mode 100644 board/pcippc2/sconsole.c delete mode 100644 board/pcippc2/sconsole.h delete mode 100644 include/configs/PCIPPC2.h delete mode 100644 include/configs/PCIPPC6.h
diff --git a/MAINTAINERS b/MAINTAINERS index 674780a..95bfcec 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -150,9 +150,6 @@ Wolfgang Denk wd@denx.de
P3G4 MPC7410
- PCIPPC2 MPC750 - PCIPPC6 MPC750 - Phil Edworthy phil.edworthy@renesas.com
rsk7264 SH7264 diff --git a/arch/powerpc/cpu/74xx_7xx/cpu.c b/arch/powerpc/cpu/74xx_7xx/cpu.c index b6a31b4..17694a1 100644 --- a/arch/powerpc/cpu/74xx_7xx/cpu.c +++ b/arch/powerpc/cpu/74xx_7xx/cpu.c @@ -229,8 +229,7 @@ soft_restart(unsigned long addr) }
-#if !defined(CONFIG_PCIPPC2) && \ - !defined(CONFIG_BAB7xx) && \ +#if !defined(CONFIG_BAB7xx) && \ !defined(CONFIG_ELPPC) && \ !defined(CONFIG_PPMC7XX) /* no generic way to do board reset. simply call soft_reset. */ @@ -288,13 +287,13 @@ unsigned long get_tbclk(void) /* ------------------------------------------------------------------------- */
#if defined(CONFIG_WATCHDOG) -#if !defined(CONFIG_PCIPPC2) && !defined(CONFIG_BAB7xx) +#if !defined(CONFIG_BAB7xx) void watchdog_reset(void) {
} -#endif /* !CONFIG_PCIPPC2 && !CONFIG_BAB7xx */ +#endif /* !CONFIG_BAB7xx */ #endif /* CONFIG_WATCHDOG */
/* ------------------------------------------------------------------------- */ diff --git a/board/pcippc2/Makefile b/board/pcippc2/Makefile deleted file mode 100644 index 6f0a928..0000000 --- a/board/pcippc2/Makefile +++ /dev/null @@ -1,47 +0,0 @@ -# -# (C) Copyright 2002-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS = $(BOARD).o cpc710_pci.o flash.o sconsole.o \ - fpga_serial.o pcippc2_fpga.o cpc710_init_ram.o i2c.o - -SOBJS = - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/pcippc2/cpc710.h b/board/pcippc2/cpc710.h deleted file mode 100644 index 8167270..0000000 --- a/board/pcippc2/cpc710.h +++ /dev/null @@ -1,96 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _CPC710_H_ -#define _CPC710_H_ - -/* Revision */ -#define CPC710_TYPE_100 0x80 -#define CPC710_TYPE_100P 0x90 - -/* System control area */ -#define HW_PHYS_SCA 0xff000000 - -#define HW_SCA_CPC0 0x000000 -#define HW_SCA_SDRAM0 0x000000 -#define HW_SCA_DMA0 0x1C0000 - -#define HW_PHYS_CPC0 (HW_PHYS_SCA + HW_SCA_CPC0) -#define HW_PHYS_SDRAM0 (HW_PHYS_SCA + HW_SCA_SDRAM0) - -#define HW_CPC0_PCICNFR 0x000c -#define HW_CPC0_RSTR 0x0010 -#define HW_CPC0_SPOR 0x00e8 -#define HW_CPC0_UCTL 0x1000 -#define HW_CPC0_SIOC0 0x1020 -#define HW_CPC0_ABCNTL 0x1030 -#define HW_CPC0_SESR 0x1060 -#define HW_CPC0_SEAR 0x1070 -#define HW_CPC0_PGCHP 0x1100 -#define HW_CPC0_RGBAN0 0x1110 -#define HW_CPC0_RGBAN1 0x1120 - -#define HW_CPC0_GPDIR 0x1130 -#define HW_CPC0_GPIN 0x1140 -#define HW_CPC0_GPOUT 0x1150 - -#define HW_CPC0_ATAS 0x1160 - -#define HW_CPC0_PCIBAR 0x200018 -#define HW_CPC0_PCIENB 0x201000 - -#define HW_SDRAM0_MCCR 0x1200 -#define HW_SDRAM0_MESR 0x1220 -#define HW_SDRAM0_MEAR 0x1230 - -#define HW_SDRAM0_MCER0 0x1300 -#define HW_SDRAM0_MCER1 0x1310 -#define HW_SDRAM0_MCER2 0x1320 -#define HW_SDRAM0_MCER3 0x1330 -#define HW_SDRAM0_MCER4 0x1340 -#define HW_SDRAM0_MCER5 0x1350 -#define HW_SDRAM0_MCER6 0x1360 -#define HW_SDRAM0_MCER7 0x1370 - -#define HW_BRIDGE_PCIDG 0xf6120 -#define HW_BRIDGE_INTACK 0xf7700 -#define HW_BRIDGE_PIBAR 0xf7800 -#define HW_BRIDGE_PMBAR 0xf7810 -#define HW_BRIDGE_CRR 0xf7ef0 -#define HW_BRIDGE_PR 0xf7f20 -#define HW_BRIDGE_ACR 0xf7f30 -#define HW_BRIDGE_MSIZE 0xf7f40 -#define HW_BRIDGE_IOSIZE 0xf7f60 -#define HW_BRIDGE_SMBAR 0xf7f80 -#define HW_BRIDGE_SIBAR 0xf7fc0 -#define HW_BRIDGE_CFGADDR 0xf8000 -#define HW_BRIDGE_CFGDATA 0xf8010 -#define HW_BRIDGE_PSSIZE 0xf8100 -#define HW_BRIDGE_BARPS 0xf8120 -#define HW_BRIDGE_PSBAR 0xf8140 - -/* Configuration space registers */ -#define CPC710_BUS_NUMBER 0x40 -#define CPC710_SUB_BUS_NUMBER 0x41 - -#endif diff --git a/board/pcippc2/cpc710_init_ram.c b/board/pcippc2/cpc710_init_ram.c deleted file mode 100644 index 8945351..0000000 --- a/board/pcippc2/cpc710_init_ram.c +++ /dev/null @@ -1,232 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <asm/io.h> - -#include "pcippc2.h" -#include "i2c.h" - -typedef struct cpc710_mem_org_s { - u8 rows; - u8 cols; - u8 banks2; - u8 org; -} cpc710_mem_org_t; - -static int cpc710_compute_mcer (u32 * mcer, - unsigned long *size, unsigned int sdram); -static int cpc710_eeprom_checksum (unsigned int sdram); -static u8 cpc710_eeprom_read (unsigned int sdram, unsigned int offset); - -static u32 cpc710_mcer_mem[] = { - 0x000003f3, /* 18 lines, 4 Mb */ - 0x000003e3, /* 19 lines, 8 Mb */ - 0x000003c3, /* 20 lines, 16 Mb */ - 0x00000383, /* 21 lines, 32 Mb */ - 0x00000303, /* 22 lines, 64 Mb */ - 0x00000203, /* 23 lines, 128 Mb */ - 0x00000003, /* 24 lines, 256 Mb */ - 0x00000002, /* 25 lines, 512 Mb */ - 0x00000001 /* 26 lines, 1024 Mb */ -}; -static cpc710_mem_org_t cpc710_mem_org[] = { - {0x0c, 0x09, 0x02, 0x00}, /* 0000: 12/ 9/2 */ - {0x0d, 0x09, 0x02, 0x00}, /* 0000: 13/ 9/2 */ - {0x0d, 0x0a, 0x02, 0x00}, /* 0000: 13/10/2 */ - {0x0d, 0x0b, 0x02, 0x00}, /* 0000: 13/11/2 */ - {0x0d, 0x0c, 0x02, 0x00}, /* 0000: 13/12/2 */ - {0x0e, 0x0c, 0x02, 0x00}, /* 0000: 14/12/2 */ - {0x0b, 0x08, 0x02, 0x01}, /* 0001: 11/ 8/2 */ - {0x0b, 0x09, 0x01, 0x02}, /* 0010: 11/ 9/1 */ - {0x0b, 0x0a, 0x01, 0x03}, /* 0011: 11/10/1 */ - {0x0c, 0x08, 0x02, 0x04}, /* 0100: 12/ 8/2 */ - {0x0c, 0x0a, 0x02, 0x05}, /* 0101: 12/10/2 */ - {0x0d, 0x08, 0x01, 0x06}, /* 0110: 13/ 8/1 */ - {0x0d, 0x08, 0x02, 0x07}, /* 0111: 13/ 8/2 */ - {0x0d, 0x09, 0x01, 0x08}, /* 1000: 13/ 9/1 */ - {0x0d, 0x0a, 0x01, 0x09}, /* 1001: 13/10/1 */ - {0x0b, 0x08, 0x01, 0x0a}, /* 1010: 11/ 8/1 */ - {0x0c, 0x08, 0x01, 0x0b}, /* 1011: 12/ 8/1 */ - {0x0c, 0x09, 0x01, 0x0c}, /* 1100: 12/ 9/1 */ - {0x0e, 0x09, 0x02, 0x0d}, /* 1101: 14/ 9/2 */ - {0x0e, 0x0a, 0x02, 0x0e}, /* 1110: 14/10/2 */ - {0x0e, 0x0b, 0x02, 0x0f} /* 1111: 14/11/2 */ -}; - -unsigned long cpc710_ram_init (void) -{ - unsigned long memsize = 0; - unsigned long bank_size; - u32 mcer; - -#ifndef CONFIG_SYS_RAMBOOT - /* Clear memory banks - */ - out32 (REG (SDRAM0, MCER0), 0); - out32 (REG (SDRAM0, MCER1), 0); - out32 (REG (SDRAM0, MCER2), 0); - out32 (REG (SDRAM0, MCER3), 0); - out32 (REG (SDRAM0, MCER4), 0); - out32 (REG (SDRAM0, MCER5), 0); - out32 (REG (SDRAM0, MCER6), 0); - out32 (REG (SDRAM0, MCER7), 0); - iobarrier_rw (); - - /* Disable memory - */ - out32 (REG (SDRAM0, MCCR), 0x13b06000); - iobarrier_rw (); -#endif - - /* Only the first memory bank is initialised now - */ - if (!cpc710_compute_mcer (&mcer, &bank_size, 0)) { - puts ("Unsupported SDRAM type !\n"); - hang (); - } - memsize += bank_size; -#ifndef CONFIG_SYS_RAMBOOT - /* Enable bank, zero start - */ - out32 (REG (SDRAM0, MCER0), mcer | 0x80000000); - iobarrier_rw (); -#endif - -#ifndef CONFIG_SYS_RAMBOOT - /* Enable memory - */ - out32 (REG (SDRAM0, MCCR), in32 (REG (SDRAM0, MCCR)) | 0x80000000); - - /* Wait until initialisation finished - */ - while (!(in32 (REG (SDRAM0, MCCR)) & 0x20000000)) { - iobarrier_rw (); - } - - /* Clear Memory Error Status and Address registers - */ - out32 (REG (SDRAM0, MESR), 0); - out32 (REG (SDRAM0, MEAR), 0); - iobarrier_rw (); - - /* ECC is not configured now - */ -#endif - - /* Memory size counter - */ - out32 (REG (CPC0, RGBAN1), memsize); - - return memsize; -} - -static int cpc710_compute_mcer (u32 * mcer, unsigned long *size, unsigned int sdram) -{ - u8 rows; - u8 cols; - u8 banks2; - unsigned int lines; - u32 mc = 0; - unsigned int i; - cpc710_mem_org_t *org = 0; - - if (!i2c_reset ()) { - puts ("Can't reset I2C!\n"); - hang (); - } - - if (!cpc710_eeprom_checksum (sdram)) { - puts ("Invalid EEPROM checksum !\n"); - hang (); - } - - rows = cpc710_eeprom_read (sdram, 3); - cols = cpc710_eeprom_read (sdram, 4); - /* Can be 2 or 4 banks; divide by 2 - */ - banks2 = cpc710_eeprom_read (sdram, 17) / 2; - - lines = rows + cols + banks2; - - if (lines < 18 || lines > 26) { - /* Unsupported configuration - */ - return 0; - } - - mc |= cpc710_mcer_mem[lines - 18] << 6; - - for (i = 0; i < sizeof (cpc710_mem_org) / sizeof (cpc710_mem_org_t); - i++) { - cpc710_mem_org_t *corg = cpc710_mem_org + i; - - if (corg->rows == rows && corg->cols == cols - && corg->banks2 == banks2) { - org = corg; - - break; - } - } - - if (!org) { - /* Unsupported configuration - */ - return 0; - } - - mc |= (u32) org->org << 2; - - /* Supported configuration - */ - *mcer = mc; - *size = 1l << (lines + 4); - - return 1; -} - -static int cpc710_eeprom_checksum (unsigned int sdram) -{ - u8 sum = 0; - unsigned int i; - - for (i = 0; i < 63; i++) { - sum += cpc710_eeprom_read (sdram, i); - } - - return sum == cpc710_eeprom_read (sdram, 63); -} - -static u8 cpc710_eeprom_read (unsigned int sdram, unsigned int offset) -{ - u8 dev = (sdram << 1) | 0xa0; - u8 data; - - if (!i2c_read_byte (&data, dev, offset)) { - puts ("I2C error !\n"); - hang (); - } - - return data; -} diff --git a/board/pcippc2/cpc710_pci.c b/board/pcippc2/cpc710_pci.c deleted file mode 100644 index ccd18e1..0000000 --- a/board/pcippc2/cpc710_pci.c +++ /dev/null @@ -1,309 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <asm/io.h> -#include <pci.h> - -#include "hardware.h" -#include "pcippc2.h" - -struct pci_controller local_hose, cpci_hose; - -static u32 cpc710_mapped_ram; - - /* Enable PCI retry timeouts - */ -void cpc710_pci_enable_timeout (void) -{ - out32(BRIDGE(LOCAL, CFGADDR), 0x50000080); - iobarrier_rw(); - out32(BRIDGE(LOCAL, CFGDATA), 0x32000000); - iobarrier_rw(); - - out32(BRIDGE(CPCI, CFGADDR), 0x50000180); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), 0x32000000); - iobarrier_rw(); -} - -void cpc710_pci_init (void) -{ - u32 sdram_size = pcippc2_sdram_size(); - - cpc710_mapped_ram = sdram_size < PCI_MEMORY_MAXSIZE ? - sdram_size : PCI_MEMORY_MAXSIZE; - - /* Select the local PCI - */ - out32(REG(CPC0, PCICNFR), 0x80000002); - iobarrier_rw(); - - out32(REG(CPC0, PCIBAR), BRIDGE_LOCAL_PHYS); - iobarrier_rw(); - - /* Enable PCI bridge address decoding - */ - out32(REG(CPC0, PCIENB), 0x80000000); - iobarrier_rw(); - - /* Select the CPCI bridge - */ - out32(REG(CPC0, PCICNFR), 0x80000003); - iobarrier_rw(); - - out32(REG(CPC0, PCIBAR), BRIDGE_CPCI_PHYS); - iobarrier_rw(); - - /* Enable PCI bridge address decoding - */ - out32(REG(CPC0, PCIENB), 0x80000000); - iobarrier_rw(); - - /* Disable configuration accesses - */ - out32(REG(CPC0, PCICNFR), 0x80000000); - iobarrier_rw(); - - /* Initialise the local PCI - */ - out32(BRIDGE(LOCAL, CRR), 0x7c000000); - iobarrier_rw(); - out32(BRIDGE(LOCAL, PCIDG), 0x40000000); - iobarrier_rw(); - out32(BRIDGE(LOCAL, PIBAR), BRIDGE_LOCAL_IO_BUS); - out32(BRIDGE(LOCAL, SIBAR), BRIDGE_LOCAL_IO_PHYS); - out32(BRIDGE(LOCAL, IOSIZE), -BRIDGE_LOCAL_IO_SIZE); - iobarrier_rw(); - out32(BRIDGE(LOCAL, PMBAR), BRIDGE_LOCAL_MEM_BUS); - out32(BRIDGE(LOCAL, SMBAR), BRIDGE_LOCAL_MEM_PHYS); - out32(BRIDGE(LOCAL, MSIZE), -BRIDGE_LOCAL_MEM_SIZE); - iobarrier_rw(); - out32(BRIDGE(LOCAL, PR), 0x00ffe000); - iobarrier_rw(); - out32(BRIDGE(LOCAL, ACR), 0xfe000000); - iobarrier_rw(); - out32(BRIDGE(LOCAL, PSBAR), PCI_MEMORY_BUS >> 24); - out32(BRIDGE(LOCAL, BARPS), PCI_MEMORY_PHYS >> 24); - out32(BRIDGE(LOCAL, PSSIZE), 256 - (cpc710_mapped_ram >> 24)); - iobarrier_rw(); - - /* Initialise the CPCI bridge - */ - out32(BRIDGE(CPCI, CRR), 0x7c000000); - iobarrier_rw(); - out32(BRIDGE(CPCI, PCIDG), 0xC0000000); - iobarrier_rw(); - out32(BRIDGE(CPCI, PIBAR), BRIDGE_CPCI_IO_BUS); - out32(BRIDGE(CPCI, SIBAR), BRIDGE_CPCI_IO_PHYS); - out32(BRIDGE(CPCI, IOSIZE), -BRIDGE_CPCI_IO_SIZE); - iobarrier_rw(); - out32(BRIDGE(CPCI, PMBAR), BRIDGE_CPCI_MEM_BUS); - out32(BRIDGE(CPCI, SMBAR), BRIDGE_CPCI_MEM_PHYS); - out32(BRIDGE(CPCI, MSIZE), -BRIDGE_CPCI_MEM_SIZE); - iobarrier_rw(); - out32(BRIDGE(CPCI, PR), 0x80ffe000); - iobarrier_rw(); - out32(BRIDGE(CPCI, ACR), 0xdf000000); - iobarrier_rw(); - out32(BRIDGE(CPCI, PSBAR), PCI_MEMORY_BUS >> 24); - out32(BRIDGE(CPCI, BARPS), PCI_MEMORY_PHYS >> 24); - out32(BRIDGE(CPCI, PSSIZE), 256 - (cpc710_mapped_ram >> 24)); - iobarrier_rw(); - - /* Local PCI - */ - - out32(BRIDGE(LOCAL, CFGADDR), 0x04000080); - iobarrier_rw(); - out32(BRIDGE(LOCAL, CFGDATA), 0x56010000); - iobarrier_rw(); - - out32(BRIDGE(LOCAL, CFGADDR), 0x0c000080); - iobarrier_rw(); - out32(BRIDGE(LOCAL, CFGDATA), PCI_LATENCY_TIMER_VAL << 16); - iobarrier_rw(); - - /* Set bus and subbus numbers - */ - out32(BRIDGE(LOCAL, CFGADDR), 0x40000080); - iobarrier_rw(); - out32(BRIDGE(LOCAL, CFGDATA), 0x00000000); - iobarrier_rw(); - - out32(BRIDGE(LOCAL, CFGADDR), 0x50000080); - iobarrier_rw(); - /* PCI retry timeouts will be enabled later - */ - out32(BRIDGE(LOCAL, CFGDATA), 0x00000000); - iobarrier_rw(); - - /* CPCI - */ - - /* Set bus and subbus numbers - */ - out32(BRIDGE(CPCI, CFGADDR), 0x40000080); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), 0x01010000); - iobarrier_rw(); - - out32(BRIDGE(CPCI, CFGADDR), 0x04000180); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), 0x56010000); - iobarrier_rw(); - - out32(BRIDGE(CPCI, CFGADDR), 0x0c000180); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), PCI_LATENCY_TIMER_VAL << 16); - iobarrier_rw(); - - /* Write to the PSBAR */ - out32(BRIDGE(CPCI, CFGADDR), 0x10000180); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), cpu_to_le32(PCI_MEMORY_BUS)); - iobarrier_rw(); - - /* Set bus and subbus numbers - */ - out32(BRIDGE(CPCI, CFGADDR), 0x40000180); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), 0x01ff0000); - iobarrier_rw(); - - out32(BRIDGE(CPCI, CFGADDR), 0x50000180); - iobarrier_rw(); - out32(BRIDGE(CPCI, CFGDATA), 0x32000000); - /* PCI retry timeouts will be enabled later - */ - out32(BRIDGE(CPCI, CFGDATA), 0x00000000); - iobarrier_rw(); - - /* Remove reset on the PCI buses - */ - out32(BRIDGE(LOCAL, CRR), 0xfc000000); - iobarrier_rw(); - out32(BRIDGE(CPCI, CRR), 0xfc000000); - iobarrier_rw(); - - local_hose.first_busno = 0; - local_hose.last_busno = 0xff; - - /* System memory space */ - pci_set_region(local_hose.regions + 0, - PCI_MEMORY_BUS, - PCI_MEMORY_PHYS, - PCI_MEMORY_MAXSIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - /* PCI memory space */ - pci_set_region(local_hose.regions + 1, - BRIDGE_LOCAL_MEM_BUS, - BRIDGE_LOCAL_MEM_PHYS, - BRIDGE_LOCAL_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(local_hose.regions + 2, - BRIDGE_LOCAL_IO_BUS, - BRIDGE_LOCAL_IO_PHYS, - BRIDGE_LOCAL_IO_SIZE, - PCI_REGION_IO); - - local_hose.region_count = 3; - - pci_setup_indirect(&local_hose, - BRIDGE_LOCAL_PHYS + HW_BRIDGE_CFGADDR, - BRIDGE_LOCAL_PHYS + HW_BRIDGE_CFGDATA); - - pci_register_hose(&local_hose); - - /* Initialize PCI32 bus registers */ - pci_hose_write_config_byte(&local_hose, - PCI_BDF(local_hose.first_busno,0,0), - CPC710_BUS_NUMBER, - local_hose.first_busno); - pci_hose_write_config_byte(&local_hose, - PCI_BDF(local_hose.first_busno,0,0), - CPC710_SUB_BUS_NUMBER, - local_hose.last_busno); - - local_hose.last_busno = pci_hose_scan(&local_hose); - - /* Write out correct max subordinate bus number for local hose */ - pci_hose_write_config_byte(&local_hose, - PCI_BDF(local_hose.first_busno,0,0), - CPC710_SUB_BUS_NUMBER, - local_hose.last_busno); - - cpci_hose.first_busno = local_hose.last_busno + 1; - cpci_hose.last_busno = 0xff; - - /* System memory space */ - pci_set_region(cpci_hose.regions + 0, - PCI_MEMORY_BUS, - PCI_MEMORY_PHYS, - PCI_MEMORY_MAXSIZE, - PCI_REGION_SYS_MEMORY); - - /* PCI memory space */ - pci_set_region(cpci_hose.regions + 1, - BRIDGE_CPCI_MEM_BUS, - BRIDGE_CPCI_MEM_PHYS, - BRIDGE_CPCI_MEM_SIZE, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(cpci_hose.regions + 2, - BRIDGE_CPCI_IO_BUS, - BRIDGE_CPCI_IO_PHYS, - BRIDGE_CPCI_IO_SIZE, - PCI_REGION_IO); - - cpci_hose.region_count = 3; - - pci_setup_indirect(&cpci_hose, - BRIDGE_CPCI_PHYS + HW_BRIDGE_CFGADDR, - BRIDGE_CPCI_PHYS + HW_BRIDGE_CFGDATA); - - pci_register_hose(&cpci_hose); - - /* Initialize PCI64 bus registers */ - pci_hose_write_config_byte(&cpci_hose, - PCI_BDF(cpci_hose.first_busno,0,0), - CPC710_BUS_NUMBER, - cpci_hose.first_busno); - pci_hose_write_config_byte(&cpci_hose, - PCI_BDF(cpci_hose.first_busno,0,0), - CPC710_SUB_BUS_NUMBER, - cpci_hose.last_busno); - - cpci_hose.last_busno = pci_hose_scan(&cpci_hose); - - /* Write out correct max subordinate bus number for cpci hose */ - pci_hose_write_config_byte(&cpci_hose, - PCI_BDF(cpci_hose.first_busno,0,0), - CPC710_SUB_BUS_NUMBER, - cpci_hose.last_busno); -} diff --git a/board/pcippc2/cpc710_pci.h b/board/pcippc2/cpc710_pci.h deleted file mode 100644 index 24d0db6..0000000 --- a/board/pcippc2/cpc710_pci.h +++ /dev/null @@ -1,51 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _CPC710_PCI_H_ -#define _CPC710_PCI_H_ - -#define PCI_MEMORY_PHYS 0x00000000 -#define PCI_MEMORY_BUS 0x80000000 -#define PCI_MEMORY_MAXSIZE 0x20000000 - -#define BRIDGE_CPCI_PHYS 0xff500000 -#define BRIDGE_CPCI_MEM_SIZE 0x08000000 -#define BRIDGE_CPCI_MEM_PHYS 0xf0000000 -#define BRIDGE_CPCI_MEM_BUS 0x00000000 -#define BRIDGE_CPCI_IO_SIZE 0x02000000 -#define BRIDGE_CPCI_IO_PHYS 0xfc000000 -#define BRIDGE_CPCI_IO_BUS 0x00000000 - -#define BRIDGE_LOCAL_PHYS 0xff400000 -#define BRIDGE_LOCAL_MEM_SIZE 0x04000000 -#define BRIDGE_LOCAL_MEM_PHYS 0xf8000000 -#define BRIDGE_LOCAL_MEM_BUS 0x40000000 -#define BRIDGE_LOCAL_IO_SIZE 0x01000000 -#define BRIDGE_LOCAL_IO_PHYS 0xfe000000 -#define BRIDGE_LOCAL_IO_BUS 0x04000000 - -#define BRIDGE(r, x) (BRIDGE_##r##_PHYS + HW_BRIDGE_##x) - -#define PCI_LATENCY_TIMER_VAL 0xff - -#endif diff --git a/board/pcippc2/flash.c b/board/pcippc2/flash.c deleted file mode 100644 index ec604e0..0000000 --- a/board/pcippc2/flash.c +++ /dev/null @@ -1,573 +0,0 @@ -/* - * (C) Copyright 2001 - * Josh Huber huber@mclx.com, Mission Critical Linux, Inc. - * - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <flash.h> -#include <asm/io.h> - -/*---------------------------------------------------------------------*/ -#undef DEBUG_FLASH - -#ifdef DEBUG_FLASH -#define DEBUGF(fmt,args...) printf(fmt ,##args) -#else -#define DEBUGF(fmt,args...) -#endif -/*---------------------------------------------------------------------*/ - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -static ulong flash_get_size (ulong addr, flash_info_t *info); -static int flash_get_offsets (ulong base, flash_info_t *info); -static int write_word (flash_info_t *info, ulong dest, ulong data); -static void flash_reset (ulong addr); - -unsigned long flash_init (void) -{ - unsigned int i; - unsigned long flash_size = 0; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - flash_info[i].sector_count = 0; - flash_info[i].size = 0; - } - - DEBUGF("\n## Get flash size @ 0x%08x\n", CONFIG_SYS_FLASH_BASE); - - flash_size = flash_get_size (CONFIG_SYS_FLASH_BASE, flash_info); - - DEBUGF("## Flash bank size: %08lx\n", flash_size); - - if (flash_size) { -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE && \ - CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE + CONFIG_SYS_FLASH_MAX_SIZE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE + monitor_flash_len - 1, - &flash_info[0]); -#endif - -#ifdef CONFIG_ENV_IS_IN_FLASH - /* ENV protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE - 1, - &flash_info[0]); -#endif - - } else { - puts ("Warning: the BOOT Flash is not initialised !"); - } - - return flash_size; -} - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (ulong addr, flash_info_t *info) -{ - short i; - uchar value; - - /* Write auto select command: read Manufacturer ID */ - out8(addr + 0x0555, 0xAA); - iobarrier_rw(); - out8(addr + 0x02AA, 0x55); - iobarrier_rw(); - out8(addr + 0x0555, 0x90); - iobarrier_rw(); - - value = in8(addr); - iobarrier_rw(); - - DEBUGF("Manuf. ID @ 0x%08lx: 0x%08x\n", (ulong)addr, value); - - switch (value | (value << 16)) { - case AMD_MANUFACT: - info->flash_id = FLASH_MAN_AMD; - break; - - case FUJ_MANUFACT: - info->flash_id = FLASH_MAN_FUJ; - break; - - case STM_MANUFACT: - info->flash_id = FLASH_MAN_STM; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - flash_reset (addr); - return 0; - } - - value = in8(addr + 1); /* device ID */ - iobarrier_rw(); - - DEBUGF("Device ID @ 0x%08lx: 0x%08x\n", addr+1, value); - - switch ((ulong)value) { - case AMD_ID_F040B: - DEBUGF("Am29F040B\n"); - info->flash_id += FLASH_AM040; - info->sector_count = 8; - info->size = 0x00080000; - break; /* => 512 kB */ - - case AMD_ID_LV040B: - DEBUGF("Am29LV040B\n"); - info->flash_id += FLASH_AM040; - info->sector_count = 8; - info->size = 0x00080000; - break; /* => 512 kB */ - - case AMD_ID_LV400T: - DEBUGF("Am29LV400T\n"); - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case AMD_ID_LV400B: - DEBUGF("Am29LV400B\n"); - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00100000; - break; /* => 1 MB */ - - case AMD_ID_LV800T: - DEBUGF("Am29LV800T\n"); - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case AMD_ID_LV800B: - DEBUGF("Am29LV400B\n"); - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00200000; - break; /* => 2 MB */ - - case AMD_ID_LV160T: - DEBUGF("Am29LV160T\n"); - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case AMD_ID_LV160B: - DEBUGF("Am29LV160B\n"); - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00400000; - break; /* => 4 MB */ - - case AMD_ID_LV320T: - DEBUGF("Am29LV320T\n"); - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ - -#if 0 - /* Has the same ID as AMD_ID_LV320T, to be fixed */ - case AMD_ID_LV320B: - DEBUGF("Am29LV320B\n"); - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00800000; - break; /* => 8 MB */ -#endif - - case AMD_ID_LV033C: - DEBUGF("Am29LV033C\n"); - info->flash_id += FLASH_AM033C; - info->sector_count = 64; - info->size = 0x01000000; - break; /* => 16Mb */ - - case STM_ID_F040B: - DEBUGF("M29F040B\n"); - info->flash_id += FLASH_AM040; - info->sector_count = 8; - info->size = 0x00080000; - break; /* => 512 kB */ - - default: - info->flash_id = FLASH_UNKNOWN; - flash_reset (addr); - return (0); /* => no or unknown flash */ - - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - if (! flash_get_offsets (addr, info)) { - flash_reset (addr); - return 0; - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection at sector address, (A7 .. A0) = 0x02 */ - /* D0 = 1 if protected */ - value = in8(info->start[i] + 2); - iobarrier_rw(); - info->protect[i] = (value & 1) != 0; - } - - /* - * Reset bank to read mode - */ - flash_reset (addr); - - return (info->size); -} - -static int flash_get_offsets (ulong base, flash_info_t *info) -{ - unsigned int i; - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM040: - /* set sector offsets for uniform sector type */ - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + i * info->size / - info->sector_count; - } - break; - default: - return 0; - } - - return 1; -} - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - volatile ulong addr = info->start[0]; - int flag, prot, sect, l_sect; - ulong start, now, last; - - if (s_first < 0 || s_first > s_last) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - out8(addr + 0x555, 0xAA); - iobarrier_rw(); - out8(addr + 0x2AA, 0x55); - iobarrier_rw(); - out8(addr + 0x555, 0x80); - iobarrier_rw(); - out8(addr + 0x555, 0xAA); - iobarrier_rw(); - out8(addr + 0x2AA, 0x55); - iobarrier_rw(); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = info->start[sect]; - out8(addr, 0x30); - iobarrier_rw(); - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = info->start[l_sect]; - - DEBUGF ("Start erase timeout: %d\n", CONFIG_SYS_FLASH_ERASE_TOUT); - - while ((in8(addr) & 0x80) != 0x80) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - flash_reset (info->start[0]); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - iobarrier_rw(); - } - -DONE: - /* reset to read mode */ - flash_reset (info->start[0]); - - printf (" done\n"); - return 0; -} - -/* - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp, data; - int i, l, rc; - - wp = (addr & ~3); /* get lower word aligned address */ - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i=0, cp=wp; i<l; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - for (; i<4 && cnt>0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt==0 && i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - } - - /* - * handle word aligned part - */ - while (cnt >= 4) { - data = 0; - for (i=0; i<4; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_word(info, wp, data)) != 0) { - return (rc); - } - wp += 4; - cnt -= 4; - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i=0, cp=wp; i<4 && cnt>0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i<4; ++i, ++cp) { - data = (data << 8) | (*(uchar *)cp); - } - - return (write_word(info, wp, data)); -} - -/* - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_word (flash_info_t *info, ulong dest, ulong data) -{ - volatile ulong addr = info->start[0]; - ulong start; - int i; - - /* Check if Flash is (sufficiently) erased */ - if ((in32(dest) & data) != data) { - return (2); - } - - /* write each byte out */ - for (i = 0; i < 4; i++) { - char *data_ch = (char *)&data; - int flag = disable_interrupts(); - - out8(addr + 0x555, 0xAA); - iobarrier_rw(); - out8(addr + 0x2AA, 0x55); - iobarrier_rw(); - out8(addr + 0x555, 0xA0); - iobarrier_rw(); - out8(dest+i, data_ch[i]); - iobarrier_rw(); - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((in8(dest+i) & 0x80) != (data_ch[i] & 0x80)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - flash_reset (addr); - return (1); - } - iobarrier_rw(); - } - } - - flash_reset (addr); - return (0); -} - -/* - * Reset bank to read mode - */ -static void flash_reset (ulong addr) -{ - out8(addr, 0xF0); /* reset bank */ - iobarrier_rw(); -} - -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - case FLASH_MAN_BM: printf ("BRIGHT MICRO "); break; - case FLASH_MAN_STM: printf ("SGS THOMSON "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM040: printf ("29F040 or 29LV040 (4 Mbit, uniform sectors)\n"); - break; - case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: printf ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: printf ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - if (info->size % 0x100000 == 0) { - printf (" Size: %ld MB in %d Sectors\n", - info->size / 0x100000, info->sector_count); - } else if (info->size % 0x400 == 0) { - printf (" Size: %ld KB in %d Sectors\n", - info->size / 0x400, info->sector_count); - } else { - printf (" Size: %ld B in %d Sectors\n", - info->size, info->sector_count); - } - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); -} diff --git a/board/pcippc2/fpga_serial.c b/board/pcippc2/fpga_serial.c deleted file mode 100644 index de61ca0..0000000 --- a/board/pcippc2/fpga_serial.c +++ /dev/null @@ -1,125 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <asm/io.h> - -#include "fpga_serial.h" -#include "hardware.h" -#include "pcippc2.h" - -DECLARE_GLOBAL_DATA_PTR; - - /* 8 data, 1 stop, no parity - */ -#define LCRVAL 0x03 - /* RTS/DTR - */ -#define MCRVAL 0x03 - /* Clear & enable FIFOs - */ -#define FCRVAL 0x07 - -static void fpga_serial_wait (void); -static void fpga_serial_print (char c); - -void fpga_serial_init (int baudrate) -{ - int clock_divisor = 115200 / baudrate; - - out8 (FPGA (INT, SERIAL_CONFIG), 0x24); - iobarrier_rw (); - - fpga_serial_wait (); - - out8 (UART (IER), 0); - out8 (UART (LCR), LCRVAL | 0x80); - iobarrier_rw (); - out8 (UART (DLL), clock_divisor & 0xff); - out8 (UART (DLM), clock_divisor >> 8); - iobarrier_rw (); - out8 (UART (LCR), LCRVAL); - iobarrier_rw (); - out8 (UART (MCR), MCRVAL); - out8 (UART (FCR), FCRVAL); - iobarrier_rw (); -} - -void fpga_serial_putc (char c) -{ - if (c) { - fpga_serial_print (c); - } -} - -int fpga_serial_getc (void) -{ - while ((in8 (UART (LSR)) & 0x01) == 0); - - return in8 (UART (RBR)); -} - -int fpga_serial_tstc (void) -{ - return (in8 (UART (LSR)) & 0x01) != 0; -} - -void fpga_serial_setbrg (void) -{ - int clock_divisor = 115200 / gd->baudrate; - - fpga_serial_wait (); - - out8 (UART (LCR), LCRVAL | 0x80); - iobarrier_rw (); - out8 (UART (DLL), clock_divisor & 0xff); - out8 (UART (DLM), clock_divisor >> 8); - iobarrier_rw (); - out8 (UART (LCR), LCRVAL); - iobarrier_rw (); -} - -static void fpga_serial_wait (void) -{ - while ((in8 (UART (LSR)) & 0x40) == 0); -} - -static void fpga_serial_print (char c) -{ - if (c == '\n') { - while ((in8 (UART (LSR)) & 0x20) == 0); - - out8 (UART (THR), '\r'); - iobarrier_rw (); - } - - while ((in8 (UART (LSR)) & 0x20) == 0); - - out8 (UART (THR), c); - iobarrier_rw (); - - if (c == '\n') { - fpga_serial_wait (); - } -} diff --git a/board/pcippc2/fpga_serial.h b/board/pcippc2/fpga_serial.h deleted file mode 100644 index 106fbf7..0000000 --- a/board/pcippc2/fpga_serial.h +++ /dev/null @@ -1,33 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _FPGA_SERIAL_H_ -#define _FPGA_SERIAL_H_ - -extern void fpga_serial_init (int); -extern void fpga_serial_putc (char); -extern int fpga_serial_getc (void); -extern int fpga_serial_tstc (void); -extern void fpga_serial_setbrg (void); - -#endif diff --git a/board/pcippc2/hardware.h b/board/pcippc2/hardware.h deleted file mode 100644 index 489929d..0000000 --- a/board/pcippc2/hardware.h +++ /dev/null @@ -1,48 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _HARDWARE_H_ -#define _HARDWARE_H_ - -#include "cpc710.h" -#include "cpc710_pci.h" -#include "pcippc2_fpga.h" -#include "ns16550.h" - -#define REG(r, x) (HW_PHYS_##r + HW_##r##_##x) - - /* Address map: - * - * 0x00000000-0x20000000 SDRAM - * 0x40000000-0x00008000 Init RAM in the CPU DCache - * 0xf0000000-0xf8000000 CPCI MEM - * 0xf8000000-0xfc000000 Local PCI MEM - * 0xfc000000-0xfe000000 CPCI I/O - * 0xfe000000-0xff000000 Local PCI I/O - * 0xff000000-0xff201000 System configuration space - * 0xff400000-0xff500000 Local PCI bridge space - * 0xff500000-0xff600000 CPCI bridge space - * 0xfff00000-0xfff80000 Boot Flash - */ - -#endif diff --git a/board/pcippc2/i2c.c b/board/pcippc2/i2c.c deleted file mode 100644 index ab52562..0000000 --- a/board/pcippc2/i2c.c +++ /dev/null @@ -1,257 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <asm/io.h> - -#include "hardware.h" -#include "i2c.h" - -static void i2c_start (void); -static void i2c_stop (void); -static int i2c_write (u8 data); -static void i2c_read (u8 * data); - -static inline void i2c_port_start (void); -static inline void i2c_clock (unsigned int val); -static inline void i2c_data (unsigned int val); -static inline unsigned int - i2c_in (void); -static inline void i2c_write_bit (unsigned int val); -static inline unsigned int - i2c_read_bit (void); - -static inline void i2c_udelay (unsigned int time); - -int i2c_read_byte ( - u8 * data, - u8 dev, - u8 offset) -{ - int err = 0; - - i2c_start(); - - err = ! i2c_write(dev); - - if (! err) - { - err = ! i2c_write(offset); - } - - if (! err) - { - i2c_start(); - } - - if (! err) - { - err = ! i2c_write(dev | 0x01); - } - - if (! err) - { - i2c_read(data); - } - - i2c_stop(); - - return ! err; -} - -static inline void i2c_udelay ( - unsigned int time) -{ - int v; - - asm volatile("mtdec %0" : : "r" (time * ((CONFIG_SYS_BUS_CLK / 4) / 1000000))); - - do - { - asm volatile("isync; mfdec %0" : "=r" (v)); - } while (v >= 0); -} - - /* Low-level hardware access - */ - -#define BIT_GPDATA 0x80000000 -#define BIT_GPCLK 0x40000000 - -static inline void i2c_port_start (void) -{ - out32(REG(CPC0, GPDIR), in32(REG(CPC0, GPDIR)) & ~(BIT_GPCLK | BIT_GPDATA)); - out32(REG(CPC0, GPOUT), in32(REG(CPC0, GPOUT)) & ~(BIT_GPCLK | BIT_GPDATA)); - iobarrier_rw(); - - i2c_udelay(1); -} - -static inline void i2c_clock ( - unsigned int val) -{ - if (val) - { - out32(REG(CPC0, GPDIR), in32(REG(CPC0, GPDIR)) & ~BIT_GPCLK); - } - else - { - out32(REG(CPC0, GPDIR), in32(REG(CPC0, GPDIR)) | BIT_GPCLK); - } - - iobarrier_rw(); - - i2c_udelay(1); -} - -static inline void i2c_data ( - unsigned int val) -{ - if (val) - { - out32(REG(CPC0, GPDIR), in32(REG(CPC0, GPDIR)) & ~BIT_GPDATA); - } - else - { - out32(REG(CPC0, GPDIR), in32(REG(CPC0, GPDIR)) | BIT_GPDATA); - } - - iobarrier_rw(); - - i2c_udelay(1); -} - -static inline unsigned int i2c_in (void) -{ - unsigned int val = ((in32(REG(CPC0, GPIN)) & BIT_GPDATA) != 0)?1:0; - - iobarrier_rw(); - - return val; -} - - - /* Protocol implementation - */ - -static inline void i2c_write_bit ( - unsigned int val) -{ - i2c_data(val); - i2c_udelay(10); - i2c_clock(1); - i2c_udelay(10); - i2c_clock(0); - i2c_udelay(10); -} - -static inline unsigned int i2c_read_bit (void) -{ - unsigned int val; - - i2c_data(1); - i2c_udelay(10); - - i2c_clock(1); - i2c_udelay(10); - - val = i2c_in(); - - i2c_clock(0); - i2c_udelay(10); - - return val; -} - -unsigned int i2c_reset (void) -{ - unsigned int val; - int i; - - i2c_port_start(); - - i=0; - do { - i2c_udelay(10); - i2c_clock(0); - i2c_udelay(10); - i2c_clock(1); - i2c_udelay(10); - val = i2c_in(); - i++; - } while ((i<9)&&(val==0)); - return (val); -} - - -static void i2c_start (void) -{ - i2c_data(1); - i2c_clock(1); - i2c_udelay(10); - i2c_data(0); - i2c_udelay(10); - i2c_clock(0); - i2c_udelay(10); -} - -static void i2c_stop (void) -{ - i2c_data(0); - i2c_udelay(10); - i2c_clock(1); - i2c_udelay(10); - i2c_data(1); - i2c_udelay(10); -} - -static int i2c_write ( - u8 data) -{ - unsigned int i; - - for (i = 0; i < 8; i++) - { - i2c_write_bit(data >> 7); - data <<= 1; - } - - return i2c_read_bit() == 0; -} - -static void i2c_read ( - u8 * data) -{ - unsigned int i; - u8 val = 0; - - for (i = 0; i < 8; i++) - { - val <<= 1; - val |= i2c_read_bit(); - } - - *data = val; - i2c_write_bit(1); /* NoAck */ -} diff --git a/board/pcippc2/i2c.h b/board/pcippc2/i2c.h deleted file mode 100644 index 1224b42..0000000 --- a/board/pcippc2/i2c.h +++ /dev/null @@ -1,36 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _I2C_H_ -#define _I2C_H_ - -#include <common.h> - -extern int i2c_read_byte (u8 * data, - u8 dev, - u8 offset); - -extern unsigned int i2c_reset (void); - - -#endif diff --git a/board/pcippc2/ns16550.h b/board/pcippc2/ns16550.h deleted file mode 100644 index 7023f13..0000000 --- a/board/pcippc2/ns16550.h +++ /dev/null @@ -1,41 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _NS16550_H_ -#define _NS16550_H_ - -#define NS16550_RBR 0x00 -#define NS16550_IER 0x01 -#define NS16550_FCR 0x02 -#define NS16550_LCR 0x03 -#define NS16550_MCR 0x04 -#define NS16550_LSR 0x05 -#define NS16550_MSR 0x06 -#define NS16550_SCR 0x07 - -#define NS16550_THR NS16550_RBR -#define NS16550_IIR NS16550_FCR -#define NS16550_DLL NS16550_RBR -#define NS16550_DLM NS16550_IER - -#endif diff --git a/board/pcippc2/pcippc2.c b/board/pcippc2/pcippc2.c deleted file mode 100644 index 5e6fc58..0000000 --- a/board/pcippc2/pcippc2.c +++ /dev/null @@ -1,253 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <command.h> -#include <asm/io.h> -#include <linux/mtd/doc2000.h> -#include <watchdog.h> -#include <pci.h> -#include <netdev.h> -#include <serial.h> - -#include "hardware.h" -#include "pcippc2.h" -#include "sconsole.h" -#include "fpga_serial.h" - -DECLARE_GLOBAL_DATA_PTR; - -#if defined(CONFIG_WATCHDOG) - -static int pcippc2_wdt_init_done = 0; - -void pcippc2_wdt_init (void); - -#endif - - /* Check board identity - */ -int checkboard (void) -{ -#ifdef CONFIG_PCIPPC2 - puts ("Board: Gespac PCIPPC-2\n"); -#else - puts ("Board: Gespac PCIPPC-6\n"); -#endif - return 0; -} - - /* RAM size is stored in CPC0_RGBAN1 - */ -u32 pcippc2_sdram_size (void) -{ - return in32 (REG (CPC0, RGBAN1)); -} - -phys_size_t initdram (int board_type) -{ - return cpc710_ram_init (); -} - -int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - out32 (REG (CPC0, SPOR), 0); - iobarrier_rw (); - while (1); - /* notreached */ - return (-1); -} - -int board_early_init_f (void) -{ - out32 (REG (CPC0, RSTR), 0xC0000000); - iobarrier_rw (); - - out32 (REG (CPC0, RSTR), 0xF0000000); - iobarrier_rw (); - - out32 (REG (CPC0, UCTL), 0x00F80000); - - out32 (REG (CPC0, SIOC0), 0x30000000); - - out32 (REG (CPC0, ABCNTL), 0x00000000); - - out32 (REG (CPC0, SESR), 0x00000000); - out32 (REG (CPC0, SEAR), 0x00000000); - - /* Detect IBM Avignon CPC710 Revision */ - if ((in32 (REG (CPC0, UCTL)) & 0x000000F0) == CPC710_TYPE_100P) - out32 (REG (CPC0, PGCHP), 0xA0000040); - else - out32 (REG (CPC0, PGCHP), 0x80800040); - - - out32 (REG (CPC0, ATAS), 0x709C2508); - - iobarrier_rw (); - - return 0; -} - -void after_reloc (ulong dest_addr) -{ - /* Jump to the main U-Boot board init code - */ - board_init_r ((gd_t *)gd, dest_addr); -} - -int misc_init_r (void) -{ - pcippc2_fpga_init (); - - pcippc2_cpci3264_init (); - -#if defined(CONFIG_WATCHDOG) - pcippc2_wdt_init (); -#endif - - fpga_serial_init (sconsole_get_baudrate ()); - - sconsole_putc = fpga_serial_putc; - sconsole_puts = default_serial_puts; - sconsole_getc = fpga_serial_getc; - sconsole_tstc = fpga_serial_tstc; - sconsole_setbrg = fpga_serial_setbrg; - - sconsole_flush (); - return (0); -} - -void pci_init_board (void) -{ - cpc710_pci_init (); - - /* FPGA requires no retry timeouts to be enabled - */ - cpc710_pci_enable_timeout (); -} - -#ifdef CONFIG_CMD_DOC -void doc_init (void) -{ - doc_probe (pcippc2_fpga1_phys + HW_FPGA1_DOC); -} -#endif - -void pcippc2_cpci3264_init (void) -{ - pci_dev_t bdf = pci_find_device(FPGA_VENDOR_ID, FPGA_DEVICE_ID, 0); - - if (bdf == -1) - { - puts("Unable to find FPGA !\n"); - hang(); - } - - if((in32(pcippc2_fpga0_phys + HW_FPGA0_BOARD) & 0x01000000) == 0x01000000) - /* 32-bits Compact PCI bus - LSB bit */ - { - iobarrier_rw(); - out32(BRIDGE(CPCI, PCIDG), 0x40000000); /* 32-bits bridge, Pipeline */ - iobarrier_rw(); - } -} - -#if defined(CONFIG_WATCHDOG) - -void pcippc2_wdt_init (void) -{ - out16r (FPGA (WDT, PROG), 0xffff); - out8 (FPGA (WDT, CTRL), 0x1); - - pcippc2_wdt_init_done = 1; -} - -void pcippc2_wdt_done (void) -{ - out8 (FPGA (WDT, CTRL), 0x0); - - pcippc2_wdt_init_done = 0; -} - -void pcippc2_wdt_reset (void) -{ - if (pcippc2_wdt_init_done == 1) - out8 (FPGA (WDT, REFRESH), 0x56); -} - -void watchdog_reset (void) -{ - int re_enable = disable_interrupts (); - - pcippc2_wdt_reset (); - if (re_enable) - enable_interrupts (); -} - -#if defined(CONFIG_CMD_BSP) -int do_wd (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - switch (argc) { - case 1: - printf ("Watchdog timer status is %s\n", - pcippc2_wdt_init_done == 1 ? "on" : "off"); - - return 0; - case 2: - if (!strcmp(argv[1],"on")) { - pcippc2_wdt_init(); - printf("Watchdog timer now is on\n"); - - return 0; - - } else if (!strcmp(argv[1],"off")) { - pcippc2_wdt_done(); - printf("Watchdog timer now is off\n"); - - return 0; - - } else - break; - default: - break; - } - return cmd_usage(cmdtp); -} - -U_BOOT_CMD( - wd, 2, 1, do_wd, - "check and set watchdog", - "on - switch watchDog on\n" - "wd off - switch watchdog off\n" - "wd - print current status" -); - -#endif -#endif /* CONFIG_WATCHDOG */ - -int board_eth_init(bd_t *bis) -{ - return pci_eth_init(bis); -} diff --git a/board/pcippc2/pcippc2.h b/board/pcippc2/pcippc2.h deleted file mode 100644 index a1366ef..0000000 --- a/board/pcippc2/pcippc2.h +++ /dev/null @@ -1,51 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _PCIPPC2_H_ -#define _PCIPPC2_H_ - -#include <config.h> -#include <common.h> - -#include "hardware.h" - -#define FPGA(r, p) (pcippc2_fpga0_phys + HW_FPGA0_##r##_##p) -#define UART(r) (pcippc2_fpga0_phys + HW_FPGA0_UART1 + NS16550_##r * 4) -#define RTC(r) (pcippc2_fpga1_phys + HW_FPGA1_RTC + r) - -extern u32 pcippc2_fpga0_phys; -extern u32 pcippc2_fpga1_phys; - -extern u32 pcippc2_sdram_size (void); - -extern void pcippc2_fpga_init (void); - -extern void pcippc2_cpci3264_init (void); - -extern void cpc710_pci_init (void); -extern void cpc710_pci_enable_timeout (void); - -extern unsigned long - cpc710_ram_init (void); - -#endif diff --git a/board/pcippc2/pcippc2_fpga.c b/board/pcippc2/pcippc2_fpga.c deleted file mode 100644 index 7f6739d..0000000 --- a/board/pcippc2/pcippc2_fpga.c +++ /dev/null @@ -1,87 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <asm/io.h> - -#include "pci.h" - -#include "hardware.h" -#include "pcippc2.h" - -u32 pcippc2_fpga0_phys; -u32 pcippc2_fpga1_phys; - -void pcippc2_fpga_init (void) -{ - pci_dev_t bdf = pci_find_device(FPGA_VENDOR_ID, FPGA_DEVICE_ID, 0); - unsigned int addr; - u16 cmd; - - if (bdf == -1) - { - puts("Unable to find FPGA !\n"); - hang(); - } - - pci_read_config_word(bdf, PCI_COMMAND, &cmd); - if ((cmd & (PCI_COMMAND_MEMORY | PCI_COMMAND_IO)) != (PCI_COMMAND_MEMORY | PCI_COMMAND_IO)) - { - puts("FPGA is not configured !\n"); - hang(); - } - - pci_read_config_dword(bdf, PCI_BASE_ADDRESS_0, &addr); - if (addr & 0x1) - { - /* IO space - */ - pcippc2_fpga0_phys = pci_io_to_phys(bdf, addr & 0xfffffffc); - } - else - { - /* Memory space - */ - pcippc2_fpga0_phys = pci_mem_to_phys(bdf, addr & 0xfffffff0); - } - - pci_read_config_dword(bdf, PCI_BASE_ADDRESS_1, &addr); - if (addr & 0x1) - { - /* IO space - */ - pcippc2_fpga1_phys = pci_io_to_phys(bdf, addr & 0xfffffffc); - } - else - { - /* Memory space - */ - pcippc2_fpga1_phys = pci_mem_to_phys(bdf, addr & 0xfffffff0); - } - - /* Interrupts are not used - */ - out32(FPGA(INT, INTR_MASK), 0xffffffff); - iobarrier_rw(); -} diff --git a/board/pcippc2/pcippc2_fpga.h b/board/pcippc2/pcippc2_fpga.h deleted file mode 100644 index 850c331..0000000 --- a/board/pcippc2/pcippc2_fpga.h +++ /dev/null @@ -1,49 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _PCIPPC2_FPGA_H_ -#define _PCIPPC2_FPGA_H_ - -#define FPGA_VENDOR_ID 0x1310 -#define FPGA_DEVICE_ID 0x000d - -#define HW_FPGA0_INT 0x0000 -#define HW_FPGA0_BOARD 0x0060 -#define HW_FPGA0_UART1 0x0080 -#define HW_FPGA0_UART2 0x0100 -#define HW_FPGA0_RTC 0x2000 -#define HW_FPGA0_DOC 0x4000 -#define HW_FPGA1_RTC 0x0000 -#define HW_FPGA1_DOC 0x4000 - -#define HW_FPGA0_INT_INTR_MASK 0x30 -#define HW_FPGA0_INT_INTR_STATUS 0x34 -#define HW_FPGA0_INT_INTR_EOI 0x40 -#define HW_FPGA0_INT_SERIAL_CONFIG 0x5c - -#define HW_FPGA0_WDT_CTRL 0x44 -#define HW_FPGA0_WDT_PROG 0x48 -#define HW_FPGA0_WDT_VAL 0x4c -#define HW_FPGA0_WDT_REFRESH 0x50 - -#endif diff --git a/board/pcippc2/sconsole.c b/board/pcippc2/sconsole.c deleted file mode 100644 index aa3c908..0000000 --- a/board/pcippc2/sconsole.c +++ /dev/null @@ -1,162 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <common.h> -#include <serial.h> -#include <linux/compiler.h> - -#include "sconsole.h" - -DECLARE_GLOBAL_DATA_PTR; - -void (*sconsole_putc) (char) = 0; -void (*sconsole_puts) (const char *) = 0; -int (*sconsole_getc) (void) = 0; -int (*sconsole_tstc) (void) = 0; -void (*sconsole_setbrg) (void) = 0; - -static int sconsole_serial_init(void) -{ - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - sb->pos = 0; - sb->size = 0; - sb->baud = gd->baudrate; - sb->max_size = CONFIG_SYS_SCONSOLE_SIZE - sizeof (sconsole_buffer_t); - - return (0); -} - -static void sconsole_serial_putc(char c) -{ - if (sconsole_putc) { - (*sconsole_putc) (c); - } else { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - if (c) { - sb->data[sb->pos++] = c; - if (sb->pos == sb->max_size) { - sb->pos = 0; - } - if (sb->size < sb->max_size) { - sb->size++; - } - } - } -} - -static void sconsole_serial_puts(const char *s) -{ - if (sconsole_puts) { - (*sconsole_puts) (s); - } else { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - while (*s) { - sb->data[sb->pos++] = *s++; - if (sb->pos == sb->max_size) { - sb->pos = 0; - } - if (sb->size < sb->max_size) { - sb->size++; - } - } - } -} - -static int sconsole_serial_getc(void) -{ - if (sconsole_getc) { - return (*sconsole_getc) (); - } else { - return 0; - } -} - -static int sconsole_serial_tstc(void) -{ - if (sconsole_tstc) { - return (*sconsole_tstc) (); - } else { - return 0; - } -} - -static void sconsole_serial_setbrg(void) -{ - if (sconsole_setbrg) { - (*sconsole_setbrg) (); - } else { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - sb->baud = gd->baudrate; - } -} - -static struct serial_device sconsole_serial_drv = { - .name = "sconsole_serial", - .start = sconsole_serial_init, - .stop = NULL, - .setbrg = sconsole_serial_setbrg, - .putc = sconsole_serial_putc, - .puts = sconsole_serial_puts, - .getc = sconsole_serial_getc, - .tstc = sconsole_serial_tstc, -}; - -void sconsole_serial_initialize(void) -{ - serial_register(&sconsole_serial_drv); -} - -__weak struct serial_device *default_serial_console(void) -{ - return &sconsole_serial_drv; -} - -int sconsole_get_baudrate (void) -{ - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - - return sb->baud; -} - -void sconsole_flush (void) -{ - if (sconsole_putc) { - sconsole_buffer_t *sb = SCONSOLE_BUFFER; - unsigned int end = sb->pos < sb->size - ? sb->pos + sb->max_size - sb->size - : sb->pos - sb->size; - - while (sb->size) { - (*sconsole_putc) (sb->data[end++]); - if (end == sb->max_size) { - end = 0; - } - sb->size--; - } - } -} diff --git a/board/pcippc2/sconsole.h b/board/pcippc2/sconsole.h deleted file mode 100644 index ff0ccab..0000000 --- a/board/pcippc2/sconsole.h +++ /dev/null @@ -1,48 +0,0 @@ -/* - * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef _SCONSOLE_H_ -#define _SCONSOLE_H_ - -#include <config.h> - -typedef struct sconsole_buffer_s { - unsigned long size; - unsigned long max_size; - unsigned long pos; - unsigned long baud; - char data[1]; -} sconsole_buffer_t; - -#define SCONSOLE_BUFFER ((sconsole_buffer_t *) CONFIG_SYS_SCONSOLE_ADDR) - -extern void (* sconsole_putc) (char); -extern void (* sconsole_puts) (const char *); -extern int (* sconsole_getc) (void); -extern int (* sconsole_tstc) (void); -extern void (* sconsole_setbrg) (void); - -extern void sconsole_flush (void); -extern int sconsole_get_baudrate (void); - -#endif diff --git a/boards.cfg b/boards.cfg index 318301a..fc09934 100644 --- a/boards.cfg +++ b/boards.cfg @@ -459,8 +459,6 @@ openrisc-generic openrisc or1200 openrisc-generic openris EVB64260 powerpc 74xx_7xx evb64260 - - EVB64260 EVB64260_750CX powerpc 74xx_7xx evb64260 - - EVB64260 P3G4 powerpc 74xx_7xx evb64260 -PCIPPC2 powerpc 74xx_7xx pcippc2 -PCIPPC6 powerpc 74xx_7xx pcippc2 ppmc7xx powerpc 74xx_7xx ZUMA powerpc 74xx_7xx evb64260 ELPPC powerpc 74xx_7xx elppc eltec diff --git a/doc/driver-model/UDM-pci.txt b/doc/driver-model/UDM-pci.txt index b65e9ea..c2cf2d5 100644 --- a/doc/driver-model/UDM-pci.txt +++ b/doc/driver-model/UDM-pci.txt @@ -240,10 +240,6 @@ III) Analysis of in-tree drivers ---------------- Standard driver, uses indirect functions.
- 8) pcippc2/cpc710_pci.c - ----------------------- - Standard driver, uses indirect functions, has two busses. - 9) Marvell/db64360/pci.c ------------------------ Standard driver, uses dword for read/write ops, has two busses. diff --git a/doc/driver-model/UDM-watchdog.txt b/doc/driver-model/UDM-watchdog.txt index 271bd26..7db3286 100644 --- a/doc/driver-model/UDM-watchdog.txt +++ b/doc/driver-model/UDM-watchdog.txt @@ -292,11 +292,6 @@ III) Analysis of in-tree drivers Only function proxy call. Code cleanup needed.
- 45) board/pcippc2/pcippc2.c - --------------------------- - The driver is standard HW watchdog. Simple conversion is possible. - - 46) board/pcs440ep/pcs440ep.c ----------------------------- The driver is standard HW watchdog. Simple conversion is possible. diff --git a/drivers/rtc/mk48t59.c b/drivers/rtc/mk48t59.c index e285823..3af2623 100644 --- a/drivers/rtc/mk48t59.c +++ b/drivers/rtc/mk48t59.c @@ -49,20 +49,6 @@ static void rtc_write (short reg, uchar val) out8(RTC_PORT_DATA, val); }
-#elif defined(CONFIG_PCIPPC2) - -#include "../board/pcippc2/pcippc2.h" - -static uchar rtc_read (short reg) -{ - return in8(RTC(reg)); -} - -static void rtc_write (short reg, uchar val) -{ - out8(RTC(reg),val); -} - #elif defined(CONFIG_EVAL5200)
static uchar rtc_read (short reg) diff --git a/include/configs/PCIPPC2.h b/include/configs/PCIPPC2.h deleted file mode 100644 index 90cee88..0000000 --- a/include/configs/PCIPPC2.h +++ /dev/null @@ -1,251 +0,0 @@ -/* - * (C) Copyright 2002-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * - * Configuration settings for the PCIPPC-2 board. - * - */ - -/* ------------------------------------------------------------------------- */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_PCIPPC2 1 /* this is a PCIPPC2 board */ - -#define CONFIG_SYS_TEXT_BASE 0xfff00000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 -#define CONFIG_MISC_INIT_R 1 - -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 9600 - -#define CONFIG_PREBOOT "" -#define CONFIG_BOOTDELAY 5 - -#ifndef __ASSEMBLY__ -#include <galileo/core.h> -#endif - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BSP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ELF -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PCI -#define CONFIG_CMD_SNTP - -#define CONFIG_PCI 1 -#define CONFIG_PCI_PNP 1 /* PCI plug-and-play */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ - -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ - -/* Print Buffer Size - */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) - -#define CONFIG_SYS_MAXARGS 64 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* Default load address */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFF00000 -#define CONFIG_SYS_FLASH_MAX_SIZE 0x00100000 -/* Maximum amount of RAM. - */ -#define CONFIG_SYS_MAX_RAM_SIZE 0x20000000 /* 512Mb */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_SDRAM_BASE && \ - CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_MAX_RAM_SIZE -#define CONFIG_SYS_RAMBOOT -#else -#undef CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MEMTEST_START 0x00004000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x02000000 /* 0 ... 32 MB in DRAM */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area - */ - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_INIT_RAM_LOCK - -/* - * Temporary buffer for serial data until the real serial driver - * is initialised (memtest will destroy this buffer) - */ -#define CONFIG_SYS_SCONSOLE_ADDR CONFIG_SYS_INIT_RAM_ADDR -#define CONFIG_SYS_SCONSOLE_SIZE 0x0002000 - -/* SDRAM 0 - 256MB - */ -#define CONFIG_SYS_DBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_DBAT0U (CONFIG_SYS_SDRAM_BASE | \ - BATU_BL_256M | BATU_VS | BATU_VP) -/* SDRAM 1 - 256MB - */ -#define CONFIG_SYS_DBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | \ - BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_DBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | \ - BATU_BL_256M | BATU_VS | BATU_VP) - -/* Init RAM in the CPU DCache (no backing memory) - */ -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_INIT_RAM_ADDR | \ - BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_DBAT2U (CONFIG_SYS_INIT_RAM_ADDR | \ - BATU_BL_128K | BATU_VS | BATU_VP) - -/* I/O and PCI memory at 0xf0000000 - */ -#define CONFIG_SYS_DBAT3L (0xf0000000 | BATL_PP_10 | BATL_CACHEINHIBIT) -#define CONFIG_SYS_DBAT3U (0xf0000000 | BATU_BL_256M | BATU_VS | BATU_VP) - -#define CONFIG_SYS_IBAT0L CONFIG_SYS_DBAT0L -#define CONFIG_SYS_IBAT0U CONFIG_SYS_DBAT0U -#define CONFIG_SYS_IBAT1L CONFIG_SYS_DBAT1L -#define CONFIG_SYS_IBAT1U CONFIG_SYS_DBAT1U -#define CONFIG_SYS_IBAT2L CONFIG_SYS_DBAT2L -#define CONFIG_SYS_IBAT2U CONFIG_SYS_DBAT2U -#define CONFIG_SYS_IBAT3L CONFIG_SYS_DBAT3L -#define CONFIG_SYS_IBAT3U CONFIG_SYS_DBAT3U - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - * For the detail description refer to the PCIPPC2 user's manual. - */ -#define CONFIG_SYS_HZ 1000 -#define CONFIG_SYS_BUS_CLK 100000000 /* bus speed - 100 mhz */ -#define CONFIG_SYS_CPU_CLK 300000000 - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* Max number of flash banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 16 /* Max number of sectors in one bank */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1000 /* Timeout for Flash Write (in ms) */ - -/* - * Note: environment is not EMBEDDED in the U-Boot code. - * It's stored in flash separately. - */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x70000) -#define CONFIG_ENV_SIZE 0x1000 /* Size of the Environment */ -#define CONFIG_ENV_SECT_SIZE 0x10000 /* Size of the Environment Sector */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/* - * L2 cache - */ -#undef CONFIG_SYS_L2 -#define L2_INIT (L2CR_L2SIZ_2M | L2CR_L2CLK_3 | L2CR_L2RAM_BURST | \ - L2CR_L2OH_5 | L2CR_L2CTL | L2CR_L2WT) -#define L2_ENABLE (L2_INIT | L2CR_L2E) - -/*----------------------------------------------------------------------- - RTC m48t59 -*/ -#define CONFIG_RTC_MK48T59 - -#define CONFIG_WATCHDOG - - -#define CONFIG_EEPRO100 -#define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ -#define CONFIG_TULIP - -#endif /* __CONFIG_H */ diff --git a/include/configs/PCIPPC6.h b/include/configs/PCIPPC6.h deleted file mode 100644 index 10b81c1..0000000 --- a/include/configs/PCIPPC6.h +++ /dev/null @@ -1,265 +0,0 @@ -/* - * (C) Copyright 2002-2005 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * - * Configuration settings for the PCIPPC-6 board. - * - */ - -/* ------------------------------------------------------------------------- */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_PCIPPC2 1 /* this is a PCIPPC2 board */ - -#define CONFIG_SYS_TEXT_BASE 0xfff00000 - -#define CONFIG_BOARD_EARLY_INIT_F 1 -#define CONFIG_MISC_INIT_R 1 - -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 9600 - -#define CONFIG_PREBOOT "" -#define CONFIG_BOOTDELAY 5 - -#ifndef __ASSEMBLY__ -#include <galileo/core.h> -#endif - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_BSP -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ELF -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PCI -#define CONFIG_CMD_SCSI -#define CONFIG_CMD_SNTP - - -#define CONFIG_PCI 1 -#define CONFIG_PCI_PNP 1 /* PCI plug-and-play */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ - -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ - -/* Print Buffer Size - */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) - -#define CONFIG_SYS_MAXARGS 64 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* Default load address */ - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFFF00000 -#define CONFIG_SYS_FLASH_MAX_SIZE 0x00100000 -/* Maximum amount of RAM. - */ -#define CONFIG_SYS_MAX_RAM_SIZE 0x20000000 /* 512Mb */ - -#define CONFIG_SYS_RESET_ADDRESS 0xFFF00100 - -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE - -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_SDRAM_BASE && \ - CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_SDRAM_BASE + CONFIG_SYS_MAX_RAM_SIZE -#define CONFIG_SYS_RAMBOOT -#else -#undef CONFIG_SYS_RAMBOOT -#endif - -#define CONFIG_SYS_MEMTEST_START 0x00004000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x02000000 /* 0 ... 32 MB in DRAM */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area - */ - -#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x8000 -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_INIT_RAM_LOCK - -/* - * Temporary buffer for serial data until the real serial driver - * is initialised (memtest will destroy this buffer) - */ -#define CONFIG_SYS_SCONSOLE_ADDR CONFIG_SYS_INIT_RAM_ADDR -#define CONFIG_SYS_SCONSOLE_SIZE 0x0002000 - -/* SDRAM 0 - 256MB - */ -#define CONFIG_SYS_DBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_DBAT0U (CONFIG_SYS_SDRAM_BASE | \ - BATU_BL_256M | BATU_VS | BATU_VP) -/* SDRAM 1 - 256MB - */ -#define CONFIG_SYS_DBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | \ - BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_DBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | \ - BATU_BL_256M | BATU_VS | BATU_VP) - -/* Init RAM in the CPU DCache (no backing memory) - */ -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_INIT_RAM_ADDR | \ - BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_DBAT2U (CONFIG_SYS_INIT_RAM_ADDR | \ - BATU_BL_128K | BATU_VS | BATU_VP) - -/* I/O and PCI memory at 0xf0000000 - */ -#define CONFIG_SYS_DBAT3L (0xf0000000 | BATL_PP_10 | BATL_CACHEINHIBIT) -#define CONFIG_SYS_DBAT3U (0xf0000000 | BATU_BL_256M | BATU_VS | BATU_VP) - -#define CONFIG_SYS_IBAT0L CONFIG_SYS_DBAT0L -#define CONFIG_SYS_IBAT0U CONFIG_SYS_DBAT0U -#define CONFIG_SYS_IBAT1L CONFIG_SYS_DBAT1L -#define CONFIG_SYS_IBAT1U CONFIG_SYS_DBAT1U -#define CONFIG_SYS_IBAT2L CONFIG_SYS_DBAT2L -#define CONFIG_SYS_IBAT2U CONFIG_SYS_DBAT2U -#define CONFIG_SYS_IBAT3L CONFIG_SYS_DBAT3L -#define CONFIG_SYS_IBAT3U CONFIG_SYS_DBAT3U - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - * For the detail description refer to the PCIPPC2 user's manual. - */ -#define CONFIG_SYS_HZ 1000 -#define CONFIG_SYS_BUS_CLK 100000000 /* bus speed - 100 mhz */ -#define CONFIG_SYS_CPU_CLK 300000000 - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* Max number of flash banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 16 /* Max number of sectors in one bank */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 1000 /* Timeout for Flash Write (in ms) */ - -/* - * Note: environment is not EMBEDDED in the U-Boot code. - * It's stored in flash separately. - */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x70000) -#define CONFIG_ENV_SIZE 0x1000 /* Size of the Environment */ -#define CONFIG_ENV_SECT_SIZE 0x10000 /* Size of the Environment Sector */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/* - * L2 cache - */ -#undef CONFIG_SYS_L2 -#define L2_INIT (L2CR_L2SIZ_2M | L2CR_L2CLK_3 | L2CR_L2RAM_BURST | \ - L2CR_L2OH_5 | L2CR_L2CTL | L2CR_L2WT) -#define L2_ENABLE (L2_INIT | L2CR_L2E) - -/*----------------------------------------------------------------------- - RTC m48t59 -*/ -#define CONFIG_RTC_MK48T59 - -#define CONFIG_WATCHDOG - - -#define CONFIG_EEPRO100 -#define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */ -#define CONFIG_TULIP - - -#define CONFIG_SCSI_SYM53C8XX -#define CONFIG_SCSI_DEV_ID 0x000B /* 53c896 */ -#define CONFIG_SYS_SCSI_MAX_LUN 8 /* number of supported LUNs */ -#define CONFIG_SYS_SCSI_MAX_SCSI_ID 15 /* maximum SCSI ID (0..6) */ -#define CONFIG_SYS_SCSI_MAX_DEVICE CONFIG_SYS_SCSI_MAX_SCSI_ID * CONFIG_SYS_SCSI_MAX_LUN /* maximum Target devices */ -#define CONFIG_SYS_SCSI_SPIN_UP_TIME 2 -#define CONFIG_SYS_SCSI_SCAN_BUS_REVERSE 0 -#define CONFIG_DOS_PARTITION -#define CONFIG_MAC_PARTITION -#define CONFIG_ISO_PARTITION - -#endif /* __CONFIG_H */
Dear Stefan Roese,
In message 1360232218-6588-1-git-send-email-sr@denx.de you wrote:
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files.
Signed-off-by: Stefan Roese sr@denx.de Cc: Guillaume Alexandre guillaume.alexandre@gespac.ch Cc: Wolfgang Denk wd@denx.de
MAINTAINERS | 3 - arch/powerpc/cpu/74xx_7xx/cpu.c | 7 +- board/pcippc2/Makefile | 47 ---- board/pcippc2/cpc710.h | 96 ------- board/pcippc2/cpc710_init_ram.c | 232 --------------- board/pcippc2/cpc710_pci.c | 309 -------------------- board/pcippc2/cpc710_pci.h | 51 ---- board/pcippc2/flash.c | 573 -------------------------------------- board/pcippc2/fpga_serial.c | 125 --------- board/pcippc2/fpga_serial.h | 33 --- board/pcippc2/hardware.h | 48 ---- board/pcippc2/i2c.c | 257 ----------------- board/pcippc2/i2c.h | 36 --- board/pcippc2/ns16550.h | 41 --- board/pcippc2/pcippc2.c | 253 ----------------- board/pcippc2/pcippc2.h | 51 ---- board/pcippc2/pcippc2_fpga.c | 87 ------ board/pcippc2/pcippc2_fpga.h | 49 ---- board/pcippc2/sconsole.c | 162 ----------- board/pcippc2/sconsole.h | 48 ---- boards.cfg | 2 - doc/driver-model/UDM-pci.txt | 4 - doc/driver-model/UDM-watchdog.txt | 5 - drivers/rtc/mk48t59.c | 14 - include/configs/PCIPPC2.h | 251 ----------------- include/configs/PCIPPC6.h | 265 ------------------
Please also make appropriate entries in doc/README.scrapyard
Except for this:
Acked-by: Wolfgang Denk wd@denx.de
Stefan Roese
