[U-Boot] Pull request for u-boot-marvell.git
Hi Albert Please pull
The following changes since commit b3fee4e17f9f2c136b8fcfc1b7e575b6b3ccd66a: Anatolij Gustschin (1): ARM: dreamplug: fix compilation
u-boot-marvell.git ..BRANCH.NOT.VERIFIED..
Ajay Bhargav (1): gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared
Holger Brunck (2): arm/km: add variable waitforne to mgcoge3un arm/km/mgcoge3un: enhance "waitforne" feature
Michael Walle (1): kirkwood: define CONFIG_SYS_CACHELINE_SIZE
Mike Frysinger (1): kirkwood: drop empty asm-offsets.s file
arch/arm/include/asm/arch-kirkwood/config.h | 3 ++- board/keymile/km_arm/km_arm.c | 11 ++++++++++- include/configs/gplugd.h | 12 +++++++++++- include/configs/mgcoge3un.h | 2 ++ 4 files changed, 25 insertions(+), 3 deletions(-) delete mode 100644 arch/arm/cpu/arm926ejs/kirkwood/asm-offsets.s
Regards... Prafulla . . .
Hi Prafulla,
Seems like you did the 'git request-pull' before updating u-boot-marvell/master. :)
Applied to u-boot-arm/master, thanks!
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Tuesday, November 01, 2011 1:05 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; wd@denx.de; Ashish Karkare; Prabhanjan Sarnaik Subject: Re: Pull request for u-boot-marvell.git
Hi Prafulla,
Hi Albert No, I follow the new guidelines given by you and life is better now (git fetch, git rebase) :-) Actually I need to pull from internal mirror, where as push is allowed to do on external repository. This always reports (expected) "branch not verified". Usually I modify it manually, this time I missed it :-D
Regards.. Prafulla . . .
Albert ARIBAUD
Prafulla Wadaskar
