[U-Boot] [PATCH 1/4] tegra: Remove merge markers in some Kconfig files
These were added by mistake in commit fde7e189. They cause a warning when configuring the boards. Remove them.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Stephen Warren swarren@nvidia.com ---
configs/beaver_defconfig | 3 --- configs/cardhu_defconfig | 3 --- configs/jetson-tk1_defconfig | 3 --- configs/trimslice_defconfig | 3 --- 4 files changed, 12 deletions(-)
diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 2930344..8add08d 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -13,11 +13,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y -<<<<<<< HEAD CONFIG_SPI_FLASH_WINBOND=y -======= CONFIG_PCI_TEGRA=y ->>>>>>> dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SLINK=y CONFIG_USB=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 5760018..c9f565a 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -13,11 +13,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y -<<<<<<< HEAD CONFIG_SPI_FLASH_WINBOND=y -======= CONFIG_PCI_TEGRA=y ->>>>>>> dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SLINK=y CONFIG_USB=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 9500d2c..efc4aee 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -13,11 +13,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y -<<<<<<< HEAD CONFIG_SPI_FLASH_WINBOND=y -======= CONFIG_PCI_TEGRA=y ->>>>>>> dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index ee40218..e34faa3 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -13,11 +13,8 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y -<<<<<<< HEAD CONFIG_SPI_FLASH_WINBOND=y -======= CONFIG_PCI_TEGRA=y ->>>>>>> dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SFLASH=y CONFIG_USB=y
For platforms that don't use device tree in SPL the only way to mark this driver as 'required by relocation' is with the DM_FLAG_PRE_RELOC flag. Add this to ensure that the driver is bound.
drivers/serial/ns16550.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 166deab..256c7ea 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -451,5 +451,6 @@ U_BOOT_DRIVER(ns16550_serial) = { .priv_auto_alloc_size = sizeof(struct NS16550), .probe = ns16550_serial_probe, .ops = &ns16550_serial_ops, + .flags = DM_FLAG_PRE_RELOC, }; #endif /* CONFIG_DM_SERIAL */
Acked-by: Thomas Chou thomas@wytron.com.tw
Fixes: fde7e18938d8 ("dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig") Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Stephen Warren swarren@nvidia.com Acked-by: Thomas Chou thomas@wytron.com.tw
At present an incorrect #if term is preventing this data from being compiled in. All tegra boards use driver model for serial, so we can just drop this.
arch/arm/mach-tegra/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-tegra/board.c b/arch/arm/mach-tegra/board.c index 8c8927d..3d1d26d 100644 --- a/arch/arm/mach-tegra/board.c +++ b/arch/arm/mach-tegra/board.c @@ -214,7 +214,7 @@ void board_init_uart_f(void) setup_uarts(uart_ids); }
-#if CONFIG_IS_ENABLED(DM_SERIAL) && !CONFIG_IS_ENABLED(OF_CONTROL) +#if !CONFIG_IS_ENABLED(OF_CONTROL) static struct ns16550_platdata ns16550_com1_pdata = { .base = CONFIG_SYS_NS16550_COM1, .reg_shift = 2,
This is currently broken since it does not have the reg-shift property for the UART in the device tree. Fix it.
Reported-by: Yegor Yefremov yegorslists@googlemail.com Signed-off-by: Simon Glass sjg@chromium.org ---
arch/arm/dts/am33xx.dtsi | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/dts/am33xx.dtsi b/arch/arm/dts/am33xx.dtsi index 21fcc44..b26e21b 100644 --- a/arch/arm/dts/am33xx.dtsi +++ b/arch/arm/dts/am33xx.dtsi @@ -214,6 +214,7 @@ ti,hwmods = "uart1"; clock-frequency = <48000000>; reg = <0x44e09000 0x2000>; + reg-shift = <2>; interrupts = <72>; status = "disabled"; dmas = <&edma 26>, <&edma 27>; @@ -225,6 +226,7 @@ ti,hwmods = "uart2"; clock-frequency = <48000000>; reg = <0x48022000 0x2000>; + reg-shift = <2>; interrupts = <73>; status = "disabled"; dmas = <&edma 28>, <&edma 29>; @@ -236,6 +238,7 @@ ti,hwmods = "uart3"; clock-frequency = <48000000>; reg = <0x48024000 0x2000>; + reg-shift = <2>; interrupts = <74>; status = "disabled"; dmas = <&edma 30>, <&edma 31>; @@ -247,6 +250,7 @@ ti,hwmods = "uart4"; clock-frequency = <48000000>; reg = <0x481a6000 0x2000>; + reg-shift = <2>; interrupts = <44>; status = "disabled"; }; @@ -256,6 +260,7 @@ ti,hwmods = "uart5"; clock-frequency = <48000000>; reg = <0x481a8000 0x2000>; + reg-shift = <2>; interrupts = <45>; status = "disabled"; }; @@ -265,6 +270,7 @@ ti,hwmods = "uart6"; clock-frequency = <48000000>; reg = <0x481aa000 0x2000>; + reg-shift = <2>; interrupts = <46>; status = "disabled"; };
OK, this isn't enough. Both this patch, and Mugunthan's more comprehensive one (That gets all TI targets) fails on the non-OF_CONTROL case.
Hi Tom,
Yes I see. I meant to test that case as well but ran out of time. I'll update the series.
Patches 1-3, Tested-by: Stephen Warren swarren@nvidia.com
It would be useful to include the appropriate Fixes: tags in the commit message, and this issue was originally:
Reported-by: Kevin Hilman khilman@linaro.org
Hi Stephen,
Thanks - what Fixes tags?
On 12/04/2015 10:25 AM, Simon Glass wrote:
Hi Stephen,
I'd expect the following at the start of the "signature paragraph":
Referencing in a standard way the commits that caused the bug that this patch fixes makes researching bug/commit history easier. Admittedly that tag is something from the Linux kernel development process and isn't mandated by U-Boot's process, but I think it's a good idea that's worth following.
Fixes: fde7e18938d8 ("dm: tegra: pci: Move CONFIG_PCI_TEGRA to Kconfig") Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Stephen Warren swarren@nvidia.com Tested-by: Stephen Warren swarren@nvidia.com Reported-by: Kevin Hilman khilman@linaro.org Acked-by: Thomas Chou thomas@wytron.com.tw
Stephen Warren
Thomas Chou
