[PATCH] arm64: zynqmp: Fix i2c bus for kd240
i2c1 is having all chips on it that's why use it instead of 0.
You can see this error when you boot system. eth0: ethernet@ff0c0000 Setting bus to 0 Failure changing bus number (-19) Enable permission for node ID 33 Enable permission for node ID 47 Hit any key to stop autoboot: 0
It also get USB to work.
Fixes: dd4a82201694 ("arm64: zynqmp: Introduce kria SOM defconfig") Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/zynqmp/zynqmp_kria.env | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/xilinx/zynqmp/zynqmp_kria.env b/board/xilinx/zynqmp/zynqmp_kria.env index 70384538ab1d..36182f1b0d85 100644 --- a/board/xilinx/zynqmp/zynqmp_kria.env +++ b/board/xilinx/zynqmp/zynqmp_kria.env @@ -58,7 +58,7 @@ kv260_setup=i2c dev 1 && run usb_hub_init # usb hub init kr260_setup=i2c dev 1 && run usb_hub_init; i2c dev 2 && run usb_hub_init; # usb hub init with enabling PM nodes for ... -kd240_setup=i2c dev 0 && run usb_hub_init;zynqmp pmufw node 33; zynqmp pmufw node 47 +kd240_setup=i2c dev 1 && run usb_hub_init;zynqmp pmufw node 33; zynqmp pmufw node 47
board_setup=\ if test ${card1_name} = SCK-KV-G; then run kv260_setup; fi;\
Applied. M
Michal Simek
