[U-Boot] [PATCH] ls102xa: etsec: Use proper settings for BE BDs
Replace the DMACTRL[LE] hack with recommended settings for ETSECDMAMCR to get the same end effect - obtaining big-endian buffer descriptors and frame data for eTSEC. The reset / default value for ETSECDMAMCR is preserved, excepting the BD and FR bits which are cleared to enable the BE mode in accordance with the H/W specifications.
Fixes: 52d00a8 "ls102xa: etsec: Add etsec support for LS102xA" Signed-off-by: Claudiu Manoil claudiu.manoil@freescale.com --- arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 2 +- board/freescale/ls1021aqds/ls1021aqds.c | 3 ++- board/freescale/ls1021atwr/ls1021atwr.c | 3 ++- drivers/net/tsec.c | 6 ------ 4 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index d34044a..60aa0d3 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -143,7 +143,7 @@ struct ccsr_gur { u32 sdhcpcr; };
-#define SCFG_ETSECDMAMCR_LE_BD_FR 0xf8001a0f +#define SCFG_ETSECDMAMCR_LE_BD_FR 0x00000c00 #define SCFG_ETSECCMCR_GE2_CLK125 0x04000000 #define SCFG_ETSECCMCR_GE0_CLK125 0x00000000 #define SCFG_ETSECCMCR_GE1_CLK125 0x08000000 diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index d6ef6ba..e585380 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -280,7 +280,8 @@ int board_early_init_f(void) unsigned int major;
#ifdef CONFIG_TSEC_ENET - out_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); + /* clear BD & FR bits for BE BD's and frame data */ + clrbits_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); #endif
#ifdef CONFIG_FSL_IFC diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b7458a9..006700f 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -481,7 +481,8 @@ int board_early_init_f(void) unsigned int major;
#ifdef CONFIG_TSEC_ENET - out_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); + /* clear BD & FR bits for BE BD's and frame data */ + clrbits_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); out_be32(&scfg->etsecmcr, SCFG_ETSECCMCR_GE2_CLK125); #endif
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 42d0374..4bdc188 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -271,9 +271,6 @@ void redundant_init(struct eth_device *dev) out_be32(®s->tstat, TSTAT_CLEAR_THALT); out_be32(®s->rstat, RSTAT_CLEAR_RHALT); clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); -#ifdef CONFIG_LS102XA - setbits_be32(®s->dmactrl, DMACTRL_LE); -#endif
do { uint16_t status; @@ -370,9 +367,6 @@ static void startup_tsec(struct eth_device *dev) out_be32(®s->tstat, TSTAT_CLEAR_THALT); out_be32(®s->rstat, RSTAT_CLEAR_RHALT); clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); -#ifdef CONFIG_LS102XA - setbits_be32(®s->dmactrl, DMACTRL_LE); -#endif }
/* This returns the status bits of the device. The return value
Acked-by: Alison Wang alison.wang@freescale.com Tested-by: Alison Wang alison.wang@freescale.com
Best Regards, Alison Wang
-----Original Message----- From: Claudiu Manoil [mailto:claudiu.manoil@freescale.com] Sent: Wednesday, August 12, 2015 6:29 PM To: Sun York-R58495 Cc: Wang Huan-B18965; u-boot@lists.denx.de Subject: [PATCH] ls102xa: etsec: Use proper settings for BE BDs
- /* clear BD & FR bits for BE BD's and frame data */
- clrbits_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR);
#endif
- clrbits_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); out_be32(&scfg->etsecmcr, SCFG_ETSECCMCR_GE2_CLK125); #endif
-#endif
-#endif }
1.7.11.7
Applied to fsl-qoriq master branch. Awaiting upstream.
York
Claudiu Manoil
Huan Wang
York Sun
