[U-Boot] [PATCH] reset: socfpga: add reset driver for SoCFPGA platform
Add a DM compatible reset driver for the SoCFPGA platform.
Signed-off-by: Dinh Nguyen dinguyen@kernel.org --- drivers/reset/Kconfig | 7 +++ drivers/reset/Makefile | 1 + drivers/reset/reset-socfpga.c | 111 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 119 insertions(+) create mode 100644 drivers/reset/reset-socfpga.c
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 3964b9e..90b021f 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -83,4 +83,11 @@ config RESET_ROCKCHIP though is that some reset signals, like I2C or MISC reset multiple devices.
+config RESET_SOCFPGA + bool "Reset controller driver for SoCFPGA" + depends on DM_RESET && ARCH_SOCFPGA + default y + help + Support for reset controller on SoCFPGA platform. + endmenu diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 7d7e080..6f791ee 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -13,3 +13,4 @@ obj-$(CONFIG_RESET_BCM6345) += reset-bcm6345.o obj-$(CONFIG_RESET_UNIPHIER) += reset-uniphier.o obj-$(CONFIG_AST2500_RESET) += ast2500-reset.o obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o +obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o diff --git a/drivers/reset/reset-socfpga.c b/drivers/reset/reset-socfpga.c new file mode 100644 index 0000000..af585ec --- /dev/null +++ b/drivers/reset/reset-socfpga.c @@ -0,0 +1,111 @@ +/* + * Socfpga Reset Controller Driver + * + * Copyright 2014 Steffen Trumtrar s.trumtrar@pengutronix.de + * + * based on + * Allwinner SoCs Reset Controller driver + * + * Copyright 2013 Maxime Ripard + * + * Maxime Ripard maxime.ripard@free-electrons.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <dm/of_access.h> +#include <reset-uclass.h> +#include <linux/bitops.h> +#include <linux/io.h> +#include <linux/sizes.h> + +#define BANK_INCREMENT 4 +#define NR_BANKS 8 + +struct socfpga_reset_data { + void __iomem *membase; +}; + +static int socfpga_reset_assert(struct reset_ctl *reset_ctl) +{ + struct socfpga_reset_data *data = dev_get_priv(reset_ctl->dev); + int id = reset_ctl->id; + int reg_width = sizeof(u32); + int bank = id / (reg_width * BITS_PER_BYTE); + int offset = id % (reg_width * BITS_PER_BYTE); + unsigned long flags; + u32 reg; + + reg = readl(data->membase + (bank * BANK_INCREMENT)); + writel(reg | BIT(offset), data->membase + (bank * BANK_INCREMENT)); + return 0; +} + +static int socfpga_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct socfpga_reset_data *data = dev_get_priv(reset_ctl->dev); + int id = reset_ctl->id; + int reg_width = sizeof(u32); + int bank = id / (reg_width * BITS_PER_BYTE); + int offset = id % (reg_width * BITS_PER_BYTE); + unsigned long flags; + u32 reg; + + reg = readl(data->membase + (bank * BANK_INCREMENT)); + writel(reg & ~BIT(offset), data->membase + (bank * BANK_INCREMENT)); + return 0; +} + +static int socfpga_reset_request(struct reset_ctl *reset_ctl) +{ + debug("%s(reset_ctl=%p) (dev=%p, id=%lu)\n", __func__, + reset_ctl, reset_ctl->dev, reset_ctl->id); + + return 0; +} + +static int socfpga_reset_free(struct reset_ctl *reset_ctl) +{ + debug("%s(reset_ctl=%p) (dev=%p, id=%lu)\n", __func__, reset_ctl, + reset_ctl->dev, reset_ctl->id); + + return 0; +} + +static const struct reset_ops socfpga_reset_ops = { + .request = socfpga_reset_request, + .free = socfpga_reset_free, + .rst_assert = socfpga_reset_assert, + .rst_deassert = socfpga_reset_deassert, +}; + +static int socfpga_reset_probe(struct udevice *dev) +{ + struct socfpga_reset_data *data = dev_get_priv(dev); + const void *blob = gd->fdt_blob; + int node = dev_of_offset(dev); + u32 modrst_offset; + + data->membase = devfdt_get_addr_ptr(dev); + + modrst_offset = fdtdec_get_int(blob, node, "altr,modrst-offset", 0x10); + data->membase += modrst_offset; + + return 0; +} + +static const struct udevice_id socfpga_reset_match[] = { + { .compatible = "altr,rst-mgr" }, + { /* sentinel */ }, +}; + +U_BOOT_DRIVER(socfpga_reset) = { + .name = "socfpga-reset", + .id = UCLASS_RESET, + .of_match = socfpga_reset_match, + .probe = socfpga_reset_probe, + .priv_auto_alloc_size = sizeof(struct socfpga_reset_data), + .ops = &socfpga_reset_ops, +};
- bool "Reset controller driver for SoCFPGA"
- depends on DM_RESET && ARCH_SOCFPGA
- default y
- help
- Socfpga Reset Controller Driver
- Copyright 2014 Steffen Trumtrar s.trumtrar@pengutronix.de
- based on
- Allwinner SoCs Reset Controller driver
- Copyright 2013 Maxime Ripard
- Maxime Ripard maxime.ripard@free-electrons.com
- void __iomem *membase;
- struct socfpga_reset_data *data = dev_get_priv(reset_ctl->dev);
- int id = reset_ctl->id;
- int reg_width = sizeof(u32);
- int bank = id / (reg_width * BITS_PER_BYTE);
- int offset = id % (reg_width * BITS_PER_BYTE);
- unsigned long flags;
- u32 reg;
- reg = readl(data->membase + (bank * BANK_INCREMENT));
- writel(reg | BIT(offset), data->membase + (bank * BANK_INCREMENT));
setbits_le32() ?
- u32 reg;
- writel(reg & ~BIT(offset), data->membase + (bank * BANK_INCREMENT));
clrbits_le32() ?
What I do not see is any user of this code, nor any conversion of existing systems to use this code. Is that expected to happen ? I do not want to see dead code piling up in U-Boot.
- default y
- help
- based on
- u32 reg;
setbits_le32() ?
Ok..
- u32 reg;
clrbits_le32() ?
Ok..
I have a patchset that tested this code, the i2c support in SoCFPGA was converted to DM, and uses this reset framework. Should I send that along with this patch in v2?
Dinh
- default y
- help
- based on
- u32 reg;
setbits_le32() ?
Ok..
- u32 reg;
clrbits_le32() ?
Ok..
Yes please, otherwise this will be just another dead code.
Ok will do! A question: ideally I'd like to have the Stratix10 SPL use the reset manager framework, so I'd not have to add a another platform specific reset_manager_s10. Would that be possible? I think it is, but wanted to confirm.
Thanks,
Dinh
Awesome
I think so, the reset handling on socfpga looks trivial.
Dinh Nguyen
