[U-Boot] [GIT PULL] Please pull u-boot-mmc master
Dear Tom,
Could you pull these patches into u-boot/master? If there are problems, let me knows.
The following changes since commit 22f3368e71321db1e0e15dfbf54b052367890ec7:
Merge branch 'master' of git://git.denx.de/u-boot-mips (2017-05-13 16:45:35 -0400)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 08c424fc0073cfad854ebc6164a24c99f31aa125:
mmc: atmel_sdhci: Enable the quirk SDHCI_QUIRK_WAIT_SEND_CMD (2017-05-15 14:00:07 +0900)
---------------------------------------------------------------- Jean-Jacques Hiblot (2): include: config: am335x: disable DM_MMC_OPS if DM_MMC is disabled drivers: omap_hsmmc: move to DM_MMC_OPS
Masahiro Yamada (5): mmc: sdhci-cadence: import updates from Linux 4.12 sandbox_noblk_defconfig: disable CONFIG_GENERIC_MMC blanche_defconfig: enable CONFIG_MMC mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMC mmc: descend into drivers/mmc only when CONFIG_MMC is enabled
Philipp Tomsich (2): env_mmc: configure environment offsets via device tree doc: document u-boot, mmc-env-offset and u-boot, mmc-env-offset-redund
Wenyou Yang (2): mmc: sdhci: Fix maximum clock for programmable clock mode mmc: atmel_sdhci: Enable the quirk SDHCI_QUIRK_WAIT_SEND_CMD
Makefile | 1 - arch/arm/Kconfig | 2 +- board/BuR/common/common.c | 2 +- board/bosch/shc/board.c | 2 +- board/compulab/cl-som-am57x/cl-som-am57x.c | 4 +- board/compulab/cm_t35/cm_t35.c | 4 +- board/compulab/cm_t3517/cm_t3517.c | 2 +- board/compulab/cm_t54/cm_t54.c | 2 +- board/corscience/tricorder/tricorder.c | 4 +- board/gumstix/duovero/duovero.c | 2 +- board/hisilicon/hikey/hikey.c | 2 +- board/isee/igep00x0/igep00x0.c | 4 +- board/logicpd/am3517evm/am3517evm.c | 2 +- board/logicpd/omap3som/omap3logic.c | 4 +- board/logicpd/zoom1/zoom1.c | 2 +- board/overo/overo.c | 4 +- board/pandora/pandora.c | 2 +- board/quipos/cairo/cairo.c | 2 +- board/samsung/arndale/arndale.c | 2 +- board/samsung/common/board.c | 2 +- board/samsung/common/misc.c | 4 +- board/samsung/goni/goni.c | 2 +- board/samsung/smdkv310/smdkv310.c | 2 +- board/sunxi/board.c | 2 +- board/technexion/tao3530/tao3530.c | 4 +- board/ti/am3517crane/am3517crane.c | 2 +- board/ti/am57xx/board.c | 2 +- board/ti/beagle/beagle.c | 4 +- board/ti/dra7xx/evm.c | 2 +- board/ti/evm/evm.c | 4 +- board/ti/ks2_evm/board_k2g.c | 2 +- board/ti/omap5_uevm/evm.c | 2 +- board/ti/panda/panda.c | 2 +- board/ti/sdp4430/sdp.c | 2 +- board/ti/ti814x/evm.c | 2 +- board/timll/devkit8000/devkit8000.c | 4 +- common/board_r.c | 4 +- common/env_mmc.c | 31 ++++++++++++-- common/spl/Kconfig | 4 +- configs/blanche_defconfig | 3 +- configs/sandbox_noblk_defconfig | 1 - doc/device-tree-bindings/config.txt | 12 ++++++ drivers/Makefile | 1 + drivers/mmc/Kconfig | 5 +-- drivers/mmc/Makefile | 28 ++++++------- drivers/mmc/atmel_sdhci.c | 4 +- drivers/mmc/davinci_mmc.c | 2 +- drivers/mmc/omap_hsmmc.c | 38 ++++++++++++++--- drivers/mmc/sdhci-cadence.c | 67 +++++++++++++++++++++++++----- drivers/mmc/sdhci.c | 18 ++++---- include/configs/am335x_evm.h | 2 + include/configs/am335x_shc.h | 1 + include/configs/chiliboard.h | 1 + 53 files changed, 211 insertions(+), 104 deletions(-)
Best Regards, Jaehoon Chung
Dear Tom,
On 05/15/2017 02:06 PM, Jaehoon Chung wrote:
Dear Tom,
Discard this PR..When i checked some patches, there are problem..So i will resend the PR.
Best Regards, Jaehoon Chung _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Jaehoon Chung
