[U-Boot] [PATCH] spi: Zap mxs_spi driver-related code
Dropped - mxs_spi driver - CONFIG_MXS_SPI
Dropped due to: - no active updates - no dm conversion - multiple pings for asking dm-conversion - no response for dm converted patch - driver-model migration expiry
Cc: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/bg0900_defconfig | 1 - configs/mx28evk_auart_console_defconfig | 1 - configs/mx28evk_defconfig | 1 - configs/mx28evk_nand_defconfig | 1 - configs/mx28evk_spi_defconfig | 1 - drivers/spi/Kconfig | 6 - drivers/spi/Makefile | 1 - drivers/spi/mxs_spi.c | 358 ------------------------ 8 files changed, 370 deletions(-) delete mode 100644 drivers/spi/mxs_spi.c
diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 2c4d3e3d54..f8421ef304 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -40,5 +40,4 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index c54b933e53..d976ea584c 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -51,7 +51,6 @@ CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 187467d3db..40ab39ccf1 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -51,7 +51,6 @@ CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 7d891e7934..0d2afbbdb0 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -50,7 +50,6 @@ CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index cb5b1b3b75..b9ea4934bb 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -50,7 +50,6 @@ CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 7043b5c0f6..955da8db64 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -370,12 +370,6 @@ config MXC_SPI Enable the MXC SPI controller driver. This driver can be used on various i.MX SoCs such as i.MX31/35/51/6/7.
-config MXS_SPI - bool "MXS SPI Driver" - help - Enable the MXS SPI controller driver. This driver can be used - on the i.MX23 and i.MX28 SoCs. - config OMAP3_SPI bool "McSPI driver for OMAP" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 25add2812d..055ef99dc9 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -40,7 +40,6 @@ obj-$(CONFIG_MT7621_SPI) += mt7621_spi.o obj-$(CONFIG_MSCC_BB_SPI) += mscc_bb_spi.o obj-$(CONFIG_MVEBU_A3700_SPI) += mvebu_a3700_spi.o obj-$(CONFIG_MXC_SPI) += mxc_spi.o -obj-$(CONFIG_MXS_SPI) += mxs_spi.o obj-$(CONFIG_ATCSPI200_SPI) += atcspi200_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_PIC32_SPI) += pic32_spi.o diff --git a/drivers/spi/mxs_spi.c b/drivers/spi/mxs_spi.c deleted file mode 100644 index 5065e407f8..0000000000 --- a/drivers/spi/mxs_spi.c +++ /dev/null @@ -1,358 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Freescale i.MX28 SPI driver - * - * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com - * on behalf of DENX Software Engineering GmbH - * - * NOTE: This driver only supports the SPI-controller chipselects, - * GPIO driven chipselects are not supported. - */ - -#include <common.h> -#include <malloc.h> -#include <memalign.h> -#include <spi.h> -#include <linux/errno.h> -#include <asm/io.h> -#include <asm/arch/clock.h> -#include <asm/arch/imx-regs.h> -#include <asm/arch/sys_proto.h> -#include <asm/mach-imx/dma.h> - -#define MXS_SPI_MAX_TIMEOUT 1000000 -#define MXS_SPI_PORT_OFFSET 0x2000 -#define MXS_SSP_CHIPSELECT_MASK 0x00300000 -#define MXS_SSP_CHIPSELECT_SHIFT 20 - -#define MXSSSP_SMALL_TRANSFER 512 - -struct mxs_spi_slave { - struct spi_slave slave; - uint32_t max_khz; - uint32_t mode; - struct mxs_ssp_regs *regs; -}; - -static inline struct mxs_spi_slave *to_mxs_slave(struct spi_slave *slave) -{ - return container_of(slave, struct mxs_spi_slave, slave); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - /* MXS SPI: 4 ports and 3 chip selects maximum */ - if (!mxs_ssp_bus_id_valid(bus) || cs > 2) - return 0; - else - return 1; -} - -struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, - unsigned int max_hz, unsigned int mode) -{ - struct mxs_spi_slave *mxs_slave; - - if (!spi_cs_is_valid(bus, cs)) { - printf("mxs_spi: invalid bus %d / chip select %d\n", bus, cs); - return NULL; - } - - mxs_slave = spi_alloc_slave(struct mxs_spi_slave, bus, cs); - if (!mxs_slave) - return NULL; - - if (mxs_dma_init_channel(MXS_DMA_CHANNEL_AHB_APBH_SSP0 + bus)) - goto err_init; - - mxs_slave->max_khz = max_hz / 1000; - mxs_slave->mode = mode; - mxs_slave->regs = mxs_ssp_regs_by_bus(bus); - - return &mxs_slave->slave; - -err_init: - free(mxs_slave); - return NULL; -} - -void spi_free_slave(struct spi_slave *slave) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - free(mxs_slave); -} - -int spi_claim_bus(struct spi_slave *slave) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; - uint32_t reg = 0; - - mxs_reset_block(&ssp_regs->hw_ssp_ctrl0_reg); - - writel((slave->cs << MXS_SSP_CHIPSELECT_SHIFT) | - SSP_CTRL0_BUS_WIDTH_ONE_BIT, - &ssp_regs->hw_ssp_ctrl0); - - reg = SSP_CTRL1_SSP_MODE_SPI | SSP_CTRL1_WORD_LENGTH_EIGHT_BITS; - reg |= (mxs_slave->mode & SPI_CPOL) ? SSP_CTRL1_POLARITY : 0; - reg |= (mxs_slave->mode & SPI_CPHA) ? SSP_CTRL1_PHASE : 0; - writel(reg, &ssp_regs->hw_ssp_ctrl1); - - writel(0, &ssp_regs->hw_ssp_cmd0); - - mxs_set_ssp_busclock(slave->bus, mxs_slave->max_khz); - - return 0; -} - -void spi_release_bus(struct spi_slave *slave) -{ -} - -static void mxs_spi_start_xfer(struct mxs_ssp_regs *ssp_regs) -{ - writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_set); - writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_clr); -} - -static void mxs_spi_end_xfer(struct mxs_ssp_regs *ssp_regs) -{ - writel(SSP_CTRL0_LOCK_CS, &ssp_regs->hw_ssp_ctrl0_clr); - writel(SSP_CTRL0_IGNORE_CRC, &ssp_regs->hw_ssp_ctrl0_set); -} - -static int mxs_spi_xfer_pio(struct mxs_spi_slave *slave, - char *data, int length, int write, unsigned long flags) -{ - struct mxs_ssp_regs *ssp_regs = slave->regs; - - if (flags & SPI_XFER_BEGIN) - mxs_spi_start_xfer(ssp_regs); - - while (length--) { - /* We transfer 1 byte */ -#if defined(CONFIG_MX23) - writel(SSP_CTRL0_XFER_COUNT_MASK, &ssp_regs->hw_ssp_ctrl0_clr); - writel(1, &ssp_regs->hw_ssp_ctrl0_set); -#elif defined(CONFIG_MX28) - writel(1, &ssp_regs->hw_ssp_xfer_size); -#endif - - if ((flags & SPI_XFER_END) && !length) - mxs_spi_end_xfer(ssp_regs); - - if (write) - writel(SSP_CTRL0_READ, &ssp_regs->hw_ssp_ctrl0_clr); - else - writel(SSP_CTRL0_READ, &ssp_regs->hw_ssp_ctrl0_set); - - writel(SSP_CTRL0_RUN, &ssp_regs->hw_ssp_ctrl0_set); - - if (mxs_wait_mask_set(&ssp_regs->hw_ssp_ctrl0_reg, - SSP_CTRL0_RUN, MXS_SPI_MAX_TIMEOUT)) { - printf("MXS SPI: Timeout waiting for start\n"); - return -ETIMEDOUT; - } - - if (write) - writel(*data++, &ssp_regs->hw_ssp_data); - - writel(SSP_CTRL0_DATA_XFER, &ssp_regs->hw_ssp_ctrl0_set); - - if (!write) { - if (mxs_wait_mask_clr(&ssp_regs->hw_ssp_status_reg, - SSP_STATUS_FIFO_EMPTY, MXS_SPI_MAX_TIMEOUT)) { - printf("MXS SPI: Timeout waiting for data\n"); - return -ETIMEDOUT; - } - - *data = readl(&ssp_regs->hw_ssp_data); - data++; - } - - if (mxs_wait_mask_clr(&ssp_regs->hw_ssp_ctrl0_reg, - SSP_CTRL0_RUN, MXS_SPI_MAX_TIMEOUT)) { - printf("MXS SPI: Timeout waiting for finish\n"); - return -ETIMEDOUT; - } - } - - return 0; -} - -static int mxs_spi_xfer_dma(struct mxs_spi_slave *slave, - char *data, int length, int write, unsigned long flags) -{ - const int xfer_max_sz = 0xff00; - const int desc_count = DIV_ROUND_UP(length, xfer_max_sz) + 1; - struct mxs_ssp_regs *ssp_regs = slave->regs; - struct mxs_dma_desc *dp; - uint32_t ctrl0; - uint32_t cache_data_count; - const uint32_t dstart = (uint32_t)data; - int dmach; - int tl; - int ret = 0; - -#if defined(CONFIG_MX23) - const int mxs_spi_pio_words = 1; -#elif defined(CONFIG_MX28) - const int mxs_spi_pio_words = 4; -#endif - - ALLOC_CACHE_ALIGN_BUFFER(struct mxs_dma_desc, desc, desc_count); - - memset(desc, 0, sizeof(struct mxs_dma_desc) * desc_count); - - ctrl0 = readl(&ssp_regs->hw_ssp_ctrl0); - ctrl0 |= SSP_CTRL0_DATA_XFER; - - if (flags & SPI_XFER_BEGIN) - ctrl0 |= SSP_CTRL0_LOCK_CS; - if (!write) - ctrl0 |= SSP_CTRL0_READ; - - if (length % ARCH_DMA_MINALIGN) - cache_data_count = roundup(length, ARCH_DMA_MINALIGN); - else - cache_data_count = length; - - /* Flush data to DRAM so DMA can pick them up */ - if (write) - flush_dcache_range(dstart, dstart + cache_data_count); - - /* Invalidate the area, so no writeback into the RAM races with DMA */ - invalidate_dcache_range(dstart, dstart + cache_data_count); - - dmach = MXS_DMA_CHANNEL_AHB_APBH_SSP0 + slave->slave.bus; - - dp = desc; - while (length) { - dp->address = (dma_addr_t)dp; - dp->cmd.address = (dma_addr_t)data; - - /* - * This is correct, even though it does indeed look insane. - * I hereby have to, wholeheartedly, thank Freescale Inc., - * for always inventing insane hardware and keeping me busy - * and employed ;-) - */ - if (write) - dp->cmd.data = MXS_DMA_DESC_COMMAND_DMA_READ; - else - dp->cmd.data = MXS_DMA_DESC_COMMAND_DMA_WRITE; - - /* - * The DMA controller can transfer large chunks (64kB) at - * time by setting the transfer length to 0. Setting tl to - * 0x10000 will overflow below and make .data contain 0. - * Otherwise, 0xff00 is the transfer maximum. - */ - if (length >= 0x10000) - tl = 0x10000; - else - tl = min(length, xfer_max_sz); - - dp->cmd.data |= - ((tl & 0xffff) << MXS_DMA_DESC_BYTES_OFFSET) | - (mxs_spi_pio_words << MXS_DMA_DESC_PIO_WORDS_OFFSET) | - MXS_DMA_DESC_HALT_ON_TERMINATE | - MXS_DMA_DESC_TERMINATE_FLUSH; - - data += tl; - length -= tl; - - if (!length) { - dp->cmd.data |= MXS_DMA_DESC_IRQ | MXS_DMA_DESC_DEC_SEM; - - if (flags & SPI_XFER_END) { - ctrl0 &= ~SSP_CTRL0_LOCK_CS; - ctrl0 |= SSP_CTRL0_IGNORE_CRC; - } - } - - /* - * Write CTRL0, CMD0, CMD1 and XFER_SIZE registers in - * case of MX28, write only CTRL0 in case of MX23 due - * to the difference in register layout. It is utterly - * essential that the XFER_SIZE register is written on - * a per-descriptor basis with the same size as is the - * descriptor! - */ - dp->cmd.pio_words[0] = ctrl0; -#ifdef CONFIG_MX28 - dp->cmd.pio_words[1] = 0; - dp->cmd.pio_words[2] = 0; - dp->cmd.pio_words[3] = tl; -#endif - - mxs_dma_desc_append(dmach, dp); - - dp++; - } - - if (mxs_dma_go(dmach)) - ret = -EINVAL; - - /* The data arrived into DRAM, invalidate cache over them */ - if (!write) - invalidate_dcache_range(dstart, dstart + cache_data_count); - - return ret; -} - -int spi_xfer(struct spi_slave *slave, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) -{ - struct mxs_spi_slave *mxs_slave = to_mxs_slave(slave); - struct mxs_ssp_regs *ssp_regs = mxs_slave->regs; - int len = bitlen / 8; - char dummy; - int write = 0; - char *data = NULL; - int dma = 1; - - if (bitlen == 0) { - if (flags & SPI_XFER_END) { - din = (void *)&dummy; - len = 1; - } else - return 0; - } - - /* Half-duplex only */ - if (din && dout) - return -EINVAL; - /* No data */ - if (!din && !dout) - return 0; - - if (dout) { - data = (char *)dout; - write = 1; - } else if (din) { - data = (char *)din; - write = 0; - } - - /* - * Check for alignment, if the buffer is aligned, do DMA transfer, - * PIO otherwise. This is a temporary workaround until proper bounce - * buffer is in place. - */ - if (dma) { - if (((uint32_t)data) & (ARCH_DMA_MINALIGN - 1)) - dma = 0; - if (((uint32_t)len) & (ARCH_DMA_MINALIGN - 1)) - dma = 0; - } - - if (!dma || (len < MXSSSP_SMALL_TRANSFER)) { - writel(SSP_CTRL1_DMA_ENABLE, &ssp_regs->hw_ssp_ctrl1_clr); - return mxs_spi_xfer_pio(mxs_slave, data, len, write, flags); - } else { - writel(SSP_CTRL1_DMA_ENABLE, &ssp_regs->hw_ssp_ctrl1_set); - return mxs_spi_xfer_dma(mxs_slave, data, len, write, flags); - } -}
Jagan Teki
