[U-Boot] [PATCH] tools: zynqmpimage: round up partition size
The FSBL copies "Total Partition Word Length" * 4 bytes from the boot.bin, which implies that the partition size is 4 byte aligned. When writing the partition, mkimage calculates "Total Partition Word Length" by dividing the size by 4. This implicitly cuts unaligned bytes at the end of the added binary.
Instead of rounding down, the size must be round up to 4 bytes and the binary padded accordingly.
Signed-off-by: Michael Tretter m.tretter@pengutronix.de --- tools/zynqmpbif.c | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/tools/zynqmpbif.c b/tools/zynqmpbif.c index 6c8f66055d..885a037da6 100644 --- a/tools/zynqmpbif.c +++ b/tools/zynqmpbif.c @@ -316,19 +316,29 @@ static int bif_add_pmufw(struct bif_entry *bf, const char *data, size_t len) return 0; }
-static int bif_add_part(struct bif_entry *bf, const char *data, size_t len) +static int bif_add_part(struct bif_entry *bf, char *data, size_t len) { size_t parthdr_offset = 0; + size_t len_padded = ROUND(len, 4); + struct partition_header parthdr = { - .len_enc = cpu_to_le32(len / 4), - .len_unenc = cpu_to_le32(len / 4), - .len = cpu_to_le32(len / 4), + .len_enc = cpu_to_le32(len_padded / 4), + .len_unenc = cpu_to_le32(len_padded / 4), + .len = cpu_to_le32(len_padded / 4), .entry_point = cpu_to_le64(bf->entry), .load_address = cpu_to_le64(bf->load), }; int r; uint32_t csum;
+ if (len != len_padded) { + data = realloc(data, len_padded); + while (len < len_padded) { + data[len] = 0; + len++; + } + } + if (bf->flags & (1ULL << BIF_FLAG_PMUFW_IMAGE)) return bif_add_pmufw(bf, data, len);
+Alex
- size_t len_padded = ROUND(len, 4);
- struct partition_header parthdr = {
data[len] = 0;
len++;
I am not using this for creating boot image but I have tested it on regular example and it is still working.
I have applied this to my branch. Alex: If you have any comment on this please let us know and I can remove it from my queue.
Thanks, Michal
On 03.12.18 14:14, Michal Simek wrote:
+Alex
data[len] = 0;
len++;
I don't think I've ever had a not-multiple-of-4 payload, so I never ran into this.
The one thing that I'm not fully sure of is the realloc(). I don't think that data is necessarily always a pointer that way allocated using malloc().
If you look at bif_add_bit() for example the data pointer is an offset into a pointer from read_full_file(). So realloc() won't work on it.
I think it's safer to just allocate a completely new buffer here and copy the payload if unaligned.
Alex
+Alex
data[len] = 0;
len++;
ok. Let me just wait a little bit to finish this discussion.
Thanks, Michal
+Alex
data[len] = 0;
len++;
Thanks. I thought about aligning data in read_full_file(), but the size read by read_full_file() is not used in bif_add_elf(). I further assumed that the bitstream is always correctly aligned (because I never saw anything else) and will never hit the realloc() path, but I'm not sure if this is a safe assumption.
As realloc() does not work in bif_add_part(), I can only malloc() a new aligned buffer and cannot free() the old one. I guess that is fine.
I will send a v2.
Michael
+Alex
data[len] = 0;
len++;
Yes. We're already leaking the old buffer, so leaking yet another one isn't a big issue either ;).
I will send a v2.
Thanks! And please CC me on patches to zynqmpbif next time :).
Alex
+Alex
data[len] = 0;
len++;
I was playing with U-Boot on Friday and I found one thing related to this commit. You can get "not-multiple-of-4 payload" quite simply just but enabling OF_SEPARATE for SPL which is generating (I am not 100% sure if all case) aligned u-boot-spl-nodtb.bin and then appends cat <filterred dtb> >> u-boot-spl-nodtb.bin which is ending up in "not-multiple-of-4 payload" very often.
I was trying to enable OF_SEPARATE because of "fdt: Add warning about CONFIG_OF_EMBED" (sha1: 841d5fbae4e993476fa87d8933db0cd58d3c2d41) which is working fine for jtag bootmode but not for SD one (I expect also others will be broken).
But I found that you are still pure len(non aligned) in image_size/image_stored_size instead of aligned one. Which caused that boot.bin with "not-multiple-of-4 payload" is not handled properly by bootrom.
After this patch, boot.bin started to work.
--- a/tools/zynqmpbif.c +++ b/tools/zynqmpbif.c @@ -425,8 +425,8 @@ static int bif_add_part(struct bif_entry *bf, const char *data, size_t len) if (!bif_output.header->image_offset) bif_output.header->image_offset = cpu_to_le32(bf->offset); - bif_output.header->image_size = cpu_to_le32(len); - bif_output.header->image_stored_size = cpu_to_le32(len); + bif_output.header->image_size = cpu_to_le32(len_padded); + bif_output.header->image_stored_size = cpu_to_le32(len_padded);
Anyway xilinx bootgen has issue with this too and also zynqmpimage.c.
Can you please retest it again but I am quite sure you need to also update header with padded len?
Thanks, Michal
+Alex
data[len] = 0;
len++;
The image_size affects only the first stage bootloader. As I use the FSBL for that, I didn't run into this issue.
I can reproduce the issue by writing a size that is not multiple of 4 into either image_size or image_stored_size. The FSBL does not boot, if the image_size is larger than the size of the image, but not 4 byte aligned. It does boot, if image_size is larger and 4 byte aligned.
I would have expected that the bootrom ignores the bytes between image_size and partition_size and just reads image_size bytes. Therefore, aligning the image_size looks like a proper fix, but the reason for the patch is different.
Michael
Thanks, Michal
Signed-off-by: Michael Tretter m.tretter@pengutronix.de --- v2: - do not realloc() data but malloc() and memcpy() new data --- tools/zynqmpbif.c | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/tools/zynqmpbif.c b/tools/zynqmpbif.c index 6c8f66055d..a33c15e1f0 100644 --- a/tools/zynqmpbif.c +++ b/tools/zynqmpbif.c @@ -319,16 +319,25 @@ static int bif_add_pmufw(struct bif_entry *bf, const char *data, size_t len) static int bif_add_part(struct bif_entry *bf, const char *data, size_t len) { size_t parthdr_offset = 0; + size_t len_padded = ROUND(len, 4); + struct partition_header parthdr = { - .len_enc = cpu_to_le32(len / 4), - .len_unenc = cpu_to_le32(len / 4), - .len = cpu_to_le32(len / 4), + .len_enc = cpu_to_le32(len_padded / 4), + .len_unenc = cpu_to_le32(len_padded / 4), + .len = cpu_to_le32(len_padded / 4), .entry_point = cpu_to_le64(bf->entry), .load_address = cpu_to_le64(bf->load), }; int r; uint32_t csum;
+ if (len < len_padded) { + char *newdata = malloc(len_padded); + memcpy(newdata, data, len); + memset(newdata + len, 0, len_padded - len); + data = newdata; + } + if (bf->flags & (1ULL << BIF_FLAG_PMUFW_IMAGE)) return bif_add_pmufw(bf, data, len);
Reviewed-by: Alexander Graf agraf@suse.de
Alex
v2:
data = newdata;
Applied. M
Alexander Graf
Michael Tretter
Michal Simek
Michal Simek
