[PATCH v2] efi_loader: move efi_var_collect to common functions
efi_var_collect() was initially placed in efi_var_file.c, since back then we only supported efi variables stored in a file. Since then we support variables stored in an RPMB as well and use that function to collect variables that should be present at runtime.
So let's move it around in efi_var_common.c which makes more sense
Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Ilias Apalodimas apalos@gmail.com --- Changes since v1: - Clean up the makefile as well - fix checkpatch error
lib/efi_loader/Makefile | 2 +- lib/efi_loader/efi_var_common.c | 74 +++++++++++++++++++++++++++++++++ lib/efi_loader/efi_var_file.c | 64 ---------------------------- 3 files changed, 75 insertions(+), 65 deletions(-)
diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index fcb0af7e7d6d..6a0ce6c32c88 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -72,11 +72,11 @@ obj-y += efi_string.o obj-$(CONFIG_EFI_UNICODE_COLLATION_PROTOCOL2) += efi_unicode_collation.o obj-y += efi_var_common.o obj-y += efi_var_mem.o -obj-y += efi_var_file.o ifeq ($(CONFIG_EFI_MM_COMM_TEE),y) obj-y += efi_variable_tee.o else obj-y += efi_variable.o +obj-y += efi_var_file.o obj-$(CONFIG_EFI_VARIABLES_PRESEED) += efi_var_seed.o endif obj-y += efi_watchdog.o diff --git a/lib/efi_loader/efi_var_common.c b/lib/efi_loader/efi_var_common.c index d528747f3fb4..4268850990f5 100644 --- a/lib/efi_loader/efi_var_common.c +++ b/lib/efi_loader/efi_var_common.c @@ -9,6 +9,7 @@ #include <efi_loader.h> #include <efi_variable.h> #include <stdlib.h> +#include <u-boot/crc.h>
enum efi_secure_mode { EFI_MODE_SETUP, @@ -416,3 +417,76 @@ void *efi_get_var(const u16 *name, const efi_guid_t *vendor, efi_uintn_t *size)
return buf; } + +/** + * efi_var_collect() - Copy EFI variables mstching attributes mask + * + * @bufp: buffer containing variable collection + * @lenp: buffer length + * @attr_mask: mask of matched attributes + * + * Return: Status code + */ +efi_status_t __maybe_unused efi_var_collect(struct efi_var_file **bufp, loff_t *lenp, + u32 check_attr_mask) +{ + size_t len = EFI_VAR_BUF_SIZE; + struct efi_var_file *buf; + struct efi_var_entry *var, *old_var; + size_t old_var_name_length = 2; + + *bufp = NULL; /* Avoid double free() */ + buf = calloc(1, len); + if (!buf) + return EFI_OUT_OF_RESOURCES; + var = buf->var; + old_var = var; + for (;;) { + efi_uintn_t data_length, var_name_length; + u8 *data; + efi_status_t ret; + + if ((uintptr_t)buf + len <= + (uintptr_t)var->name + old_var_name_length) + return EFI_BUFFER_TOO_SMALL; + + var_name_length = (uintptr_t)buf + len - (uintptr_t)var->name; + memcpy(var->name, old_var->name, old_var_name_length); + guidcpy(&var->guid, &old_var->guid); + ret = efi_get_next_variable_name_int( + &var_name_length, var->name, &var->guid); + if (ret == EFI_NOT_FOUND) + break; + if (ret != EFI_SUCCESS) { + free(buf); + return ret; + } + old_var_name_length = var_name_length; + old_var = var; + + data = (u8 *)var->name + old_var_name_length; + data_length = (uintptr_t)buf + len - (uintptr_t)data; + ret = efi_get_variable_int(var->name, &var->guid, + &var->attr, &data_length, data, + &var->time); + if (ret != EFI_SUCCESS) { + free(buf); + return ret; + } + if ((var->attr & check_attr_mask) == check_attr_mask) { + var->length = data_length; + var = (struct efi_var_entry *)ALIGN((uintptr_t)data + data_length, 8); + } + } + + buf->reserved = 0; + buf->magic = EFI_VAR_FILE_MAGIC; + len = (uintptr_t)var - (uintptr_t)buf; + buf->crc32 = crc32(0, (u8 *)buf->var, + len - sizeof(struct efi_var_file)); + buf->length = len; + *bufp = buf; + *lenp = len; + + return EFI_SUCCESS; +} diff --git a/lib/efi_loader/efi_var_file.c b/lib/efi_loader/efi_var_file.c index 532b6b40eefe..413e1794e88c 100644 --- a/lib/efi_loader/efi_var_file.c +++ b/lib/efi_loader/efi_var_file.c @@ -52,70 +52,6 @@ static efi_status_t __maybe_unused efi_set_blk_dev_to_system_partition(void) return EFI_SUCCESS; }
-efi_status_t __maybe_unused efi_var_collect(struct efi_var_file **bufp, loff_t *lenp, - u32 check_attr_mask) -{ - size_t len = EFI_VAR_BUF_SIZE; - struct efi_var_file *buf; - struct efi_var_entry *var, *old_var; - size_t old_var_name_length = 2; - - *bufp = NULL; /* Avoid double free() */ - buf = calloc(1, len); - if (!buf) - return EFI_OUT_OF_RESOURCES; - var = buf->var; - old_var = var; - for (;;) { - efi_uintn_t data_length, var_name_length; - u8 *data; - efi_status_t ret; - - if ((uintptr_t)buf + len <= - (uintptr_t)var->name + old_var_name_length) - return EFI_BUFFER_TOO_SMALL; - - var_name_length = (uintptr_t)buf + len - (uintptr_t)var->name; - memcpy(var->name, old_var->name, old_var_name_length); - guidcpy(&var->guid, &old_var->guid); - ret = efi_get_next_variable_name_int( - &var_name_length, var->name, &var->guid); - if (ret == EFI_NOT_FOUND) - break; - if (ret != EFI_SUCCESS) { - free(buf); - return ret; - } - old_var_name_length = var_name_length; - old_var = var; - - data = (u8 *)var->name + old_var_name_length; - data_length = (uintptr_t)buf + len - (uintptr_t)data; - ret = efi_get_variable_int(var->name, &var->guid, - &var->attr, &data_length, data, - &var->time); - if (ret != EFI_SUCCESS) { - free(buf); - return ret; - } - if ((var->attr & check_attr_mask) == check_attr_mask) { - var->length = data_length; - var = (struct efi_var_entry *)ALIGN((uintptr_t)data + data_length, 8); - } - } - - buf->reserved = 0; - buf->magic = EFI_VAR_FILE_MAGIC; - len = (uintptr_t)var - (uintptr_t)buf; - buf->crc32 = crc32(0, (u8 *)buf->var, - len - sizeof(struct efi_var_file)); - buf->length = len; - *bufp = buf; - *lenp = len; - - return EFI_SUCCESS; -} - /** * efi_var_to_file() - save non-volatile variables as file * -- 2.43.0
Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
Changes since v1:
return buf; }
- efi_var_collect() - Copy EFI variables mstching attributes mask
- @bufp: buffer containing variable collection
- @lenp: buffer length
- @attr_mask: mask of matched attributes
- Return: Status code
- if (!buf)
- var = buf->var;
- old_var = var;
- for (;;) {
u8 *data;
efi_status_t ret;
break;
free(buf);
return ret;
old_var = var;
&var->time);
free(buf);
return ret;
- *bufp = buf;
- *lenp = len;
- if (!buf)
- var = buf->var;
- old_var = var;
- for (;;) {
u8 *data;
efi_status_t ret;
break;
free(buf);
return ret;
old_var = var;
&var->time);
free(buf);
return ret;
- *bufp = buf;
- *lenp = len;
- efi_var_to_file() - save non-volatile variables as file
-- 2.43.0
Ilias Apalodimas
