[U-Boot-Users] [PATCH] Fix various redefinition build warnings
- warning: "ICMR" redefined - warning: "RCSR" redefined - warning: "OSMR3" redefined - warning: "OSCR" redefined - warning: "OWER" redefined - warning: "OIER" redefined - warning: "CCCR" redefined
Signed-off-by: Marcel Ziswiler marcel@ziswiler.com --- cpu/pxa/start.S | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/cpu/pxa/start.S b/cpu/pxa/start.S index 31f408d..a460f30 100644 --- a/cpu/pxa/start.S +++ b/cpu/pxa/start.S @@ -166,17 +166,17 @@ _start_armboot: .word start_armboot /* */ /****************************************************************************/ /* mk@tbd: Fix this! */ -#if defined(CONFIG_PXA250) || defined(CONFIG_CPU_MONAHANS) +#if defined(CONFIG_PXA250) || defined(CONFIG_PXA27X) || defined(CONFIG_CPU_MONAHANS) #undef ICMR #undef OSMR3 #undef OSCR #undef OWER #undef OIER -#endif /* CONFIG_PXA250 || CONFIG_CPU_MONAHANS */ -#ifdef CONFIG_PXA250 +#endif /* CONFIG_PXA250 || CONFIG_PXA27X || CONFIG_CPU_MONAHANS */ +#if defined(CONFIG_PXA250) || defined(CONFIG_PXA27X) #undef RCSR #undef CCCR -#endif /* CONFIG_PXA250 */ +#endif /* CONFIG_PXA250 || CONFIG_PXA27X */
/* Interrupt-Controller base address */ IC_BASE: .word 0x40d00000
Already fixed (slightly different) by
commit 27c38689d0cfde0e444239345f97b5eecc9f4067 Author: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com Date: Thu May 1 02:13:44 2008 +0200
pxa: fix previous definition on cpu init
Thanks anyway.
Marcel Ziswiler
