[PATCH] efi_loader: access __efi_runtime_rel_start/stop without &
A symbol defined in a linker script (e.g. __efi_runtime_rel_start = .;) is only a symbol, not a variable and should not be dereferenced. The common practice is either define it as extern uint32_t __efi_runtime_rel_start or extern char __efi_runtime_rel_start[] and access it as &__efi_runtime_rel_start or __efi_runtime_rel_start respectively.
So let's access it properly since we define it as an array
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_runtime.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/efi_loader/efi_runtime.c b/lib/efi_loader/efi_runtime.c index 9185f1894c47..fdf2fbd9ba3d 100644 --- a/lib/efi_loader/efi_runtime.c +++ b/lib/efi_loader/efi_runtime.c @@ -669,14 +669,14 @@ static __efi_runtime void efi_relocate_runtime_table(ulong offset) void efi_runtime_relocate(ulong offset, struct efi_mem_desc *map) { #ifdef IS_RELA - struct elf_rela *rel = (void*)&__efi_runtime_rel_start; + struct elf_rela *rel = (void *)__efi_runtime_rel_start; #else - struct elf_rel *rel = (void*)&__efi_runtime_rel_start; + struct elf_rel *rel = (void *)__efi_runtime_rel_start; static ulong lastoff = CONFIG_TEXT_BASE; #endif
debug("%s: Relocating to offset=%lx\n", __func__, offset); - for (; (ulong)rel < (ulong)&__efi_runtime_rel_stop; rel++) { + for (; (ulong)rel < (ulong)__efi_runtime_rel_stop; rel++) { ulong base = CONFIG_TEXT_BASE; ulong *p; ulong newaddr;
Ilias Apalodimas
