[U-Boot] [PATCH 2/3] OMAP: rename timer divisor
Divisor field is called PTV not PVT.
Signed-off-by: Ladislav Michl ladis@linux-mips.org
--- cpu/arm925t/interrupts.c | 2 +- include/configs/SX1.h | 6 +++--- include/configs/apollon.h | 6 ++---- include/configs/netstar.h | 4 ++-- include/configs/omap1510inn.h | 6 +++--- include/configs/omap1610h2.h | 4 ++-- include/configs/omap1610inn.h | 4 ++-- include/configs/omap2420h4.h | 10 +++++----- include/configs/omap3_beagle.h | 6 ++---- include/configs/omap3_evm.h | 6 ++---- include/configs/omap3_overo.h | 6 ++---- include/configs/omap3_pandora.h | 6 ++---- include/configs/omap3_zoom1.h | 6 ++---- include/configs/omap5912osk.h | 4 ++-- include/configs/omap730p2.h | 7 +++---- include/configs/voiceblue.h | 6 +++--- 16 files changed, 38 insertions(+), 51 deletions(-)
diff --git a/cpu/arm925t/interrupts.c b/cpu/arm925t/interrupts.c index ce3c4ad..361047b 100644 --- a/cpu/arm925t/interrupts.c +++ b/cpu/arm925t/interrupts.c @@ -51,7 +51,7 @@ int interrupt_init (void)
/* Start the decrementer ticking down from 0xffffffff */ *((int32_t *) (CONFIG_SYS_TIMERBASE + LOAD_TIM)) = TIMER_LOAD_VAL; - val = MPUTIM_ST | MPUTIM_AR | MPUTIM_CLOCK_ENABLE | (CONFIG_SYS_PVT << MPUTIM_PTV_BIT); + val = MPUTIM_ST | MPUTIM_AR | MPUTIM_CLOCK_ENABLE | (CONFIG_SYS_PTV << MPUTIM_PTV_BIT); *((int32_t *) (CONFIG_SYS_TIMERBASE + CNTL_TIMER)) = val;
/* init the timestamp and lastdec value */ diff --git a/include/configs/SX1.h b/include/configs/SX1.h index 78c5152..cb6ee16 100644 --- a/include/configs/SX1.h +++ b/include/configs/SX1.h @@ -140,9 +140,9 @@ /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE /* use timer 1 */ +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/apollon.h b/include/configs/apollon.h index f83dd9c..a3c7acf 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -204,11 +204,9 @@ * or by 32KHz clk, or from external sig. This rate is divided by a local * divisor. */ -#define V_PVT 7 /* use with 12MHz/128 */ - #define CONFIG_SYS_TIMERBASE OMAP2420_GPT2 -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/netstar.h b/include/configs/netstar.h index 0b38549..2fa0366 100644 --- a/include/configs/netstar.h +++ b/include/configs/netstar.h @@ -219,8 +219,8 @@ * This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(pvt+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
#define OMAP5910_DPLL_DIV 1 #define OMAP5910_DPLL_MUL ((CONFIG_SYS_CLK_FREQ * \ diff --git a/include/configs/omap1510inn.h b/include/configs/omap1510inn.h index c7d1b6c..2ebf692 100644 --- a/include/configs/omap1510inn.h +++ b/include/configs/omap1510inn.h @@ -137,9 +137,9 @@ /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE /* use timer 1 */ +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap1610h2.h b/include/configs/omap1610h2.h index e2a6360..382b231 100644 --- a/include/configs/omap1610h2.h +++ b/include/configs/omap1610h2.h @@ -133,8 +133,8 @@ * DPLL1. This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap1610inn.h b/include/configs/omap1610inn.h index 5dcfce1..cf4197d 100644 --- a/include/configs/omap1610inn.h +++ b/include/configs/omap1610inn.h @@ -138,8 +138,8 @@ * DPLL1. This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index 983b5f2..2048548 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -224,14 +224,14 @@ * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ #ifdef CONFIG_APTIX -#define V_PVT 3 +#define V_PTV 3 #else -#define V_PVT 7 /* use with 12MHz/128 */ +#define V_PTV 7 /* use with 12MHz/128 */ #endif
-#define CONFIG_SYS_TIMERBASE OMAP2420_GPT2 -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP2420_GPT2 +#define CONFIG_SYS_PTV V_PTV /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 9057606..a197517 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -223,11 +223,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PVT 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index f4498a9..5fe9700 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -222,11 +222,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index dee0417..ac33308 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -216,11 +216,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 00c0374..13f2bfd 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -218,11 +218,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index f8ae163..45a9336 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -225,11 +225,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap5912osk.h b/include/configs/omap5912osk.h index 63cd9c6..4de0ce5 100644 --- a/include/configs/omap5912osk.h +++ b/include/configs/omap5912osk.h @@ -142,8 +142,8 @@ * DPLL1. This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap730p2.h b/include/configs/omap730p2.h index 166d592..c7e3daa 100644 --- a/include/configs/omap730p2.h +++ b/include/configs/omap730p2.h @@ -150,10 +150,9 @@ * the RefClk (12Mhz) or by DPLL1. This time is further subdivided by a * local divisor. */ - -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ +#define CONFIG_SYS_PVT 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/voiceblue.h b/include/configs/voiceblue.h index cadd906..4283adc 100644 --- a/include/configs/voiceblue.h +++ b/include/configs/voiceblue.h @@ -215,9 +215,9 @@ /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ -#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
Signed-off-by: Ladislav Michl ladis@linux-mips.org Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- V2: Fix Remaing CONFIG_SYS_PVT Best Regards, J. cpu/arm1136/omap24xx/interrupts.c | 2 +- cpu/arm925t/interrupts.c | 2 +- cpu/arm926ejs/omap/timer.c | 2 +- cpu/arm_cortexa8/omap3/interrupts.c | 2 +- include/configs/SX1.h | 6 +++--- include/configs/apollon.h | 6 ++---- include/configs/netstar.h | 4 ++-- include/configs/omap1510inn.h | 6 +++--- include/configs/omap1610h2.h | 4 ++-- include/configs/omap1610inn.h | 4 ++-- include/configs/omap2420h4.h | 10 +++++----- include/configs/omap3_beagle.h | 6 ++---- include/configs/omap3_evm.h | 6 ++---- include/configs/omap3_overo.h | 6 ++---- include/configs/omap3_pandora.h | 6 ++---- include/configs/omap3_zoom1.h | 6 ++---- include/configs/omap5912osk.h | 4 ++-- include/configs/omap730p2.h | 7 +++---- include/configs/voiceblue.h | 6 +++--- 19 files changed, 41 insertions(+), 54 deletions(-)
diff --git a/cpu/arm1136/omap24xx/interrupts.c b/cpu/arm1136/omap24xx/interrupts.c index fb02a49..6be1262 100644 --- a/cpu/arm1136/omap24xx/interrupts.c +++ b/cpu/arm1136/omap24xx/interrupts.c @@ -49,7 +49,7 @@ int interrupt_init (void)
/* Start the counter ticking up */ *((int32_t *) (CONFIG_SYS_TIMERBASE + TLDR)) = TIMER_LOAD_VAL; /* reload value on overflow*/ - val = (CONFIG_SYS_PVT << 2) | BIT5 | BIT1 | BIT0; /* mask to enable timer*/ + val = (CONFIG_SYS_PTV << 2) | BIT5 | BIT1 | BIT0; /* mask to enable timer*/ *((int32_t *) (CONFIG_SYS_TIMERBASE + TCLR)) = val; /* start timer */
reset_timer_masked(); /* init the timestamp and lastinc value */ diff --git a/cpu/arm925t/interrupts.c b/cpu/arm925t/interrupts.c index ce3c4ad..361047b 100644 --- a/cpu/arm925t/interrupts.c +++ b/cpu/arm925t/interrupts.c @@ -51,7 +51,7 @@ int interrupt_init (void)
/* init the timestamp and lastdec value */ diff --git a/cpu/arm926ejs/omap/timer.c b/cpu/arm926ejs/omap/timer.c index 49e74ab..bedc2e7 100644 --- a/cpu/arm926ejs/omap/timer.c +++ b/cpu/arm926ejs/omap/timer.c @@ -52,7 +52,7 @@ int timer_init (void)
/* init the timestamp and lastdec value */ diff --git a/cpu/arm_cortexa8/omap3/interrupts.c b/cpu/arm_cortexa8/omap3/interrupts.c index 384ffdc..e0b3fbc 100644 --- a/cpu/arm_cortexa8/omap3/interrupts.c +++ b/cpu/arm_cortexa8/omap3/interrupts.c @@ -47,7 +47,7 @@ int interrupt_init(void) /* start the counter ticking up, reload value on overflow */ writel(TIMER_LOAD_VAL, &timer_base->tldr); /* enable timer */ - writel((CONFIG_SYS_PVT << 2) | TCLR_PRE | TCLR_AR | TCLR_ST, + writel((CONFIG_SYS_PTV << 2) | TCLR_PRE | TCLR_AR | TCLR_ST, &timer_base->tclr);
reset_timer_masked(); /* init the timestamp and lastinc value */ diff --git a/include/configs/SX1.h b/include/configs/SX1.h index ebc8236..caa6592 100644 --- a/include/configs/SX1.h +++ b/include/configs/SX1.h @@ -138,9 +138,9 @@ /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE /* use timer 1 */ +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/apollon.h b/include/configs/apollon.h index 97c8806..04da083 100644 --- a/include/configs/apollon.h +++ b/include/configs/apollon.h @@ -203,11 +203,9 @@ * or by 32KHz clk, or from external sig. This rate is divided by a local * divisor. */ -#define V_PVT 7 /* use with 12MHz/128 */ - #define CONFIG_SYS_TIMERBASE OMAP2420_GPT2 -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/netstar.h b/include/configs/netstar.h index 1110ecc..39560de 100644 --- a/include/configs/netstar.h +++ b/include/configs/netstar.h @@ -226,8 +226,8 @@ * This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(pvt+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
#define OMAP5910_DPLL_DIV 1 #define OMAP5910_DPLL_MUL ((CONFIG_SYS_CLK_FREQ * \ diff --git a/include/configs/omap1510inn.h b/include/configs/omap1510inn.h index ac5040a..6c1c5ec 100644 --- a/include/configs/omap1510inn.h +++ b/include/configs/omap1510inn.h @@ -135,9 +135,9 @@ /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE /* use timer 1 */ +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap1610h2.h b/include/configs/omap1610h2.h index 79cf608..42e0198 100644 --- a/include/configs/omap1610h2.h +++ b/include/configs/omap1610h2.h @@ -131,8 +131,8 @@ * DPLL1. This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap1610inn.h b/include/configs/omap1610inn.h index ce30f55..22c873e 100644 --- a/include/configs/omap1610inn.h +++ b/include/configs/omap1610inn.h @@ -136,8 +136,8 @@ * DPLL1. This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap2420h4.h b/include/configs/omap2420h4.h index aa82326..331bf45 100644 --- a/include/configs/omap2420h4.h +++ b/include/configs/omap2420h4.h @@ -222,14 +222,14 @@ * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ #ifdef CONFIG_APTIX -#define V_PVT 3 +#define V_PTV 3 #else -#define V_PVT 7 /* use with 12MHz/128 */ +#define V_PTV 7 /* use with 12MHz/128 */ #endif
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index ad00b4c..7db1eb7 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -226,11 +226,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index baf71f4..2f532d5 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -219,11 +219,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 02d4fbc..0c32100 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -213,11 +213,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 9a32452..fb4e50d 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -215,11 +215,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index b544ea1..883234a 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -223,11 +223,9 @@ * 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by * 32KHz clk, or from external sig. This rate is divided by a local divisor. */ -#define V_PVT 7 - #define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) -#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ -#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap5912osk.h b/include/configs/omap5912osk.h index 2bc5383..d0ce9dc 100644 --- a/include/configs/omap5912osk.h +++ b/include/configs/omap5912osk.h @@ -140,8 +140,8 @@ * DPLL1. This time is further subdivided by a local divisor. */ #define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/omap730p2.h b/include/configs/omap730p2.h index 0b0d8b6..32a9b23 100644 --- a/include/configs/omap730p2.h +++ b/include/configs/omap730p2.h @@ -148,10 +148,9 @@ * the RefClk (12Mhz) or by DPLL1. This time is further subdivided by a * local divisor. */ - -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
/*----------------------------------------------------------------------- * Stack sizes diff --git a/include/configs/voiceblue.h b/include/configs/voiceblue.h index b76c794..3f97843 100644 --- a/include/configs/voiceblue.h +++ b/include/configs/voiceblue.h @@ -213,9 +213,9 @@ /* The 1510 has 3 timers, they can be driven by the RefClk (12Mhz) or by DPLL1. * This time is further subdivided by a local divisor. */ -#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE -#define CONFIG_SYS_PVT 7 /* 2^(pvt+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PVT)) +#define CONFIG_SYS_TIMERBASE OMAP1510_TIMER1_BASE +#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ +#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV))
Ladislav Michl
