[PATCH 0/2] phy: rockchip-inno-usb2: Write to correct GRF
This series fixes an issue where the rockchip-inno-usb2 driver is writing to wrong GRF reg for RK3328, RK356x and RK3588.
The driver is currently always using the common GRF, something that is only correct for RK3399. Remaining SoCs have USB2PHY regs in a different or dedicated usb2phy GRF.
First patch changes to use regmap functions and gets the regmap for correct GRF, from rockchip,usbgrf phandle or parent device.
Second patch reduces to only configure utmi_suspend_n and utmi_sel bits, similar to how is done for RK3399.
USB have continued to work in device and host mode on all supported SoCs with this series applied.
Jonas Karlman (2): phy: rockchip-inno-usb2: Write to correct GRF phy: rockchip-inno-usb2: Limit changes made to regs
drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 158 ++++-------------- 1 file changed, 36 insertions(+), 122 deletions(-)
On RK3399 the USB2PHY regs are located in the common GRF, remaining SoCs that is supported by this driver have the USB2PHY regs in a different GRF.
When support for RK356x, RK3588 and RK3328 was added this driver was never updated to use correct GRF and have instead incorrectly written to wrong GRF for these SoCs.
The default reset values for the USB2PHY have made USB mostly working even when wrong GRF was used, however, following have been observed:
scanning bus usb@fd840000 for devices... ERROR: USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did not provide a handshake (OUT) (5) ERROR: USB-error: DEVICENOTRESPONDING: Device did not respond to token (IN) or did not provide a handshake (OUT) (5) unable to get device descriptor (error=-1)
Fix this by using a regmap from rockchip,usbgrf prop and fall back to getting a regmap for parent udevice instead of always getting the common GRF.
Also protect against accidental clear of bit 0 in a reg with offset 0, only bind driver to enabled otg/host-ports and remove unused headers.
Fixes: 3da15f0b49a2 ("phy: rockchip-inno-usb2: Add USB2 PHY for rk3568") Fixes: cdf9010f6e17 ("phy: rockchip-inno-usb2: add initial support for rk3588 PHY") Fixes: 9aa93d84038b ("phy: rockchip-inno-usb2: Add USB2 PHY for RK3328") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 41 ++++++++++--------- 1 file changed, 22 insertions(+), 19 deletions(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 70e61eccb79a..7317128d135e 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -6,23 +6,16 @@ * Copyright (C) 2020 Amarula Solutions(India) */
-#include <common.h> #include <clk-uclass.h> #include <dm.h> -#include <asm/global_data.h> #include <dm/device_compat.h> #include <dm/device-internal.h> #include <dm/lists.h> #include <generic-phy.h> -#include <reset.h> +#include <regmap.h> #include <syscon.h> -#include <asm/gpio.h> -#include <asm/io.h> -#include <linux/iopoll.h> #include <asm/arch-rockchip/clock.h>
-DECLARE_GLOBAL_DATA_PTR; - #define usleep_range(a, b) udelay((b)) #define BIT_WRITEABLE_SHIFT 16
@@ -61,30 +54,39 @@ struct rockchip_usb2phy_cfg { };
struct rockchip_usb2phy { - void *reg_base; + struct regmap *reg_base; struct clk phyclk; const struct rockchip_usb2phy_cfg *phy_cfg; };
-static inline int property_enable(void *reg_base, +static inline int property_enable(struct regmap *base, const struct usb2phy_reg *reg, bool en) { unsigned int val, mask, tmp;
+ if (!reg->offset && !reg->enable && !reg->disable) + return 0; + tmp = en ? reg->enable : reg->disable; mask = GENMASK(reg->bitend, reg->bitstart); val = (tmp << reg->bitstart) | (mask << BIT_WRITEABLE_SHIFT);
- return writel(val, reg_base + reg->offset); + return regmap_write(base, reg->offset, val); }
-static inline bool property_enabled(void *reg_base, +static inline bool property_enabled(struct regmap *base, const struct usb2phy_reg *reg) { + int ret; unsigned int tmp, orig; unsigned int mask = GENMASK(reg->bitend, reg->bitstart);
- orig = readl(reg_base + reg->offset); + if (!reg->offset && !reg->enable && !reg->disable) + return false; + + ret = regmap_read(base, reg->offset, &orig); + if (ret) + return false;
tmp = (orig & mask) >> reg->bitstart; return tmp != reg->disable; @@ -248,7 +250,11 @@ static int rockchip_usb2phy_probe(struct udevice *dev) unsigned int reg; int index, ret;
- priv->reg_base = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (dev_read_bool(dev, "rockchip,usbgrf")) + priv->reg_base = + syscon_regmap_lookup_by_phandle(dev, "rockchip,usbgrf"); + else + priv->reg_base = syscon_get_regmap(dev_get_parent(dev)); if (IS_ERR(priv->reg_base)) return PTR_ERR(priv->reg_base);
@@ -305,11 +311,8 @@ static int rockchip_usb2phy_bind(struct udevice *dev) int ret = 0;
dev_for_each_subnode(node, dev) { - if (!ofnode_valid(node)) { - dev_info(dev, "subnode %s not found\n", dev->name); - ret = -ENXIO; - goto bind_fail; - } + if (!ofnode_is_enabled(node)) + continue;
name = ofnode_get_name(node); dev_dbg(dev, "subnode %s\n", name);
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- Copyright (C) 2020 Amarula Solutions(India)
- void *reg_base;
- struct regmap *reg_base; struct clk phyclk; const struct rockchip_usb2phy_cfg *phy_cfg; };
- if (!reg->offset && !reg->enable && !reg->disable)
- tmp = en ? reg->enable : reg->disable; mask = GENMASK(reg->bitend, reg->bitstart); val = (tmp << reg->bitstart) | (mask << BIT_WRITEABLE_SHIFT);
- return regmap_write(base, reg->offset, val); }
- int ret; unsigned int tmp, orig; unsigned int mask = GENMASK(reg->bitend, reg->bitstart);
return false;
if (ret)
return false;
- if (dev_read_bool(dev, "rockchip,usbgrf"))
priv->reg_base =
- else
if (IS_ERR(priv->reg_base)) return PTR_ERR(priv->reg_base);priv->reg_base = syscon_get_regmap(dev_get_parent(dev));
ret = -ENXIO;
goto bind_fail;
continue;
The USB2PHY regs already contain working default reset values for RK3328 and RK35xx as evidenced by the fact that this driver never has changed a single value for these SoCs.
Reduce to only configure utmi_suspend_n and utmi_sel bits similar to what is currently done on RK3399. Also add missing clkout_ctl for RK3588.
When enabled utmi_suspend_n is changed to normal mode and utmi_sel to use otg/host controller utmi interface to phy. When disabled utmi_suspend_n is changed to suspend mode and utmi_sel to use GRF utmi interface to phy.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 117 +++--------------- 1 file changed, 14 insertions(+), 103 deletions(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 7317128d135e..d392aed2d4de 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -35,16 +35,6 @@ struct usb2phy_reg {
struct rockchip_usb2phy_port_cfg { struct usb2phy_reg phy_sus; - struct usb2phy_reg bvalid_det_en; - struct usb2phy_reg bvalid_det_st; - struct usb2phy_reg bvalid_det_clr; - struct usb2phy_reg ls_det_en; - struct usb2phy_reg ls_det_st; - struct usb2phy_reg ls_det_clr; - struct usb2phy_reg utmi_avalid; - struct usb2phy_reg utmi_bvalid; - struct usb2phy_reg utmi_ls; - struct usb2phy_reg utmi_hstdet; };
struct rockchip_usb2phy_cfg { @@ -131,7 +121,6 @@ static int rockchip_usb2phy_init(struct phy *phy) { struct udevice *parent = dev_get_parent(phy->dev); struct rockchip_usb2phy *priv = dev_get_priv(parent); - const struct rockchip_usb2phy_port_cfg *port_cfg = us2phy_get_port(phy); int ret;
ret = clk_enable(&priv->phyclk); @@ -140,14 +129,6 @@ static int rockchip_usb2phy_init(struct phy *phy) return ret; }
- if (phy->id == USB2PHY_PORT_OTG) { - property_enable(priv->reg_base, &port_cfg->bvalid_det_clr, true); - property_enable(priv->reg_base, &port_cfg->bvalid_det_en, true); - } else if (phy->id == USB2PHY_PORT_HOST) { - property_enable(priv->reg_base, &port_cfg->bvalid_det_clr, true); - property_enable(priv->reg_base, &port_cfg->bvalid_det_en, true); - } - return 0; }
@@ -351,27 +332,13 @@ bind_fail: static const struct rockchip_usb2phy_cfg rk3328_usb2phy_cfgs[] = { { .reg = 0x100, - .clkout_ctl = { 0x108, 4, 4, 1, 0 }, + .clkout_ctl = { 0x0108, 4, 4, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { - .phy_sus = { 0x0100, 15, 0, 0, 0x1d1 }, - .bvalid_det_en = { 0x0110, 3, 2, 0, 3 }, - .bvalid_det_st = { 0x0114, 3, 2, 0, 3 }, - .bvalid_det_clr = { 0x0118, 3, 2, 0, 3 }, - .ls_det_en = { 0x0110, 0, 0, 0, 1 }, - .ls_det_st = { 0x0114, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0118, 0, 0, 0, 1 }, - .utmi_avalid = { 0x0120, 10, 10, 0, 1 }, - .utmi_bvalid = { 0x0120, 9, 9, 0, 1 }, - .utmi_ls = { 0x0120, 5, 4, 0, 1 }, + .phy_sus = { 0x0100, 1, 0, 2, 1 }, }, [USB2PHY_PORT_HOST] = { - .phy_sus = { 0x104, 15, 0, 0, 0x1d1 }, - .ls_det_en = { 0x110, 1, 1, 0, 1 }, - .ls_det_st = { 0x114, 1, 1, 0, 1 }, - .ls_det_clr = { 0x118, 1, 1, 0, 1 }, - .utmi_ls = { 0x120, 17, 16, 0, 1 }, - .utmi_hstdet = { 0x120, 19, 19, 0, 1 } + .phy_sus = { 0x0104, 1, 0, 2, 1 }, } }, }, @@ -385,19 +352,9 @@ static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { .port_cfgs = { [USB2PHY_PORT_OTG] = { .phy_sus = { 0xe454, 1, 0, 2, 1 }, - .bvalid_det_en = { 0xe3c0, 3, 3, 0, 1 }, - .bvalid_det_st = { 0xe3e0, 3, 3, 0, 1 }, - .bvalid_det_clr = { 0xe3d0, 3, 3, 0, 1 }, - .utmi_avalid = { 0xe2ac, 7, 7, 0, 1 }, - .utmi_bvalid = { 0xe2ac, 12, 12, 0, 1 }, }, [USB2PHY_PORT_HOST] = { - .phy_sus = { 0xe458, 1, 0, 0x2, 0x1 }, - .ls_det_en = { 0xe3c0, 6, 6, 0, 1 }, - .ls_det_st = { 0xe3e0, 6, 6, 0, 1 }, - .ls_det_clr = { 0xe3d0, 6, 6, 0, 1 }, - .utmi_ls = { 0xe2ac, 22, 21, 0, 1 }, - .utmi_hstdet = { 0xe2ac, 23, 23, 0, 1 } + .phy_sus = { 0xe458, 1, 0, 2, 1 }, } }, }, @@ -407,19 +364,9 @@ static const struct rockchip_usb2phy_cfg rk3399_usb2phy_cfgs[] = { .port_cfgs = { [USB2PHY_PORT_OTG] = { .phy_sus = { 0xe464, 1, 0, 2, 1 }, - .bvalid_det_en = { 0xe3c0, 8, 8, 0, 1 }, - .bvalid_det_st = { 0xe3e0, 8, 8, 0, 1 }, - .bvalid_det_clr = { 0xe3d0, 8, 8, 0, 1 }, - .utmi_avalid = { 0xe2ac, 10, 10, 0, 1 }, - .utmi_bvalid = { 0xe2ac, 16, 16, 0, 1 }, }, [USB2PHY_PORT_HOST] = { - .phy_sus = { 0xe468, 1, 0, 0x2, 0x1 }, - .ls_det_en = { 0xe3c0, 11, 11, 0, 1 }, - .ls_det_st = { 0xe3e0, 11, 11, 0, 1 }, - .ls_det_clr = { 0xe3d0, 11, 11, 0, 1 }, - .utmi_ls = { 0xe2ac, 26, 25, 0, 1 }, - .utmi_hstdet = { 0xe2ac, 27, 27, 0, 1 } + .phy_sus = { 0xe468, 1, 0, 2, 1 }, } }, }, @@ -432,24 +379,10 @@ static const struct rockchip_usb2phy_cfg rk3568_phy_cfgs[] = { .clkout_ctl = { 0x0008, 4, 4, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { - .phy_sus = { 0x0000, 8, 0, 0x052, 0x1d1 }, - .bvalid_det_en = { 0x0080, 2, 2, 0, 1 }, - .bvalid_det_st = { 0x0084, 2, 2, 0, 1 }, - .bvalid_det_clr = { 0x0088, 2, 2, 0, 1 }, - .ls_det_en = { 0x0080, 0, 0, 0, 1 }, - .ls_det_st = { 0x0084, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, - .utmi_avalid = { 0x00c0, 10, 10, 0, 1 }, - .utmi_bvalid = { 0x00c0, 9, 9, 0, 1 }, - .utmi_ls = { 0x00c0, 5, 4, 0, 1 }, + .phy_sus = { 0x0000, 1, 0, 2, 1 }, }, [USB2PHY_PORT_HOST] = { - .phy_sus = { 0x0004, 8, 0, 0x1d2, 0x1d1 }, - .ls_det_en = { 0x0080, 1, 1, 0, 1 }, - .ls_det_st = { 0x0084, 1, 1, 0, 1 }, - .ls_det_clr = { 0x0088, 1, 1, 0, 1 }, - .utmi_ls = { 0x00c0, 17, 16, 0, 1 }, - .utmi_hstdet = { 0x00c0, 19, 19, 0, 1 } + .phy_sus = { 0x0004, 1, 0, 2, 1 }, } }, }, @@ -458,20 +391,10 @@ static const struct rockchip_usb2phy_cfg rk3568_phy_cfgs[] = { .clkout_ctl = { 0x0008, 4, 4, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { - .phy_sus = { 0x0000, 8, 0, 0x1d2, 0x1d1 }, - .ls_det_en = { 0x0080, 0, 0, 0, 1 }, - .ls_det_st = { 0x0084, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, - .utmi_ls = { 0x00c0, 5, 4, 0, 1 }, - .utmi_hstdet = { 0x00c0, 7, 7, 0, 1 } + .phy_sus = { 0x0000, 1, 0, 2, 1 }, }, [USB2PHY_PORT_HOST] = { - .phy_sus = { 0x0004, 8, 0, 0x1d2, 0x1d1 }, - .ls_det_en = { 0x0080, 1, 1, 0, 1 }, - .ls_det_st = { 0x0084, 1, 1, 0, 1 }, - .ls_det_clr = { 0x0088, 1, 1, 0, 1 }, - .utmi_ls = { 0x00c0, 17, 16, 0, 1 }, - .utmi_hstdet = { 0x00c0, 19, 19, 0, 1 } + .phy_sus = { 0x0004, 1, 0, 2, 1 }, } }, }, @@ -481,49 +404,37 @@ static const struct rockchip_usb2phy_cfg rk3568_phy_cfgs[] = { static const struct rockchip_usb2phy_cfg rk3588_phy_cfgs[] = { { .reg = 0x0000, + .clkout_ctl = { 0x0000, 0, 0, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { .phy_sus = { 0x000c, 11, 11, 0, 1 }, - .ls_det_en = { 0x0080, 0, 0, 0, 1 }, - .ls_det_st = { 0x0084, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, - .utmi_ls = { 0x00c0, 10, 9, 0, 1 }, } }, }, { .reg = 0x4000, + .clkout_ctl = { 0x0000, 0, 0, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_OTG] = { - .phy_sus = { 0x000c, 11, 11, 0, 0 }, - .ls_det_en = { 0x0080, 0, 0, 0, 1 }, - .ls_det_st = { 0x0084, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, - .utmi_ls = { 0x00c0, 10, 9, 0, 1 }, + .phy_sus = { 0x000c, 11, 11, 0, 1 }, } }, }, { .reg = 0x8000, + .clkout_ctl = { 0x0000, 0, 0, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_HOST] = { .phy_sus = { 0x0008, 2, 2, 0, 1 }, - .ls_det_en = { 0x0080, 0, 0, 0, 1 }, - .ls_det_st = { 0x0084, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, - .utmi_ls = { 0x00c0, 10, 9, 0, 1 }, } }, }, { .reg = 0xc000, + .clkout_ctl = { 0x0000, 0, 0, 1, 0 }, .port_cfgs = { [USB2PHY_PORT_HOST] = { .phy_sus = { 0x0008, 2, 2, 0, 1 }, - .ls_det_en = { 0x0080, 0, 0, 0, 1 }, - .ls_det_st = { 0x0084, 0, 0, 0, 1 }, - .ls_det_clr = { 0x0088, 0, 0, 0, 1 }, - .utmi_ls = { 0x00c0, 10, 9, 0, 1 }, } }, },
Hi Jonas,
I would prefer to keep it as is for now, I think these configs are needed for the phy init,
but I'm not sure these configs are all default correct after sw/hw reset/reboot and for
all the SoC versions.
I don't understand, you also remove configs for rk3399 in this patch, isn't it?
This is necessary, would be better send as a separate patch.
I don't understand this change for not much knowledge on utmi interface, any issue if we use the old config?
If necessary, should send as a separate patch.
Thanks, - Kever
- return 0; }
.port_cfgs = { [USB2PHY_PORT_OTG] = {.clkout_ctl = { 0x0108, 4, 4, 1, 0 },
}, },.phy_sus = { 0x0104, 1, 0, 2, 1 }, }
}, },.phy_sus = { 0xe458, 1, 0, 2, 1 }, }
}, },.phy_sus = { 0xe468, 1, 0, 2, 1 }, }
}, },.phy_sus = { 0x0004, 1, 0, 2, 1 }, }
.port_cfgs = { [USB2PHY_PORT_OTG] = { .phy_sus = { 0x000c, 11, 11, 0, 1 },.clkout_ctl = { 0x0000, 0, 0, 1, 0 },
}, }, { .reg = 0x4000,.utmi_ls = { 0x00c0, 10, 9, 0, 1 }, }
.port_cfgs = { [USB2PHY_PORT_OTG] = {.clkout_ctl = { 0x0000, 0, 0, 1, 0 },
}, }, { .reg = 0x8000,.phy_sus = { 0x000c, 11, 11, 0, 1 }, }
.port_cfgs = { [USB2PHY_PORT_HOST] = { .phy_sus = { 0x0008, 2, 2, 0, 1 },.clkout_ctl = { 0x0000, 0, 0, 1, 0 },
}, }, { .reg = 0xc000,.utmi_ls = { 0x00c0, 10, 9, 0, 1 }, }
}, },.utmi_ls = { 0x00c0, 10, 9, 0, 1 }, }
Hi Kever,
On 2024-03-08 10:06, Kever Yang wrote:
Hi Jonas,
This driver currenly only use the phy_sus and bvalid_det_en/clr regs. The bvalid_det_en/clr regs is related to interrupts, something this driver does not use, and in mainline linux they are only applied to otg/peripheral ports and not to all ports like in u-boot.
My understanding is that the phy_sus reg is intented to control phy suspend mode, currently that is what the rk3399 and rk3588 variant is doing. However, for the other socs it tries to control phy suspend and also set values for other bits in the same hw reg.
I think it is better to clean this up to make it work consistent and/or limit what bits we write now, instead of possibly introducing new issues because of the GRF fix in the first patch of this series.
By default the phy seem to work for otg or host mode after a reset for all SoCs currently supported by this driver. I have tested this using host/otg/peripheral mode on RK3308, RK3328, RK3399, RK356x and RK3588.
The missing RK3308 parts will be added in a separate series.
If I remember correctly I had some issue with otg when existing values where written to hw reg, and the working hw reset default value did not fully match the values defined for phy_sys on some port of rk3328 and/or rk356x.
This patch fixes the inconsistent meaning/affect of phy_sus reg for all socs, instead of having different and possible unintended behaviour depending on the soc.
Ensuring that the phy is configured in a similar way accross soc was the main intent for this patch, not sure how to split this in another way.
Regards, Jonas
Thanks,
- Kever
- return 0; }
Thanks, - Kever
- return 0; }
Jonas Karlman
Kever Yang
