[U-Boot] [PATCH 0/2] [for 2018.03] RPi: Drain RX queue on setbrg
We had a few reports coming in from people that had their autoboot chain aborted after pinmuxing support was added for the RPi.
The culprit is easy: The UARTs may have been enabled before, but muxed to an incorrect pin. That pin may have pulled the RX line down which again lead to lots of zero bytes gathered in the RX buffer.
The easy fix for that is to drain the RX queue every time we set the baud rate.
This patch set is the minimally intrusive fix for the RPi. We may want to do that generically for all serial devices later.
Alexander Graf (2): serial_bcm283x_mu: Flush RX queue after setting baud rate bcm283x_pl011: Flush RX queue after setting baud rate
drivers/serial/serial_bcm283x_mu.c | 8 +++++++- drivers/serial/serial_bcm283x_pl011.c | 25 ++++++++++++++++++++++++- drivers/serial/serial_pl01x.c | 10 +++++----- drivers/serial/serial_pl01x_internal.h | 7 ++++++- 4 files changed, 42 insertions(+), 8 deletions(-)
After the UART was initialized, we may still have bogus data in the RX queue if it was enabled with incorrect pin muxing before.
So let's flush the RX queue whenever we initialize baud rates.
This fixes a regression with the dynamic pinmuxing code when enable_uart=1 is not set in config.txt.
Fixes: caf2233b28 ("bcm283x: Add pinctrl driver") Reported-by: Göran Lundberg goran@lundberg.email Reported-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Alexander Graf agraf@suse.de --- drivers/serial/serial_bcm283x_mu.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_bcm283x_mu.c b/drivers/serial/serial_bcm283x_mu.c index 40029fadbc..d87b44e902 100644 --- a/drivers/serial/serial_bcm283x_mu.c +++ b/drivers/serial/serial_bcm283x_mu.c @@ -51,6 +51,8 @@ struct bcm283x_mu_priv { struct bcm283x_mu_regs *regs; };
+static int bcm283x_mu_serial_getc(struct udevice *dev); + static int bcm283x_mu_serial_setbrg(struct udevice *dev, int baudrate) { struct bcm283x_mu_serial_platdata *plat = dev_get_platdata(dev); @@ -59,13 +61,17 @@ static int bcm283x_mu_serial_setbrg(struct udevice *dev, int baudrate) u32 divider;
if (plat->skip_init) - return 0; + goto out;
divider = plat->clock / (baudrate * 8);
writel(BCM283X_MU_LCR_DATA_SIZE_8, ®s->lcr); writel(divider - 1, ®s->baud);
+out: + /* Flush the RX queue - all data in there is bogus */ + while (bcm283x_mu_serial_getc(dev) != -EAGAIN) ; + return 0; }
Tested-by: Peter Robinson pbrobinson@gmail.com
Tested on both 32 bit using extlinux and 64 bit using uEFI boots. The 32 bit one, the one I saw issues with, didn't enable enable_uart because it's attached to HDMI without a serial console, the 64 does have serial console with the option in config.txt
goto out; divider = plat->clock / (baudrate * 8); writel(BCM283X_MU_LCR_DATA_SIZE_8, ®s->lcr); writel(divider - 1, ®s->baud);
+out:
-- 2.12.3
This fixes a regression with the dynamic pinmuxing code when enable_uart=1 is not set in config.txt on Raspberry Pis that use pl011 for serial.
Fixes: caf2233b28 ("bcm283x: Add pinctrl driver") Reported-by: Göran Lundberg goran@lundberg.email Reported-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Alexander Graf agraf@suse.de --- drivers/serial/serial_bcm283x_pl011.c | 25 ++++++++++++++++++++++++- drivers/serial/serial_pl01x.c | 10 +++++----- drivers/serial/serial_pl01x_internal.h | 7 ++++++- 3 files changed, 35 insertions(+), 7 deletions(-)
diff --git a/drivers/serial/serial_bcm283x_pl011.c b/drivers/serial/serial_bcm283x_pl011.c index bfd39f84f3..2c6fb267ff 100644 --- a/drivers/serial/serial_bcm283x_pl011.c +++ b/drivers/serial/serial_bcm283x_pl011.c @@ -9,6 +9,7 @@ #include <asm/gpio.h> #include <dm/pinctrl.h> #include <dm/platform_data/serial_pl01x.h> +#include <serial.h> #include "serial_pl01x_internal.h"
/* @@ -55,6 +56,28 @@ static int bcm283x_pl011_serial_ofdata_to_platdata(struct udevice *dev) return 0; }
+static int bcm283x_pl011_serial_setbrg(struct udevice *dev, int baudrate) +{ + int r; + + r = pl01x_serial_setbrg(dev, baudrate); + + /* + * We may have been muxed to a bogus line before. Drain the RX + * queue so we start at a clean slate. + */ + while (pl01x_serial_getc(dev) == -EAGAIN) ; + + return r; +} + +static const struct dm_serial_ops bcm283x_pl011_serial_ops = { + .putc = pl01x_serial_putc, + .pending = pl01x_serial_pending, + .getc = pl01x_serial_getc, + .setbrg = bcm283x_pl011_serial_setbrg, +}; + static const struct udevice_id bcm283x_pl011_serial_id[] = { {.compatible = "brcm,bcm2835-pl011", .data = TYPE_PL011}, {} @@ -67,7 +90,7 @@ U_BOOT_DRIVER(bcm283x_pl011_uart) = { .ofdata_to_platdata = of_match_ptr(bcm283x_pl011_serial_ofdata_to_platdata), .platdata_auto_alloc_size = sizeof(struct pl01x_serial_platdata), .probe = pl01x_serial_probe, - .ops = &pl01x_serial_ops, + .ops = &bcm283x_pl011_serial_ops, .flags = DM_FLAG_PRE_RELOC, .priv_auto_alloc_size = sizeof(struct pl01x_priv), }; diff --git a/drivers/serial/serial_pl01x.c b/drivers/serial/serial_pl01x.c index 23d9d839cb..45f1282770 100644 --- a/drivers/serial/serial_pl01x.c +++ b/drivers/serial/serial_pl01x.c @@ -273,7 +273,7 @@ __weak struct serial_device *default_serial_console(void)
#ifdef CONFIG_DM_SERIAL
-static int pl01x_serial_setbrg(struct udevice *dev, int baudrate) +int pl01x_serial_setbrg(struct udevice *dev, int baudrate) { struct pl01x_serial_platdata *plat = dev_get_platdata(dev); struct pl01x_priv *priv = dev_get_priv(dev); @@ -299,21 +299,21 @@ int pl01x_serial_probe(struct udevice *dev) return 0; }
-static int pl01x_serial_getc(struct udevice *dev) +int pl01x_serial_getc(struct udevice *dev) { struct pl01x_priv *priv = dev_get_priv(dev);
return pl01x_getc(priv->regs); }
-static int pl01x_serial_putc(struct udevice *dev, const char ch) +int pl01x_serial_putc(struct udevice *dev, const char ch) { struct pl01x_priv *priv = dev_get_priv(dev);
return pl01x_putc(priv->regs, ch); }
-static int pl01x_serial_pending(struct udevice *dev, bool input) +int pl01x_serial_pending(struct udevice *dev, bool input) { struct pl01x_priv *priv = dev_get_priv(dev); unsigned int fr = readl(&priv->regs->fr); @@ -324,7 +324,7 @@ static int pl01x_serial_pending(struct udevice *dev, bool input) return fr & UART_PL01x_FR_TXFF ? 0 : 1; }
-const struct dm_serial_ops pl01x_serial_ops = { +static const struct dm_serial_ops pl01x_serial_ops = { .putc = pl01x_serial_putc, .pending = pl01x_serial_pending, .getc = pl01x_serial_getc, diff --git a/drivers/serial/serial_pl01x_internal.h b/drivers/serial/serial_pl01x_internal.h index c56dd54c7b..d4605f24a3 100644 --- a/drivers/serial/serial_pl01x_internal.h +++ b/drivers/serial/serial_pl01x_internal.h @@ -43,7 +43,12 @@ struct pl01x_regs {
int pl01x_serial_ofdata_to_platdata(struct udevice *dev); int pl01x_serial_probe(struct udevice *dev); -extern const struct dm_serial_ops pl01x_serial_ops; + +/* Needed for external pl01x_serial_ops drivers */ +int pl01x_serial_putc(struct udevice *dev, const char ch); +int pl01x_serial_pending(struct udevice *dev, bool input); +int pl01x_serial_getc(struct udevice *dev); +int pl01x_serial_setbrg(struct udevice *dev, int baudrate);
struct pl01x_priv { struct pl01x_regs *regs;
This causes my RPi2 devices not to actually boot. When I connected a HDMI monitor to one of them I get the rainbow square.
Peter
int r;
return r;
struct pl01x_priv { struct pl01x_regs *regs; -- 2.12.3
Ok, I was able to reproduce this on the RPi3 CM. See below ...
Peter
int r;
... this is obviously wrong. It doesn't drain the queue but instead loops as long as the queue is empty. Bleks.
I'll send a v2. Please retest then. Sorry for the mess :).
Alex
This causes mixed effects for me, a regression on the RPi2 using the pl011, but fixes the issue on the RPi3. Both my RPi2 have serial console and playing with the enable in config.txt doesn't seem to have any effect on whether they auto boot or not but with it commented out I seem to get more random chars.
Peter
Thanks a lot for testing! I'll try it on a rpi2 later tonight and check why it's failing.
Alex
Alexander Graf
Peter Robinson
