[U-Boot] [PATCH 0/5] ARM: uniphier: prepare for ARMv8 SoC support
Masahiro Yamada (5): ARM: uniphier: merge two defconfig files ARM: uniphier: rework UniPhier SoC select in Kconfig ARM: uniphier: rename PH1-LD10/PH1-sLD11 to PH1-LD20/PH1-LD11 ARM: uniphier: prepare directory structure for ARMv8 SoC support ARM: uniphier: fix warnings reported by aarch64 compiler
arch/arm/Kconfig | 1 - arch/arm/mach-uniphier/Kconfig | 66 +++++++++++----------- arch/arm/mach-uniphier/Makefile | 9 +-- arch/arm/mach-uniphier/arm32/Makefile | 13 +++++ arch/arm/mach-uniphier/{ => arm32}/arm-mpcore.h | 0 .../arm/mach-uniphier/{ => arm32}/cache_uniphier.c | 0 arch/arm/mach-uniphier/{ => arm32}/debug_ll.S | 0 .../mach-uniphier/{ => arm32}/late_lowlevel_init.S | 0 arch/arm/mach-uniphier/{ => arm32}/lowlevel_init.S | 0 arch/arm/mach-uniphier/{ => arm32}/ssc-regs.h | 0 arch/arm/mach-uniphier/{ => arm32}/timer.c | 0 arch/arm/mach-uniphier/cpu_info.c | 4 +- arch/arm/mach-uniphier/dram_init.c | 5 +- arch/arm/mach-uniphier/micro-support-card.c | 3 +- arch/arm/mach-uniphier/sg-regs.h | 2 +- arch/arm/mach-uniphier/soc-info.h | 16 +++--- arch/arm/mach-uniphier/soc_info.c | 8 +-- configs/uniphier_ld4_sld8_defconfig | 3 +- configs/uniphier_pro5_defconfig | 33 ----------- configs/uniphier_pxs2_ld6b_defconfig | 3 +- doc/README.uniphier | 4 +- 21 files changed, 71 insertions(+), 99 deletions(-) create mode 100644 arch/arm/mach-uniphier/arm32/Makefile rename arch/arm/mach-uniphier/{ => arm32}/arm-mpcore.h (100%) rename arch/arm/mach-uniphier/{ => arm32}/cache_uniphier.c (100%) rename arch/arm/mach-uniphier/{ => arm32}/debug_ll.S (100%) rename arch/arm/mach-uniphier/{ => arm32}/late_lowlevel_init.S (100%) rename arch/arm/mach-uniphier/{ => arm32}/lowlevel_init.S (100%) rename arch/arm/mach-uniphier/{ => arm32}/ssc-regs.h (100%) rename arch/arm/mach-uniphier/{ => arm32}/timer.c (100%) delete mode 100644 configs/uniphier_pro5_defconfig
PH1-Pro5 support and ProXstream2/PH1-LD6b support can coexist in one image and there is bit more room in SPL to accommodate all of them. Merge uniphier_pro5_defconfig into uniphier_pxs2_defconfig.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
configs/uniphier_pro5_defconfig | 33 --------------------------------- configs/uniphier_pxs2_ld6b_defconfig | 1 + doc/README.uniphier | 4 ++-- 3 files changed, 3 insertions(+), 35 deletions(-) delete mode 100644 configs/uniphier_pro5_defconfig
diff --git a/configs/uniphier_pro5_defconfig b/configs/uniphier_pro5_defconfig deleted file mode 100644 index 0029cd3..0000000 --- a/configs/uniphier_pro5_defconfig +++ /dev/null @@ -1,33 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_UNIPHIER=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_ARCH_UNIPHIER_PH1_PRO5=y -CONFIG_MICRO_SUPPORT_CARD=y -CONFIG_SYS_TEXT_BASE=0x84000000 -CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-pro5-4kbox" -CONFIG_HUSH_PARSER=y -# CONFIG_CMD_XIMG is not set -# CONFIG_CMD_ENV_EXISTS is not set -CONFIG_CMD_NAND=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -# CONFIG_CMD_FPGA is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_TFTPPUT=y -CONFIG_CMD_PING=y -CONFIG_CMD_TIME=y -# CONFIG_CMD_MISC is not set -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_SPL_SIMPLE_BUS=y -CONFIG_GPIO_UNIPHIER=y -CONFIG_MMC_UNIPHIER=y -CONFIG_NAND_DENALI=y -CONFIG_SYS_NAND_DENALI_64BIT=y -CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 -CONFIG_SPL_NAND_DENALI=y -CONFIG_PINCTRL=y -CONFIG_SPL_PINCTRL=y -CONFIG_UNIPHIER_SERIAL=y -CONFIG_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index 0115c21..10af9c8 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ARCH_UNIPHIER_PH1_PRO5=y CONFIG_ARCH_UNIPHIER_PROXSTREAM2=y CONFIG_ARCH_UNIPHIER_PH1_LD6B=y CONFIG_MICRO_SUPPORT_CARD=y diff --git a/doc/README.uniphier b/doc/README.uniphier index 5ac52bd..6c3b092 100644 --- a/doc/README.uniphier +++ b/doc/README.uniphier @@ -45,8 +45,8 @@ PH1-Pro4 reference board: $ make CROSS_COMPILE=arm-linux-gnueabi-
PH1-Pro5 4KBOX Board: - $ make uniphier_pro5_defconfig - $ make CROSS_COMPILE=arm-linux-gnueabi- + $ make uniphier_pxs2_ld6b_defconfig + $ make CROSS_COMPILE=arm-linux-gnueabi- DEVICE_TREE=uniphier-ph1-pro5-4kbox
ProXstream2 Gentil board: $ make uniphier_pxs2_ld6b_defconfig
The chains of "depends on <SoC_name>" in the current Kconfig is clumsy. The idea here is to allow users to choose a SoC group first (SoC group consists of some SoCs that can coexist in one binary). Then, allow to enable/disable each SoC support in the selected SoC group. This makes the Kconfig menu clearer.
arch/arm/mach-uniphier/Kconfig | 62 ++++++++++++++++-------------------- configs/uniphier_ld4_sld8_defconfig | 3 +- configs/uniphier_pxs2_ld6b_defconfig | 4 +-- 3 files changed, 30 insertions(+), 39 deletions(-)
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 03256be..e859ca3 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -3,54 +3,48 @@ if ARCH_UNIPHIER config SYS_CONFIG_NAME default "uniphier"
+choice + prompt "UniPhier SoC select" + default ARCH_UNIPHIER_PH1_PRO4 + config ARCH_UNIPHIER_PH1_SLD3 bool "UniPhier PH1-sLD3 SoC" - help - This enables support for UniPhier PH1-sLD3 SoC.
-config ARCH_UNIPHIER_PH1_LD4 - bool "UniPhier PH1-LD4 SoC" - depends on !ARCH_UNIPHIER_PH1_SLD3 - help - This enables support for UniPhier PH1-LD4 SoC. +config ARCH_UNIPHIER_LD4_SLD8 + bool "UniPhier PH1-LD4/PH1-sLD8 SoC"
config ARCH_UNIPHIER_PH1_PRO4 bool "UniPhier PH1-Pro4 SoC" - depends on !ARCH_UNIPHIER_PH1_SLD3 && \ - !ARCH_UNIPHIER_PH1_LD4 && \ - !ARCH_UNIPHIER_PH1_SLD8 - help - This enables support for UniPhier PH1-Pro4 SoC. + +config ARCH_UNIPHIER_PRO5_PXS2_LD6B + bool "UniPhier PH1-Pro5/ProXstream2/PH1-LD6b SoC" + +endchoice + +config ARCH_UNIPHIER_PH1_LD4 + bool "Enable UniPhier PH1-LD4 SoC support" + depends on ARCH_UNIPHIER_LD4_SLD8 + default y
config ARCH_UNIPHIER_PH1_SLD8 - bool "UniPhier PH1-sLD8 SoC" - depends on !ARCH_UNIPHIER_PH1_SLD3 - help - This enables support for UniPhier PH1-sLD8 SoC. + bool "Enable UniPhier PH1-sLD8 SoC support" + depends on ARCH_UNIPHIER_LD4_SLD8 + default y
config ARCH_UNIPHIER_PH1_PRO5 - bool "UniPhier PH1-Pro5 SoC" - depends on !ARCH_UNIPHIER_PH1_SLD3 && \ - !ARCH_UNIPHIER_PH1_LD4 && \ - !ARCH_UNIPHIER_PH1_SLD8 - help - This enables support for UniPhier PH1-Pro5 SoC. + bool "Enable UniPhier PH1-Pro5 SoC support" + depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B + default y
config ARCH_UNIPHIER_PROXSTREAM2 - bool "UniPhier ProXstream2 SoC" - depends on !ARCH_UNIPHIER_PH1_SLD3 && \ - !ARCH_UNIPHIER_PH1_LD4 && \ - !ARCH_UNIPHIER_PH1_SLD8 - help - This enables support for UniPhier ProXstream2 SoC. + bool "Enable UniPhier ProXstream2 SoC support" + depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B + default y
config ARCH_UNIPHIER_PH1_LD6B - bool "UniPhier PH1-LD6b SoC" - depends on !ARCH_UNIPHIER_PH1_SLD3 && \ - !ARCH_UNIPHIER_PH1_LD4 && \ - !ARCH_UNIPHIER_PH1_SLD8 - help - This enables support for UniPhier PH1-LD6b SoC. + bool "Enable UniPhier PH1-LD6b SoC support" + depends on ARCH_UNIPHIER_PRO5_PXS2_LD6B + default y
config MICRO_SUPPORT_CARD bool "Use Micro Support Card" diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index 892bccc..4d7afb8 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -1,8 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_ARCH_UNIPHIER_PH1_LD4=y -CONFIG_ARCH_UNIPHIER_PH1_SLD8=y +CONFIG_ARCH_UNIPHIER_LD4_SLD8=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-ph1-ld4-ref" diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index 10af9c8..4a8d70b 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -1,9 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_UNIPHIER=y CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_ARCH_UNIPHIER_PH1_PRO5=y -CONFIG_ARCH_UNIPHIER_PROXSTREAM2=y -CONFIG_ARCH_UNIPHIER_PH1_LD6B=y +CONFIG_ARCH_UNIPHIER_PRO5_PXS2_LD6B=y CONFIG_MICRO_SUPPORT_CARD=y CONFIG_SYS_TEXT_BASE=0x84000000 CONFIG_DEFAULT_DEVICE_TREE="uniphier-proxstream2-vodka"
Due to the company's awful projecting, PH1-LD10 and PH1-sLD11 have been renamed to PH1-LD20 and PH1-LD11, respectively.
arch/arm/mach-uniphier/cpu_info.c | 4 ++-- arch/arm/mach-uniphier/soc-info.h | 16 ++++++++-------- arch/arm/mach-uniphier/soc_info.c | 8 ++++---- 3 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/mach-uniphier/cpu_info.c b/arch/arm/mach-uniphier/cpu_info.c index 4e9d01b..aae8d1f 100644 --- a/arch/arm/mach-uniphier/cpu_info.c +++ b/arch/arm/mach-uniphier/cpu_info.c @@ -45,10 +45,10 @@ int print_cpuinfo(void) puts("PH1-LD6b (MN2WS0320)"); break; case 0x31: - puts("PH1-sLD11 ()"); + puts("PH1-LD11 ()"); break; case 0x32: - puts("PH1-LD10 ()"); + puts("PH1-LD20 ()"); break; default: printf("Unknown Processor ID (0x%x)\n", revision); diff --git a/arch/arm/mach-uniphier/soc-info.h b/arch/arm/mach-uniphier/soc-info.h index 3cfd1e9..606094c 100644 --- a/arch/arm/mach-uniphier/soc-info.h +++ b/arch/arm/mach-uniphier/soc-info.h @@ -15,8 +15,8 @@ enum uniphier_soc_id { SOC_UNIPHIER_PH1_PRO5, SOC_UNIPHIER_PROXSTREAM2, SOC_UNIPHIER_PH1_LD6B, - SOC_UNIPHIER_PH1_SLD11, - SOC_UNIPHIER_PH1_LD10, + SOC_UNIPHIER_PH1_LD11, + SOC_UNIPHIER_PH1_LD20, SOC_UNIPHIER_UNKNOWN, };
@@ -28,8 +28,8 @@ enum uniphier_soc_id { IS_ENABLED(CONFIG_ARCH_UNIPHIER_PH1_PRO5) + \ IS_ENABLED(CONFIG_ARCH_UNIPHIER_PROXSTREAM2) + \ IS_ENABLED(CONFIG_ARCH_UNIPHIER_PH1_LD6B) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_PH1_SLD11) + \ - IS_ENABLED(CONFIG_ARCH_UNIPHIER_PH1_LD10) + IS_ENABLED(CONFIG_ARCH_UNIPHIER_PH1_LD11) + \ + IS_ENABLED(CONFIG_ARCH_UNIPHIER_PH1_LD20)
#define UNIPHIER_MULTI_SOC ((UNIPHIER_NR_ENABLED_SOCS) > 1)
@@ -59,11 +59,11 @@ static inline enum uniphier_soc_id uniphier_get_soc_type(void) #if defined(CONFIG_ARCH_UNIPHIER_PH1_LD6B) return SOC_UNIPHIER_PH1_LD6B; #endif -#if defined(CONFIG_ARCH_UNIPHIER_PH1_SLD11) - return SOC_UNIPHIER_PH1_SLD11; +#if defined(CONFIG_ARCH_UNIPHIER_PH1_LD11) + return SOC_UNIPHIER_PH1_LD11; #endif -#if defined(CONFIG_ARCH_UNIPHIER_PH1_LD10) - return SOC_UNIPHIER_PH1_LD10; +#if defined(CONFIG_ARCH_UNIPHIER_PH1_LD20) + return SOC_UNIPHIER_PH1_LD20; #endif
return SOC_UNIPHIER_UNKNOWN; diff --git a/arch/arm/mach-uniphier/soc_info.c b/arch/arm/mach-uniphier/soc_info.c index fd799ca..3cfc183 100644 --- a/arch/arm/mach-uniphier/soc_info.c +++ b/arch/arm/mach-uniphier/soc_info.c @@ -52,14 +52,14 @@ enum uniphier_soc_id uniphier_get_soc_type(void) ret = SOC_UNIPHIER_PH1_LD6B; break; #endif -#ifdef CONFIG_ARCH_UNIPHIER_PH1_SLD11 +#ifdef CONFIG_ARCH_UNIPHIER_PH1_LD11 case 0x31: - ret = SOC_UNIPHIER_PH1_SLD11; + ret = SOC_UNIPHIER_PH1_LD11; break; #endif -#ifdef CONFIG_ARCH_UNIPHIER_PH1_LD10 +#ifdef CONFIG_ARCH_UNIPHIER_PH1_LD20 case 0x32: - ret = SOC_UNIPHIER_PH1_LD10; + ret = SOC_UNIPHIER_PH1_LD20; break; #endif default:
Before adding ARMv8 support, this commit refactors the directory structure. Move ARMv7 specific files to arch/arm/mach-uniphier/arm32 to avoid a mess by mixture of ARMv7 and ARMv8 code. Also move the "select CPU_V7" to the lower-level menu because we will have to select ARM64 instead of CPU_V7 for ARMv8 SoCs.
arch/arm/Kconfig | 1 - arch/arm/mach-uniphier/Kconfig | 4 ++++ arch/arm/mach-uniphier/Makefile | 9 ++------- arch/arm/mach-uniphier/arm32/Makefile | 13 +++++++++++++ arch/arm/mach-uniphier/{ => arm32}/arm-mpcore.h | 0 arch/arm/mach-uniphier/{ => arm32}/cache_uniphier.c | 0 arch/arm/mach-uniphier/{ => arm32}/debug_ll.S | 0 arch/arm/mach-uniphier/{ => arm32}/late_lowlevel_init.S | 0 arch/arm/mach-uniphier/{ => arm32}/lowlevel_init.S | 0 arch/arm/mach-uniphier/{ => arm32}/ssc-regs.h | 0 arch/arm/mach-uniphier/{ => arm32}/timer.c | 0 11 files changed, 19 insertions(+), 8 deletions(-) create mode 100644 arch/arm/mach-uniphier/arm32/Makefile rename arch/arm/mach-uniphier/{ => arm32}/arm-mpcore.h (100%) rename arch/arm/mach-uniphier/{ => arm32}/cache_uniphier.c (100%) rename arch/arm/mach-uniphier/{ => arm32}/debug_ll.S (100%) rename arch/arm/mach-uniphier/{ => arm32}/late_lowlevel_init.S (100%) rename arch/arm/mach-uniphier/{ => arm32}/lowlevel_init.S (100%) rename arch/arm/mach-uniphier/{ => arm32}/ssc-regs.h (100%) rename arch/arm/mach-uniphier/{ => arm32}/timer.c (100%)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 37b20ff..6e5544f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -690,7 +690,6 @@ config TARGET_COLIBRI_PXA270 config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" select CLK_UNIPHIER - select CPU_V7 select SUPPORT_SPL select SPL select OF_CONTROL diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index e859ca3..660f83c 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -9,15 +9,19 @@ choice
config ARCH_UNIPHIER_PH1_SLD3 bool "UniPhier PH1-sLD3 SoC" + select CPU_V7
config ARCH_UNIPHIER_LD4_SLD8 bool "UniPhier PH1-LD4/PH1-sLD8 SoC" + select CPU_V7
config ARCH_UNIPHIER_PH1_PRO4 bool "UniPhier PH1-Pro4 SoC" + select CPU_V7
config ARCH_UNIPHIER_PRO5_PXS2_LD6B bool "UniPhier PH1-Pro5/ProXstream2/PH1-LD6b SoC" + select CPU_V7
endchoice
diff --git a/arch/arm/mach-uniphier/Makefile b/arch/arm/mach-uniphier/Makefile index e65d602..1a8c649 100644 --- a/arch/arm/mach-uniphier/Makefile +++ b/arch/arm/mach-uniphier/Makefile @@ -4,16 +4,11 @@
ifdef CONFIG_SPL_BUILD
-obj-y += lowlevel_init.o - obj-y += init/ bcu/ memconf/ pll/ early-clk/ early-pinctrl/ obj-$(CONFIG_MICRO_SUPPORT_CARD) += sbc/
-obj-$(CONFIG_DEBUG_LL) += debug_ll.o - else
-obj-y += late_lowlevel_init.o obj-$(CONFIG_BOARD_EARLY_INIT_F) += board_early_init_f.o obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o obj-$(CONFIG_MISC_INIT_F) += print_misc_info.o @@ -22,16 +17,16 @@ obj-y += board_common.o obj-$(CONFIG_BOARD_EARLY_INIT_R) += board_early_init_r.o obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o obj-y += reset.o -obj-y += cache_uniphier.o
obj-y += pinctrl/ clk/
endif
-obj-y += timer.o obj-y += boards.o obj-y += soc_info.o obj-y += boot-mode/ obj-y += dram/
obj-$(CONFIG_MICRO_SUPPORT_CARD) += micro-support-card.o + +obj-$(CONFIG_CPU_V7) += arm32/ diff --git a/arch/arm/mach-uniphier/arm32/Makefile b/arch/arm/mach-uniphier/arm32/Makefile new file mode 100644 index 0000000..376c06b --- /dev/null +++ b/arch/arm/mach-uniphier/arm32/Makefile @@ -0,0 +1,13 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_SPL_BUILD +obj-y += lowlevel_init.o +obj-$(CONFIG_DEBUG_LL) += debug_ll.o +else +obj-y += late_lowlevel_init.o +obj-y += cache_uniphier.o +endif + +obj-y += timer.o diff --git a/arch/arm/mach-uniphier/arm-mpcore.h b/arch/arm/mach-uniphier/arm32/arm-mpcore.h similarity index 100% rename from arch/arm/mach-uniphier/arm-mpcore.h rename to arch/arm/mach-uniphier/arm32/arm-mpcore.h diff --git a/arch/arm/mach-uniphier/cache_uniphier.c b/arch/arm/mach-uniphier/arm32/cache_uniphier.c similarity index 100% rename from arch/arm/mach-uniphier/cache_uniphier.c rename to arch/arm/mach-uniphier/arm32/cache_uniphier.c diff --git a/arch/arm/mach-uniphier/debug_ll.S b/arch/arm/mach-uniphier/arm32/debug_ll.S similarity index 100% rename from arch/arm/mach-uniphier/debug_ll.S rename to arch/arm/mach-uniphier/arm32/debug_ll.S diff --git a/arch/arm/mach-uniphier/late_lowlevel_init.S b/arch/arm/mach-uniphier/arm32/late_lowlevel_init.S similarity index 100% rename from arch/arm/mach-uniphier/late_lowlevel_init.S rename to arch/arm/mach-uniphier/arm32/late_lowlevel_init.S diff --git a/arch/arm/mach-uniphier/lowlevel_init.S b/arch/arm/mach-uniphier/arm32/lowlevel_init.S similarity index 100% rename from arch/arm/mach-uniphier/lowlevel_init.S rename to arch/arm/mach-uniphier/arm32/lowlevel_init.S diff --git a/arch/arm/mach-uniphier/ssc-regs.h b/arch/arm/mach-uniphier/arm32/ssc-regs.h similarity index 100% rename from arch/arm/mach-uniphier/ssc-regs.h rename to arch/arm/mach-uniphier/arm32/ssc-regs.h diff --git a/arch/arm/mach-uniphier/timer.c b/arch/arm/mach-uniphier/arm32/timer.c similarity index 100% rename from arch/arm/mach-uniphier/timer.c rename to arch/arm/mach-uniphier/arm32/timer.c
The UniPhier SoC family has not supported ARMv8 yet, but these would cause warnings if they were compiled with a 64bit compiler. Before adding the ARMv8 support really, fix them now.
Because UniPhier SoCs do not support Large Physical Address Extension, casting "phys_addr_t" into "unsigned long" would carry the address as is.
arch/arm/mach-uniphier/dram_init.c | 5 +++-- arch/arm/mach-uniphier/micro-support-card.c | 3 ++- arch/arm/mach-uniphier/sg-regs.h | 2 +- 3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-uniphier/dram_init.c b/arch/arm/mach-uniphier/dram_init.c index 32cc448..cffdfc9 100644 --- a/arch/arm/mach-uniphier/dram_init.c +++ b/arch/arm/mach-uniphier/dram_init.c @@ -32,7 +32,7 @@ int dram_init(void)
gd->ram_size = fdt32_to_cpu(*(val + 1));
- debug("DRAM size = %08lx\n", gd->ram_size); + debug("DRAM size = %08lx\n", (unsigned long)gd->ram_size);
return 0; } @@ -54,6 +54,7 @@ void dram_init_banksize(void) gd->bd->bi_dram[i].size = fdt32_to_cpu(*val++);
debug("DRAM bank %d: start = %08lx, size = %08lx\n", - i, gd->bd->bi_dram[i].start, gd->bd->bi_dram[i].size); + i, (unsigned long)gd->bd->bi_dram[i].start, + (unsigned long)gd->bd->bi_dram[i].size); } } diff --git a/arch/arm/mach-uniphier/micro-support-card.c b/arch/arm/mach-uniphier/micro-support-card.c index f777ac1..f7a37e3 100644 --- a/arch/arm/mach-uniphier/micro-support-card.c +++ b/arch/arm/mach-uniphier/micro-support-card.c @@ -142,7 +142,8 @@ static void detect_num_flash_banks(void) memory_bank;
debug("flash bank found: base = 0x%lx, size = 0x%lx\n", - memory_bank->base, memory_bank->size); + (unsigned long)memory_bank->base, + (unsigned long)memory_bank->size); cfi_flash_num_flash_banks++; } } diff --git a/arch/arm/mach-uniphier/sg-regs.h b/arch/arm/mach-uniphier/sg-regs.h index 678d437..3a535c7 100644 --- a/arch/arm/mach-uniphier/sg-regs.h +++ b/arch/arm/mach-uniphier/sg-regs.h @@ -105,7 +105,7 @@ static inline void sg_set_pinsel(unsigned pin, unsigned muxval, unsigned mux_bits, unsigned reg_stride) { unsigned shift = pin * mux_bits % 32; - unsigned reg = SG_PINCTRL_BASE + pin * mux_bits / 32 * reg_stride; + unsigned long reg = SG_PINCTRL_BASE + pin * mux_bits / 32 * reg_stride; u32 mask = (1U << mux_bits) - 1; u32 tmp;
2016-02-26 18:59 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Series, applied to u-boot-uniphier/master
Masahiro Yamada
